  • 1 Post By TurboGsxr600
 Old 10-08-2012, 09:12 PM   #1
TurboGsxr600's Avatar
Posts: 127   (View Stats)
TurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond repute
Default Going Bnr Stage 3
Finally doing a turbo upgrade on my 08 speed 3. Car has 75K miles, it has been stage 2 since it had 6k on it. Driven hard daily and has never had any issues. I'm hoping it holds up for a little while longer with a little more power. Turbo came today from BNR and I will be doing the install tomorrow. Wish me luck. I'm hoping to be able to leave the manifold in. I see some guys take it out, some don't. My egr is fully deleted so maybe that will help some. Any advice or tips would be appreciated. Will post pics of the install.
TurboGsxr600 is offline   Reply With Quote
The Following 8 Users Say Thank You to TurboGsxr600 For This Useful Post:
boostdmazda3 (10-29-2012), Code Monkey (10-18-2012), Jh8909 (10-09-2012), Juyoung (02-16-2013), kritz (10-08-2012), MazdaBoy2.3 (10-08-2012), psychophyr (10-22-2012), speed23 (10-08-2012)
 Old 10-08-2012, 09:14 PM   #2
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
To do a bnr you dont have to remove the mani. Just pull it out towards where the battery would be. You will however need to remove the coolant hose just under the egr location.
It also helps if you do the 4 bolts between the mani and turbo last and just have someone under the car hold it up as you start to slide it out
And lastly DONATE BROWNIE.
TEAM LUXURY
The Following 4 Users Say Thank You to Sid3wayS For This Useful Post:
Andjo (10-22-2012), J'sSpeed3 (10-18-2012), kritz (10-08-2012), nycMS3 (10-12-2012)
 Old 10-08-2012, 09:15 PM   #3
JDW1's Avatar
Posts: 486   (View Stats)
JDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the world
You won't be disappointed. The coolant line will be the only hang up. I'd also make sure alm the bolts on the turbo are super snug before the install. I had one of mine come loose. Besides that enjoy.
07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas AlphaTuned. Parting out.
11 Mustang GT current.
JDW1 is offline   Reply With Quote
 Old 10-08-2012, 09:20 PM   #4
Big_Burd's Avatar
Posts: 831   (View Stats)
Big_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the world
Groans: 118
Everything should hold fine, as long as you're not on original motor mounts..and depending on how hard you've raped the clutch.
Elaborate what you mean by stage 2 setup.. Do you have a hpfp,FMIC,dp, different mani?
2008 Speed3// Cobb SRI / Cobb TI/ Cobb STS Koni Yellows, stock springs/ JBR 88 Trilogy / JBR RSB / JBR CamberArms/ Hotchkis FSB
Big_Burd is offline   Reply With Quote
 Old 10-08-2012, 09:37 PM   #5
Actually I'm still on stock motor mounts..but I have the JBR 88 on the way. I haven't been to hard on the clutch.
Mods are, Cobb AP, Cobb SRI, Cobb TIP, CNT Catback, Turbo XS DP, Forge BPV, Autotech Internals, Cpe TMIC, SSP Egr delete.
Thanks man appreciate it!
Big_Burd likes this.
Last edited by TurboGsxr600; 10-08-2012 at 09:37 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-08-2012, 09:56 PM   #6
Big_Burd's Avatar
Groans: 118
Nice! I have the JBR 88 trilogy and they made a huge difference. I wouldn't want to put a bigger turbo on the stock mounts.
 Old 10-09-2012, 07:30 PM   #7
Install went well today. Took me about 8hrs with lunch and a parts run. The only issue I had was a leaking coolant line. I ended up just bending the stock line instead of using the supplied banjo bolt.
The Following 2 Users Say Thank You to TurboGsxr600 For This Useful Post:
Jh8909 (10-09-2012), Voltwings (10-09-2012)
 Old 10-09-2012, 08:34 PM   #8
speed23's Avatar
Posts: 1,480   (View Stats)
Glad it went well. Did you end up taking any pics?
 Old 10-11-2012, 06:14 PM   #9
Didn't get alot. Phone died but heres a few.
The Following 5 Users Say Thank You to TurboGsxr600 For This Useful Post:
IshiKage (10-12-2012), J'sSpeed3 (10-18-2012), nycMS3 (10-12-2012), psychophyr (10-22-2012), speed23 (10-11-2012)
 Old 10-16-2012, 04:06 PM   #10
kpsoerensen's Avatar
Posts: 144   (View Stats)
kpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond repute
Nice work. Thinking of doing this myself.
