Like Tree43Likes
 Old 09-11-2012, 04:06 AM   #1
sleepyspeed6's Avatar
Posts: 288   (View Stats)
sleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the world
Neutral  :  0 score
Default Frankin-turbo (hx35)
Alright so I figure now is a great time to make this thread.
when I decided to go bt, I orginally wanted to go with the gtx3076 or gtx35 (who knows maybe I will still to it). But for now since I am trying to get a house, I would go for a cheaper route. So I ended up on the HX35w, it is just bearly smaller then a gt35r. The 35r flows 61lbs/min and the HX is 60.80lbs/min (kind of weird I know).
Now on to the important thing, here is a list of what is going with the turbo with prices
Hx35w-$250 shipped
ATP turbine housing with ewg & mazdaspeed flang-$350 shipped with 8% discount
TAIL 38mm wastegate (I already have one from my last car)-they go for about $250 shipped
custom 4" intake-$80 shipped
AEM dry flow air filter 4"x9"- $20 shipped
miscellaneous parts-$30
=$980
The turbo came with an aftermarket wastegate that I can resell for about $100, and I am going to sell my intake and turbo inlet pipe for 210.
I will post pictures of everything as I get it and when it is made/installed
As in all of my threads feel free to post thoughts
Before I polish the turbine inlet
Middle of pnp
All done with pnping
If you do this you will need to get the clamp ring to hold the turbo to the turbine housing, I just happend to have one laying around.
Where the wastegate goes on the turbine housing it looks like I will need to port it to help with boost creap. Their are some big ledges blocking flow the the wastegate.
Really dirty turbo before I clean it and repaint it. This turbo is in really good shap though, zero shaft play in or out, or side to side and the blades on it are all perfect.
after cleaning ready to go in
loop for the coolant lines (didn't need them oil only turbo)
I had to cut the exhaust manifold stud by the EGR, about 3/4 of an inch
the wastegate doesnt fit like this
so i got a 90* and a o2 dump
this is what the tial looks like with a 21.50 psi springs in it (three springs).
Wastegate from the top of the motor
I cut the end of this so that it is flush with the bottom of the car, I didn't get a picture of it though. As you can see in the picture it hung down about a 1/4 of an inch.
Flow chart for 500hp
06Speed6, memin, jracer and 1 others like this.
Hx35 sold
New sc6266
Last edited by sleepyspeed6; 01-12-2013 at 04:02 PM. Reason: MSF Database - Automerged Doublepost
sleepyspeed6 is offline   Reply With Quote
The Following 69 Users Say Thank You to sleepyspeed6 For This Useful Post:
06Speed6 (09-12-2012), 801MS3 (09-13-2012), 86AmishMs3 (09-12-2012), :: Gusto :: (11-10-2012), atvfreek (01-05-2013), AZSPEED3 (11-28-2012), beachshoer (09-13-2012), bewsted (09-25-2012), BigjohnB20 (09-11-2012), Black Metal (09-11-2012), bmylez (09-13-2012), BobtailedSnail (09-13-2012), btstarcher (09-17-2013), Caligula (09-13-2012), charlesfist (10-15-2012), chuckms6 (09-16-2012), cld12pk2go (09-13-2012), CrawlingMS3 (01-11-2013), DiGi Faggot (09-12-2012), djuosnteisn (01-06-2013), doubleflusher (09-13-2012), Downmented (09-12-2012), DSIT995 (03-16-2013), dsmluck (11-01-2012), EdgeAutosport.com (09-11-2012), Fail_6 (05-28-2013), fishin53 (09-17-2012), forcedinduktion (09-13-2012), helmetface (09-11-2012), IshiKage (09-17-2012), J'sSpeed3 (09-17-2012), J-Liss (10-08-2012), jack_hammer (09-17-2012), jracer (09-11-2012), Manny (11-30-2012), memin (09-11-2012), Menace1 (03-10-2013), Monotonous ONE (09-11-2012), MS3-a(sore)ASS-rex (09-11-2012), Ms3_Miami (09-13-2012), nybe0010 (05-07-2013), outshined (10-10-2012), Payne Racing 67 (05-07-2013), pmartz16 (08-12-2014), psychophyr (09-11-2012), Rich990 (06-26-2013), RichieRichness (09-13-2012), robry (09-13-2012), Seatime3 (09-13-2012), silentwolf8 (09-25-2012), smoogs12 (09-16-2012), snailD (09-12-2012), Snap Off (09-20-2012), Snyeed (09-13-2012), SofaKingAwesome (09-12-2012), speed14 (09-13-2012), Speed3eak (09-14-2012), speedms6 (09-11-2012), SpeedRebirth (09-11-2012), theschrum (09-11-2012), Tomas (10-03-2012), torquemaniac (11-22-2013), TWOptSL0W (09-12-2012), twowheelrides (05-01-2013), uncorked11 (09-16-2012), xb2ms3 (01-06-2013), xdm88 (09-15-2012), xtasy (09-11-2012), Zdraveca (10-02-2012)
 Old 09-11-2012, 04:49 AM   #2
thehead's Avatar
Posts: 1,141   (View Stats)
thehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the world
Groans: 143
what'd you end up doing for the oil return line, doesn't look like you needed to use the factory one fabbed up like most others did.
