![]() Join Date: Nov 2008 Location: Charlotte, NC
(Thread Starter) | Not Ranked : 0 score I am used to a screamer pipe being loud but releasing a smooth sound. Like the normal exhaust note just kicked up a notch. This is happening under part throttle or when the WGDC is 0. When I am at full throttle and the wgdc is at my max setting of around 40, it sounds like someone is clanging pots and pans together. Sort of like an old car that is constantly misfiring. Is this what is is supposed to sound like? My thought is that the gate is opening 100% then closing 100% instead of holding open at x% consistently. Is there a setting I am missing, or something to look at?
__________________ 07 Mazdaspeed3 Mods: ATP GT3076R EWG | TiAl MV-S 38mm Wastegate| Cobb EBCS | Mazdaspeed Intake| CP-E TIP| Cobb Downpipe| TWM Full Short Shifter | SURE Shifter Weight | Hotchkiss Front and Rear Sways | H&R Springs | Koni Yellows | Crossdrilled and Slotted Rotors | EBC Yellow Pads | Goodrich SS Brake Lines | PIAA Forza Wiperblades | Z1 Star Specs on Rear | Michelin PS2 on Front | SURE RMM| Cobb AP | HKS Dual Port BPV | Optima Yellow Top Battery | ACT 6 Puck Clutch | ACT Streetlite Flywheel |
(Thread Starter) | Not Ranked : 0 score No thoughts?
![]() Join Date: Jan 2009 Location: Baltimore, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,896
| Not Ranked : 0 score Did you forget to put the valve seat in when you installed the WG ( looks like a metal ring)? If you forgot to put that in it will sound like it's open at idle and could cause the odd sounds you are hearing under WOT.
__________________ 2006 Mazdaspeed6 GT BCM SpeedPerf6rmanc3 10.6:1 Pistons, PI Fuel Kit, PnP Head, 75mm TB, Pinned Cams/Keyed Crank, 11mm H11 Head Studs \\ PT&E PT6266 CEA BB S-Comp. \\ Manley H+ Rods \\ JMF V2 PI Intake Mani w/ Bosch 1000cc Injectors Squash Performance Top Hat w/ Dual DW300 Pumps \\ AEM FPR \\ Split Second AIC1 \\ CP-e LRT Ex. Mani, SAFEseals, RDM, EGRD \\ SURE TMM, PMM, Juggernaut, Anchors \\ TiAL MVR, Q \\ Bosch 4 Bar MAP HTP 4" Intake \\ Autotech HPFP Internals \\ ATP Catless DP \\ ACT HD 6-Puck w/ Streetlite FW \\ Cobb AP \\ Treadstone TR10 \\ Magnaflow CBE \\ MSD Dashhawk \\ JBR SSP, BSD, RMM Stratified EBCS \\ Corksport SS Braided Clutch Line \\ H&R Coilovers \\ SPC BJs \\ Rotora Drilled/Slotted Rotors \\ H2 Ceramic Pads \\ Enkei EKM3 7.5+45 \\ VG Sharkfin \\ RHO-Plate Most powerful MS6 720/584 @42psi E42 9Oct13 Tuned by NISHAN ![]() |
(Thread Starter) | Not Ranked : 0 score The valve seat ring is on there. If I remember correctly the larger OD of the ring was on the turbo side and the smaller OD went into the waste gate. Also, it seems to smooth out almost to normal when I hit rpm's closer to redline.
![]() Join Date: Feb 2009 Location: Salt Lake City, Utah
Rep Power: 427 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Does it sound like this?
__________________ 417whp 428tq 12.037@117.2mph |
![]() Join Date: Oct 2011 Location: Boca Raton, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,717
Groaned at 50 Times in 17 Posts
__________________ 2012 LSM MS3 Some mods, No list, too much "zapos". | |
![]() Join Date: Nov 2011 Location: Caldwell, ID
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,042
__________________ Old stuff: Stock k04 12.301 @ 113.20 New Stuff: PTE 5858 and Built, not bought, by ME ![]() |
![]() Join Date: Mar 2012 Location: Cary NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score try running the wg directly off of spring pressure. IE: bypass the solenoid. If you still get the flutter, you know its the solenoid, if not its something in your wg.
__________________ 2010 - BMW 335i M-Sport - Lemans Blue Metallic 2005 - Kawasaki ZX-6R 636 - Magma Red |
| Hide Yo Kids-No really, Hide them! ![]() Join Date: Oct 2011 Location: PMITA Jail until 12/2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,515
Groans: 77
| Not Ranked : 0 score my old setup sounded like that...... took my car to Turbo Trix for custom dp and new dump, and now it sounds like all motor. @doubleflusher; has his setup made there also, and it sounds all motor also. |
| The Following User Says Thank You to Voltron For This Useful Post: | doubleflusher (08-05-2013) |
Groans: 77
| Not Ranked : 0 score Details please....I would like to hear that. .
Groans: 77
| Down pipe question? | GrizzlyMPS6 | Mazdaspeed3/6 General Discussion | 1 | 04-22-2012 05:51 PM |
| EWG screamer pipe videos | whoosh@Realtune | Mazdaspeed3/6 General Discussion | 17 | 10-06-2008 05:25 PM |
