Like Tree10Likes
 Old 10-15-2015, 01:45 PM   #121
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Long time since last post, the car feels and drives great. Of course it does! Having the car built from stock to where it is now (chassis, engine, suspension) by an Europe Top 5 Mazda technician is something that makes me very proud of.
In the following video clip only the top 3 teams were presented, the Romanian team took the 5th place.
My dear friend Anis, you are one of the best people I've ever met! Thank you!
https://www.youtube.com/watch?v=4tBqM4xYhv4
P.S.: @Jackis, your guys were in 3rd place! Congrats!
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
mazdakaps (10-20-2015), SpeedRebirth (10-19-2015)
 Old 10-20-2015, 03:46 AM   #122
Jackis's Avatar
Posts: 428   (View Stats)
Jackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the world
Wow, great competition! I have heard of it, I do also know Igor Andreev, he is from Nizhniy Novgorod and he owned MPS3 several years ago
Does your MS3 start when it's -30C (-22F)?
Forged, bolted, tuned, gtx30/tial/ewg. Thanks.
Jackis is offline   Reply With Quote
The Following User Says Thank You to Jackis For This Useful Post:
mituc (10-20-2015)
 Old 01-11-2016, 05:36 AM   #123
pankrok's Avatar
Posts: 18   (View Stats)
pankrok is a jewel in the roughpankrok is a jewel in the roughpankrok is a jewel in the rough
mituc can you share more info on the hexer clutch ?
these guys have only fb page , is there any other contact info?
pankrok is offline   Reply With Quote
 Old 01-11-2016, 09:23 AM   #124
mituc's Avatar
Groans: 111
I found them on a local car forum and then their FB page.
The clutch I have is pretty good. Basically I handed them over my clutch (disc, pressure plate and flywheel) and they resurfaced the FW, balanced it, changed the wear material on the pressure plate, changed the wear material on the clutch disk.
What I ended up with is a clutch that feels as good if not better than the stock one but can hold 600+Nm.
The Spec Stage2+ I had was able to hold them too but it was a lot more grabby and not that easy on stop&go traffic. It was so grabby that I blew the passenger mount 500kms after fitting it. If this car wasn't one of my DD it wouldn't matter, but it's not the case so it really matters.
Also, the Spec clutch was 50% worn after 25k kms of mainly street driving (found that when I rebuilt my engine).
 Old 01-11-2016, 09:32 AM   #125
pankrok's Avatar
I m on the same side , the dual disc gigen i have now is way too racy for daily driving (plus have my plastics are willing to detach when passing 1800-2000 rpm ) so if the hexer is good for 600nm will work for me too.
can you pm price and email for them?
 Old 01-11-2016, 03:49 PM   #126
mituc's Avatar
Groans: 111
They initially told me it's going to be 300EUR max depending on what they need to do and what my requirements are, and it was about that including transport back and forth. So a decent price. Shipping from Greece to Hungary may be a bit more expensive but not by much.
It may seem odd but I communicated with them via a forum. It's this user: Forum 4Tuning - View Profile: Hexer .
 Old 01-12-2016, 12:46 AM   #127
pankrok's Avatar
thanks mate.
If I dont succeed communicating with them I ll come back.
how long is this clutch working and how much power/torque are you making ?
 Old 01-12-2016, 01:25 AM   #128
mituc's Avatar
Groans: 111
thanks mate.
If you don't succeed in contacting them just let me know.
The clutch is working for about 6000kms and the power figures before upgrading my catback were about 390-410bhp from 4500 to 6800rpm and the peak torque was around 630-640Nm. After upgrading the catback I probably gained about 20bhp more (or whatever 0.10-0.12 more load at the same timing means) in the same RPM range but I was never able to measure them properly because of the cold weather and winter tires.
 Old 01-19-2018, 01:39 AM   #129
mituc's Avatar
Groans: 111
Long time since the last post, even though this is not outdated, the car still exists and it's doing awesome.
Still holding the title of "First Romanian BT MS3", first big turbo 2.3DISI-T in general and currently the only running BT 2.3DISI-T (there was a 6MPS which lifted the head and which will come back soon).
I will build a CX7 later this year with the spare engine I have, if things go well.
In the meanwhile the car went through the following:
  • new engine. The custom Sp63 pistons touched the oil squirters in a hot summer day and that was it. the block is still good, I will rebuild it and keep it as a spare (already bought all the parts for it);
  • upgraded valve springs from Crower;
  • Southbend Stage3 Enduro clutch;
  • damond Motorsports catch-can;
The GTX3071R (gen1) turbo is still doing good, pushing it at 31PSI and I decided to push it to 31PSI on a broader RPM range after analysing the compressor map (attached) and determining I'm pretty much where I should across the entire rpm/boost range.
With the current tune 60-100mph goes in 3.92s:
...And some on-board WOT action:
 Old 06-04-2019, 06:41 AM   #130
Empirestrikes1st's Avatar
Posts: 1   (View Stats)
Empirestrikes1st is an unknown quantity at this point
Hi mituc, I have a question: is it possible to pass emission test with yours UR high flow cat DP? I'm from Czech rep., so I guess our emission test would be likely pretty much the same as in Romania.
Thx
Sorry for posting here, but I just found out I'm not able to send PM's yet...
Empirestrikes1st is offline   Reply With Quote
 Old 09-02-2019, 01:39 PM   #131
mituc's Avatar
Groans: 111
That moment when you think your car is on meth but it's actually sniffing metal bungs:
https://forum.clubmazda.ro/uploads/m...4d413cd709.jpg
https://forum.clubmazda.ro/uploads/m...2acb3dcda0.jpg
https://forum.clubmazda.ro/uploads/m...cdc9affc59.jpg
https://forum.clubmazda.ro/uploads/m...b1bf7077ab.jpg
https://forum.clubmazda.ro/uploads/m...731757c0b8.jpg
 Old 09-02-2019, 06:50 PM   #132
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
WHAT THE FRICK did you do?!!