2016 BMW M235i
[Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles
Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals
Electrical - GS EBC - Cobb AP Richtune in progress
Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's
Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40.
thehead is offline   Reply With Quote
 Old 09-11-2012, 05:12 AM   #3
theschrum's Avatar
Posts: 1,031   (View Stats)
This is the same turbine housing as the ATP GT35 series housing I assume?
I see you have an 8 blade compressor. IIRC, the 7 blade compressors are billet (the 6 blade might be as well) but a little more expensive and harder to find.
08 Speed 3|SOLD
 Old 09-11-2012, 06:55 AM   #4
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
This is a journal bearing turbo correct? Looks great. Any vdyno charts yet? I want to see how fast this spools, or slow.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 09-11-2012, 01:02 PM   #5
No I ended up using a steel bearded one that they sent to one of the nator ut guys for his gtx3071, it didnt fit his.
this was the 3076 atp housing, I put it on a lath and took out almost a 1/4 of an inch in material so the blade would fit.
Correct it is journal bearing, right now in 4th i'm at full boost (22psi) at 4300 rpms. I will post some logs later for you guys to see
Hx35 sold
New sc6266
The Following 10 Users Say Thank You to sleepyspeed6 For This Useful Post:
06Speed6 (09-12-2012), 86AmishMs3 (09-12-2012), atvfreek (01-05-2013), Black Metal (09-16-2012), bmylez (09-13-2012), Boosted Beluga (09-11-2012), MS3-a(sore)ASS-rex (09-11-2012), Speed3eak (09-14-2012), theschrum (09-11-2012), xdm88 (09-15-2012)
 Old 09-11-2012, 01:33 PM   #6
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Great job machining out the exhaust housing to fit the larger exhaust wheel on the HX35
I'd been considering this as an option to run a BW S259 myself
NATOR PA
The Following 2 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
rfinkle2 (01-11-2013), sleepyspeed6 (09-12-2012)
 Old 09-11-2012, 01:39 PM   #7
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
big motherfucking turbo on small turbine housing, and stock exhaust manifold?
heloooooo lag.
I'd do 3 things.
1) build the motor
2) upgrade to a t3 flanged manifold with ewg
3) get twinscroll turbine housing
I do like your creativity with it though and that you did the work yourself.
You took out most of the hump on the inlet portion of the turbine housing, were you nervous about piercing into the machined portion where the IWG flapper normally goes?
I wanted to port mine more but I'm nervous about it.
07 MS3
The original Genpoo Hater
 Old 09-12-2012, 12:20 AM   #8
heloooooo lag.
I'd do 3 things.
1) build the motor
I'm looking to build it soon, I am looking at houses rights now. That kind of why I went the way I did. I will be
going twin scroll and bigger hotside. One thing thay is really hurting spool is I'm still running the htp inlet with the cobb sri I need 3" or bigger.
With the hump I took out enough to make it almost perfectly round. Didnt really make me nervous it still had more material then the thinnest spot on the housing.
