Like Tree10Likes
 Old 03-28-2011, 07:07 PM   #321
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Look at the .xls file I attached earlier in this thread for how to calculate the fueling changes.
In CL, the computer will use the STFT and LTFT to adjust to AFR target. In WOT conditions (after a delay), the computer switches to OL, which should not adjust AFR if it is off target.
Since you mentioned Dashhawk, I assume you do not have any tuning device to adjust your tune.
If this is the case and considering how basic the questions you are asking are, I really wouldn't suggest you play with (fire) E85 at this time until you have read up enough to understand the consequences of your actions and how the computer logic works.
If you goof it up, you can expect upwards of $7k to replace your engine.
 Old 03-31-2011, 09:30 AM   #322
mrQQ's Avatar
Posts: 1,164   (View Stats)
mrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the world
Hi,
you're right, this is dangerous territory, and you're very nice to be warning me.
I'm not jumping into anything. I'll buy VersaTune eventually (soon enough), so just wanted to start reading and understanding.
Ugnius from VersaTune said, that ECU adjusts AFR using LTFT in OL aswell, so that might be reason why you're not seeing AFR change with mild mixes. With more aggressive mixes your LTFTS might be out of max ranges and/or not learned enough..
I want to try a very mild mix, to see if stock tune can adjust it via LTFTs..
mrQQ is offline   Reply With Quote
 Old 03-31-2011, 06:31 PM   #323
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Originally Posted by mrQQ View Post
Hi,
woooooah...there...do not pass go...do not buy VersaTune.....why??? buy either of the 2 proven solutions that work.
a tuning solution is only as powerful as its user base....
now back to our regularly scheduled thread.....
manelscout4life (03-31-2011)
 Old 03-31-2011, 11:17 PM   #324
mrQQ's Avatar
the other tuning solutions started from nothing aswell besides, in this case, I'm 100% certain the developer knows what he's doing
The Following User Says NO Thank You to mrQQ For This Un-useful Post:
manelscout4life (04-26-2011)
 Old 04-19-2011, 09:42 AM   #325
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I started playing with E85 before my computer started hating my Accessport. Sent in for repairs and just got it back - working fine, now. I live in the center of the corn belt, so E85 is everywhere around here. I'll post up some datalogs and thoughts in the next week or two, if we can get some decent weather.
Me rambling about calculated comparisons:
As for non-dyno comparisons, has anyone considered just comparing acceleration rates in a specific gear? This could be done the overly simplified method of saying x2 ending mph @ y2 ending time [minus] x1 starting mph @ y1 starting time. Or, have excel calculate an equation of your vehicle speed, derive and plot (1st derivative of speed is accleration), compare acceleration rates. Data sets would need to be normalized for the second method, but it should work well, and give some information as to what specific rpm range is picking up in accleration.
Both of these methods require a number of data sets to ensure quality, consistent data. At the very least it should answer, yes or no, whether everyone is experiencing the placebo affect.
 Old 04-26-2011, 06:13 PM   #326
Eth Fiend
phate's Avatar
Just as a warning to anyone considering running E85, you quite possibly need to run some sort of additive to aid in lubrication if you want to mostly ethanol. I was running a 50% ethanol mix for a while and everything was fine. I began running straight e85 and my fuel pump took a shit in ~35 miles. Luckily,
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 04-26-2011, 11:20 PM   #327
mrQQ's Avatar
perhaps it had to run @100% all the time?
 Old 05-01-2011, 04:05 PM   #328
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
phate: need updates. People are saying the o-rings died. Did they die or did the moving parts get worn out?
2007 CTS-V - Trying to sell
 Old 05-01-2011, 05:11 PM   #329
Eth Fiend
phate's Avatar
Neither, I think...O-rings looked fine and the metal parts looked pretty darn good. I started a thread here: http://www.mazdaspeedforum.org/forum/foru...-issues-79030/. I have the relief valve sitting on my desk, but I don't have a compressor in my apartment's garage to test it. I'm going to have it tested tomorrow.
