Like Tree16Likes
 Old 05-23-2012, 01:18 PM   #81
driver311's Avatar
Posts: 1,769   (View Stats)
For anyone that cares to know I torqued my head studs to 65ft.lbs. which is 5lbs over arps recommended 60ftlbs. Everything went together way easier than I had anticipated after reading all the horror stories on here about peeps troubles. Mazda did a great job of making it easy to time it and put it all together. Hopefully by early next week it will be driving down the street.
Mazdaspeed
The Following 6 Users Say Thank You to driver311 For This Useful Post:
Chimmike (07-31-2012), cld12pk2go (05-23-2012), doubleflusher (05-23-2012), memin (05-29-2012), predapio (05-23-2012), Realgib3 (05-23-2012)
 Old 05-23-2012, 01:24 PM   #82
Master of Hard Parts
Evan@COBB's Avatar
Posts: 240   (View Stats)
Evan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the world
Groaned at 8 Times in 2 Posts
I found it also a great pleasure to put this motor together. Everything is really easy to get to, torque down, time, assemble. I hope I don't have to do it again but, in the end, it was a lot of fun.
Hard Parts Engineer - Mazda Expert Group
2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else - SOLD!
2008 Toyota Tacoma TRD Sport 4x4 - Current Daily Until Next Turbo Car
Evan@COBB is offline   Reply With Quote
The Following 3 Users Say Thank You to Evan@COBB For This Useful Post:
Broxer (05-23-2012), driver311 (05-23-2012), Realgib3 (05-23-2012)
 Old 05-23-2012, 01:27 PM   #83
driver311's Avatar
Few more pics.
Mazdaspeed
The Following 11 Users Say Thank You to driver311 For This Useful Post:
Alpha (05-23-2012), doubleflusher (05-23-2012), Evan@COBB (05-23-2012), Full-Race (05-24-2012), jracer (05-24-2012), kunfu (05-24-2012), mazdafreak (05-23-2012), NoRegrets (05-23-2012), predapio (05-23-2012), SLOWHATCH (06-06-2012), trf5000 (05-23-2012)
 Old 05-23-2012, 05:59 PM   #84
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Didn't you break your timing cover?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 05-24-2012, 08:04 AM   #85
driver311's Avatar
OHHHH shit, almost ready to put this badboy in.
SLOWHATCH likes this.
Mazdaspeed
The Following 2 Users Say Thank You to driver311 For This Useful Post:
NoRegrets (05-24-2012), SLOWHATCH (06-06-2012)
 Old 05-24-2012, 08:10 AM   #86
Evan@COBB's Avatar
That's neither here nor there. But yes...yes I did.
That part was frustrating...
What is your intake manifold coated with?
Last edited by Evan@COBB; 05-24-2012 at 08:10 AM. Reason: MSF Database - Automerged Doublepost
 Old 05-24-2012, 08:40 AM   #87
driver311's Avatar
I cant remember. I have a can at home. It not coated just sprayed with some heat disipating/resistant shit. LOL I just shaved the mani and sprayed it to look good. I think the mani looks so much better shaved and black.
Mazdaspeed
 Old 05-24-2012, 08:45 AM   #88
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
I prefer shaved too.
Looks good.
Please post pics of motor with the turbo on it?
Beanfab / Tuned by Nishan
The Following 6 Users Say Thank You to doubleflusher For This Useful Post:
802MS3 (05-24-2012), Alpha (05-24-2012), Boosted Beluga (05-24-2012), NJSPEED3 (05-24-2012), SLOWHATCH (06-07-2012), Tokay444 (05-24-2012)
 Old 05-24-2012, 10:32 AM   #89
Tokay444's Avatar
Groans: 793
How did you end up locking everything down the second time around?
Driver you also, did you leave the cam plate, crank pin, and timing wheel screw in?
Demodded.
The Seals
 Old 05-24-2012, 11:02 AM   #90
driver311's Avatar
SEt it, then pulled them off and rotated it around then put them back in place and all was good. Didnt have any issue.
Mazdaspeed
 Old 05-24-2012, 01:12 PM   #91
Tokay444's Avatar
Groans: 793
Not that it matters now for you two, but, you should lightly torque the cam bolts and old crank bolt with the cam plate and crank pin in, but the timing cover off, and check for interference before going right to buttoning everything down.
That way, IF you have an issue, your not scrambling for and new crank bolt and 5 diamond washers.