Hx35 sold
New sc6266
The Following User Says Thank You to sleepyspeed6 For This Useful Post:
Chimmike (09-12-2012)
 Old 09-12-2012, 12:53 AM   #9
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Very nice, no doubt the smaller a/r turbine housing helps that guy spool.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 09-11-2012, 03:11 PM   #10
dot584's Avatar
Posts: 426   (View Stats)
dot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the world
Wait ewg with stock Mani? Is this new? I feel so nub all over again.
Sent from my ADR6300 using Tapatalk 2
CP-E TIP and Cai - Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP - Fat Cat Motorsports Coilovers!
dot584 is offline   Reply With Quote
The Following User Says NO Thank You to dot584 For This Un-useful Post:
captain slow (09-13-2012)
 Old 09-11-2012, 03:14 PM   #11
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
ATP EWG Hotside.
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
The Following 2 Users Say Thank You to Black Metal For This Useful Post:
Ms3_Miami (09-13-2012), sleepyspeed6 (09-12-2012)
 Old 09-11-2012, 03:15 PM   #12
MSFer87's Avatar
Posts: 1,162   (View Stats)
Groans: 83
I appreciate your innovation with this........
The Following User Says Thank You to MSFer87 For This Useful Post:
 Old 09-12-2012, 02:07 AM   #13
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Wow thats a sweet turbo, I have been wanting the he351vgt for a while now and this has me thinking.
2006 Mazdaspeed 6
 Old 09-12-2012, 02:14 AM   #14
snailD's Avatar
Posts: 3,039   (View Stats)
haha and no comments on ur 21psi spring(s) yet
sleepyspeed6 likes this.
The Following User Says Thank You to snailD For This Useful Post:
 Old 09-12-2012, 02:58 AM   #15
I am getting a WMI kit, and a 3 bar map this next week, So we will see where boost goes from there.
Here is a log I have a heat shield that is vibrating thats what all of the noise is coming from, this is a third gear pull and it just spun. I will get some 4th gear pulls tomorrow.
My vd isn't working so when the nator dyno in a couple weeks I will post the dyno sheet
Hx35 sold
New sc6266
Boosted Beluga (09-12-2012)
 Old 09-12-2012, 04:35 AM   #16
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Just out of curiousity, if you dont have a 3bar installed yet, what made you think that a 21psi spring was a good idea?
Not knocking your creativity here, but be smart about it. We dont use gt40r's for a reason, they are too much.
700HP CLUB
11.479@124mph
#DIX
The Following User Says Thank You to Downmented For This Useful Post:
 Old 09-12-2012, 01:02 PM   #17
I tried to run a 14psi spring but my factory ebs wasn't working, and I wanted to get the turbo close to its compressor map. Why it is okay is because I live at 4500 ft above sea level, its not going to run the same cfm as it would at lower altitude.
Were you using the gt40 as a reference, because this is close to the gt35. I would run something that big on this car it would be pointless
Hx35 sold
New sc6266
 Old 09-12-2012, 01:29 PM   #18
Downmented's Avatar
Groans: 493
That makes perfect sense then, as long as you did it for a reason rather than just " i want more power" And no i was not using it as a reference to your turbo, just the fact that its pointless thats all
700HP CLUB
11.479@124mph
#DIX
 Old 09-13-2012, 06:17 AM   #19
LOL I know im brown, but I understand things. I like that you tried to question my 21psi move unlike other people who just said "thanks for trying to improve out community". I will though be moving up to 25-26 psi here in the next couple weeks. And the gt40 is over kill on this platfrom.
Anyone wondering I am running 50/50 E85/91 mix right now, and next week I will have my WMI and 3 bar map sensor. ALOT mor logs to come and videos
P.S. one reason I wanted to do the 35 series turbo is that I wanted to run higher boost, so looking at flow charts I decided with this one for my build
Hx35 sold
New sc6266
The Following 5 Users Say Thank You to sleepyspeed6 For This Useful Post:
Boosted Beluga (09-13-2012), Downmented (09-13-2012), jracer (09-13-2012), Mizzle (03-06-2013), RichieRichness (09-13-2012)
 Old 09-13-2012, 01:21 PM   #20
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
Can you explain why a GT40 is too much? honest inquiry.