 Old 05-01-2011, 06:49 PM   #330
bmylez's Avatar
Groans: 31
So that means that e85 might still be safe on the HPFP.
djuosnteisn (05-02-2011)
 Old 07-10-2011, 05:40 PM   #331
driver311's Avatar
Posts: 1,769   (View Stats)
Ok some updates. Car has a new turbo. Im currently running atps new ewg back half 3076r. Powerband is definately different than the 3071r. Its hard to say if the turbo actually made the car faster. At 18psi for 18psi Id have to say the 3071r made more usable power. The car straight felt faster. But past 19psi the 3076r does feel faster and holds boost much better then the iwg 3071. At my altitude I had a hard time holding more than 20psi without huge spikes in boost of 24-25psi. I didnt want that at all. So I like how the ewg atp holds boost kick ass. Anyways on to the goods.
Car is currently running 21-22psi on a mix of 50/50 e85/pump, and it feels hella good. Just like I remember last time running it. This is the farthest I have went and Im on my second full tank. And the 93 octane Im running with it has 10% e85 in it also. All is well and the afrs and ltft are perfect. So I mix 6 gallons of e85 with 6 gallons of pump every time I fill up. Im able to run max timing of 14.5 degrees even on 100 degree days with 0 knock. Thats pretty effing cool. I went out and raced my buddies vette the other day that traps close to 120 and put 1 car on him. So its flying. My max gs before on a 85 degree day was around 290gs at 20psi. NOw at 20psi im seeing well over 340gs solid. In fact the other night I was seeing right at 360gs. CAr is loving it. Seat of the pants straight up says it faster. Dyno results will come when I get a nice cool day and some extra time and money. Im super excited to see what it does. My guess based off old results is the car is making about 425whp at 21psi. WE will see soon enough.
If anyones curious all I did to get my fuel trims right was multiply my maf scaling by 1.12 to get it spot on. Car runs perfect, and for now plan to stick with this mixture. NO need to go farther when Im maxing timing out with 0 knock and hoping to have no isues with fuel components on only 50%. Ill post long term results as time passes.
Mazdaspeed
The Following 13 Users Say Thank You to driver311 For This Useful Post:
4G63 (07-14-2011), Alpha (08-04-2011), bewsted (07-10-2011), charlesfist (07-10-2011), Ckmazdaspeed3 (07-11-2011), Dano (07-11-2011), djuosnteisn (07-11-2011), essejkcamraw (07-11-2011), jracer (07-10-2011), manselainen (07-13-2011), MarkyMark (07-10-2011), Monotonous ONE (07-10-2011), mr_mazda329 (07-14-2011)
 Old 07-10-2011, 06:28 PM   #332
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Just to get it out there, that'd be a tank full of E47.5
The whole 50/50 E85/pump thing bothered me... moving along...
 Old 07-10-2011, 07:24 PM   #333
driver311's Avatar
Ps. Went to track yesterday on 20psi and was running 114-115 traps with horrible track prep and 93 degree temps. Car is making alot of power. Soon as I can get some cool temps and good track prep, 118-120 traps will follow. My car was worthless out there in 1st and 2nd boucing off limiter. Just couldnt get any hook. Im sure -3 degrees of camber didnt help. LOL
Ps. I raced an 03 r6 on the way home from track twice and put two cars on him. Two fellow members witnessed the ass whooping. CAr is ripping hard.
Mazdaspeed
The Following 3 Users Say Thank You to driver311 For This Useful Post:
801MS3 (07-10-2011), bewsted (07-10-2011), IshiKage (07-15-2011)
 Old 07-10-2011, 07:36 PM   #334
bewsted's Avatar
Posts: 2,456   (View Stats)
Sounds like your doing something right.....I am running about 40-50% e85 on the genpoo. Just curious what the most timing you've run is. I for some reason kept getting the feeling past 15.5 the car wasn't gaining anything. Just curious to what your thoughts are?
EWG K04...GETSUM!
 Old 07-10-2011, 07:45 PM   #335
driver311's Avatar
Past 14.5 there are no gains. Ive tried on the dyno twice.
Mazdaspeed
 Old 07-10-2011, 07:47 PM   #336
bewsted's Avatar
LOL funny thing....I just went back to targeting 14.5 with my last map....And noticed instantly it was pulling harder. 11.8 afr seam to be the sweet spot for your or you pushing it farther LOL
EWG K04...GETSUM!