Demodded.
The Seals
 Old 05-24-2012, 02:15 PM   #92
Jackis's Avatar
Posts: 428   (View Stats)
Jackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the world
Subbing! Push to leamits! Every day!
Those cp-e magnum pistons - are they wiseco-based, by the way?
Does your MS3 start when it's -30C (-22F)?
Forged, bolted, tuned, gtx30/tial/ewg. Thanks.
Jackis is offline   Reply With Quote
 Old 05-24-2012, 08:15 PM   #93
Tokay444's Avatar
Groans: 793
I believe cpe contracts weisco to manufacture them.
Demodded.
The Seals
 Old 05-29-2012, 04:36 PM   #94
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
Alright everybody!!!! Anthony's motor got dropped in today. Standby for incoming pix, video, 500whp, and 10s
NoRegrets likes this.
The Following 7 Users Say Thank You to h.h.sk1nny For This Useful Post:
BigjohnB20 (05-30-2012), Full-Race (05-30-2012), Jackis (05-30-2012), jracer (05-30-2012), SKiZ0TT (05-31-2012), SLOWHATCH (06-06-2012), TriO (06-06-2012)
 Old 06-05-2012, 11:34 PM   #95
driver311's Avatar
Well boys and girls after quite a few months the beast is back up and going. Im sooooo fucking excited to have my car back, let me tell you. Turned out beautiful. The @Full-Race manifold looks soo good under the hood and the welds look mean after some heat to them. Ill post pics of the motor installed in the very near future. Motor sounds pissed and revs sooo fast. Combo of the head work and clutch Im guessing. I cant wait to get on it.
Jackis, SLOWHATCH and Full-Race like this.
Mazdaspeed
The Following 18 Users Say Thank You to driver311 For This Useful Post:
Alpha (06-06-2012), BigjohnB20 (06-06-2012), Black Metal (06-07-2012), Boosted Beluga (06-06-2012), ckMS3 (06-06-2012), cld12pk2go (06-06-2012), Evan@COBB (06-07-2012), Full-Race (06-07-2012), jracer (06-06-2012), NJSPEED3 (06-07-2012), NoRegrets (06-06-2012), predapio (06-07-2012), Realgib3 (06-06-2012), Roddiy (06-07-2012), SLOWHATCH (06-06-2012), socks (06-06-2012), SPEED6 KILLAH (06-06-2012), TriO (06-06-2012)
 Old 06-06-2012, 08:15 AM   #96
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
what clutch did you go with?
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 06-06-2012, 08:22 AM   #97
ant_wailes's Avatar
Posts: 124   (View Stats)
ant_wailes has much to be proud ofant_wailes has much to be proud ofant_wailes has much to be proud ofant_wailes has much to be proud ofant_wailes has much to be proud ofant_wailes has much to be proud ofant_wailes has much to be proud ofant_wailes has much to be proud of
Can't wait for pics! I've been following your build!
ant_wailes is offline   Reply With Quote
 Old 06-07-2012, 09:47 AM   #98
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Subbed for beast numbers!
Sent from my DROID4 using Tapatalk 2
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
 Old 06-07-2012, 12:02 PM   #99
MarkyMark's Avatar
Posts: 1,624   (View Stats)
Groans: 62
Is our intake in there? Still awaiting your experience with it.
MarkyMark is offline   Reply With Quote
 Old 06-07-2012, 12:14 PM   #100
TRSpeed's Avatar
@StreetUnitMark
By that you better mean IM!
Lex Tuned
 Old 06-07-2012, 01:12 PM   #101
h.h.sk1nny's Avatar
It is, I saw it. He says the car is running awesome, so I'd imagine it's going well with intake too.
Originally Posted by TRSpeed View Post
@StreetUnitMark
He means a 3" intake...............or was it a 3.25"
Last edited by h.h.sk1nny; 06-07-2012 at 01:12 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-07-2012, 01:14 PM   #102
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
I didn't read through the 3 pages, but is the GTX on or still on k04? I wanted to see sub 11 sec k04 records on a 3.
