Closed Thread
 Old 01-23-2013, 07:35 PM   #1
bigturbo3's Avatar
Posts: 25   (View Stats)
bigturbo3 is infamous around these parts
Groaned at 21 Times in 6 Posts
Default engine build need advice!
hey msf, i am going with an engine build and big turbo and would like you help to make sure i make the right choices, i have done alot of research and just want to make sure i have it all down
so here is what i have so far:
Cobb bov: $265.00
CP Pistons: $550.00
Carrillo A beam rods: $790.00<-- going with these i think
Carrillo H beam rods: $920.0
Cometic HG: $100.00
ARP Headstuds: $145.00
ARP Mainstuds: $98.00
Cobb 3 port: $105.00
Cobb FMIC: $985.00
GT2871: $1,680.00 <--changing this to gtx3071r
Externally wastegated turbine housing: $380.00
Tial 44mm wastegate: $359.00
Turbo XS test pipe: $165.00
autotech internals: $339
and i also just picked up a brand new fuel pump also
total part $5,600 roughly<--- all pricing was from my builder
and this is where my research came in on the little stuff.
3x crank pully washers
2x cam washers
thrust washer
crank pully seal
Crank flywheel seal
16x valve stem seal
32x valve locks (optional)
5x flywheel bolts
Oil pickup o-ring (optional)
Oil pickup (optional)
Oil strainer (recommended)
Oil pump (recommended)
Oil chain
oil chain guide(s?)
Timing chain
timing guides (2 different ones)
Timing tensioner
Dcr vvt (recommended)
Cometec/oem head gasket
Thermostat
Injector seals (recommended)
Injector stud kit (optional)
Pcv
OEM Crank Pulley Bolt
i had my timing chain,vvt and all timing parts changed 10k ago by the dealer so not sure if i need to replace that since its only been 10k.
well guys please let me know what you think i will be going green very soon so dont worry i got that covered since that the most important part to my build
oh and i will also get the injector seals, and all jbr motor mounts as well
Last edited by bigturbo3; 01-23-2013 at 07:35 PM. Reason: MSF Database - Automerged Doublepost
bigturbo3 is offline
The Following User Says Thank You to bigturbo3 For This Useful Post:
SpeedRebirth (01-23-2013)
 Old 01-23-2013, 07:40 PM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
You can reuse a lot of stuff from your old engine. There is a thread almost exactly like this posted by theurgy from a day or two ago.
-06 MS6
-Corn fed 07 MS3 - Sold
phate is offline
helmetface (01-23-2013)
 Old 01-23-2013, 07:44 PM   #3
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Go 38mm WG for a 3071r
Also, save yourself the hassle and get a 90 -AN fitting to use in substitute of the 45 that is supplied with the oil return for the ATP hotside.
helmetface is offline
The Following 2 Users Say Thank You to helmetface For This Useful Post:
SpeedRebirth (01-23-2013), Voltwings (01-24-2013)
 Old 01-23-2013, 07:44 PM   #4
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
Edgeautosport can hook you up with an ewg gtx30 kit. Comes with wastegate, dump pipe, oil lines.
You'll also need big turbo TIP.
captain slow is offline
 Old 01-23-2013, 08:27 PM   #5
Eth Fiend
phate's Avatar
Dang man, you could at least give @06Speed6 some credit for that list you "researched":
Originally Posted by bigturbo3 View Post
[INDENT]
2x cam washers
thrust washer
crank pully seal
Crank flywheel seal
16x valve stem seal
5x flywheel bolts
Oil chain
oil chain guide(s?)
Timing chain
Timing tensioner
Thermostat
Pcv
2x cam washers
thrust washer
crank pully seal
Crank flywheel seal
16x valve stem seal
5x flywheel bolts
Oil chain
oil chain guide(s?)
Timing chain
Timing tensioner
Thermostat (recommended)
Pcv
Maybe more im not thinking of, im tired.
-06 MS6
phate is offline
06Speed6 (01-24-2013), atvfreek (01-24-2013), helmetface (01-24-2013), silvapain (01-24-2013)
 Old 01-24-2013, 12:55 AM   #6
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Rofl that cracked me up
I also have the part numbers in my part number thread that is stickied in the ms6 engine subforum.
