Closed Thread
 Old 04-06-2010, 01:06 AM   #1
h0rsies's Avatar
Posts: 133   (View Stats)
h0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond repute
Default gt 28751r
I just got the gt 28751r turbo. With the necessary mods to support the turbo will it still be safe to run on stock internals? Or will I most likely blow up?
h0rsies is offline
The Following 3 Users Say NO Thank You to h0rsies For This Un-useful Post:
 Old 04-06-2010, 08:45 AM   #2
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
I hope you mean the 2871R? if not, I'd like to know what's different between the 2871 and the 28751.....
and it could be safe depending on the boost you plan on running.
07 MS3
The original Genpoo Hater
Chimmike is offline
 Old 04-06-2010, 09:04 AM   #3
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
Like chim said, depending on the boost you run. I had a buddy run a 2871r for a long time on 18psi with stock internals and was fine.
tbot is offline
 Old 04-06-2010, 09:06 AM   #4
BUNGEEZZ's Avatar
Posts: 426   (View Stats)
BUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the world
Groaned at 49 Times in 36 Posts
what about a 3076 on 20 psi stock internals?? lol
Mazdaspeed6,2006, 46k miles.
COBB AP*
Gt3076, 19psi. CPE dp (catless), Dnp Mani 38-EWG, CorkSport Dual CB, CPE BIG MAF SRI, Big Turbo Inlet, CPE Fuel Pump, HKS SSQ Black out edition, Ported stock intake Mani, Intake mani spacer (PT), 2 step colder plugs, FMIC Custom 3.5 inch core, Meth (PT), OCC, BSD, TTFMM, CPE Rear Diff, CPE engine Mount, H&R Springs, Whiteline Rear Sway Bar, Stage 1 short shifter kit Base+bushings, Rotora Break Rotors All 4 (Slotted), Techna fit Brake Lines, Ebc red Stuff pads All 4, Enkei PF01 18's Wrapped in 245/40/18 Falkanzzzz ... Stock clutch until i get some funds.
I HAZ THE FASTEZ CAR ALIVE!!!!!!!!!!!! REDBULL FTW
BUNGEEZZ is offline
 Old 04-06-2010, 09:13 AM   #5
Alpha's Avatar
Posts: 3,711   (View Stats)
It's not about how much PSI, it's about efficiency and ultimately, a good tune.
Alpha is offline
nutsac76 (04-06-2010)
 Old 04-06-2010, 09:19 AM   #6
ALL-IN.
AndyMS3's Avatar
Posts: 671   (View Stats)
AndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the world
Groans: 30
Wtf is a 28751r? And you can answer your own question by not being lazy a doing a search. There's enough pertinent information on this forum to answer your question.
-1 for you and FYCN.
AndyMS3 is offline
The Following User Says Thank You to AndyMS3 For This Useful Post:
Darksun280 (04-06-2010)
 Old 04-06-2010, 09:22 AM   #7
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
This thread is fail. Closed...
Carry on citizens....
10.7 @ 133 auto 1G DSM
Darksun280 is offline
The Following 2 Users Say Thank You to Darksun280 For This Useful Post:
BUNGEEZZ (04-06-2010), phillyb (04-06-2010)
Closed Thread
Page generated in 0.27142 seconds with 25 queries
