 Old 03-01-2011, 06:52 AM   #1
obijack's Avatar
Posts: 1,830   (View Stats)
Default Garret GTX & EWG V BAND,5 bolt Exhaust housing
Since building the motor and going BT is such a PITA and expensive I am trying to buy one piece at a time, starting with the most costly and work my way down. I have three questions; 1. Has anyone used the new Garret GTX series turbos? 2. I have never seen an exhaust housing with a v-band flange for a EWG, its normally on the exhaust manifold, would this work fine? 3. Is there an exhaust manifold that uses stock location for gt30 series turbos, so i could bolt a factory location dp to it and have it line up with my catback?
BT gods please chime in
Garrett GTX3076R Dual Ball Bearing Turbo : atpturbo.com
Externally Wastgated Turbine Housing for Mazdspeed 3/6/CX7 - GT3071R/GT3076R : atpturbo.com
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
 Old 03-01-2011, 07:02 AM   #2
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
1: no, nobody has a GTX series turbo on their car to my knowledge
2: EWG flanges on the hotside do work, but since you want a bolt-on option for a turbo's hotside you won't be able to run that.
3: ATP makes bolt-on exhaust housings for these cars, that being said I don't know if the exhaust wheel on a GTX is a different size than a regular 3076. Using a bolt-on housing will require you to run a manifold with an EWG runner.
Good luck!
Edit: just looked at your second link, that looks promising. Still don't know if a GTX will fit though, most aftermarket manifolds for our cars come flanged for EWG don't they? If you can find one without it I say go for it!
NATOR PA
The Following 2 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
obijack (03-02-2011), SIXual Panda (03-01-2011)
 Old 03-01-2011, 07:51 AM   #3
sallyspeed3's Avatar
Posts: 638   (View Stats)
sallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the world
Wow that thing looks insane, certainly nothing like our K04. I know almost nothing about turbos so what are the advantages/disadvantages of running this kind of turbo? Not that I'm considering it, just curious.
2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40//
sallyspeed3 is offline   Reply With Quote
 Old 03-01-2011, 03:38 PM   #4
steedspeed's Avatar
Posts: 582   (View Stats)
steedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the world
I can do you an IWG manifold with T3 in stock location so you should be able to reuse your DP.
steedspeed is offline   Reply With Quote
The Following 2 Users Say Thank You to steedspeed For This Useful Post:
Alpha (03-01-2011), obijack (03-02-2011)
 Old 03-01-2011, 03:55 PM   #5
Alpha's Avatar
Posts: 3,711   (View Stats)
Thumbs up
I was just going to recommend Steedspeed for this. Great work and service by this man ^^^
 Old 03-01-2011, 04:16 PM   #6
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Yeah, Steedspeed all the way. I'm definitely picking up one those manifolds some time.
2007 CTS-V - Trying to sell
 Old 03-01-2011, 05:10 PM   #7
mason's Avatar
Posts: 946   (View Stats)
cant wait to get my revised top mount steed manny!
 Old 03-01-2011, 05:30 PM   #8
bmylez's Avatar
Groans: 31
Wha???? I've been talkin with Dustin and he said you're gonna have to hack your firewall to hell. You going through with that?
 Old 03-01-2011, 05:46 PM   #9
mason's Avatar
if i got to mabey, i havent herd anything yet? so was it fitted up and no way to make it work????
 Old 03-01-2011, 05:48 PM   #10
zx2man's Avatar
Posts: 1,356   (View Stats)
zx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the world
UMMMMMMMMMMMMMMM..this is "prabaly" the setup Im going with. in my MS3, I have plenty of room. I checked several days ago. The only slight prab is, the ewg flange+Tial wg would rub up or not clear the "stock" oil return line.
But I already have a 3071, with atp's ss braided oil return line where I have alittle flexibility, and with that being said it will work out just fine. On the "MS3"...theres enough room to make a simple elbow shaped dumptube, you would go 3-4 inches towards passenger, then aim downtowards ground, plenty clearence.
I have been on to the Subi forums, and they also have this as a option, and they are loving this hotside, no boost creep and holds psi really good.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO*
zx2man is offline   Reply With Quote
The Following User Says Thank You to zx2man For This Useful Post:
 Old 03-01-2011, 05:53 PM   #11
mason's Avatar
im making my own down pipe, intake ect.... i just need the turbo to fit in the space provided. so you looked it all over and think we got the room to change the angle???
 Old 03-01-2011, 05:59 PM   #12
mason's Avatar
wait wait, MARK street unit has a gt40 top mount on a ms3! and so does someone else (ssinstaller) i think...?
 Old 03-01-2011, 06:01 PM   #13
zx2man's Avatar
Change angle?? Shouldnt have to..you refering to changing mani flange angle?
Few days ago I got underneathe my 09 ms3. I currently have stock turbo-dnp mani. I looked at that atp hotside, the ewg flange will be down at the bottom of the hotside, not the exact bottom, but close. I use the bolt holes where it connects to the compressor for a reference, and compared it with my atp 3071.
So getting under the car there is pleny of room as far as I can see. I would "AIM" the Tial ewg towards passenger section of car, thats where you have the most room.
*Edit* I also took into consideration that 3071 is larger than k04 lol. And eyeballed the size difference, doing best I can..and should be good to go.
