Like Tree4Likes
 Old 11-23-2010, 05:06 PM   #1
essejkcamraw's Avatar
Posts: 922   (View Stats)
Default essejkcamraw's big turbo build
well, coming towards the end of this LONG ass road so, i figured i would post up the build thread and will update it as it progresses. for the most part, this was socks' old setup which i bought month's back from kilik on here.
this whole thing started with a race roots dyno/tune day. then ended with this fail thread here RR tuner fail fuck race roots.
anyways, goals - higher 400's for a little while, then going for 500's later one. i know the 35r might be a little big for the initial goal but, i will shoot for higher numbers later on, i just want this thing up and running smoothly before i get to going ape shit. this is 7 months in the making and im excited to finally be nearing the end.
shitty photo's provided by cell phone.
DCR ewg manifold.
Tial 38mm
CP-E fuel pump
CP-E big maf + big turbo inlet
Devils own stg2 meth
CP-E SB+ flashes
K1 rods - and before anyone say's anything i've done A LOT of researching on these before buying. although inexpensive i feel these rods are MORE than capable to withstand high HP applications. there are a lot of 600+ hp vettes and camaros around here on these rods and even a 800hp supra running them with NO problems
Wiseco pistons - 9.5:1 ratio
TurboXS fmic
custom v-band DP and cobb exhaust
GT35R .82ar T3 V-band
there is still a BUNCH of stuff and little shit i still need to pick up but, ill be updating this thread as i go.
Quick video! 3rd gear.
The Following 14 Users Say Thank You to essejkcamraw For This Useful Post:
802MS3 (11-23-2010), Docnox (12-05-2010), dougefresh_ (05-01-2011), emag remrofni (04-28-2011), I Love Brownies (11-24-2010), i8urgti (07-05-2011), JacksonMS30 (02-02-2011), jwilkins88 (12-05-2010), madvillain (11-23-2010), MS3-a(sore)ASS-rex (11-23-2010), NJSPEED3 (11-24-2010), rodrigo (11-24-2010), wankular (11-24-2010), zx2man (11-23-2010)
 Old 11-23-2010, 07:43 PM   #2
zx2man's Avatar
Posts: 1,356   (View Stats)
zx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the world
Looks good man. Couple questions, do you plan to have any bracing for the turbo? Dcr manifold looks like puresex, but with those long runners and heavy 35r, might be a potential prab. Also refering to the k1 rods. I too have heard good things. I also have heard of the k1 rods in 600 hp corvette setups too, but are those Corvette and Supra setups have the same cylinder pressure and stress on the rods as your setup will? From the little research I have done, the stres on a engine internal on a 4 banger wont be the same as a 6 or 8. Sometimes the rods are designed alittle differently,and have different dimensions compared to thier 4 cylinder cousins. I think if you plan to stay 500 whp or under youll be fine, but anything after that and Pauter&Carillo rods would be the best choice.
anyways things look good, cant wait to see your setup when completed
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO*
zx2man is offline   Reply With Quote
The Following User Says Thank You to zx2man For This Useful Post:
essejkcamraw (11-23-2010)
 Old 11-23-2010, 08:25 PM   #3
haven't got around to thinking about bracing yet, i was gonna get everything mounted up an running and see how it goes then get around to bracing if need be. ill be on full mounts so hopefully wont be too much movement going on there. the 35r really isn't that heavy it's somehow actually 6oz lighter than the 3071.
as far as cylinder pressure i haz no clue what kind of pressure those car's are seeing and what the difference between them are.
The Following User Says Thank You to essejkcamraw For This Useful Post:
zx2man (11-23-2010)
 Old 11-23-2010, 08:17 PM   #4
kmac's Avatar
Posts: 1,792   (View Stats)
good luck, It looks like you will have a nice setup under the hood.
The Following User Says Thank You to kmac For This Useful Post:
 Old 11-23-2010, 08:39 PM   #5
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Looks good man !!
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
 Old 11-23-2010, 09:41 PM   #6
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Setup looks great man! Best of luck, hopefully this thing will be up and running soon.