 Old 07-10-2011, 10:46 PM   #337
driver311's Avatar
Im at 12.3 afr, 14.5 max timing and 1800psi on e85. It doesnt like being rich and car is loving this tune.
Mazdaspeed
 Old 07-10-2011, 11:10 PM   #338
bewsted's Avatar
Meth as well?
Sent from my T-Mobile G1 using Tapatalk
EWG K04...GETSUM!
 Old 07-11-2011, 05:41 AM   #339
Eth/Meth Junkie
cld12pk2go's Avatar
Driver,
It sounds like you are about where I am ethanol wise....
I have been filling up my last 3 tanks with 6 gallons E85 and ~6.2-6.5 gallons 93 octane. So I am in the ~40% ethanol ballpark.
My question is what are your injector duty cycle % numbers? Mine are ~70% with a K04, I would expect you are ~90%.
 Old 07-11-2011, 09:18 AM   #340
bewsted's Avatar
I'm just curious as to what you guys were doing without meth?
EWG K04...GETSUM!
 Old 07-11-2011, 10:04 AM   #341
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
If anyones curious all I did to get my fuel trims right was multiply my maf scaling by 1.12 to get it spot on.....
So using that same 12% increase on your previous g/s (290 * 1.12) yields ~325, and assuming your hitting 350 routinely right now, means you picked up about 25 g/s with the new setup.
Not too shabby man.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 07-11-2011, 11:07 AM   #342
Navy_Mech2's Avatar
Posts: 484   (View Stats)
hmmmm the gate station by my house just put in an e85 pump...
KILLAH BUILT
 Old 07-11-2011, 04:01 PM   #343
driver311's Avatar
Driver,
Took two logs today. Im about 85%. This is at 1800psi.
Not too shabby man.
Thats what I was thinking. It definately pulling harder. Im gonna rerace the e55 I raced the other night on pump. WE were neck and neck. So I will see how it goes this time. Hoping to put 2-3 cars on him.
Mazdaspeed
Last edited by driver311; 07-11-2011 at 04:01 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to driver311 For This Useful Post:
djuosnteisn (07-11-2011), mr_mazda329 (07-14-2011)
 Old 07-11-2011, 04:06 PM   #344
Captain
I would think 2-3 cars is more than 25 whp.... So if you put that much on him, there may be even more power gained other than airflow alone.
www.permtuning.com
 Old 07-11-2011, 04:07 PM   #345
bewsted's Avatar
12.3 afr targets is captian insano...I'm nervous as shit to go above 12 lol
EWG K04...GETSUM!
 Old 07-11-2011, 04:16 PM   #346
11cruzito11's Avatar
Posts: 824   (View Stats)
11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world
Groaned at 5 Times in 2 Posts
Driver,
Is an increase of injector duty cycle % an indicator of power increase?
11cruzito11 is offline   Reply With Quote
 Old 07-11-2011, 04:32 PM   #347
Eth/Meth Junkie
cld12pk2go's Avatar
Basically, both more airflow and higher ethanol in the gas require a longer injector pulsewidth (and thus duty cycle) to sustain an AFR target.
So if you are keeping the fuel type the same and not changing your AFR, then any injector duty cycle change can be attributed to air flow, which should correlate with power potential.
Now if your injector duty cycle goes up simply b/c of the fuel type change, then that doesn't necessarily mean power is higher. It simply means more volumetric fuel flow is required to deliver the proper fueling. In my case, I added 7% on my MAF curve from ~0-80g/s and my CL LTFTs are in the ~+7% range (I split the difference between gas and E40 to keep the trims tolerable).
My OL AFRs still haven't budged and the ECU is somehow knowing to increase injector pw ~15% to keep my AFRs on target...
 Old 07-11-2011, 04:39 PM   #348
Snyeed's Avatar
Posts: 743   (View Stats)
Groaned at 8 Times in 4 Posts
Can we get some pictures of the new turbo setup please.
417whp 428tq 12.037@117.2mph
 Old 07-11-2011, 04:41 PM   #349
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
pics of new turbo back half ??.........