2010 LSM Speed3
#BakeryTuned
 Old 06-07-2012, 01:26 PM   #103
driver311's Avatar
Yes the 3in Sure intake is in there Mark. Was a beautiful piece just like the stock sized one. Fitment was spot on and was very easy to scale. I love these intakes and had to have it on this build. Ill post the pics very very soon. Thanks @StreetUnitMark for another awesome part. In my eyes the 3in maf is a great all around size for these cars. Makes great power, easy to tune and runs great. Cant wait for you to get me the inlet Mark. hint hint LOL
I ended up with the act hd pressure plate paired to the ss disc. I believe it came with the pro lite flywheel. I think it may have been the only option for this setup. I dont remember sorry. But yes act HDSS. Engagement is smooth and pedal feel is only slightly stiffer than stock. I daily my car and the life of a clutch is dictated by the operator. I made hundreds of passes on my stock clutch at 400+whp and for the most part stock was great. I almost replaced it with another stocker, but feared at 500whp it would have come up short. Ive been very much impressed with the stock clutch and drivetrain in this car. Im still on my stock axles and they have more racetime than any two cars on this site. LOL
Gtx for now but the k04 will be going on for some 11s dont you worry. The one off hhskinnys car is obviously a good runner. LOL Ill rock 11s with his. Thanks bud. LOL
Mazdaspeed
Last edited by driver311; 06-07-2012 at 01:26 PM. Reason: MSF Database - Automerged Doublepost
The Following 4 Users Say Thank You to driver311 For This Useful Post:
h.h.sk1nny (06-07-2012), Jackis (06-07-2012), MarkyMark (06-09-2012), Tokay444 (06-07-2012)
 Old 06-07-2012, 01:33 PM   #104
Roddiy's Avatar
Groans: 279
Thats awesome man, add me to the cheering crowd when you do this.
Best of luck!
2010 LSM Speed3
#BakeryTuned
 Old 06-07-2012, 01:42 PM   #105
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Nice Anthony. Glad the wait is over for you.
Needs moar engine bay pics.
 Old 06-07-2012, 02:32 PM   #106
TRSpeed's Avatar
Seriously wtf. Where are the engine bay pics and new wheels pics you promised months ago!!!!!
Lex Tuned
 Old 06-07-2012, 04:04 PM   #107
driver311's Avatar
Damn ok homies. Ill bring the camera to work and get some shots. whys everyone picking on me? lol
Mazdaspeed
 Old 06-07-2012, 04:40 PM   #108
mason's Avatar
Posts: 946   (View Stats)
DO IT!
 Old 07-01-2012, 05:58 AM   #109
jracer's Avatar
Groans: 89
Update ?
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 07-30-2012, 02:50 AM   #110
Jackis's Avatar
^^^ update?
 Old 07-30-2012, 09:35 AM   #111
jracer's Avatar
Groans: 89
update ? @driver311
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 07-31-2012, 02:43 AM   #112
Jackis's Avatar
He's hitting the tens, no time even to write here )))
The Following 3 Users Say Thank You to Jackis For This Useful Post:
Boosted Beluga (07-31-2012), jracer (07-31-2012), Tokay444 (07-31-2012)
 Old 07-31-2012, 07:09 AM   #113
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Driver, hows is that clutch holding for you? My concern is you might've wanted to go with the ACT 6puck....
07 MS3
The original Genpoo Hater
 Old 08-01-2012, 09:13 PM   #114
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Hello?
 Old 08-01-2012, 09:33 PM   #115
Bob Ross Fanclub
Tomas's Avatar
May be it's potato picking season in Idaho.
Potatoes> MS3?
The Following 5 Users Say Thank You to Tomas For This Useful Post:
802MS3 (08-01-2012), Chimmike (08-02-2012), Jackis (08-02-2012), NJSPEED3 (08-01-2012), Tokay444 (08-02-2012)
 Old 08-01-2012, 11:42 PM   #116
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
You da what?
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Forged pistons and building the motor Lex MazdaSpeed 3 - Engine, Transmission & Driveline 45 06-11-2012 12:11 AM
Help Hyundai build the 2012 Azera by... building a 2012 Azera Haltech Automotive News 0 08-30-2011 11:50 AM
Hispania Racing finally joins the party with new F1 car and drivers Haltech Automotive News 0 03-16-2011 06:50 AM
Report: Georgia finally mandates seatbelt usage among pickup truck drivers Haltech Automotive News 0 04-29-2010 09:40 AM
Motor Building cageyvet MazdaSpeed 3/6 - Turbo Induction 5 12-24-2009 03:03 PM
Page generated in 0.54404 seconds with 36 queries
