 Old 02-20-2011, 07:06 AM   #1
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Default A few build questions.......
Didnt know if i should be asking this in the BT section..
i am starting to order parts for my build in the next few weeks, but i have a few questions..
can the head bolts and main bolts be reused ? timing chain ?
since i dont know the mileage on the motor i am replacing the oil pump and the VVt.
my goal is 350-400 hp.. nothing too crazy
going to do wiseco/K1 combo..
Eagle is making rods now for the mzr.. " up to 900hp "
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 02-20-2011, 07:59 AM   #2
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
You definitely DO NOT want to reuse stock head bolts or main bolts. That's asking for fail. They are torque-to-yield and are much weaker when you reuse them.
This is my first timing chain car and my motor is fairly new, so I'm not sure about reusing that.
You're talking about power at the wheels, right? The MS3 can easily hold together at 400 crank hp as long as you do WOT above 3k. Just takes a good tune and common sense. If you want 400whp, building the block is basically a must, yes.
2007 CTS-V - Trying to sell
jracer (02-20-2011)
 Old 02-20-2011, 08:17 AM   #3
DSIT995's Avatar
Posts: 1,768   (View Stats)
Might want to think about getting the DCR VVT instead of buying an oem one too......
99 Miata NB - Stock for now
The Following User Says Thank You to DSIT995 For This Useful Post:
jracer (02-20-2011)
 Old 02-21-2011, 01:05 AM   #4
Highestrich4's Avatar
Posts: 259   (View Stats)
Highestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond repute
Groaned at 7 Times in 2 Posts
dude to be honest i mean if u ever plan on going for more power in the future i recommend pauter rods instead
2006 ms6 titanium grey - sold
2006 ms6 liquid platnium - Sold
Tmic, Intake, Inlet pipe, Test Pipe, BPV, H.I.D. Fogs, Cobb Ap
2006 ms6 velocity red mica - daily driver
2005 c6 corvette black - daily driver
Highestrich4 is offline   Reply With Quote
 Old 02-21-2011, 09:14 AM   #5
jracer's Avatar
Groans: 89
when you do the BSD do you have to use a a oil pan baffle tray ? i know i need to plug the hole with a BSD kit... what windage tray is the best.. i know F2 doesnt make them anymore.. PTP/PG our only choice now ?
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 02-21-2011, 01:04 PM   #6
essejkcamraw's Avatar
Posts: 922   (View Stats)
you dont have to use the baffle but it is a good idea.
From built & Big turbo to Miata Gheys
The Following User Says Thank You to essejkcamraw For This Useful Post:
jracer (02-21-2011)
 Old 02-21-2011, 09:20 AM   #7
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
super_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the world
500 or gtfo
super_pablo_ is offline   Reply With Quote
 Old 02-21-2011, 09:32 AM   #8
jracer's Avatar
Groans: 89
Originally Posted by super_pablo_ View Post
500 or gtfo
as in 500 HP ?? LOL.............
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 02-21-2011, 10:46 AM   #9
haha, jk man. props to u for going forged .. and BT eventually i assume?
The Following User Says Thank You to super_pablo_ For This Useful Post:
jracer (02-21-2011)
 Old 02-21-2011, 10:53 AM   #10
bmylez's Avatar
Groans: 31
Yeah, he's thinkin PTE 5557.
jracer (02-21-2011)
 Old 02-21-2011, 01:32 PM   #11
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
lol all these good ideas are gona add up to ALOT haha
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
jracer (02-21-2011)
 Old 02-21-2011, 02:04 PM   #12
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
As far as the BSD goes, CFM makes a kit very similar to F2s. Fuck PTPs kit, it's total garbage. I would rather run a BS than theirs. CFM unfortunately does not make a baffle so unless there's a one available somewhere else, I would bite the bullet and run PTPs. It way better than nothing.
AtTheDriveIn is offline   Reply With Quote
DSC Questions banzairx7 MazdaSpeed 6 - Engine, Transmission & Driveline 8 03-20-2010 01:10 PM
Build status & questions Speedie6 Mazdaspeed3/6 General Discussion 15 05-19-2009 08:51 PM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.33635 seconds with 27 queries
