  • 1 Post By rgvms6
  • 1 Post By rgvms6
 Old 12-22-2012, 05:21 PM   #1
rgvms6's Avatar
Posts: 250   (View Stats)
rgvms6 has a reputation beyond reputergvms6 has a reputation beyond reputergvms6 has a reputation beyond reputergvms6 has a reputation beyond reputergvms6 has a reputation beyond reputergvms6 has a reputation beyond reputergvms6 has a reputation beyond reputergvms6 has a reputation beyond reputergvms6 has a reputation beyond reputergvms6 has a reputation beyond reputergvms6 has a reputation beyond repute
Groaned at 9 Times in 3 Posts
Default finally going BT!!!
So as the title says im finally going bt. Gonna buy my pistons and rods next week first. Going k1 rods with wiesco pistons. Also doing the balance shaft delete and egr delete as well. Ive been talking with alan over at edgeauto and hes hooking me up pretty well. Just wanna make sure i have it all though. Its pistons, rods, overhaul gasket set, cometic head gasket, crank pulley bolt, friction washers, front oil seal, rear main seal, main bearings, rod bearings, arp main studs, arp head studs, the balance shaft delete kit and egr plate correct?
The turbo im going with is between the Gtx3071 or gtx3076...im still undecided. I know im gonna need a mbc, the safe seals, 3 bar map sensor and of course a bigger intake. Any of you know which intake i should use. Jbr wide mouth or the 3.5" from sure? I wanna get this done right. Any feed back is greatly appreciated
MazdaBoy2.3 likes this.
Current mods installed: greddy type rs bov, autometer boost gauge, magnaflow exhaust, su sri, 3" downpipe, kmd v.2 internals, cobb ap, dreadnaught, juggernaught, whiteline adj. rear sway bar, sure rmm, cx racing fmic, h&r springs, drag wheels, autolite plugs
Parts awaiting install: k1 rods, jbr egr block off plate, weisco pistons, 3 bar map sensor and pnp harness, stratified 3 port ebcs, cpe safe seals
Parts awaiting order: gtx3071r, SURE 3.25" intake
Currently Freek Tuned on pump gas and e85 50/50
rgvms6 is offline   Reply With Quote
 Old 12-22-2012, 07:41 PM   #2
Matrix311's Avatar
Posts: 2,133   (View Stats)
congrats man you'll love it I wish I could provide feedback but i dont have a built motor.
 Old 12-22-2012, 07:46 PM   #3
rgvms6's Avatar
Which intake set up are you running on your gtx? And where did you get your 3bar map
 Old 12-22-2012, 11:18 PM   #4
Matrix311's Avatar
i'm using the htp 3" TIP with the 3" treadstone MAF with a filter on the end of the MAF so it's an SRI setup. I got the 3 bar map sensor from edge motorsports and the map sensor plug and play harness from matt jackson.
 Old 12-23-2012, 01:13 PM   #5
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
gt turbo is a better choice than the gtx, unless you are gonna run really high boost. just sayin
The Following User Says Thank You to h.h.sk1nny For This Useful Post:
Jh8909 (12-24-2012)
 Old 12-23-2012, 03:00 PM   #6
rgvms6's Avatar
I plan on going 27ish
 Old 12-23-2012, 07:58 PM   #7
h.h.sk1nny's Avatar
I would hope you have a built motor, running 27psi on a gtx
 Old 12-23-2012, 08:03 PM   #8
rgvms6's Avatar
Yup. Ordering pistons and rods come jan. 2nd cause alan is out on vacation.
 Old 12-23-2012, 10:14 PM   #9
Importfan12's Avatar
Posts: 171   (View Stats)
Importfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond repute
I went with the Sure Full 3 aeros for my GT3076. I would also recommend going with the grimmspeed or Cobb EBCS
2007 MS6 GT3076 Built motor.
Importfan12 is offline   Reply With Quote
 Old 12-24-2012, 12:06 PM   #10
Or a sweet Stratified EBCV: Mazda 3 Port Electronic Boost Control Valve [MAZ 3P EBCV (0100-0005.1)] - $85.00CAD : Stratified Automotive Controls
Finally remember that the injectors run out of fuel around 400-420whp and you will need a source of additional fueling. However with 93 pump gas and no methanol or E85 it will be hard to make more than 350-375 due to the knock limitations of the motor and that is around the 23psi mark on a GT3071.
