Like Tree10Likes
 Old 01-03-2011, 12:21 PM   #41
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
well, dont forget that i also had 8.8:1 pistons.
the power increase was something like 360whp to 394whp, but im pretty sure that was after all the other optimization was done like fueling and fuel pressure, etc.
i could be remembering this wrong, it was almost a year ago.
The Following 2 Users Say Thank You to socks For This Useful Post:
djuosnteisn (01-03-2011), driver311 (01-03-2011)
 Old 01-03-2011, 12:24 PM   #42
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Sean had 8.8 : 1 compression as well, which probably helped with that much timing and no meth.
When you start adding timing, the power will pick up real fast.... but eventually, it'll plateau. That plateau will last for a surprising amount of further advance... until you finally blow up the motor (rod usually). When i was tuning my car i was up to like 19 degrees (plateau started around 16 ish), on 91 octane and 50/50 wmi. I had no active knock sensor at those rpms so i decided it was only stupid to push it further. But i never saw any signs of detonation... just no more signs of power.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 4 Users Say Thank You to djuosnteisn For This Useful Post:
driver311 (01-03-2011), Fobio (01-03-2011), madvillain (01-03-2011), NJSPEED3 (01-03-2011)
 Old 01-03-2011, 12:26 PM   #43
socks's Avatar
Groans: 125
yea, we saw it plateau around 20. jason (the tuner) said he had run as high as 27* on robbies car with no additional gains, so we stuck to 19-20*
The Following 6 Users Say Thank You to socks For This Useful Post:
djuosnteisn (01-03-2011), driver311 (01-03-2011), Fobio (01-03-2011), madvillain (01-03-2011), NJSPEED3 (01-03-2011), wette460 (04-20-2011)
 Old 01-03-2011, 02:03 PM   #44
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Cant wait to see what 50% and a dyno comparison show, good stuff Anthony!
The Following User Says Thank You to NJSPEED3 For This Useful Post:
 Old 01-03-2011, 02:06 PM   #45
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
pish posh, enough tuning..lets see you run already anthony..i got $50 on you cracking 11s b4 anyone else
 Old 01-03-2011, 02:25 PM   #46
driver311's Avatar
Posts: 1,769   (View Stats)
19-20 huh! I dont see why my setup on 50% e85 couldnt handle that. I will play with it on the dyno when I go here soon. This tank is about gone so Im gonna add another gallon of e85 to my tank and see how it likes it. Even if I cant go farther than 25% e85, I will continue to run it. Car seems to like it and it gives me a little more peace of mind knowing my octane is around 96. 50% would have me over 100 octane. e85 is only 2.50 a gallon here in boise so at .80 cents cheaper than 93 octane, the mileage I lose will be countered by price difference. Im pretty excited about it. LOL
Thats if I can get to sacramento soon enough. I see alot of guys right on the threshold. I hope to be the first 3 atleast. Would be fitting i was the first in the 12s. LOL
Mazdaspeed
Last edited by driver311; 01-03-2011 at 02:25 PM. Reason: MSF Database - Automerged Doublepost
The Following 4 Users Say Thank You to driver311 For This Useful Post:
Dano (01-03-2011), djuosnteisn (01-03-2011), madvillain (01-03-2011), NJSPEED3 (01-03-2011)
 Old 01-03-2011, 03:06 PM   #47
cageyvet's Avatar
Posts: 715   (View Stats)
Just use the e85 to lean the car even more.
The Following User Says Thank You to cageyvet For This Useful Post:
driver311 (01-04-2011)
 Old 01-03-2011, 05:48 PM   #48
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Anthony, you still running without meth?
seems to me meth is a better way but what do I know...you are using gas 100% of the time whereas meth only at WOT...
Does meth not add more octane/cooling than an e85 mix.
not hating over here just axing.