NATOR PA
 Old 11-23-2010, 09:47 PM   #7
spiker98's Avatar
Posts: 427   (View Stats)
spiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the world
Hells yeah! Looks sick.
spiker98 is offline   Reply With Quote
The Following User Says Thank You to spiker98 For This Useful Post:
 Old 11-23-2010, 10:11 PM   #8
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Oh heeeeeell yeah Jesse. That is going to be one great setup. Remind me of when the motor will be under the knife? When will turbo be mounted?
I know things never go as planned, well at least not for me, but do you have any forcasted timeline at all?
Also, did you ever mount up that DCR mani and 3071? I can't remember. What ever happened after the RR tune? Did you motor get fucked or what? I can't remember that either. Its been a time warp man....
 Old 11-23-2010, 10:28 PM   #9
im REALLY hoping by xmas this will be up and running. motors getting finished up as we speak, just got done with the machining. so hopefully next week start dropping in the internals an such.
but after the tune and taking it back to scott (see thread link posted in OP) you can see he pretty much fucked me. so result of that was bent valves. and the rings were pretty much no good.
mani and turbo never saw the car so, the 35r is the first BT this cars seeing. should be pretty good haha
The Following 3 Users Say Thank You to essejkcamraw For This Useful Post:
Docnox (12-05-2010), jwilkins88 (12-05-2010), madvillain (11-23-2010)
 Old 11-23-2010, 10:26 PM   #10
801MS3's Avatar
Posts: 453   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
This thing is going to be nuts!
Sub'd for updates.
Way to go for it man, props for that.
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline   Reply With Quote
The Following User Says Thank You to 801MS3 For This Useful Post:
 Old 11-23-2010, 10:56 PM   #11
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
subed
 Old 11-23-2010, 11:24 PM   #12
driver311's Avatar
Posts: 1,769   (View Stats)
You my sir dont roll like a bitch. DCR does fuck around when it comes to making shit go fast. That mani reminds me alot of full race mani's. Nice choice bud. Did u find out if that was a .63 back half?
Ps. I really want that core.
Mazdaspeed
The Following User Says Thank You to driver311 For This Useful Post:
essejkcamraw (11-24-2010)
 Old 11-24-2010, 12:20 AM   #13
nope. it is a .82 housing. im gonna run it see how i like it for the initial set up, if not i was gonna go down to a .63 though.
 Old 11-24-2010, 12:22 AM   #14
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
are u sure thats a 82 A/R ? hahahahahhahahahhahahahha
good looking bro.... please repaint turbo and go kick ass on the build
 Old 11-24-2010, 12:31 AM   #15
mannn das my lil red turbo leaves it alone!
i keep telling myself i wont see much of it haha but, in person the wrinkle red looks good, my cell phone pics make it look like dick. im just not a fan of red really. cant complain really with the price i got it for though and essentially it's new and im cheap when it comes to shit like that so the red's stayin.
 Old 11-24-2010, 12:38 AM   #16
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Did you buy this set up from someone else?
I guess my question is how do you know the dp will fit with that mani?
I also think you may need to get a bigger wastegate you may wana refer to rigor's thread.
 Old 11-24-2010, 12:47 AM   #17
yup. the whole setup minus the turbo was socks' old set up.
as for the wastegate, i've tossed this around a lot. im going to be running quite a bit of boost. so the 38mm should work out. wont know till it's together an running though.
 Old 11-24-2010, 12:47 AM   #18
driver311's Avatar
The wg will be fine. I dont think thats the problem on the other car personally. Just my opinion and some may disagree but it theoretically should work great. Ive personally assembled srt4 that make 500whp at 30psi on tial 38mm wgs to ebay 38mm wgs. LOL This one will be just fine.
Mazdaspeed
 Old 11-24-2010, 06:37 AM   #19
obijack's Avatar
Posts: 1,830   (View Stats)
Who is machining and putting your internals in? What $$$ are we talkin?
 Old 11-24-2010, 09:32 AM   #20
a place called pyramid did machining on the block. Clearwater cylinder head did the head work.
for everything came in a little over a grand.
im dropping the internals in myself along with a buddy of mine.
jwilkins88 (12-05-2010), obijack (11-24-2010), tbot (11-24-2010)
 Old 11-24-2010, 08:45 AM   #21
jracer's Avatar
Groans: 89
looking good jess.. cant wait to see it..
