 Old 03-26-2013, 08:20 PM   #1
Juliandlr1004's Avatar
Posts: 226   (View Stats)
Juliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the world
Groaned at 8 Times in 4 Posts
Default which ewg spring is which in the gtx3071r kit
Just got my gtx3071r ewg kit today and it didnt come with any directions. I was just wondering which spring is which for the ewg. Can someone help?
Gtx3071r//Tial ewg//Wiseco Pistons//K1 Rods//Cometic head gasket//JBR bsd and baffle//Jbr egr delete//ARP main studs//ARP head studs//Stratified 3 port ebcs// 3 bar map and pnp harness//ACT 6 puck with prolite flywheel//ARP flywheel bolts//Treadstone tr8 core with cx racing intercooler piping//CPE safe seals//CPE big turbo inlet pipe//CPE 3.25" maf housing//Turbosmart dual port nov//h&r springs// Whiteline rear sway bar//Sure dreadnought//Sure juggernaut//Sure rmm//3" dp//Custom exhaust//Drag wheels//KMD hpfpinternals//Cobb AP
Juliandlr1004 is offline   Reply With Quote
 Old 03-26-2013, 08:24 PM   #2
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
You got the tial mvs which is the 38mm. Google.
 Old 03-26-2013, 08:26 PM   #3
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
You're supposed to tell them which one to put in it. IIRC they put a 14 psi spring if you don't specify...? Don't quote me on that, its been a few months since I was considering piecing together a kit....
It might help if you specify which kit... Atmosphere? Atp?
Reading comprehension > you
Last edited by Fatguy729; 03-26-2013 at 08:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-26-2013, 08:28 PM   #4
Etipp98's Avatar
Lol he got ewg not iwg. Ewg comes with all the springs and you pick which combo of springs to put in.
LumberJack (03-26-2013)
 Old 03-26-2013, 08:28 PM   #5
LumberJack's Avatar
They send you all the springs in the box. Use this thing called google and look up Tial and pretty sure they have a spring chart for you to use. This is my nice deed of the day, someone is gonna rip your asshole a new one for a dumb question!
10.36@148 Fastest Gen 2
Etipp98 (03-26-2013)
 Old 03-26-2013, 09:02 PM   #6
Ok so if i plan on going lets say 24 psi on the turbo id use a 12psi spring set up?
 Old 03-26-2013, 09:04 PM   #7
LumberJack's Avatar
Dude, it all depends on how much boost you wanna go with off gate pressure and not be using your boost control. Go with at least 17psi off gate. It's probably gonna creep to about 22-24psi off gate pressure anyways. gtx3071 is creep and boost happy
Also, you don't wanna be doubling spring pressure with the boost controller if you don't have too. You'll be okay on 91/93 whatever gas you have where you are running the spring pressure I stated above
 Old 03-26-2013, 09:14 PM   #8
Here is the chart
[IMG][/IMG]
 Old 03-26-2013, 09:26 PM   #9
Not sure whether to go with the 1 bar or 1.1 bar. New to the ewg...bee. On the k04
 Old 03-26-2013, 09:40 PM   #10
Motor is forged, gtx3071r turbo, cpe big tip, 3.25 maf, 3 bar map, and gonna be on 50/50 meth. Justin is gonna tune me. Gotta break in the motor and clutch first so i only wanna run on spring pressure. A stratified 3 port ebc is gonna be hooked up on 3 port mode obviously. Just wanna put the right springs first time around. Sorry about this.
The Following User Says Thank You to Juliandlr1004 For This Useful Post:
AZSPEED3 (03-26-2013)
 Old 03-27-2013, 06:57 AM   #11
Black/red or blue/yellow or black/blue
pads: top spring clip or back spring plate breakfasteatre MSF KB - Mazdaspeed 3/6 - Suspension & Brakes 5 09-19-2012 01:44 PM
gtx3071r bigRED MazdaSpeed 3/6 - Dyno Sheets/Discussions 7 07-11-2012 05:19 PM
pads: top spring clip or back spring plate breakfasteatre MazdaSpeed 3/6 - Suspension & Brakes 4 11-05-2011 09:52 AM
Possible track spring spring setup for use with Koni yellows stretch MazdaSpeed 3/6 - Suspension & Brakes 154 04-18-2011 12:18 PM
Page generated in 0.31182 seconds with 23 queries