And thanks @Captain KR for the post.
Skreets be calling...
 Old 09-13-2012, 01:25 PM   #21
Will fuck up ur day
Chimmike's Avatar
Groans: 433
well, unless you want something like 700whp, a GT40 is going to be way overkill. Very laggy, not a very big powerband.
Just look at the HP ratings for the turbo.
07 MS3
 Old 09-13-2012, 11:32 AM   #22
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
this setup looks promising. just a heads up i would keep an eye on your IDC's especially if you start getting spark blowout.
Sorry if i missed it but how large of a meth nozzle are you planning on running? IMO you're going to need quite a bit of meth to keep your fuel system at a managable level.
this is all assuming that you will still be running that much e85 on top of meth.
Murdered out 2007 speed3 GT with navi.
Last edited by mtnrunner; 09-13-2012 at 11:32 AM. Reason: MSF Database - Automerged Doublepost
mtnrunner is offline   Reply With Quote
 Old 09-13-2012, 01:25 PM   #23
mtnrunner's Avatar
^^i believe a large frame turbo like a gt40 would be beneficial if we could rev our motors higher and reliably. tuning up past 7500 is sketchy and is almost non-existant at 8k afaik. Evos do great with large turbos when they rev to 10k and have a huge power band.
I do think the large turbos will make great power but for area under the curve it would be hard to be faster than a slightly smaller unit.
 Old 09-13-2012, 01:28 PM   #24
Captain KR's Avatar
Posts: 2,320   (View Stats)
Captain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the world
Groans: 391
Groaned at 75 Times in 49 Posts
@sleepyspeed6 do you think a internal gate (welded flapper) atp hotside can be machined for a hx35 wheel also? I dont think there would be an issue but since you have done extensive research i'm hoping to get the simple answer.
@superskaterxes can you post a picture of a 3076 hotside for reference
moore automitive 4/13/13 515whp 511 tq
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
Captain KR is offline   Reply With Quote
 Old 09-13-2012, 02:37 PM   #25
Yes it can be, But the problem IWG with this big of a turbo really suck. I don't know how big the flapper is on the 76 hotside, but you would want it something close to at least a 38mm or you will be fighting boost creep all of the time.
Simple answer, can it be done? Yes.
As for meth, I am going to be running a DO7 or a DO8 nozzle. Two nights ago it dipped into the high 60's, and I hit 100 idc's with the 50/50 mix. So for right now the more meth I can get in there the better
Hx35 sold
New sc6266
 Old 09-13-2012, 01:30 PM   #26
oh ok that I knew I thought there was some actual limitation on the our platform I wasn't aware of. I know SUmark had one on his MS6 a long time ago.
@Captain KR these boys aren't ready yet lol
 Old 09-13-2012, 02:07 PM   #27
Downmented's Avatar
Groans: 493
These boys arent ready yet? Will does this kid even know who i am? Im guessing you are another captain kr groupie, funny, we were just talking about people like you.
700HP CLUB
11.479@124mph
#DIX
 Old 09-13-2012, 02:30 PM   #28
Will fuck up ur day
Chimmike's Avatar
Groans: 433
limitation? yeah. The block.
Do you know the work done to Erich's motor to get the power he has?
SU Mark had one on his car, and it never ran.
Yes, there is a limitation on this platform. Unless you want to slap a GT40R on the stock motor and run it way below it's efficiency range to make 400whp, and lag like a motherfucker.
You need some education on turbos. "Just because you can doesn't mean you should"
BTW: Captain KR ain't gonna pierce 550whp, let alone 700. He's on a ATP housing 3076. He's not going to be pushing any major boundaries. His motor is built the same as mine; pistons, rods, headstuds, headgasket.