I also should say that Iam refering to atp3071 turbo..the atp2871-3076 turbos will fit stock location. This ewg hotside is not any bigger. I emailed ATP. It is a .55 a/r, and is flanged for the oem downpipe and manifold.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
 Old 03-01-2011, 06:32 PM   #14
mason's Avatar
ummmmm, i think we are talking about two different things, im talking about the steed speed twin scroll top mount manny for the speed 3. there was a fitment issue with the 3s manny and the 6s fit just fine. we need to find the rite angle for the 3s due to less room than the 6 behind the head.
 Old 03-01-2011, 06:39 PM   #15
zx2man's Avatar
Awww Mason....indeed sir we are talking about 2 different things...Yeah according to Dustin the fitment for topmount on ms3 is shitty.......Carry on lol Iam sorry.
Goodluck with topmount, I myself love the looks..but too many fuckin hassles for this ms3 owner.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
 Old 03-01-2011, 06:40 PM   #16
bmylez's Avatar
Groans: 31
Right. This thread is not about top mount at all.
 Old 03-01-2011, 09:36 PM   #17
Mazdanspeed3's Avatar
Posts: 157   (View Stats)
Mazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond repute
That would be a killer option, been thinking about this as well hmmmmm...
btw, i do believe the gtx series turbos would fit this hotside...
From ATP:
GTX turbos use same turbine housing as GT turbos and turbine housings are sold separately. This GTX model as uses all the same oil and coolant fittings at the standard GT30R/GT35R turbo.** **
Mazdanspeed3 is offline   Reply With Quote
The Following User Says Thank You to Mazdanspeed3 For This Useful Post:
 Old 03-02-2011, 06:16 AM   #18
Groans: 224
Mason, both SSinstaller and SUmark have ms6's, as far as we know the top-mount mani still won't work on the 3.
Back on topic, if the GTX has the same exhaust side dimensions I say go for it, I'd be interested to see if the small .55 a/r for the bolt-on housing can keep up with the compressor side of a GTX
NATOR PA
 Old 03-02-2011, 06:57 AM   #19
obijack's Avatar
That would be awesome, that's exactly what i am looking for. I am going to try and find some more information about this hotside before i buy. Zx2 said a lot of subbies are running it with great success. What would be the downfall of the wastgate being that close, if any?
[QUOTE=Back on topic, if the GTX has the same exhaust side dimensions I say go for it, I'd be interested to see if the small .55 a/r for the bolt-on housing can keep up with the compressor side of a GTX[/QUOTE]
Im glad you brought that up, isn't .55 a/r kinda small. Also how did you find out what size it is? I looked on the atp page but it did not list its size.
2014 Honda Grom-Red
 Old 03-02-2011, 08:35 AM   #20
Groans: 224
Okay, well first Leen would need to make you a stock flange IWG manifold bcause your looking at a bolt-on exhaust housing.
As for the A/R size, I can't recall where I got it from but I'm 100% it is .55. Yes .55 is small but it also means quick spool, the GTX line is supposed to spool pretty quick with a .82 housing so this will probably be like lightning lol, but since you're forged it'll be fine.
I just don't know whether the small exhaust housing will support the better compressor side or if it will not be able to move enough air to get that compressor moving.
NATOR PA
 Old 03-02-2011, 04:51 PM   #21
bmylez's Avatar
Groans: 31
The small exhaust housing would negate a lot of the benefit of the GTX compressor, but I'm sure there is a little power to be had. speedsixx said he had his ATP exhaust housing ported out as much as possible. Sounds like that would be a good idea if you're bothering with GTX.
 Old 03-02-2011, 04:55 PM   #22
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Buying the more expensive GTX turbo makes absolutely no sense if your just going to hamstring it with the Mazda fail turbine housing, and the higher efficiency compressor will make boost creep even more likely than it was on the standard gt's...
The Following User Says Thank You to SSinstaller For This Useful Post:
 Old 03-02-2011, 04:57 PM   #23
bmylez's Avatar
Groans: 31
Yeah, I should have specified that I wouldn't recommend it.
GTX turbos are for ballers. They're meant to be put on custom setups...or at the VERY LEAST, get a stock location T3 manifold.
 Old 03-02-2011, 05:20 PM   #24
obijack's Avatar
And the steedspeed top mount manifold is a PITA to fit on the speed 3? I really like the look and theoretical 'ease of access' with the top mount.
2014 Honda Grom-Red
 Old 03-02-2011, 05:42 PM   #25
bmylez's Avatar
Groans: 31
This thread isn't for talking about top mount. There is a whole thread about that already. But no, it doesn't fit the 3.
If people want to stick with stock flanged setups, they need to realize that power is going to be limited and it's not worth dumping too much money into.
V-band to stock exhaust flange -cj- MazdaSpeed 3/6 - Turbo Induction 10 11-17-2010 04:12 PM
WG right off the exhaust housing -cj- MazdaSpeed 3/6 - Big Turbo Builds 4 07-15-2010 09:22 PM
GT3071R (T3 Exhaust Housing) holeinmypocket MazdaSpeed 3/6 - Turbo Induction 28 07-06-2010 10:51 PM
Page generated in 0.44113 seconds with 29 queries