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 11-24-2010, 11:14 AM   #22
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
Good to know since I'm going to be doing a lot of this stuff here in the near future, granted not up and running as soon as you are haha.
The only reason I'm having a shop install the internals is to balance and blueprint the motor before I drop it back in the car.
 Old 11-24-2010, 11:49 AM   #23
get that shit rollin!
 Old 11-24-2010, 11:53 AM   #24
tbot's Avatar
Groans: 40
It is...just very slowly, especially with turkey day and all. If he's open on friday i'm going to try and roll up there and help him at least get the motor pulled to find out wtf is exactly wrong. Dunno, we'll see tho.
 Old 11-24-2010, 11:55 AM   #25
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
im curious to see how that DP will fit with the 35r. i told jason it would have to be tweaked (even on the 3071r), because i wasnt 100% thrilled with the fitment.
The Following 2 Users Say Thank You to socks For This Useful Post:
essejkcamraw (11-24-2010), kilik2 (11-24-2010)
 Old 11-24-2010, 12:53 PM   #26
Hopefully it isn't too Outta whack. I gotta feeling I can make it work, if not I have a couple of friends who could tweak it if need be.
 Old 12-05-2010, 04:27 AM   #27
small update:
called up mark @ SU the other day and made an order. pretty much everything to get this motor done and buttoned up and back in my car haha. nothing too special, pretty much just all the OEM gaskets. rod bearing. main bearings. etc.
big thanks to mark!
just a few more things i'd like to get such as clutch but other than that. all major shit is done. just about assembling an dropping in the motor and bolting everything up now. wont be long till i can start shooting for big numbers
The Following 2 Users Say Thank You to essejkcamraw For This Useful Post:
madvillain (12-05-2010), tbot (12-06-2010)
 Old 11-24-2010, 12:02 PM   #28
kilik2's Avatar
Posts: 1,254   (View Stats)
kilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the world
Groans: 127
Groaned at 40 Times in 31 Posts
I am anxious to see this build come to fruition, I only met Jesse for a short minute but he was a really cool dude and I hope this build works out for him unlike the RR fiasco.
kilik2 is offline   Reply With Quote
The Following User Says Thank You to kilik2 For This Useful Post:
 Old 12-05-2010, 05:52 AM   #29
mghtymouse380's Avatar
Posts: 1,182   (View Stats)
mghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the world
Groans: 58
Good lets get this put together. Waiting to see what a 35r can do on the speed.
2013 CWP (DD)
COBB AP| JBR HSK| JBR RSB| JBR SSP| JBR Shifter Bushings| AT Internals| Ksport Kontrol Pro Coilovers| 3.5 MAF HOUSING| 3' HTP TIP| UR FMIC| TIGS| GTX2867| EBAY 3' DP
TUNE IN PROGRESS (RFINKLE2)
1999 Mazda Miata (PROJECT) (blown motor)
BEGI Cast Manifold| BEGI DP| SR20 Turbo (GT2554)| Flying Miata Silicone IC Piping| Cx Racing IC| HKS BOV| TEIN SA| Harddog Rollbar|Sparco Spint V| TRmotorsports C1 15x8
mghtymouse380 is offline   Reply With Quote
 Old 12-05-2010, 06:46 AM   #30
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
he has the bigger hot side, and will probably run more boost than i was shooting for, lower boost targets and small hot sides require bigger w/g to get rid of excess boost
and the build looks great!
at 104000 2 bent rods
tuned by nishan
The Following User Says Thank You to rigor For This Useful Post:
essejkcamraw (12-05-2010)
 Old 12-05-2010, 07:41 AM   #31
jwilkins88's Avatar
Posts: 3,675   (View Stats)
Groans: 126
Can't believe I missed this!
Shit looks good man. I'm really curious to see what the 35r will do for you. How many people are running gt35s?
The Following User Says Thank You to jwilkins88 For This Useful Post:
 Old 12-05-2010, 08:40 AM   #32
07ms3obrien's Avatar
Posts: 157   (View Stats)
07ms3obrien is a splendid one to behold07ms3obrien is a splendid one to behold07ms3obrien is a splendid one to behold07ms3obrien is a splendid one to behold07ms3obrien is a splendid one to behold07ms3obrien is a splendid one to behold07ms3obrien is a splendid one to behold
Can't wait to see this finished! U mite as well satisfy everyone when ur done and post videos and pics in the first post as soon as its running! Haha
U know every1 b begging 4 em
2006 Evolution 9 SE- ported and polished 16g, ported manifold, buschur icp, buschur 3" tbe, buschur MBC (23lbs), buschur mini battery, NGK 1 step colder plugs, custom intake with blox filter, and some appearence shiiiat.