2006 Mazdaspeed 6
06Speed6 is offline
The Following 4 Users Say Thank You to 06Speed6 For This Useful Post:
atvfreek (01-24-2013), bigturbo3 (01-24-2013), GartzSpeed (01-24-2013), phate (01-24-2013)
 Old 01-23-2013, 08:30 PM   #7
bigturbo3's Avatar
yes sorry that list was from 06speed6
 Old 01-23-2013, 09:34 PM   #8
Juliandlr1004's Avatar
Posts: 226   (View Stats)
Juliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the world
Groaned at 8 Times in 4 Posts
I have all my parts already. Here is my list:
Overhaul gasket set
Cometic head gasket (if over boring)
Arp head studs
Arp main studs
Front oil seal (overhaul comes with one)
Rear main seal
Rod bearings
Main bearings
Crank pulley bolt
Thrust washer
Friction washers
Cam friction washers
Egr delete(if you dont have one)
I got weisco pistons
I got k1 rods
Also going gtx3071r so i also got:
Stratified 3 port ebcs
Cpe big turbo inlet
Cpe big maf housing
Bosch 3 bar map
3 bar map pnp harness
Cpe injector seals
Going to buy a treadstone intercooler (you can get any upgraded one)
And going to buy a stage 3 clutch
The turbo im getting comes with the tial ewg and dump tube. Go with edgeauto. Speak with alan or jp. Tell em aj referred you. They will hook you up big time.
And thats assuming you have a cobb ap, down pipe, hpfp internals, exhaust
Last edited by Juliandlr1004; 01-23-2013 at 09:34 PM. Reason: MSF Database - Automerged Doublepost
Juliandlr1004 is offline
The Following User Says Thank You to Juliandlr1004 For This Useful Post:
 Old 01-24-2013, 07:32 AM   #9
bigturbo3's Avatar
THANKS FOR THE INFO, IS ALL THAT STUFF NECESSARY OR DEPEND WHAT THE CONDITIONS ARE WHEN THE MOTOR GETS TAKING APART? I KNOW SOME THINGS ARE A MUST LIKE THE CRANK BOLT AND STUFF LIKE THAT, JUST TRYING TO SAVE A LITTLE ON THE BUILD IF I CAN BUT I DONT WANT TO CHEAP OUT EITHER
 Old 01-24-2013, 08:23 AM   #10
Jh8909's Avatar
Posts: 1,457   (View Stats)
Groans: 130
Groaned at 8 Times in 7 Posts
Don't you yell at me.
Jh8909 is offline
The Following 3 Users Say Thank You to Jh8909 For This Useful Post:
bigturbo3 (01-24-2013), ccspeed3 (01-24-2013), phate (01-24-2013)
 Old 01-24-2013, 08:48 AM   #11
Go with my list bro...im not sure if im allowed to discuss what prices i got
 Old 01-24-2013, 08:58 AM   #12
bigturbo3's Avatar
i just called jp so he will be helping me out, thanks for the info
 Old 01-24-2013, 09:02 AM   #13
Voltwings's Avatar
Posts: 3,713   (View Stats)
The carillo rods are twice as expensive as the K1's and the K1's are every bit as good for making useable power... thats whats in my engine, just saying. The K1 / wiseco is a very proven set up on this platform, dont fix what aint broken (no pun intended in regards to blown motor...).
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
Voltwings is offline
 Old 01-24-2013, 09:15 AM   #14
Im glad to hear that. My rods are on back order :/
 Old 01-24-2013, 09:20 AM   #15
bigturbo3's Avatar
with the egr delete, i know you can check off that code but will it make any problem as far as inspection?
 Old 01-24-2013, 09:23 AM   #16
Not sure. Barely gonna do mine
 Old 01-24-2013, 09:26 AM   #17
Voltwings's Avatar
well i have an EGR delete and a catted DP. Bought a catted DP so i would pass inspections, but after talking to a few people COBB turns off the "catless DP" code on all base maps anyways... so basically even with a catted DP the computer will read as catless. I'll be getting an inspection in the next few days and if i pass ill try to remember to post here haha.
Past:
-Sold-
-Sold-
Current:
 Old 01-24-2013, 10:02 AM   #18
StayBroke's Avatar
Posts: 2,075   (View Stats)
it depends on the state.
I no nc cars can have one not ready.
So if i have a egr delete and a catless downpipe i will have 2 not readys.
so what i do is put my egr back on before i get my inspection and i pass.
