10Likes ![]() |
![]() Join Date: Feb 2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
(Thread Starter) | Not Ranked : 0 score The story behind it all: I bought a 2007 black mica ms3 from a used car dealership back in February of 2015. Exactly a week later the car bent two rods from a blown turbo leaking oil, causing it to hydrolock. I took the car back to the dealership, from there they told me to take it to a shop and have the knock diagnosed. So the shop tore the car completely apart (not labeling any bolts, nuts, etc.) After the shop came to a conclusion on what had happened and how much it would cost to replace the engine the dealership basically told me I was on my own from that point. So I took it upon myself to take the car back to my garage and just do a full build. Parts: -Precision vband 5858 dbb, .82ar hotside, 4in inlet, 3in outlet -Precision 46mm wastegate -k1 connecting rods -wiseco pistons -king rod and main bearings -H11 headstuds -oem headgasket -full vvt kit -custom exhaust manifold -custom 3in downpipe -custom underrouted intercooler piping -htp 4in intake -custom battery tray -devils own meth injection 300psi pump -Do14 nozzle -Aem methonal controller -Damond motorsports pcv plate -Kozmic motorsports vented occ -Kozmic oil return line -Kozmic oil feed line -Damond full engine mount set -Southbend stage 3 endurance clutch -treadstone tr8 intercooler -GoFastBits BOV -Corksport 3.5bar map sensor -Cobb apv3 -bride shift boot That's all that I can think of off the top of my head. I will update if anything else comes to mind. Most of these pictures are going to be potato phone quality so I apologize ahead of time. received_1117159448309872[1].jpeg received_1117159438309873[1].jpeg Screenshot_20160902-191650[2].png Screenshot_20160902-191711[1].png IMG_0275[1].jpg IMG_0279[1].jpg IMG_0282[1].jpg Now on to the goodies: Screenshot_20160910-101616[1].png Screenshot_20160902-191626[1].png Screenshot_20160902-191533[1].png Screenshot_20160902-191512[1].png Screenshot_20160902-191416[1].png Screenshot_20160902-191606[1].png Screenshot_20160902-191329[1].png Screenshot_20160902-191306[1].png Screenshot_20160902-190354[1].png Screenshot_20160902-191258[1].png Screenshot_20160902-190347[1].png Screenshot_20160902-190231[1].png Screenshot_20160902-190221[1].png Screenshot_20160902-190150[1].png Screenshot_20160902-190145[1].png Screenshot_20160902-190141[1].png Screenshot_20160902-190130[1].png Screenshot_20160902-190111[1].png Screenshot_20160902-190055[1].png Screenshot_20160902-185949[1].png 20150814_113459[2].jpg
__________________ 2007 black mica Gen Juan. Build is currently underway. |
| Not Ranked : 0 score Wow, that's quite the jump from "stock"? Have you done this before? Should make some good power, good luck
__________________ Max Bolted and Built Stock K04 |
(Thread Starter) | Not Ranked : 0 score Never done this before. On any car lol I had speed solutions in Lonoke AT assemble the engine for me. And I work in a fabrication shop so I can get most the material for the exhaust stuff. A guy i work with made the manifold and down pipe. Sent from my SAMSUNG-SM-J320A using Tapatalk
![]() Join Date: May 2014 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
| Not Ranked : 0 score Good looking build, interested in seeing what it puts down. Small recommendation, go dual nozzle with your meth injection. There are a couple threads with solid evidence it will atomize better and deliver more octane with more even distribution among the cylinders. Good luck!
__________________ "Keep your head clear and suffer like a man" |
(Thread Starter) | Not Ranked : 0 score Awesome, thanks for the tip! Sent from my SAMSUNG-SM-J320A using Tapatalk Just a little more dp love. ![]() ![]() ![]() Sent from my SAMSUNG-SM-J320A using Tapatalk
__________________ 2007 black mica Gen Juan. Build is currently underway. Last edited by cmosh07; 09-11-2016 at 06:16 PM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Feb 2015 Location: Palmer, Iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 152
| Not Ranked : 0 score Are you not running a wastegate? I cant see from the pics if you have an ewg flange on the manifold but it looks like you dont and if your collector goes straight to your outlet flange like that then you wont be able to get an ewg flange anywhere where it would work.
