![]() Join Date: Mar 2009
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score What have you guys found to be the limits of these blocks while they are built?? I dont want to run into anymore problems then i need to and i want a safe reliable 350ish on my speed6. I have tried to do some research and am starting to get my knowledge up but i figuered this would be the fastest way. thanks for anyhelp. also now that Cobb has adjusted the load cap what do you guys recommend Cobb or standback? or still preferance.. goodluck to me! |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
| Not Ranked : 0 score if you're going all out go with cp-e. even with the load cap removed, there is probably something else that the cp-e has figured out that the AP's tables cannot address right now. |
![]() Join Date: Oct 2008 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,135
Groans: 234
Groaned at 154 Times in 122 Posts
| Not Ranked : 0 score no one knows the limit of these forged blocks and internals. no one has gotten there. id say you can do 350 on stock block and internals if that's all you really want. no need to waste all the money.
__________________ '08 MazdaSpeed3 - sold |
![]() Join Date: Dec 2009 Location: Dublin, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 443
Groans: 54
| Not Ranked : 0 score Go with cp-e the flashes alone feel great on the car and you have a great company that will back their product.
__________________ Parting out! http://www.mazdaspeedforum.org/forum/forum/f229/spoolme-parting-out-76016/ |
| The Following User Says Thank You to Spoolme For This Useful Post: | djuosnteisn (07-09-2010) |
(Thread Starter) | Not Ranked : 0 score thanks for the input so far guys, anyone for the accessport? and also what turbo would you guys recommend for the 350-375 range? |
| NEC ![]() Join Date: Mar 2008
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
| Not Ranked : 0 score Socks made 433 with the 3071 and a proper hotside. You can probably hit just under 400... or hell who knows, maybe more with the ATP version. GT28 might even do the trick.
__________________ 2006 Lotus Elise: Toy car 1999 B4000: DD / Parts hauler / SC Project 2007 Mazdaspeed 3: *sold* 2005 Corolla XRS: *sold* |
Groans: 54
| Not Ranked : 0 score Talk to silver demon he's running a 2871 on a stock block.
Groans: 54
| Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's | Dre | 2010 MS3 - Engine, Transmission & Driveline | 23 | 05-21-2016 08:47 AM |
| I have some questions about the Mazdaspeed motor | Mazda360 | Mazdaspeed3/6 General Discussion | 39 | 07-17-2008 11:26 AM |
| motor mount durometer questions | johnheer | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-09-2008 10:19 AM |