 Old 01-03-2011, 06:15 PM   #49
driver311's Avatar
From what Ive seen over in the evo community, they can push e85 far past water/meth injection. I dont know from experience but I definately havent seen any of you guys do anything special on meth but clean your motor. LOL
Just teasin, I know meth can do cool things past straight pump but I can get e85 right at pump and its way cheap. And all I know is everyone of my friends that have switched from meth to e85 is pushing there tuning way farther and detonation is non existent. From what I understand its damn near impossible to detontate on straight e85.
Mazdaspeed
The Following 3 Users Say Thank You to driver311 For This Useful Post:
Dano (01-03-2011), Darksun280 (01-03-2011), madvillain (01-03-2011)
 Old 01-03-2011, 07:10 PM   #50
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
does E85 have a much lower stoich? you should adjust your AFR accordingly to maximize power/fuel economy......
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 01-03-2011, 07:20 PM   #51
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Yeah, stoich for E85 is more like 6:1.
 Old 01-03-2011, 07:21 PM   #52
Trail of Fail
Dano's Avatar
Hater. Meth hater that is. LOL
 Old 01-03-2011, 08:29 PM   #53
Trail of Fail
Dano's Avatar
Well I went from 14* advance at 6.5K on 100% meth to barely 11* advance without...now I know 14 aint nothing special but I lost 3* of total advance and ~4* in the 4-5.5 range.
jussayin
signed
E85 hater LOL
 Old 01-03-2011, 09:30 PM   #54
driver311's Avatar
I run 14 degrees on straight pump gas no problem.
Mazdaspeed
 Old 01-03-2011, 09:40 PM   #55
Trail of Fail
Dano's Avatar
Well I guess my car just sucks. Haha
 Old 01-03-2011, 10:50 PM   #56
Captain
Indeed e85 has a lower stoich point... but AFAIK the o2 sensor reads in labda... in terms of stoich, regardless what that ratio may be. So whenever it's reporting 14.7... it's basically just saying, "the mixture it stoich".
The only reason it says 14.7 is cause mazda figures people will be running gasoline.
www.permtuning.com
Click Here (01-03-2011), driver311 (01-04-2011), FreeFlyFreak (01-03-2011), socks (01-13-2011)
 Old 01-03-2011, 11:18 PM   #57
kylemzspd3@gmail.com's Avatar
Posts: 90   (View Stats)
kylemzspd3@gmail.com is a splendid one to beholdkylemzspd3@gmail.com is a splendid one to beholdkylemzspd3@gmail.com is a splendid one to beholdkylemzspd3@gmail.com is a splendid one to beholdkylemzspd3@gmail.com is a splendid one to beholdkylemzspd3@gmail.com is a splendid one to beholdkylemzspd3@gmail.com is a splendid one to behold
Groaned at 52 Times in 16 Posts
Ive been running 93oct mixed 50/50 with 110leaded racegas. and its beautiful. everybody is scared but gas is f**king gas.......just dont put 87. lol. leaded gas just burns dirty thus failing cats and 02 sensors. other then that. up the f**kin timing n quit crying. wana go fast? experiment.....i never posted it, cause who wants to hear discouragement? anyway. point is dont be afraid ppl.
;Injen Intake, Turbo Inlet; 3in Custom catless DP; Cobb AP- Street Tuned by me at 20psi; HKS Bov Vta; EGR delete; 5w 30 Mobil 1; Hawk Hp Pads;
800k HID; SU rear Motor Mount
NGK 1step colder spark plugs.
Custom Front Mount Intercooler.
AEM Meth Kit-315cc nozzle
(Cobb's new Jacket.)
(Cobb Shift Knob.)
kylemzspd3@gmail.com is offline   Reply With Quote
The Following User Says Thank You to kylemzspd3@gmail.com For This Useful Post:
 Old 01-03-2011, 11:34 PM   #58
gonads and strife
Matt's Avatar
Posts: 274   (View Stats)
Matt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the world
I like the sounds of this. So, you guys running e85, any fears of fuel line degradation or excessive CDFP wear?
My only concern would be ending up in the middle of nowhere someday with only 91 octane gas available. If it happened to also be a hot day your ECU would be pissed. Creating separate maps for such an occasion would be ideal.
