  • 1 Post By makjur
  • 1 Post By silvapain
 Old 08-27-2012, 11:55 AM   #1
TEASE's Avatar
Posts: 18   (View Stats)
TEASE is a glorious beacon of lightTEASE is a glorious beacon of lightTEASE is a glorious beacon of lightTEASE is a glorious beacon of lightTEASE is a glorious beacon of light
Default Grimmspeed EBCS in 2-port mode
I've just installed an ATP Turbo GT2871R kit in my MS6 and trying to figure out how to connect my Grimmspeed EBCS in 2-port mode. Does anyone know..? I will switch to 3-port mode later on when I can fully tune it.
TEASE is offline   Reply With Quote
 Old 08-27-2012, 12:06 PM   #2
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
If you cant tune for a 3 port how do you plan on tunning for the gt28
TEAM LUXURY
 Old 08-27-2012, 12:09 PM   #3
ChimmyChong's Avatar
Posts: 592   (View Stats)
ChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the world
Groans: 39
1 to wastegate... 3 to intake... iirc
i would search just to double check...
2010 Liquid Silver MS3
// BNR S3 // 3Bar Map+MJ Harness // JBR 3.5" WP // CS TMIC // KMD HPFP // 3" Catless DP/RP // TS Dual Port // Cobb AP // GS 3 port EBCS // ITV-22's // MD OCC // JBR Small Battery Tray //
// JBR Dog Bone RMM // JBR Heavy Knob // JBR Solid Shifter Bushings // JBR Short Shifter Plate // JBR RSB // JBR 80D PMM // 15mm Front // 10mm Rear // SPC Rear Camber Arms // Sonic Tuning Coilovers //
// 6K HID // 35% tint // 12"RF with Infinity Amp // MZ Front Lip // 17x8 Enkei RPF1's //
ChimmyChong is offline   Reply With Quote
 Old 08-27-2012, 12:18 PM   #4
Here's a useful document I created about how to connect a 3 port solenoid in interrupt and bleed mode.
Drive By Fire (01-23-2015), ms3blackmica (01-16-2013), RichieRichness (08-27-2012)
 Old 08-27-2012, 01:05 PM   #5
TEASE's Avatar
Ahhh, in 2-port mode there's no line at all connected to the WG. Now I get it. Thanks.
This is just temporary. I'll upgrade my HPFP aswell and just drive at really low boost for 400-500 miles before I'll go and tune my car. I have VersaTune and was planning to install a tune for the Grimmspeed EBCS, but they are just for stock DP.
The Following User Says Thank You to TEASE For This Useful Post:
Sid3wayS (08-27-2012)
 Old 04-08-2013, 08:10 PM   #6
makjur's Avatar
Posts: 1,313   (View Stats)
makjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the world
Groaned at 15 Times in 8 Posts
At an install meet I recently had no option but to go with a used grimmspeed 3 port, the nipple to my stock EBCS broke off and I didnt have the foresight to have a spare with me
Thankfully @RedBliss; is in the process of parting out, had his stock EBCS in one piece, and sold me his Grimmspeed
We used this PDF as a guideline, I have put about 100 miles on the car so far, have done some WOT driving, and no explosions yet...
I want to make sure I'm running in 2 port mode properly...
@Lex; @atvfreek; @silvapain; @rfinkle2;
davros likes this.
makjur is offline   Reply With Quote
The Following 2 Users Say Thank You to makjur For This Useful Post:
davros (03-02-2015), silvapain (04-09-2013)
 Old 04-08-2013, 09:24 PM   #7
this is correct.
atvfreek (04-09-2013), makjur (04-08-2013), MHHC5280 (01-09-2014), rfinkle2 (04-09-2013)
 Old 04-09-2013, 08:31 AM   #8
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
You don't have to plug port 3 on the GS EBCS, but it doesn't hurt anything. There's a check valve in there that will allow air out of port 3, but not back in. It will show up as a "boost leak" if that port isn't plugged though.
davros likes this.
davros (03-03-2015), makjur (04-09-2013)
 Old 04-09-2013, 10:23 AM   #9
makjur's Avatar
Since I have it capped off with a bolt im going to leave it as is
Thank for confirming its safe to use this way
derpatapped
2010 blue with tech, cobb sri+tip+dp+cbe, ets tmic, grimmspd ebcs, autotek hpfp, jbr boosttoobs+rmm+roundknob+bushings, turbosmart bpv, swift springs, APv3 FreekTuned
retrofitted headlights: morimoto 5k HIDs with XB35 ballasts, in mini D2S projectors. VLED triton 5k switchback DRL/turn signals
♡°☆(ಠೆಒಠಿ)☆°♡
 Old 04-09-2013, 03:45 PM   #10
pochylkospeed3's Avatar
Posts: 21   (View Stats)
pochylkospeed3 is a jewel in the roughpochylkospeed3 is a jewel in the roughpochylkospeed3 is a jewel in the rough
dont you need a boost source? T'd into your wastegate? worked on mine forever before i gave up and did it in 3 port mode, in 2 port with stratified i couldnt only reach 12 psi
2010 Mazdaspeed 3
K&N SRI , Cobb TIH, Cobb AP, Cobb LMM, Cobb FMIC, Cobb DP, Cobb CBE, Autotech HPFP internals, ITV-22, Stratified EBCS 3 port, Corksport SSP, Cobb CW, BC Racing Coilovers,
pochylkospeed3 is offline   Reply With Quote
 Old 04-09-2013, 04:57 PM   #11
atvfreek's Avatar
Posts: 7,787   (View Stats)
Gitarpik is on the k04 with 2 ports at the wastegate actuator. If you're tuning a BT then you will need a tee between the wastegate and boost source
Sent from your couch
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
Grimmspeed 3 port interrupt mode-Stock K04 mrmonk7663 2010 MS3 - ECU Computer Tuning 115 08-13-2014 10:40 PM
Grimmspeed 3 Port In 2 Port Mode on IWG? bewsted MazdaSpeed 3/6 - ECU Computer Tuning 1 12-21-2011 08:59 AM
Page generated in 0.31695 seconds with 28 queries
