Like Tree10Likes
  • 7 Post By ms3blackmica
  • 1 Post By atvfreek
  • 1 Post By ms3blackmica
 Old 11-18-2013, 03:53 PM   #1
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Default Finally went BT
Well all the cool kids are doing it right?
The k04 was a load of fun but ultimately I could not take the loss of power in the higher revs any longer. Small turbo was just too small.
I was originally going to purchase an HTA3076 from Forced Performance but decided against it for the simple fact that I was never going to make use of its potential given the extra fabrication (i.e. custom DP, etc.) to make it work. So, I decided to go with the ATP GTX3076R to keep things simple and easy.
I asked @NJSPEED3; if he would port the ATP hotside and remove the extra material from the casting in hopes to remove some restriction to exhaust flow.
I decided that if I was going to have everything out of the engine bay, I might as well purchase all the accompanying hardware to make the best of this setup.
-GTX3076R
-CP-e Exhaust Manifold
-CP-e Catted DP
-Tial MV-R 44mm EWG
-SSP Dumptube for CP-e Manifold
-HTP 3.5" Intake
-Custom PushLoc Oil Return Line (thanks to rfinkle2)
-Mac 4 Port Electronic Boost Control Solenoid (Running a 9 PSI Spring in the EWG)
I am currently running this with my CP-e TMIC and have had great success. I did not do anything in regards to a FMIC at the time due to funds but have plans to change in the near future.
Right now the car is producing ~400whp @ 22 PSI on 93 octane without any aux fueling. I have a VD plot attached below from a month ago but also have a couple 395 whp plots on my other computer from the recent cooler weather.
I am more than pleased. The car is a ton of fun and is already a wild ride on 215's (LOL)
Everything went very smooth and I've been driving and enjoying the car for quite a while now.
Pics attached below.
File Type: jpg 2013-09-12_11-32-24_871_zps0b93e3ca.jpg (1.84 MB, 114 views)
www.tunedbynishan.com
The Following 56 Users Say Thank You to ms3blackmica For This Useful Post:
6ixof1 (11-23-2013), 865ms3 (11-18-2013), Agent_Orange (11-22-2013), alaskazero (11-21-2013), amggilly305 (10-22-2014), atvfreek (11-22-2013), AZSPEED3 (11-28-2013), Big_Burd (11-20-2013), Bolted6 (11-28-2013), Boosted Beluga (11-18-2013), btstarcher (11-30-2013), Bulgsta (10-26-2014), CarlitoSpeed3 (11-22-2013), charlesfist (11-21-2013), chaser27 (11-22-2013), CrawlingMS3 (10-24-2014), cshunter (11-22-2013), cthomp (11-21-2013), CWP_MS3 (11-21-2013), DaUberSchwebel (10-28-2014), DISIindahead (11-30-2013), donjohnk (11-28-2013), Drive By Fire (10-23-2014), Easter Bunny (11-22-2013), ESA (11-22-2013), Fail_6 (11-28-2013), h0ckeyman (11-22-2013), ink28 (11-18-2013), jreiden1 (11-22-2013), jseams (11-30-2013), Jsn_Rob (11-23-2013), kritz (11-18-2013), manila (11-18-2013), Mauro_Penguin (01-30-2014), Micha (10-29-2014), Mike@Stratified (11-18-2013), Mikey (11-28-2013), mzr0818 (11-22-2013), NJSPEED3 (11-21-2013), nycMS3 (11-20-2013), Poohster (11-23-2013), redboat (11-27-2013), Roddiy (11-23-2013), shawn. (11-28-2013), sidekick (11-28-2013), SilverDemon (11-21-2013), Snyeed (10-23-2014), SPEED6 KILLAH (11-30-2013), SpeedLife (11-22-2013), SpeedRebirth (11-24-2013), stanley0910 (11-23-2013), Status Update (11-21-2013), TiGraySpeed6 (11-19-2013), trini247 (11-21-2013), Vader (11-18-2013), WetzMS3 (04-09-2014)
 Old 11-18-2013, 03:55 PM   #2
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Noiiice!