Matt is offline   Reply With Quote
The Following User Says Thank You to Matt For This Useful Post:
 Old 01-04-2011, 07:26 PM   #59
bmylez's Avatar
Groans: 31
Yeah, the O2 sensor doesn't know the difference. The lambda x 14.7 is built into the sensor, so you can't change that aspect. When tuning for E85, it's best to have the gauge display lambda instead of AFR.
The Following 2 Users Say Thank You to bmylez For This Useful Post:
djuosnteisn (01-04-2011), driver311 (01-04-2011)
 Old 01-04-2011, 07:51 PM   #60
Must Have Teh 10's!
lol kinda like owning a PTP pump haha
The Following 4 Users Say Thank You to superskaterxes For This Useful Post:
djuosnteisn (01-04-2011), driver311 (01-04-2011), madvillain (01-04-2011), triplejumper18 (01-13-2011)
 Old 01-04-2011, 08:04 PM   #61
driver311's Avatar
You aint bullshitting, LOL Thats why I keep an extra pump with me at all times now. LOL HOw sad. Hopefully I dont have to use it.
I got one even better for you. Im gonna be putting a ptp rail valve on my car this weekend and try to get my car to hold 2000psi across the board. Ill put that info in its own thread though. God knows how thatll spiral!!!
Mazdaspeed
 Old 01-04-2011, 08:19 PM   #62
mason's Avatar
Posts: 946   (View Stats)
PTP started doing some cool stuff, different stuff that was very needed...... just sucks they went down like that! wish the shit was legit!
 Old 01-04-2011, 08:28 PM   #63
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i just want to say this....
PEEEEEE TEAAAAAAAAAA PEEEEEEEEEE
FreeFlyFreak (01-13-2011)
 Old 01-04-2011, 09:15 PM   #64
Captain
Hope you have an e-torx bit duct taped to the spare pump, cause you aren't gonna swap that shit out with a leatherman lol.
And ask erich about the rail valve... he's been running one for a while, and is seeing a lil weird stuff...
He was running more pressure than the pressure sensor could even read (maxed out basically), and was actually disrupting the injectors from opening properly, and leaning way the fuck out. He's fine with doin it cause he has a spare motor sitting around, and he's not making anywhere near the power you are (which means less fuel demand).
Just be careful being PTP's "learning" car. Esp if your so concerned about your block. Just cause he gets all excited and talks all loud about how fucking cool his products are, doesn't mean he's thought them through entirely, or tested em out thoroughly. That's essentially what you'll be doing, haha.
But shit... who knows... maybe he's running that valve on his srt...
www.permtuning.com
The Following 7 Users Say Thank You to djuosnteisn For This Useful Post:
driver311 (01-04-2011), FreeFlyFreak (01-13-2011), jracer (01-13-2011), madvillain (01-04-2011), NJSPEED3 (01-05-2011), rigor (01-04-2011), SilverDemon (01-05-2011)
 Old 01-04-2011, 10:29 PM   #65
driver311's Avatar
Sooooo your saying theres a chance???? LOL
Quote the movie????
Mazdaspeed
The Following User Says Thank You to driver311 For This Useful Post:
djuosnteisn (01-05-2011)
 Old 01-04-2011, 10:42 PM   #66
zx2man's Avatar
Posts: 1,356   (View Stats)
zx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the world
Quote the movie????
Dumb&Dumber
So How many maps are you running Anthony? I thought you were @20 psi last time I checked, How does Tim feel with e85 on this car?
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO*
zx2man is offline   Reply With Quote
 Old 01-04-2011, 10:48 PM   #67
driver311's Avatar
He doesnt know lol. I have 3 maps. I just posted two vids of me at 18psi and 19psi. I can set me boost where ever I want. My tune allows me to put my boost where ever I want with my mbc and its dialed in.