StayBroke is offline
The Following User Says Thank You to StayBroke For This Useful Post:
 Old 01-24-2013, 12:29 PM   #19
Volcom8190's Avatar
Posts: 448   (View Stats)
Volcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the world
Originally Posted by Matrix311 View Post
I'm kind of looking at building my engine up as well. My car will be paid off in the next few months so i'll have some extra money to build up the engine. What would you say the average labor cost is to do the engine build? I'm talking just labor, not the cost of parts. I contacted 1 shop here in Phoenix and they quoted me $10,500 installed with parts. I thought that seemed a little high to me.
That seems really high, I know a shop around here that would swap out an engine for around 1200$ + parts. Yet again though, it all depends on what crap you are putting into the bottom end.
I know nc cars can have one not ready.
NC inspectors are required to lift the car and check for the presence of a cat also, among other things like wheel bearings. You can always weld a shell on the outside of the dp.
2010 - BMW 335i M-Sport - Lemans Blue Metallic
2005 - Kawasaki ZX-6R 636 - Magma Red
Volcom8190 is offline
 Old 01-24-2013, 03:53 PM   #20
StayBroke's Avatar
lol, i no people so that does not matter lol.
 Old 01-24-2013, 12:20 PM   #21
Matrix311's Avatar
Posts: 2,133   (View Stats)
Matrix311 is offline
 Old 01-24-2013, 12:26 PM   #22
Voltwings's Avatar
WAY high. Granted i know the guy doing mine, but he is still running a business so its not like he's cutting me a super deal and my quote was $2500. thats build + clutch, i want the head ported and any machining will be extra of corse.
Past:
-Sold-
-Sold-
Current:
 Old 01-24-2013, 12:35 PM   #23
Matrix311's Avatar
So $2500 seems about right to me, thats the price I had in mind. I will certainly shop around. This is just a shop another local mazda club uses for dyno days and such. We have LOTS of options here in Phoenix with lots of great shops, i'm not to worried about finding better pricing because i know it's out there. To save on the money I could pull the engine myself and bring it to a shop for them to do the work, that would probably save me even more money. I was just curious what everyone else has paid so i can get an idea of the standard costs and maybe use that as part of the price negotiation.
 Old 01-24-2013, 12:44 PM   #24
Eth Fiend
phate's Avatar
You could build an engine right, for about $2500 if you pull it yourself. That includes machine work, forged rods and pistons, and the few small pieces that are necessary.
-06 MS6
phate is offline
magicka (01-24-2013)
 Old 01-24-2013, 12:50 PM   #25
This guy is charging me $500 for labor excluding machone shop prices
 Old 01-24-2013, 04:49 PM   #26
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
I have an excel file with a parts list including part numbers & cost in my build thread. The URL is in my sig.
Tapadatass
silvapain is offline
magicka (01-24-2013), phate (01-24-2013)
 Old 01-24-2013, 10:05 PM   #27
bigturbo3's Avatar
all my parts come out to like $5500-6000 and i was told the total build would cost me like $7500 maybe 8 at the most... and thats with machine work and a few other things
 Old 01-25-2013, 05:11 AM   #28
Sounds to me like you are getting but raped lol
phate (01-25-2013)
 Old 01-25-2013, 07:51 AM   #29
bigturbo3's Avatar
why do you say that?
 Old 01-25-2013, 05:52 AM   #30
silvapain's Avatar
Groans: 136
I had to buy a new block and had the machine shop build my shortblock for me, and my total cost was only ~$5500. You can certainly get it done for cheaper than me.
Tapadatass
magicka (01-25-2013), phate (01-25-2013)
 Old 01-25-2013, 07:57 AM   #31
bigturbo3's Avatar
Tapadatass
well if you look at my part list it comes out to 5,500 so how much should the labor cost?