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 09-02-2019, 11:00 PM   #133
mituc's Avatar
Groans: 111
I asked my fabricator if we can cap the holes between the intake manifold runners after removing the VTCS shaft. He said he can, provided a solution I agreed with.
One year later those studs were rattled out and started to come loose. The first one that got out, a 2.5cm/1" stud, went into cylinder 3 when I was WOT at 6000rpm. At that moment I did not know WTF happened, I thought I popped a hose or something, so after pulling the car on the side of the road and managed to start it again I drove back home 25kms/15 miles (slowly, not exceeding 2500rpm, as the car wasn't really pulling), with a check engine light because missfire on cylinder 3.
I went back to the rented parking and started to work on the car. Because of the hit that spark plug took the electrode side was shattered so the thread on the head was fucked as well. When unscrewing the plug and figuring that it turned way too hard and way too many times than it should have was the time I dropped a smidge of piss in my pants.
When I pulled the spark plug I managed to also drop a smidge of shit in my panties, and while holding the spark plug in my left hand my right arm suddenly became numb and I hit myself in the nuts while still having the wrench in my hand.
When I stuck a magnet inside #3 and heard that "Click!!" sound a thick metal bung sticks to it I figured that my engine just got its holy fuck this year.
The fabricator used studs like this to cap those VTCS shaft holes. These were threaded in and then sealed with tin I guess.
The exhaust valves are bent but they did an amazing job at shattering that metal and not letting it by to the turbo and cats.
I will try to recover the block which may be fine after boring it at 0.5mm over to 88. The cams, caps and everything else in that area is good, so may be the bearings, rods, griddle and crankshaft. The iron of the head is royally fucked.
So a rebuild is already being done. I have a new GTX3071R gen2 and CorkSport cams, which is what's going to be different from the previous build. So we will make the power and 60-100mph record holder on stock manifolds and full emissions compliance (EGR, double-catted exhaust, and so on) even stronger and will try to surpass the current figures (476WHP/509PS at the crank, 3.62s for 60-100mph).
I have no idea what's going to fail next, I suppose the cats or something on the exhaust side.
 Old 09-03-2019, 06:19 AM   #134
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
oh shit sorry for you!
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 09-03-2019, 06:29 AM   #135
Fstrnyou's Avatar
First thing to do is change your plugs and check for boost leaks.
Kidding aside, at least you have a story behind it. My built motor going kaput is just low compression.
Other rides:
History:
 Old 09-03-2019, 09:17 AM   #136
mituc's Avatar
Groans: 111
Pulled the pistons today. I was more interested in the one that took the hits.
 Old 09-03-2019, 09:24 AM   #137
Fstrnyou's Avatar
Yep. I figured broken ringlands was the problem.
That piston (and head) took a beating getting you home. But it got you home. Winning.
Other rides:
History:
 Old 09-03-2019, 01:43 PM   #138
Jeff23spl's Avatar
4032 ? It lasted quite well, it could have been worst if the piston exploded and let the rod break the bloc....Was the bearing damaged ?
I also had a screw falling into an engine recently but it was not the same level of problems with a small lawnmower tractor and a low cost engine. The screw was small enough to fit inside the chamber without too much damages
mituc likes this.
Wife drive 2010 CX7
 Old 09-03-2019, 01:47 PM   #139
Jeff23spl's Avatar
repost
Wife drive 2010 CX7
 Old 09-03-2019, 02:07 PM   #140
mituc's Avatar
Groans: 111
Yes, Mahle 4032.
The rod is untouched, the bearings are clean, the engine builder decided to reuse the crank for the new motor even though I had a spare one which was also within the factory specs.
Also the block may have a pretty good chance of being good after boring it to 88mm.
 Old 09-04-2019, 06:40 AM   #141
MSMS3's Avatar
Posts: 2,826   (View Stats)
So sorry. I’ve been following your posts and learning from your experience for years. Glad it wasn’t worse and that the bottom end other than pistons and bore are good and can be reused. I hope the cylinders clear up with the bore to 88mm. Probably not enough room to sleeve it.
Jeff’s story reminded me of an experience I had with my first car at age 16. It was a Fiat 1100 sedan. Freshly rebuilt engine. Driving home from school the tires locked up, just like the diff was frozen. Turned out it had sucked in a nut from the air filter housing that had not been installed with a lock washer. The nut stuck between the piston and cylinder head combustion chamber. When we pulled the head, the top of the piston had a neat hexagonal imprint of the nut. We removed the nut, saw no other damage, no bent valves, put it back together and it ran like a champ. The little engine, even freshly rebuilt, just didn’t make enough power to hurt itself. Not unlike Jeff’s lawn mower. I sort of had a four door lawn mower, anyway. I believe the engine made about 40 bhp.
Keep us posted on the rebuild. I hope the fabricator that failed to retrieve that piece of metal steps up and helps you. Probably a good guy who just made a mistake. But actions have consequences.
 Old 09-04-2019, 02:23 PM   #142
mituc's Avatar
Groans: 111
It was a fun day:
...especially when the engine stalled the moment I stepped on the clutch for more than one second to pull over. That's when I knew I fucked up.
Video: Romanian gas is like a troupe of French maids for your engine Haltech Automotive News 0 07-13-2012 11:10 AM
Video: Romanian criminals attempt to loot a moving truck Haltech Automotive News 1 06-14-2012 11:53 AM
Next in line to get irked by Jeremy Clarkson? The Romanian government [w/VIDEO] Haltech Automotive News 0 11-24-2009 06:00 PM
Page generated in 0.51131 seconds with 27 queries