Mazdaspeed
The Following 2 Users Say Thank You to driver311 For This Useful Post:
jracer (01-13-2011), zx2man (01-04-2011)
 Old 01-04-2011, 11:35 PM   #68
gonads and strife
Matt's Avatar
Apparently there's already some guy in Everette WA that's running 100% E85 at 26.5 PSI on stock internals. He lists his mods as "CS FMIC kit / Turbosmart - BOV , Eboost Street 40 EBC , ProGate 50 EWG / DNP header / CS power catless exhaust w/ a straight cutout in the race pipe / GT3076R / CP-e - Standback 2 , Profuel / Walbro 255 x2 / HKS twin power ignition / water meth kit / SS braided fuel line."
I asked him if he's adding lubricant to the fuel, but he doesn't have very much info yet. He's having MSP in Arlington WA (Subie shop) build the car while he's deployed in Iraq.
 Old 01-04-2011, 11:46 PM   #69
zx2man's Avatar
Haha...Yeah Father Tim tends to be a conservative man,only because he cares about his customer's cars alot. But sometimes I feel like he is overly conservative with the ms3/6 platform.
nice to see you trying new things There is shell station near by with e-85, might have to give it a shot.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
 Old 01-13-2011, 08:19 AM   #70
Tripple OG
NJSPEED3's Avatar
Groans: 113
Anthony any updates homie?
 Old 01-13-2011, 08:27 AM   #71
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
what kinda MBC do you use ?
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 01-13-2011, 09:06 PM   #72
EnigmaOperator's Avatar
Posts: 61   (View Stats)
EnigmaOperator has a reputation beyond reputeEnigmaOperator has a reputation beyond reputeEnigmaOperator has a reputation beyond reputeEnigmaOperator has a reputation beyond reputeEnigmaOperator has a reputation beyond reputeEnigmaOperator has a reputation beyond reputeEnigmaOperator has a reputation beyond reputeEnigmaOperator has a reputation beyond reputeEnigmaOperator has a reputation beyond reputeEnigmaOperator has a reputation beyond reputeEnigmaOperator has a reputation beyond repute
Groaned at 22 Times in 4 Posts
Default Setting the E85 record straight
Originally Posted by 240mazspd3 View Post
so the fuel system doesnt need to be modded running 50/50 mix or lower?
Correct. your stock fuel system is completely safe running a a 50/50 E85 & Premium fuel mix.
My biggest concern is how the friction parts will take the alcohol. Injectors, CDFP, cylinder walls etc. ....Just don't let the car sit for too long, ethanol fuel separates after a while.
^ That is not a concern. As of the inception of OBDII cars, Manufacturers were required to build fuel systems and engines capable of handling and adapting to the ethanol which is added to all forms of gasoline in both winter and summer mixes.(summer depending on location)
Chemically, ethanol is really no more corrosive than gasoline, meaning it's not. Both are solvents and not an acid -
as for ethanol fuel seperation - its as common as premium fuel seperation. basically, cars can sit for a very long time before that happens. with as frequently as you drive your car (probably a DD) you may never experience that.
fuel lines on most cars have to be changed not sure why you MS3 owners would be any different.
FALSE.
modern fuel lines in all cars post 1990 are capable of handling ethanol fuels- PER manufacturer requirements. replacing a fuel line with an upgraded line such as stainless is something some folks do for peace of mind - but speaking of mind - keep in mind that even stainless lines have fuel tubing / rubber inner linings.. again capable of handling E85.
All you need to lubricate the alc in the fuel system is 1 cap full of marvels mystery oil per gallon of E85.
FALSE.
though a novel idea, E85 is STILL 15% Premium gasoline. that 15% is left in there for a reason: lubrication for parts that need it.. fuel pumps etc.
Originally Posted by Click Here View Post
I think ethanol does have some benefits even without any tuning. Whether these power advantages are measurable in practice, I guess is a different question...
1. Ethanol has less energy than gas does per volume, but when mixed at a stoich ratio the ethanol mixture is going to release more energy by about 5% over gasoline.