The intake to get for the 400whp power level is 3-3.5"
atvfreek (12-24-2012), Bob-o (12-24-2012), mituc (12-24-2012), rgvms6 (12-24-2012)
 Old 12-23-2012, 11:02 PM   #11
aggierandy's Avatar
Posts: 2,241   (View Stats)
aggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the world
Groaned at 18 Times in 14 Posts
Go super big on the intake. 4" ftw
Sent from my DROID RAZR HD using Tapatalk 2
2010 MS3 Mica Black Tech
Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals
CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch
aggierandy is offline   Reply With Quote
 Old 12-23-2012, 11:06 PM   #12
rgvms6's Avatar
Where can i find the 4" all the way through? The jbr doesnt fit the ms6 so that sucks. Do you know if streetunit does exchanges?
 Old 12-23-2012, 11:42 PM   #13
aggierandy's Avatar
Htp has one about to be released. There is a thread on here somewhere. Not sure about it fitting a 6.
 Old 12-24-2012, 11:18 AM   #14
rgvms6's Avatar
I hope it does man. If not it looks like ill have to get rid of my 2.5 and get one from streetunit
 Old 12-24-2012, 12:23 PM   #15
rgvms6's Avatar
I have e85 down here. I am currently tuned by Justin. So a 3-3.5 inch will be fine then. I also gotta find that plug and play map sensor
Definately getting that boost controller.
Last edited by rgvms6; 12-24-2012 at 12:23 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to rgvms6 For This Useful Post:
Lex (12-24-2012)
 Old 12-24-2012, 12:25 PM   #16
-Bosch - 0 281 002 845 (Home » Shop » Sensors » Pressure Sensors » Bosch 3 Bar TMap Map Sensor with IAT)
-PNP harness: Mazdaspeed MAP Harness - Bitwise Motorsports
 Old 12-24-2012, 12:33 PM   #17
rgvms6's Avatar
And thats why you are awesome lex. Im really excited for this build. I was gonna go BT first but i had a feeling i was gonna blow it so im doing my engine build first then buying the turbo right after. Still undecided on gtx3071/3076...
Lex (12-24-2012)
 Old 12-24-2012, 12:41 PM   #18
In the big scheme of things there is very little difference between the 2 turbos. Think about your power goals first and let that be the decision maker.
The BNR S3 supports around 400whp (I know you are not considering it but thought I'd mention). The GT3071 is efficient to around 450whp, GTX3071 to around 475whp, and GTX3076 to around 500whp but the exhaust side will be limiting at this point and to go above that 420whp you still need either a lot of methanol or 5th port injection.
The more power the turbo supports, the slower it will be to spool.
helmetface (12-24-2012)
 Old 12-24-2012, 12:59 PM   #19
rgvms6's Avatar
Definately not bnr. Reason im leaning towards gtx over gt is due to the ewg and boost creep problems the gt has. Would running e85 be a solution over meth or 5th port?
ms3bamf (12-24-2012)
 Old 12-24-2012, 01:08 PM   #20
ms3bamf's Avatar
Posts: 745   (View Stats)
ms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the world
E85 will be great for knock but sucks up fueling head room.
2011 Ford Mustang GT Premium - 6spd manual, brembos, 3.73, Roush Axle Back, JLT Oil Seperator, Air Raid intake
Previous - 2011 Mazdaspeed3 - Corned out FREEKTUNE
ms3bamf is offline   Reply With Quote
 Old 12-24-2012, 01:18 PM   #21
rgvms6's Avatar
So in the long run a 5th port would end up cheaper huh
dot584 likes this.
Finally McGee Mazdaspeed3/6 General Discussion 17 02-28-2012 03:11 AM
Finally got my MS3 urville Gen2 MS3 General Discussion 45 08-11-2011 09:49 AM
yes!!! finally 11s !!!!! rodrigo Drag Racing 29 02-19-2011 04:07 PM
Page generated in 0.42305 seconds with 26 queries
