  • 1 Post By
Closed Thread
 Old 09-05-2012, 04:20 PM   #1
AlwaysBoostin's Avatar
Posts: 4   (View Stats)
AlwaysBoostin will become famous soon enoughAlwaysBoostin will become famous soon enough
Default Finally Going Big Turbo
Whats up guys? I'm getting my parts to go big turbo in the next couple weeks. I'm looking to hit 400whp. Here's the list. Any suggestions would be appreciated. 70,000 miles on car, been stage 2 basically all its life. I hope it holds up.
EWG GTX3071R
Custom FMIC (Cobb piping/Treadstone core TR8L)
JBR Intake
Injector Seals
08 Ms3
Current Mods
Cobb AP Stage 2 tweeked by me @ 20psi
Cobb SRI
Turbo XS DP/Race pipe
CNT Catback
Autotech Internals
Eibach ProKit
AlwaysBoostin is offline
The Following 3 Users Say Thank You to AlwaysBoostin For This Useful Post:
atvfreek (09-05-2012), JacksonMS30 (09-05-2012), speed14 (09-05-2012)
The Following 2 Users Say NO Thank You to AlwaysBoostin For This Un-useful Post:
aggierandy (09-06-2012), Raider (09-06-2012)
 Old 09-05-2012, 04:23 PM   #2
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
EWG GTX3071R
JBR Intake
Injector Seals
Other mods are in my sig
Wut sig?
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline
 Old 09-05-2012, 04:27 PM   #3
Originally Posted by Black Metal View Post
Wut sig?
My bad, fixed
 Old 09-05-2012, 04:33 PM   #4
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
OCC, at least 1
AND
Replacement BPV
AND
ALL the maintainence that is needed to start out. (list is large)
Donate to find good cheap parts....
pzr2874 is offline
 Old 09-05-2012, 04:36 PM   #5
Voltwings's Avatar
Posts: 3,713   (View Stats)
what method of boost control? Without a 5th port if you use a Factory style load based tune, you will probably be victim of the "Injector duty cycle cap" which will lower your boost if your injector duty cycle gets too high. That leaves your options to be either run a manual boost controller or use an electronic controller to control a boost based tune. I hit the cap on a load based tune and switch to a manual but i hate the lack of versatility so im switching back to electric and going to build myself a boost tune. Good luck!
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
Voltwings is offline
InFeXIoN (09-06-2012)
 Old 09-05-2012, 04:39 PM   #6
Groans: 78
I'm on a boost tune and still hitting the IDC cap.
- 6MT - Stock -
 Old 09-05-2012, 05:59 PM   #7
Voltwings's Avatar
really? I was told going boost based would eliminate that -_- shit haha
Past:
-Sold-
-Sold-
Current:
Black Metal (09-05-2012)
 Old 09-05-2012, 07:24 PM   #8
Groans: 78
Nope hit 90% and it starts forcing my wgdc's down.
- 6MT - Stock -
 Old 09-05-2012, 04:39 PM   #9
Hallman MBC sorry shoulda added that. And yes will be boost based tuning
 Old 09-05-2012, 06:01 PM   #10
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
You gonna need a 3 bar map sensors son.
07 MS3
The original Genpoo Hater
Chimmike is offline
The Following 4 Users Say Thank You to Chimmike For This Useful Post:
AlwaysBoostin (09-05-2012), helmetface (09-05-2012), uncorked11 (09-05-2012), Voltwings (09-05-2012)
 Old 09-05-2012, 06:37 PM   #11
Voltwings's Avatar
@eric@edgeautosport has a good price on that + the pigtail.
Past:
-Sold-
-Sold-
Current:
 Old 09-05-2012, 06:46 PM   #12
dantes5823's Avatar
Posts: 6,576   (View Stats)
Good choice on turbo. I love mine.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
dantes5823 is offline
The Following User Says Thank You to dantes5823 For This Useful Post:
 Old 09-05-2012, 07:26 PM   #13
dantes5823's Avatar
I was getting it at like 85 percent
 Old 09-05-2012, 08:09 PM   #14
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
Start planning on how to supplymore fuel.
New....Camaro SS/RS
Stocked out selling parts.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
uncorked11 is offline
 Old 09-05-2012, 08:14 PM   #15
dantes5823's Avatar
Or how not to get knock limited
 Old 09-06-2012, 05:22 AM   #16
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
OP is already banned?
Buahaha that was fast!
helmetface is offline
 Old 09-06-2012, 05:50 AM   #17
InFeXIoN's Avatar
Posts: 1,159   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
Or you can go Matt Jackson pigtail that's pnp no cutting or soldering ftw!
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is offline
The Following User Says Thank You to InFeXIoN For This Useful Post:
MattJackson86 (09-06-2012)
 Old 09-06-2012, 05:53 AM   #18
helmetface's Avatar
Groans: 219
It's okay, you drive a PU, I understand.
Scroll up
 Old 09-06-2012, 06:09 AM   #19
You guys were getting trolled by @khonzo, look in the MSF Troll of Shame for the Roid Rage thread, VIPers.
Raider is offline
aggierandy (09-06-2012), RayRay (09-06-2012)
Closed Thread
First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo Haltech Automotive News 2 05-04-2009 06:48 PM
BMW finally acknowledges turbo lag, will update software Haltech Automotive News 0 11-18-2008 02:50 PM
Finally got my RPMC Turbo Inlet!!! AutoXRacer MazdaSpeed 3/6 - Turbo Induction 55 08-07-2008 08:54 AM
Page generated in 0.39942 seconds with 29 queries