__________________ 06 MS6 GT Titanium Gray II Metallic Last edited by davychronic; 09-12-2016 at 09:48 AM. |
| Yeah, you listed that you have PTE 46mm Wastegate and i don't see an EWG flange on your manifold. sent from my Nexus 6P
| Not Ranked : 0 score Wastegates are for wimps :-)
(Thread Starter) | Not Ranked : 0 score The wg comes in the mail tomorrow actually. Will post updated pictures of the manifold when it's finished. Sent from my SAMSUNG-SM-J320A using Tapatalk
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score Thoes head studs look like arp 2000. Edit: did you have your block checked I still see the gasket marks.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
(Thread Starter) | Not Ranked : 0 score Yes, block went to a machine shop and got checked out. Sent from my SAMSUNG-SM-J320A using Tapatalk
(Thread Starter) | Not Ranked : 0 score I recieved the wastegate, 4in intake, oil return line and some misc. Meth parts in the mail yesterday. ![]() ![]() ![]() Sent from my SAMSUNG-SM-J320A using Tapatalk
| The Following User Says Thank You to cmosh07 For This Useful Post: | KiwiFlavor (09-15-2016) |
(Thread Starter) | Not Ranked : 0 score @5doorsoffurry I'm pretty sure they are h11 studs. Lol ![]() Also got the wastegate mounted to the manifold last night. ![]() ![]() ![]() ![]() Sent from my SAMSUNG-SM-J320A using Tapatalk
| The Following 2 Users Say Thank You to cmosh07 For This Useful Post: | 5doorsoffury (09-27-2016), impossible (07-16-2017) |
Better make sure you start tuning with a low pressure spring because that placement of the wg flange is going to cause a lot of creep
__________________ 06 MS6 GT Titanium Gray II Metallic | |
| The Following User Says Thank You to davychronic For This Useful Post: | cmosh07 (09-18-2016) |
![]() Join Date: Feb 2013 Location: Anchorage AK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 131
Groaned at 9 Times in 4 Posts
| Not Ranked : 0 score sweet
__________________ YEEMARKS SP63 Built Engine. 5858. Meth. Old Time in S3: 12.4 @ 111 Parts needed to install: JMF, HTP 4.0", HKS BOV |
(Thread Starter) | Not Ranked : 0 score After many failed attempts I finally got the exhaust manifold wrapped. ![]() ![]() Sent from my SAMSUNG-SM-G935A using Tapatalk
| The Following 2 Users Say Thank You to cmosh07 For This Useful Post: | 5doorsoffury (10-18-2016), impossible (10-19-2016) |
Groans: 74
| Not Ranked : 0 score Correct me if i am wrong but doesn't wrapping a tubular manifold promote cracking over time with no turbo bracket to support the weight? Any reason you didn't go with the cpe manafold? It has a good wg placement and it can support a lot of weight. I only ask since my build is very similar except for manifold/aux fuel purchase. Also are you going meth for fueling and not 5/6th port? If so how is your wireing going to be done? Progressive or boost switch? Why did you pick a 3 inch outlet on a 5858 instead of the 2.5 offered with the ported s cover? What are your hp goals? Manafold looks awesome wrapped. can't wait to see some numbers!
(Thread Starter) | Not Ranked : 0 score You could be right about the manifold cracking, but my day job is actually tig welder/fabricator. So if it Cracks I'll just fix it. And I went with a custom manifold simply because it was cheaper. I made a package deal with a guy I work with. He's actually trying to start his own business that specializes in tubular manifolds, downpipes, etc. "Spoolin Fools" on Facebook, check him out. Yes, meth for fueling simply because it was the less expensive route lol plan on PI after the car is up and running for a while. I picked the 3in outlet because I knew I wanted a 3in dp so it was easier to fab. I'm shooting for 500whp. Sent from my SAMSUNG-SM-G935A using Tapatalk
__________________ 2007 black mica Gen Juan. Build is currently underway. Last edited by cmosh07; 10-19-2016 at 04:01 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score I managed to finally find the time to install my oil pan baffle this evening. I also got my valve cover and turbo compressor housing powder coated metallic purple. ![]() ![]() And a little parts pic to go along with it. ![]() Sent from my SAMSUNG-SM-G935A using Tapatalk
| The Following User Says Thank You to cmosh07 For This Useful Post: | impossible (10-19-2016) |
![]() | | #20 | ![]() |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
| Not Ranked : 0 score Glad to see you finally posted a build thread Clayton, excited for your build bro
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning |
| The Following User Says Thank You to impossible For This Useful Post: | cmosh07 (10-19-2016) |
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score Not a huge update but it's something... Finished up the hot side intercooler piping today, started the fabrication on the wg dump, and the intake manifold is coming along nicely. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SAMSUNG-SM-G935A using Tapatalk
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got my wastegate dump tube free all welded up and installed. ![]() ![]() ![]() ![]() Sent from my SAMSUNG-SM-G935A using Tapatalk
| The Following 2 Users Say Thank You to cmosh07 For This Useful Post: | impossible (02-05-2017), WetzMS3 (11-10-2016) |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just a little update picture. I've got everything except transmission fluid, basemap, and a little key on no power issue. I'm sure it's something simple I just keep looking over. I also found a killer deal on this jmf that I couldn't pass up. ![]() Sent from my SAMSUNG-SM-G935A using Tapatalk