Sent from fastest Ko4 Pu.
Nator is what it does.
 Old 11-18-2013, 03:57 PM   #3
manila's Avatar
Posts: 1,767   (View Stats)
Good shit Nishan
Them numbers on pump gas though!
'12 MS3 Black Mica w/ Tech
 Old 11-20-2013, 11:22 PM   #4
nycMS3's Avatar
Posts: 1,067   (View Stats)
nycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the world
Groans: 129
Oh you just went BT!? lol congrats dude
NATOR NJ/NY/FL
09 MS3 tuned by Nishan
nycMS3 is offline   Reply With Quote
 Old 11-21-2013, 12:27 AM   #5
alaskazero's Avatar
Posts: 195   (View Stats)
alaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond repute
Groans: 34
Groaned at 55 Times in 18 Posts
looking good dude
alaskazero is offline   Reply With Quote
 Old 11-22-2013, 12:13 PM   #6
Jkspeed's Avatar
Posts: 293   (View Stats)
Jkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond repute
Groaned at 6 Times in 4 Posts
Gonna be the route I hope to soon take.
2008.5 Metro Grey MS3
Performance:
HTP 3.5" Intake | Autotech HPFP Internals | SU TMIC | EBay Catless DP | Stratified Tuned | JBR 88a Dogbone - Short shift plate | Eibach Pro-Kit | 18x8 MB Interline wheels | Conti DW's 235/40R18 | JBR Rear Sway Bar
Other fun:
Dashhawk | Single res delete | Corksport Interior LED light kit - Bypass valve hose | Vent pod boost gage | Custom Heated driver and passenger seats | Leather shift boot
Jkspeed is offline   Reply With Quote
 Old 11-22-2013, 12:46 PM   #7
SpeedLife's Avatar
Posts: 890   (View Stats)
SpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the world
Now for some big tires son! lol Looks good!
2013 Mazdaspeed3
Mods:Stock as shit, trading in for e92
Add me on instagram: @mario_speed3
SpeedLife is offline   Reply With Quote
 Old 11-22-2013, 01:01 PM   #8
atvfreek's Avatar
Posts: 7,787   (View Stats)
The secret is out. lol. And how the hell did I miss this thread that was made a few days ago.
ms3blackmica likes this.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 4 Users Say Thank You to atvfreek For This Useful Post:
Jh8909 (11-22-2013), jreiden1 (11-22-2013), rfinkle2 (11-22-2013), SPEED6 KILLAH (11-30-2013)
 Old 11-23-2013, 12:40 PM   #9
speed_freak91's Avatar
Posts: 1,189   (View Stats)
Groans: 34
This is the setup I wanted to run, except I have an ebay dp and not sure if the ewg would clear the O2 sensor.
speed_freak91 is offline   Reply With Quote
 Old 11-23-2013, 02:45 PM   #10
stanley0910's Avatar
Posts: 364   (View Stats)
stanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the world
Nice settup, simple but effective.
Need more parts.
stanley0910 is offline   Reply With Quote
 Old 11-28-2013, 05:21 PM   #11
shawn.'s Avatar
Posts: 541   (View Stats)
shawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the world
Groaned at 22 Times in 16 Posts
400whp on 93 is very impressive!
ATP GTX3071r// Cobb 3 Port EBCS // 3 Bar MAP // Cobb Accessport Freek Tuned // E85 Mix // JBR 3.5" Intake/TIP // Treadstone TR8C FMIC // Autotech HPFP Internals // Ported IM //C-pe Catted Downpipe // TRZ RMM // Corksport CBE // ISC Coilovers // EBC Slotted Rotors--Redstuff Pads // TWM shifter bushings // Dashhawk v2 // 6000k HIDs
Built engine--Manley H Beam Rods--Wiseco Pistons
shawn. is offline   Reply With Quote
 Old 11-28-2013, 05:31 PM   #12
calizoomzoom's Avatar
Posts: 684   (View Stats)
calizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the world
good shit..
calizoomzoom is offline   Reply With Quote
 Old 11-30-2013, 05:42 AM   #13
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
Black ninja look sexy with that sleeper set up..