2. Ethanol generates lower exhaust gas temperatures as compared to gas, and also increases the total exhaust volume, which can be particularly beneficial for turbos.
3. Ethanol's evaporative cooling advantage is only amplified by the high-pressure DI system, which can cool the air charge and ultimately increase VE.
4. Ethanol burns much more efficiently (faster) at richer mixtures than gas does.
5. Ethanol's initial burn time is much slower than gasoline which reduces the amount of negative work done on the piston at the end of the compression stroke.
And I think what Driver is doing is bad ass.
^ that is absolutely correct. Additionally, E85's natural octane rating is 105. so as is, it has an octatne rating similar to 100 octane racing fuel. where E85 really shines is its inherent cooling properties.. through its cooling effects on the head's and combustion chamber E85 runs much like 116 Octane - much like Sunoco's 116 octane racing fuel. Many tuners running 100% E85 are maxing exact power levels as they are with 116 Octane race gas. The difference being in the price. 116 can be INCREDIBLY expensive sometimes as much as 10-20 dollars a gallon depending on location. - E85 is 2 bucks a gallon.
basically, many folks in the know consider it cheap race gas from the pump.
I thought that about ten years ago, all fuel systems were required to be able to handle ethanol, since it is put in most gasoline, often as much as 10% during the summer months?
Stealth is correct. as i previously mentioned, fuel systems were brought up to speed and designed to be able to handle Ethanol fuels in the 1990's. Many times, that ethanol is added in the Winter months however.
Sounds like Stealth may know his stuff.
I always thought the fuel pumps had to be different but now I learned the stock ones are ok. So now its a matter of Driver feeling frisky and throwing 25 Degrees of timing at the car. Good luck who knows how this car reacts to high timing.
Yes. the stock fuel pump can handle ethanol fuel. However, often the pump is upraded to support applications which require high fuel flow.
Also e85 will fuck up the HPFP it's just not an instant thing. I doubt even with in 2 years would you see the effect of it not lubricating the piston properly but then again that fucker rev's at an insane speed so wear might show quicker than i expect.
Fuel pumps have gone, but they have also failed under normal Premium gasoline use too. but consider this- many folks running E85 in their high WHP application EVO's STi's Porsches, BMW's and GT-R's are using pumps for 5 years at a time without failure. Additionally, Deatchwerks now makes a pump specifically designed for E85 use - negating the arguement that E85 kills fuel pumps. Besides, even if it were to kill pumps, a Walboro 225lph pump costs 90 bucks. if it fails in 5 years - thats 18 dollars a year in fuel pump costs. or 0.04 cents per day.
hope that helps to set the E85 record straight. It seems there is quite a bit of aprehension on this board against E85, which really is a shame- considering it can make more power than Meth injection systems (without fear of a meth injection system hiccup) , its Knock proof, and it's basically like race fuel that costs $2.30 a gallon.
Probaholic1 likes this.
EnigmaOperator is offline   Reply With Quote
The Following 17 Users Say Thank You to EnigmaOperator For This Useful Post:
Alpha (08-04-2011), Benis (06-03-2013), Dano (01-13-2011), DingoDave (01-13-2011), driver311 (01-13-2011), FreeFlyFreak (01-14-2011), ItsNox (07-20-2013), JacksonMS30 (01-21-2011), jracer (01-14-2011), Matt (01-13-2011), mazdaspeeding (01-14-2011), mituc (01-15-2011), NJSPEED3 (01-13-2011), Probaholic1 (08-13-2013), ruthless013 (01-14-2011), trigun22 (01-20-2011), xdm88 (01-14-2011)
 Old 01-13-2011, 09:09 PM   #73
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
For what its worth, I added two gallons of e85 with a tank of regular gas, and a bit of marvels oil, and the car is just as slow as ever.