2007 Mazda Speed3 cosmic blue-Stock for now..
07ms3obrien is offline   Reply With Quote
The Following User Says Thank You to 07ms3obrien For This Useful Post:
 Old 12-05-2010, 12:09 PM   #33
mason's Avatar
Posts: 946   (View Stats)
your set up looks great!!! im going with the 35r also on the new steed top mount manni. but it will take some time. still in research phase. and ill be custom making dp, intake, ect... but starting to order some of the goods now.
The Following User Says Thank You to mason For This Useful Post:
 Old 12-05-2010, 05:42 PM   #34
thanks doods! hopefully xmas doesnt fuck me too hard, id like to have this done within the next month.
 Old 12-11-2010, 08:50 PM   #35
wette460's Avatar
Posts: 385   (View Stats)
wette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the world
good to hear things are finally panning out for you Jessie. Fuck Race Roots so hard! Scott never did update my AP tune like he said he would. That guy needs to get a GT35 shoved up his ass for being such a douche. And yes, you better post pics of that beastly setup man!
T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels
wette460 is offline   Reply With Quote
 Old 12-28-2010, 11:44 AM   #36
UPDATE.
finally!! this fucker showed up at my door today. the cluster fuck with holidays and shipping sucks! after the headache of dealing with 2 weeks of not receiving this thing it finally got here.
ACT race clutch. 6puck sprung hub.
the motor should of been in 4 weeks ago but, i wanted to order the clutch and have it here to put in while everything was out so i wouldn't have to deal with that headache later.
happy to say the motor will be dropped in and ill be putting up more pics of everything being bolted up here very soon!
From built & Big turbo to Miata Gheys
The Following 5 Users Say Thank You to essejkcamraw For This Useful Post:
amoosenamedhank (12-28-2010), bmylez (12-28-2010), Boosted Beluga (12-28-2010), mason (12-28-2010), tbot (12-28-2010)
 Old 12-28-2010, 11:50 AM   #37
socks's Avatar
Groans: 125
<---- still twitches when he hears act 6 puck.
 Old 12-28-2010, 01:02 PM   #38
haha why is that?
 Old 12-28-2010, 03:02 PM   #39
socks's Avatar
Groans: 125
nah, its not that bad. its just stiff, and i drive alot, even when my ms3 was my daily.
its a great clutch, grabs hard, and is tolerable for the street.
Boosted Beluga (12-28-2010), essejkcamraw (12-30-2010)
 Old 02-02-2011, 11:12 AM   #40
MS3KO's Avatar
Posts: 579   (View Stats)
MS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the world
Any progress man??
2009 MazdaSpeed 3 Metro Grey-T3 Gt3071, Re-flanged RR mani, 44mm Tial WG, Cusom DP, Custom 4in to 3.5in intake, Custom 3.5in maf, Custom FMIC kit, Tial BOV, EVO Prosport Boost gauge, EVO oil temp gauge, AEM wideband, TRZ RMM, JBR PMM, JBR TM, JBR Shifter Plate, TWM SS, Hks CBE, COBB AP, Road Magnet Springs.
PERM Tuned!///389hp 360tq///Best time:12.2 @117 (with new tires 11's here i come!)
Hit up BC Autoworks for all your powder coating needs!
MS3KO is offline   Reply With Quote
The Following User Says Thank You to MS3KO For This Useful Post:
socks (02-02-2011)
GTK-450 turbo build matgod MazdaSpeed 3/6 - Big Turbo Builds 18 09-09-2013 08:00 PM
Oil/Dirt Build up in Turbo JCMS07 MazdaSpeed 3/6 - Turbo Induction 20 08-06-2009 09:25 PM
Big turbo kit, build one or not? ptperformance Mazdaspeed3/6 General Discussion 33 10-12-2008 02:55 PM
Page generated in 0.63710 seconds with 43 queries