SPEED6 KILLAH is offline   Reply With Quote
The Following User Says Thank You to SPEED6 KILLAH For This Useful Post:
 Old 11-30-2013, 07:46 AM   #14
DISIindahead's Avatar
Posts: 911   (View Stats)
DISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the world
Looks good Nishan!
2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD
2012 Jeep Wrangler Unlimited Sport: Current DD
DISIindahead is offline   Reply With Quote
 Old 04-09-2014, 06:19 PM   #15
Nishan
Many of you may or may not know but I now have a 2013 VRM Gen 2 MS3.
I've actually had it since January.
It is stock for right now. Just has a basic tune on it.
I sent my GTX3076 out to Forced Performance to transform it to an HTA3076.
Once it gets back, and it warms up a little bit more here in NJ, I'll be swapping everything over to the Pu.
Agent_Orange likes this.
The Following 8 Users Say Thank You to ms3blackmica For This Useful Post:
Agent_Orange (04-09-2014), Easter Bunny (04-09-2014), fivefingerdeathpunch (10-24-2014), ItsNox (04-10-2014), Mauro_Penguin (10-23-2014), Micha (04-14-2014), MZRSPEED (04-09-2014), WetzMS3 (04-09-2014)
 Old 04-09-2014, 06:44 PM   #16
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Mmmmmm red rocket HTA style!
You keeping the juan?
 Old 04-09-2014, 06:39 PM   #17
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Does it rev to 8000rpm yet?
 Old 10-22-2014, 07:44 PM   #18
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
dead thread revival. Did you ever end up swapping to the gen2? Still on the stock flange?
'08 CWP MS3 w/ T3 3071r
 Old 10-22-2014, 08:20 PM   #19
Nishan
Nigga...
 Old 10-23-2014, 07:48 AM   #20
rabble rabble
802MS3's Avatar
Groans: 221
Nigga...
Is that information confidential?
Easter Bunny (10-23-2014), Mauro_Penguin (10-23-2014), WetzMS3 (10-23-2014)
 Old 10-23-2014, 07:37 PM   #21
twenty5psi's Avatar
Posts: 213   (View Stats)
Hey @ms3blackmica, just curious what your impressions of the HTA3076 vs. the GTX are. FP makes some great products.
2013 MS3 VRM w/Tech
 Old 10-28-2014, 02:54 PM   #22
Nishan
The HTA sucks in babies from all the homes that I do WOT pulls passed.
@doubleflusher;
doubleflusher likes this.
The Following 7 Users Say Thank You to ms3blackmica For This Useful Post:
doubleflusher (10-28-2014), Easter Bunny (10-28-2014), fivefingerdeathpunch (10-28-2014), ItsNox (10-29-2014), Mauro_Penguin (10-28-2014), Micha (10-29-2014), twenty5psi (10-29-2014)
 Old 10-28-2014, 03:20 PM   #23
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
All the babies.
Beanfab / Tuned by Nishan
The Following 3 Users Say Thank You to doubleflusher For This Useful Post:
ItsNox (10-29-2014), Mauro_Penguin (10-28-2014), ms3blackmica (10-28-2014)
 Old 10-28-2014, 04:23 PM   #24
Nishan
Thanks Bunny.
The Boost damaged my brain.
BLKSTIG (10-28-2014), Easter Bunny (10-28-2014), SarcasticOne (10-28-2014)
 Old 10-28-2014, 06:24 PM   #25
Thanks Bunny.
That's what I'm here for
Being a dick
 Old 10-28-2014, 05:11 PM   #26
rabble rabble
802MS3's Avatar
Groans: 221
well that settles that
Finally KMD... Cataphract_40 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 124 08-08-2011 11:49 AM
Finally got an ap volodya84 MazdaSpeed 3/6 - ECU Computer Tuning 38 05-13-2011 07:19 AM
It finally came!!! supergoose MazdaSpeed 3/6 - Turbo Induction 16 04-08-2009 07:45 AM
Page generated in 0.47399 seconds with 40 queries