SpeedSixxx (02-01-2011)
 Old 01-13-2011, 09:13 PM   #74
driver311's Avatar
Thats what Im talking bout. Thanks for breaking it down. The shits legit for real. Just takes more than internet racers to know that. LOL
My first tank was 2.5 gallons and no issues. This tank was 3 gallons and car runs just as good. Next tank will be 3.5 gallons. im gonna slowly work my way up and make adjustments as needed. But thus far none have been needed. Car is just straight up ripping.
Mazdaspeed
Last edited by driver311; 01-13-2011 at 09:13 PM. Reason: MSF Database - Automerged Doublepost
DingoDave (01-13-2011), FreeFlyFreak (01-14-2011), NJSPEED3 (01-13-2011)
 Old 01-13-2011, 09:14 PM   #75
^ slaps forhead.
you will not see a power gain from 2 gallons of e85 mixed with your fuel. you'll add a touch of knock protection, but gains in power while running a race fuel or E85 come from added timing and addtional boost - From tuning.
jorgea3281 likes this.
Fail Fixer.
The Following 2 Users Say Thank You to EnigmaOperator For This Useful Post:
djuosnteisn (01-14-2011), RichieRichness (09-28-2011)
 Old 01-13-2011, 09:15 PM   #76
driver311's Avatar
Turbosmart but looking to experiment with hallman pro. My car didnt have any spikes when temps were above 50 degrees but now that its cold it spikes a few when i shift. I doubt the hallman will fix that. Its just the nature of the beast(cold weather)
Mazdaspeed
jracer (01-14-2011)
 Old 01-13-2011, 09:15 PM   #77
gonads and strife
Matt's Avatar
Good post. Thanks!
Unfortunately we DI guys need the meth injection anyway to keep our intake valves from caking.
 Old 01-13-2011, 09:17 PM   #78
Good post. Thanks!
Keep in mind that E85's denatured fuel ethanol works to clean the intake system and combustion chamber very much like a methanol does.
not only does it make power, it cleans as it does it.
also, a can of BG 44k once every 6 months is also an effective cleaner
Fail Fixer.
The Following User Says Thank You to EnigmaOperator For This Useful Post:
 Old 01-13-2011, 09:29 PM   #79
ms3brendan's Avatar
Posts: 1,017   (View Stats)
ms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the world
Sub'ddddddd. Very interested.
2012 BMW 135i //M-Sport
ms3brendan is offline   Reply With Quote
 Old 01-13-2011, 09:34 PM   #80
gonads and strife
Matt's Avatar
also, a can of BG 44k once every 6 months will mitigate any caking for ya.
The difference is where the injection takes place. What you're talking about is Port injection, which cleans the intake valves/ports all by itself. With Direct Injection the fuel never sees the intake side of the valves or ports. This is why meth injection is pretty much necessary to limit the HP losses from caking.
The Following 3 Users Say Thank You to Matt For This Useful Post:
FreeFlyFreak (01-14-2011), JacksonMS30 (01-21-2011), NJSPEED3 (01-13-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/drivers-attempt-e85-68330/
GPL - Pagina 9 - Cafenea - Club Mazda This thread Refback 11-11-2014 10:08 AM
turbo charging e85 pu - Web Search Results This thread Refback 04-18-2014 05:27 PM
GPL - Club Mazda - Page 9 This thread Refback 12-17-2011 08:53 AM
partial e 85 on disi - Colorado Mazda Club This thread Refback 04-03-2011 05:15 PM
E15 Ethanol gas Controversy - Page 7 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 01-28-2011 09:16 AM
GPL - Club Mazda This thread Refback 01-15-2011 01:20 PM
My Photography Attempt... CWP MS3 typeshluder Members Rides Gallery 5 07-18-2010 09:58 PM
first attempt at datalogging and graphing super_pablo_ MazdaSpeed 3/6 - ECU Computer Tuning 9 02-15-2010 08:02 PM
Heres my first attempt at some pictures! ZMB MazdaSpeed 3/6 - Appearance 14 02-16-2009 12:49 PM
British study suggests that older drivers are safer drivers Haltech Automotive News 0 05-01-2008 05:50 AM
Page generated in 0.62117 seconds with 37 queries