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 07-11-2011, 04:45 PM   #350
driver311's Avatar
Rematch tomorrow night. we will see. Ill be happy just pulling him at all. That will to me be as good as a dyno. If I pull him at all, itll prove more power is being made. Literally from 45-140 we were neck and neck. So wel will see.
Mazdaspeed
Dano (07-11-2011), djuosnteisn (07-11-2011), jracer (07-11-2011)
 Old 07-11-2011, 09:28 PM   #351
driver311's Avatar
Took some logs in 85 degree temps a minute ago. Let me tell you what. This car flat out rips like a mother fucker at 21psi. I was seeing consistant over 355gs and from 5500-6700 I was seeing over 365gs with peak at 371gs. WTF. LOL Im so pumped car is running insanely fast. YEssssss!!!!!!!
Mazdaspeed
The Following User Says Thank You to driver311 For This Useful Post:
Dano (07-12-2011)
 Old 07-12-2011, 05:35 PM   #352
Navy_Mech2's Avatar
shit man that thing is movin some air!
KILLAH BUILT
The Following User Says Thank You to Navy_Mech2 For This Useful Post:
driver311 (07-12-2011)
 Old 07-12-2011, 07:32 PM   #353
driver311's Avatar
Yes sir it is. Im extremely happy. Gonna pull her back to 19-20psi on the street and run 22-23psi at track. Its just to fast at 22psi for daily use and its to much wear and tear. LOL
Mazdaspeed
 Old 07-12-2011, 11:21 PM   #354
Trail of Fail
Dano's Avatar
I keep hearing about how fast it runs but no logs with g/s to back it up...hum
and if you post up we want to see MAF vt, AFR Actual and what is commanded.
no funny business.
hahah glad to see your progress man!
11cruzito11 (07-12-2011), manelscout4life (07-13-2011), mr_mazda329 (07-14-2011)
 Old 07-13-2011, 06:16 AM   #355
driver311's Avatar
Just for you Ill post some tonight. Its not pretty lol
Mazdaspeed
Dano (07-13-2011)
 Old 07-13-2011, 08:28 AM   #356
Trail of Fail
Dano's Avatar
hahah
I'm just kinda sorta fucking with you.
 Old 07-13-2011, 11:33 AM   #357
801MS3's Avatar
Posts: 453   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
Ive seen the logs.. He saw 386 g/s this morning... Pretty nasty..
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline   Reply With Quote
The Following User Says Thank You to 801MS3 For This Useful Post:
Dano (07-13-2011)
 Old 07-13-2011, 11:51 AM   #358
Eth Fiend
phate's Avatar
Everything is skewed with E85. I see over 400g/s with a K04, haha. :/
Driver, sounds like a fun car!
Dano (07-13-2011), djuosnteisn (07-13-2011)
 Old 07-13-2011, 12:50 PM   #359
bewsted's Avatar
I hit around 300 on my ko4 with 5 gallons.
EWG K04...GETSUM!
 Old 07-13-2011, 12:58 PM   #360
Captain
I saw 500 once when the load cap was still unknown.
www.permtuning.com
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/drivers-attempt-e85-68330/
GPL - Pagina 9 - Cafenea - Club Mazda This thread Refback 11-11-2014 10:08 AM
turbo charging e85 pu - Web Search Results This thread Refback 04-18-2014 05:27 PM
GPL - Club Mazda - Page 9 This thread Refback 12-17-2011 08:53 AM
partial e 85 on disi - Colorado Mazda Club This thread Refback 04-03-2011 05:15 PM
E15 Ethanol gas Controversy - Page 7 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 01-28-2011 09:16 AM
GPL - Club Mazda This thread Refback 01-15-2011 01:20 PM
My Photography Attempt... CWP MS3 typeshluder Members Rides Gallery 5 07-18-2010 09:58 PM
first attempt at datalogging and graphing super_pablo_ MazdaSpeed 3/6 - ECU Computer Tuning 9 02-15-2010 08:02 PM
Heres my first attempt at some pictures! ZMB MazdaSpeed 3/6 - Appearance 14 02-16-2009 12:49 PM
British study suggests that older drivers are safer drivers Haltech Automotive News 0 05-01-2008 05:50 AM
Page generated in 0.58497 seconds with 34 queries