1. Bore up to 0.20 over
2.Plate hone up toe 0.20 over
3.Vinny’s own plateau hone
4.Line hone main cap
5.Deck Block
6.Radius oil holes/Micro polish crank
7.Remove Galley balls, flush crank & install set screws
8.Balance entire rotating assembly
9.Resize rods for additional clearance
10.File fit rings to bore
PARTS
1.Hand finished C.P. pistons, rings 8.5:1 compression with
thermal barrier coating option, locks & 866 tool steel pins
2.Carrillo “SA” rods
3.ARP main stud kit
4.ARP Head Stud kit
5.A.C.L./Calico coated main bearings
6.A.C.L./Calico coated rod bearings
7.New thrust washers
8.GTR skyline factory head gaskets
STAGE I CYLINDER HEAD
1. COMPLETE FULL RADIUS COMPETITION VALVE JOB
2.REFACE ALL STOCK VALVES
3.LAP ALL VALVES
4.MILL/DECK 2 CYLINDER HEADS
5.INSTALL VITON VALVE SEALS
6.INSTALL jim wolf SINGLE VALVE SPRINGS
7.REASSEMBLE BOTH CYLINDER HEADS
8.ADJUST VALVE CLEARANCE
9.MILD PORTING ON IN/EX TO BLEND SEAT TO PORT
10.HONE VALVE GUIDE TO SIZE
this is what will be done and some step are for an nissan engine but you get the idea
 Old 01-25-2013, 08:00 AM   #32
Thats why the price is so high
 Old 01-25-2013, 08:14 AM   #33
bigturbo3's Avatar
why what would you say shouldnt be done, i feel like if i am going to do this might as well go all out and have it done the best way and make sure its done right plus it also include a tune and free oil changes on them and 1 year warranty.
 Old 01-25-2013, 09:00 AM   #34
magicka's Avatar
Posts: 520   (View Stats)
Part of the difference is that you're starting from scratch, so you included $1800 or so in things like the FMIC and pump internals in your build price that most people already have done. What shop are you using? How much experience do they have tuning our cars?
Sent from my DROID RAZR using Forum Runner
2009 CWP MS3 GT
magicka is offline
 Old 01-25-2013, 09:11 AM   #35
Id buy supporting mods, rebuild pistons and.rods, slap on a gtx3071 and call it a day. Build the head when you plan on going 600+hp
 Old 01-25-2013, 09:36 AM   #36
bigturbo3's Avatar
i am having vinny ten racing shop in long island build it, i know some people dont like him but i have had him tune my car before and he know what he is doing and does very good work. and yes the parts are what is making the prices so high i think the labor and machine work and stuff will be around 1500 maybe less it depends you know
if you read my op i am buying supporting mods, and some things will be different that what was on the list becasue some of that was meant for a nissan, i do not believe the head will have alot of work done other then clean valves and stuff like that, no new valves or springs or nothing
what should labor be around on a build like what i have posted just labor
just checked he said it should be around 6k-7.5k for the total build
Last edited by bigturbo3; 01-25-2013 at 09:36 AM. Reason: MSF Database - Automerged Doublepost
 Old 01-25-2013, 09:48 AM   #37
Eth Fiend
phate's Avatar
Check out my build threads, they outline the machine work performed for a brand new block build, and a used block rebuild. Silvapain used the same machine shop and all 3 came out to ~$1k for everything (including main/rod bearings).
Most race shops don't do their own machine work, so there is a mark up on whatever they have done. I've worked with Vinny tens guys one time and had a good experience - I did a remote tuning session there for a NY guy.
IDK anything about their engine building expertise, though. I would definitely make sure they have done these engines before, because they have some uncommon aspects. Unless you're going for >5-600hp, you probably don't need to do anything to the head except recondition it (valve job, seals, milled flat).
-06 MS6
phate is offline
bigturbo3 (01-25-2013), silvapain (01-25-2013)
 Old 01-25-2013, 09:52 AM   #38
Man shops up there are crazy expensive
phate (01-25-2013)
 Old 01-25-2013, 09:56 AM   #39
silvapain's Avatar
Groans: 136
IMO, the head should be inspected for valve guides, seals, and bent valves when doing an engine build.
Tapadatass
bigturbo3 (01-25-2013), phate (01-25-2013)
 Old 01-25-2013, 11:39 AM   #40
bigturbo3's Avatar
he told me he has not done an ms3 engine before, i was like hmm, but i do trust him and im sure it will be fine, is there anything i should make him aware of on the build? he has been building motors sine the 80's and hes an master technician,cobb certified.
Closed Thread
Time for some EFR Forged Madness! Motor Build Advice Needed >>> Alpha MazdaSpeed 6 - Engine, Transmission & Driveline 103 06-03-2014 03:34 PM
New engine break-in advice corypechon Mazdaspeed3/6 General Discussion 7 02-11-2013 03:58 PM
engine overheat problem! please HELP!/ADVICE! ziggi MazdaSpeed 6 - Engine, Transmission & Driveline 15 05-16-2011 10:06 AM
Engine build josh0408 MazdaSpeed 3/6 - Big Turbo Builds 5 12-28-2010 07:15 PM
Page generated in 0.60320 seconds with 32 queries
