 Old 07-01-2014, 04:59 PM   #1
jvms3's Avatar
Posts: 61   (View Stats)
jvms3 is a glorious beacon of lightjvms3 is a glorious beacon of lightjvms3 is a glorious beacon of lightjvms3 is a glorious beacon of lightjvms3 is a glorious beacon of lightjvms3 is a glorious beacon of light
Default Driving no wastegate?
Using external.wastegate on hotside of my 3071gtx..waiting for elbow cuz wastegate is too big with the dp there..is it.dangerous to drive.even a little bit with.no wastegate?.. I wont.be.boosting just.granny it home..I keep getting mixed signals
building motor, 3071gtx,cp-3 tbe,cpe 3.5 full intake , 3bar map , cp-e front mount, cp-3 hpfp
Pnp im, Tial 38mmewg, JBR rear sway bar, BC Racing extreme drop coils, Spc camber arms, Ugly garage door lip for now lol, xxr 527s,FreekTune!
jvms3 is offline   Reply With Quote
 Old 07-01-2014, 05:07 PM   #2
You will get a shitload of exhaust gases in the engine bay, not sure if this can fuck things up from excessive heat.
 Old 07-01-2014, 05:08 PM   #3
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
if you block it off youll spike and boost all over the place
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 07-01-2014, 05:25 PM   #4
Darth_Nuruodo's Avatar
Posts: 2,775   (View Stats)
Groans: 88
And if you leave it open you won't run because you won't have AFRs, if you can keep it from stalling you'll just hydro lock the motor as it thinks it's running super lean.
Edit: on the plus side I don't think you'll have too much to worry about heat or exhaust fumes as I doubt the motor will function long enough for those to become a problem lol
Bone stock so far
The Following 2 Users Say Thank You to Darth_Nuruodo For This Useful Post:
ABolewski (07-01-2014), jvms3 (07-01-2014)
 Old 07-01-2014, 05:27 PM   #5
Bob-o's Avatar
Posts: 1,312   (View Stats)
I wonder if the car would even start with a huge hole in the system like that.
I personally wouldn't drive it, but if its a necessity, don't go near the throttle
EWG GTX3071 | PERM 3.5" intake | COBB FMIC | CP-e injector seals | UR downpipe | CS testpipe | HKS catback | KW V1's | Blahblahblah
 Old 07-01-2014, 05:47 PM   #6
jvms3's Avatar
It starts and I moved it in the driveway but I might.just take the.safe route and.leave it there until the elbow for the wastegate.comes in
Just needed it outta my.neighbors driveway.but ill take the safe rout
Last edited by jvms3; 07-01-2014 at 05:47 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-01-2014, 06:50 PM   #7
mxlplx71's Avatar
Groans: 128
Does it have an internal wastegate? Or blocked off?
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 07-01-2014, 06:57 PM   #8
jvms3's Avatar
Ewg not blocked off at the noment.cause im.waiting on a part.. so theres just a hole there and its very loud as expected lol so no wastegate at moment
 Old 07-01-2014, 07:04 PM   #9
Johnasaurus's Avatar
Posts: 359   (View Stats)
Johnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the world
Why didn't you plan your build better is the real question
2012 black mica. Totaled 10/31/14.
Johnasaurus is offline   Reply With Quote
 Old 07-01-2014, 07:28 PM   #10
jvms3's Avatar
I thought the wastegate would fit the down pipe dosent let it.get there.by just a little..and ordered the parts.before I started building but.k04 finaly went lol
So I just went straight.to throwing the turbo in and the dp killed me by a hair lol
Last edited by jvms3; 07-01-2014 at 07:28 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-17-2014, 01:29 PM   #11
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
if the internal wasgate is still there and not welded shut, you may just remove what maintain it closed and plug your EWG port to run almost n/a without any issues.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Tial Wastegate vs EMUSA Wastegate SleeperHatch MazdaSpeed 3/6 - Turbo Induction 6 09-12-2012 04:31 PM
Distracted Driving Laws Quickly Changing Use Of Smartphones While Driving Haltech Automotive News 0 04-15-2012 09:40 PM
Video: AMG Driving Academy publishes ten-part driving course on YouTube Haltech Automotive News 0 08-24-2011 09:20 AM
How to connect the stock wastegate solenoid to an external wastegate cageyvet MazdaSpeed 3/6 - Turbo Induction 0 03-17-2010 05:02 PM
Drowsy driving is equal to drunk driving Haltech Automotive News 0 05-29-2008 06:30 AM
Page generated in 0.30641 seconds with 26 queries