07 MS3
sleepyspeed6 (09-13-2012)
 Old 09-13-2012, 02:49 PM   #29
bobbybennett23's Avatar
Posts: 132   (View Stats)
bobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond repute
but wills is the purple drank lol
Captain KR likes this.
bobbybennett23 is offline   Reply With Quote
The Following 2 Users Say Thank You to bobbybennett23 For This Useful Post:
Captain KR (09-13-2012), Jh8909 (09-13-2012)
 Old 09-13-2012, 03:16 PM   #30
Yeah this was really refering to my personal build.
 Old 09-13-2012, 02:27 PM   #31
Easy man I know this is MSF but don't get defensive so quick. I'm not out to make anyone look like a fool. And not a Will groupie either. I know who you are and the comment wasn't directed towards you so chill out some. Will and I have been discussing some holset plans for quite some time if you must know. FWIW I do follow your build with much respect. Can we pleez haz mutual friendz status again?
The Following 4 Users Say Thank You to BobtailedSnail For This Useful Post:
Captain KR (09-13-2012), Downmented (09-13-2012), impossible (11-29-2016), Jh8909 (09-13-2012)
 Old 09-13-2012, 02:39 PM   #32
mtnrunner's Avatar
I believe he is planning on using an ewg just wondering if the iwg housing would fit. i am guessing he already has a housing that he can use for the project.
The Following User Says Thank You to mtnrunner For This Useful Post:
 Old 09-13-2012, 06:24 PM   #33
Captain KR's Avatar
Groans: 391
wtf happened here lol
ANYWAYS...... I will not be using a iwg but the housing I have is iwg and I welded the flapper shut then welded a ewg arm on my manifold...... that being said my question was directed towards space contraints of the different atp hotsides. iwg vs ewg i notices that you cut toward the flange but i was making sure you didnt have to enlarge towards the flapper hole..... @sleepyspeed6
HNIC OUT! lol @BobtailedSnail
btw mike doesnt realize how determined i am to hit 500whp (not 550 JERK) on this atp hotside so he can EAD! (eat a dick)
Killah Built
The Following 2 Users Say Thank You to Captain KR For This Useful Post:
802MS3 (09-17-2012), BobtailedSnail (09-13-2012)
 Old 09-13-2012, 07:08 PM   #34
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
500 is super doable, Will. Ginger Joel hit 465+ with your same turbo, and that was before a lot of AP updates.
2007 CTS-V - Trying to sell
 Old 09-13-2012, 07:51 PM   #35
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Very creative Frankensnail.
I like it.
sleepyspeed6 (09-14-2012)
 Old 09-13-2012, 08:18 PM   #36
I guess the best way to figure it out would be to see which Holset and Garrett share similiar turbine dimensions. But I'm eager to get my hx-30 on my car, just need meth and a FMIC
 Old 09-13-2012, 08:30 PM   #37
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
This is baddass. I might consider doing this...just a smaller turbo
The Following User Says Thank You to forcedinduktion For This Useful Post:
 Old 09-13-2012, 08:49 PM   #38
Downmented's Avatar
Groans: 493
@BobtailedSnail I ♥ you
700HP CLUB
11.479@124mph
#DIX
 Old 09-13-2012, 08:58 PM   #39
Every ghey relationship has it's bumpy roads, I need you more than a whore needs meth
EDIT: and dick and crack and condoms and foods stamps, my completement is falling apart here but the main thing is I love you dos.
Downmented and Captain KR like this.
 Old 09-16-2012, 09:29 AM   #40
chuckms6's Avatar
Posts: 1,618   (View Stats)
this is a very interesting build and great alternative to the stock flange turbos that are available right now. the turbo and housing is half the price of a bnrs3 or atp upgrade, and its upgradable! think about it, all you need is the stock exhaust housing (which you should already have) and a custom twin scroll mani to go to the next step. i absolutely love this idea, and i may try this route with a hx30. thanks for the inspiration!
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
The Following User Says Thank You to chuckms6 For This Useful Post:
sleepyspeed6 (09-16-2012)
holset hx35? Fagwagon MazdaSpeed 3/6 - Turbo Induction 154 09-13-2012 01:39 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S Haltech Automotive News 0 02-16-2010 03:20 PM
Page generated in 0.77333 seconds with 41 queries