Sent from my space phone
-~-2008 MS3 cosmic blue mica-~-
Orinda, CA 94563
kpsoerensen is offline   Reply With Quote
 Old 10-18-2012, 05:41 PM   #11
PRMS3's Avatar
Posts: 120   (View Stats)
PRMS3 has a brilliant futurePRMS3 has a brilliant futurePRMS3 has a brilliant futurePRMS3 has a brilliant futurePRMS3 has a brilliant futurePRMS3 has a brilliant futurePRMS3 has a brilliant futurePRMS3 has a brilliant futurePRMS3 has a brilliant futurePRMS3 has a brilliant futurePRMS3 has a brilliant future
Awesome! Just bought my BNR S3 today! Joining the club... Should be here Saturday or Monday! It's almost like Christmas!
PRMS3 is offline   Reply With Quote
 Old 10-18-2012, 05:49 PM   #12
tastysi2004's Avatar
Posts: 1,063   (View Stats)
tastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the world
im doing it as a new years resolution.
post some numbers on the dyno with the new tune.
2008 MS3 gt mica black
EL NATOR DE Virginia/Florida
Update: getting that
Purple drank in my tank.
build block, pnp everything, tr825 core, meth and lots of it.
554whp/546wtq @ 30psi.
another build? maybe soon..
b/c race cars need more attention than women.
adlpb: ~Fast cars are for straight lines. Corners are for fast drivers.~
#CATBACKEXHAUST
tastysi2004 is offline   Reply With Quote
 Old 10-22-2012, 03:33 PM   #13
Matrix311's Avatar
Posts: 2,133   (View Stats)
subbed. I'm pretty much in the same boat as you. My car has been fully bolted stage 2 since about 5,000 miles and I just rolled over 80,000 miles and i'm finally thinking of swapping the stock turbo out. My stock turbo still purrs and runs fine and no smoke and I have an '07, guess i'm a lucky one. I just want something basic to install without a ton of more supporting mods. I bought a Jeep so I have to keep funds free'd up for my new habit.
Please post your results. How are you liking the BNR upgrade vs the stock turbo so far?
 Old 10-22-2012, 06:58 PM   #14
Will do bro. I love the turbo so far. But I am trying to tune it myself and I'm taking my time with it. I am currently trying to hold 22psi to redline. Full boost is around 3800rpm which I'm sure can be a little better.
 Old 10-24-2012, 05:00 PM   #15
G Sp33dy's Avatar
Posts: 337   (View Stats)
G Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the world
Groaned at 7 Times in 3 Posts
congrats man @phate has tuned my bnr3 setup and I love how it doesnt run out of breath past 5k. welcome to the bnr club lol
08 MGM::BNR S3:: PG-TR8 FMIC::Autotech HPFP:: Yota Injector Seals:: HTP 3.5":: Grimmspeed ECBS::gutted DP and TP:: FREEKTUNE:: 3bar:: Forge V1:: Koni yellows and corksport springs::: TB & IM thermal gaskets:: CNT cat back:DM 6k:: 30% tint:: shaved doors:: RPF1 17x8:: MD OCC::
'99 XJ, 3.5" lift, ARB front bumper, magnaflow exhaust on 31's
G Sp33dy is offline   Reply With Quote
The Following User Says Thank You to G Sp33dy For This Useful Post:
phate (10-24-2012)
 Old 10-24-2012, 06:56 PM   #16
sikksohc's Avatar
Posts: 17   (View Stats)
sikksohc will become famous soon enoughsikksohc will become famous soon enough
Im looking into buying this turbo also, can you use the factory boost control with this?
sikksohc is offline   Reply With Quote
 Old 10-25-2012, 05:11 PM   #17
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
You should be able to be at full boost at 3k with that guy. Maybe 3200.
Yes, but you need to run a restrictor pill in the boost line that feeds the WGA and EBCS. I could mail you my leftover welding tips if you want to try it out. Or make life simple and buy Grimmspeed.
2007 CTS-V - Trying to sell
 Old 10-29-2012, 02:55 PM   #18
G Sp33dy's Avatar
We tried this setup and my stock boost solenoid took a shit for whatever reason once the BNR was on. So in went the Grimmspeed. Hunt the forums you can find one used.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/going-bnr-stage-3-a-126872/
porting du turbo oem - Mazda 3 Quebec This thread Refback 01-24-2013 03:28 PM
Cobb ATR Support
4 05-24-2009 07:52 PM
Page generated in 0.45000 seconds with 32 queries
