![]() Join Date: Jun 2010 Location: Shreveport, LA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 68
Groaned at 3 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score Ok, im guessing this is the appropriate area for this thread... But heres the question, what are you big turbo/ 1/4 guys running for slicks? Since i have 18's, its hard to find a descent tire that will fit... I really would love to run like a 16" rim and order some mickeys... Please tell me what you guys are doing to get your 60 fts... i need ideas... Big Import Face Off race is in two weeks and i need to have some tires/wheels ordered before then... Thanks
__________________ 2008.5 MS3 White BNR StageIII, RPMC TIP, NGK ITV7IX-11, GS EBCS, Cobb SRI, HKS SSQV3 VTA, Exhaust Depot Black IC Piping, Godspeed FMIC, PTP HPFP, CP-e 75 duro RMM, Turbo XS long 3" DP, Magnaflow 3" CBE, Raceland CO, TWM STS & Bushings, Hawk Pads, Stop-tech Slotted Rotors, Pioneer Avic-Z130BT, Motegi MR-116's wrapped with 235/40/18 Eagle GTs 320WHP/364WTQ 20lbs 93- Calvin @ Cobb (13.3@109 Skreet Tires)3/8 mix E85 21lbs- Ziggo (12.9@113 Skreet Tires) |
![]() Join Date: Jun 2010 Location: li, merrick, new york
Rep Power: 2273 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,757
| Not Ranked : 0 score Get a set of mickey drag radials . That's all u need. |
(Thread Starter) | Not Ranked : 0 score THey dont make anything in a size on an 18" rim that i can fit... unless im missing something here?
| Not Ranked : 0 score They make a et street radial 2 in size 245/40/18 if u have wide enough after market rims they fit I have them on a set. |
(Thread Starter) | Not Ranked : 0 score ok... thanks for that... im looking at getting some 16" rims and buying tires to go on that.. i have an 8" rim with lowering springs... the stock 215/45's are rubbing, but at the track i wont be doing a LOT of turning... do you have rubbing issues? are you lowered?
| Not Ranked : 0 score I'm on coilovers and I don't have a problem thus far , but I'm also not that low. |
![]() Join Date: Nov 2009 Location: las vegas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 711
| Not Ranked : 0 score i got nitto N1 dot drag radials, i like them alot.
__________________ T3 Steed Speed twinscroll manifold- GT35R- CPE HPFP- COBB AP- DO METH- PTP BSD/WIN- CPE FMIC 2.5 piping- Twin Gates- CorkSport Exhaust- Full Mounts |
(Thread Starter) | Not Ranked : 0 score Ok. I may just go with the nt05.
| drag radials??? | arielmalespin | MazdaSpeed 3/6 - Wheels & Tires | 17 | 03-18-2011 01:03 PM |
| what size slicks/drag radials for 16x8 | BeeZaa | 2010 MS3 - Wheels & Tires | 4 | 12-06-2010 08:05 AM |
| Slicks / Drag Radials | 9900rpm | 2010 MS3 - Wheels & Tires | 0 | 03-23-2010 02:55 PM |
| Slicks / Drag Radials | 9900rpm | 2010 MS3 - Wheels & Tires | 8 | 11-27-2009 03:42 PM |
| Drag Radials | MidwestSpeed3 | MazdaSpeed 3/6 - Wheels & Tires | 3 | 06-24-2008 01:57 PM |