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score No power issue is fixed. Also got my transmission fluid in the mail today ![]() ![]() Sent from my SAMSUNG-SM-G935A using Tapatalk
| The Following User Says Thank You to cmosh07 For This Useful Post: | KiwiFlavor (03-16-2017) |
![]() | | #25 | ![]() |
![]() Join Date: Oct 2016
Rep Power: 0 ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score You are a straight fab whore and I LOVE it... make me some Parts please hahaha.. black gen Juan mica!! Cheers man!! Sent from my iPhone using Tapatalk |
![]() | | #26 | ![]() |
__________________ 2007 black mica Gen Juan. Build is currently underway. | |
![]() | | #27 | ![]() |
Groans: 211
| Not Ranked : 0 score I'm guessing a bong.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles |
| The Following 2 Users Say Thank You to Thor Hammer For This Useful Post: | KiwiFlavor (03-20-2017), monkey.bones.007 (03-20-2017) |
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
Update: Yet another issue rises... went to install AP to the car and it won't recognise the ECU. I thought maybe I damaged one of the pins while checking for power so I went ahead and replaced the port and all pins (total of like $12.) Still won't recognise it. Any ideas on where to start with that one?? Sent from my SAMSUNG-SM-G935A using Tapatalk Sent from my SAMSUNG-SM-G935A using Tapatalk
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score I think I may have found the reason as to way a code reader or my AP won't communicate to my ECU. Whenever I turn the key to the on position the "engine immobilizer" light flashes rapidly. (This is the light that looks like a car with a key on it) if I understand correctly this basically means that my key code isn't communicating with my ECU? Kind of like the ECU thinks the car was stollen. Does anybody know of a way to fix this?? Sent from my SAMSUNG-SM-G935A using Tapatalk
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hauled the car to the stealership yesterday... Sure enough, they're computer won't communicate with the ECU. With a whole trip an hour away I hauled the car back home. The immobilizer light is throwing code 16 "communication error with PCM (no response)" I've checked the condition of all the wires going to the PCM itself, they all look brand new. I've checked all my grounding points, all are securely connected. All pins are in the correct place on the obd port itself, I'm leaning towards the PCM being fried. (Possibly caused from the positive fuse box cable being grounded before??) Any input on this at all is greatly appreciated.
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score So took the car back to the dealer and they were no help whatsoever. They literally told me they don't know what the problem is. After a heated discussion with the two techs I eventually just left. I had a buddy of mine meet me on my way home so he could take a look at it. He unlplugged the harness for the fuse box under the hood, said there was a piece of plastic or something in there so he blew it out. Much to my surprise my AP immediately connected and the immobilizer light went away. Got the car home, had a few little leaks (oil cooler, fuel pressure sensor) fixed the leaks. Built oil pressure and what do you know, it fires right up! No leaks no weird noises purrs like a kitten! Now on to the break in! https://youtu.be/N7kv48uHunM Sent from my SAMSUNG-SM-G935A using Tapatalk
![]() | | #33 | ![]() |
| Not Ranked : 0 score Sounds good! Glad you got it sorted. Sometimes its the easy things that are the hardest to figure out. Is that front bumper setup for additional cooling?
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
| Not Ranked : 0 score No, I was being serious .... about the sound and getting it working. The bumper was supposed to be funny, at least in my head it was
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Little update for those interested. I've gone through the break in period. Around 800 miles i started doing some wot logs for Justin Brasil. After a few pulls I started having issues with spark blowout so i bought a new set of 6510 plugs and gapped them to .024". Car ran fantastic for about 100 miles then started having issues again. I did a 3rd gear pull for Justin to see if he could tell what was going on. During the pull the car started cutting out again. But this time the fuel pressure dropped off to 505. I let out and took the car home. I noticed it was running a little rich on the drove home. I pulled into the drive and the CEL came on. "Fuel system too rich at idle" and "cyl 2 misfire". Ill attach a log of the pull for anyone curious. Now the car has trouble starting if i let it cool down. And afr's are around 11.8 ish at idle with hpfp pressure at 780 ish. Any ideas?? Stuck open number 2 injector? I've replaced the plug and stretched my coil springs already with no luck.
| 865ms3's 5858 build | 865ms3 | 2010 MS3 - Build Diaries | 184 | 06-01-2016 05:34 AM |
| Pte 5858 build | STiKiLLa | MazdaSpeed 3/6 - Big Turbo Builds | 74 | 03-13-2015 06:12 AM |
| Frankie's ghey pte 5858 build | ms3driver213 | 2010 MS3 - Big Turbo Builds | 17 | 04-18-2014 08:11 AM |
| PTE 5858 BT build!! | katoom17 | MazdaSpeed 3/6 - Big Turbo Builds | 3 | 02-22-2014 02:48 PM |
