 Old 07-11-2013, 04:26 PM   #1
MS6_Newb's Avatar
Posts: 105   (View Stats)
MS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud of
Groaned at 7 Times in 3 Posts
Default GT 3071 install and fitment problems
Is there any easier way to install a GT on a speed6? Is there something I can do that will speed things up with the install?
Story:
I bought the turbo and was excited to put it on. I started the install and after dropping subframe and finagling to GT in I find that it doesn't quite fit. Along with this the oil drain isn't quite lining up and the feed is hitting the turbo keeping me from installing. I'm using factory lines but ATP bolts. Also the ATP bolts are to short. I also purchased a Lex tune and times ticking. To add to my dilemma I don't see a braided line working for the drain due to the transfer case. My factory drain tube is touching the TC. I read the how to's and it seems like my install went completely different. I'm so frustrated I can't think so any advise is welcomed. I don't and can't bring it to the mechanic as the front end is apart.
Mods: AEM CAI, Cobb AP, AT internals, Juggernaut, Dreadnaught, R6, Ebay DP catted, SURE TMIC, custom 3" Y to dual 2.5" CBE, ATP GT3071, Cobb 3 port, CP-e 4" TIP, LEX Tuned (stratified auto) in progress
MS6_Newb is offline   Reply With Quote
 Old 07-11-2013, 04:58 PM   #2
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Troll?
Nator is what it does.
 Old 07-11-2013, 05:03 PM   #3
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Funny how it fits in 8637 other people's speed, but not yours. Hmmmmmmmm.
 Old 07-11-2013, 08:13 PM   #4
h0ckeyman's Avatar
Posts: 1,126   (View Stats)
h0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the world
I remember my first BT install.
Rapey Agendas Racing
h0ckeyman is offline   Reply With Quote
The Following 6 Users Say Thank You to h0ckeyman For This Useful Post:
Agent_Orange (07-11-2013), blackms3_71 (07-13-2013), Colin1337 (07-13-2013), ms3blackmica (07-15-2013), Sid3wayS (07-12-2013), thehead (07-12-2013)
 Old 07-11-2013, 08:21 PM   #5
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Thank you for explaining your problem so thoroughly. We don't even need pics.
See the problem is, your car hates you. You sure you got the mazda specific stage 5 kit?
 Old 07-11-2013, 08:27 PM   #6
kladuscan's Avatar
Posts: 70   (View Stats)
kladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant future
At least you chose the right username..
BCM MS6 #5338
Mods: a few things here and there...
kladuscan is offline   Reply With Quote
The Following User Says Thank You to kladuscan For This Useful Post:
 Old 07-12-2013, 08:12 AM   #7
MS6_Newb's Avatar
I'll try to post pics. I think my car does hate me. I followed the how tos but it they seemed like they where missing steps unless my car is that much different for some odd reason. As for th turbo I bought the ATP bolt in kit from edge. The coolant lines worked without an issue but for the oil my drain studs are almost flush with the flange. My feed bolt only has 3 threads to grip the turbo with. As for fitment it's extremely tight and touching coolant lines on the firewall.
I might be a newb to the speed6 but I'm definitely not a newb to cars. I know my way around the engine bay. However this one has me beat.
 Old 07-12-2013, 08:19 AM   #8
SLOWHATCH's Avatar
Groans: 274
I know some guys remove the wiper cowl for more access. But it has to be able to go back in. @djoustein; I think it was he who had a thread explaining how to remove the cowl for more space. Hope that helps.
Edit: Failed at tagging. Can't remember how to spell his username.
 Old 07-12-2013, 08:28 AM   #9
thehead's Avatar
Posts: 1,141   (View Stats)
thehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the world
Groans: 143
why did you drop the subframe... seams like extra unnecessary work.
take the tmic off, take a bolt out of the rmm, jack the engine up to move it forward, slide the exh manifold out, remove old turbo, place in new turbo and repeat in reverse order.. going through the top isn't that bad, especially with a stock exh manifold, try it with the cp-e one, that's a bitch.
as for the drain to the transfer case, that is kind of a pain, I don't really have any advice for that.
2016 BMW M235i
[Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles
Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals
Electrical - GS EBC - Cobb AP Richtune in progress
Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's
Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40.
thehead is offline   Reply With Quote
The Following User Says Thank You to thehead For This Useful Post:
SLOWHATCH (07-12-2013)
 Old 07-12-2013, 11:45 AM   #10
MS6_Newb's Avatar
I don't plan on taking out the TC this could be my bad in the explanation.
I had the drop subframe because of the factory turbo mounts and bolts. I tried to remove the manifold but mine is stuck and I've soaked it with different penetrant oils with on luck. So I guess I'm doing it right, just the car is fighting me the entire way.
If pictures load:
In the pictures I'm showing the length of the stock oil banjo bolt vs the ATP. Also I'm trying to show the drain tube. I know in the one picture I have both crush washers one end, its to show how many threads I have to deal with. Also I have a picture showing how small the atp bolt head is and the gap between the banjo and the head. Finally the picture shows how it's sitting right know and how tight it is.
 Old 07-12-2013, 02:29 PM   #11
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
The oil drain -AN line is too long; you need to cut it down to length. For the banjo bolt, one washer per side of the banjo fitting on the hard line; you have both crush washers on the bolt in the pic.
I had to extend one of the coolant lines and move the coolant hardline out of the way to get my GTX3071 to fit.
Colin1337 (07-13-2013), SLOWHATCH (07-12-2013)
 Old 07-12-2013, 02:33 PM   #12
LumberJack's Avatar
The fail is strong within this one. Hope you figure out where those washers actually go on the feed line, yes that line is a bitch and the bolt may seem a little small, but everyone else runs the same bolt with the atp kit, it works. Not to mention the other 7856 speeds that are running the ATP kit. Either way goodluck hope you figure it out
10.36@148 Fastest Gen 2
 Old 07-12-2013, 02:42 PM   #13
soul.survivor's Avatar
Posts: 335   (View Stats)
soul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the world
You seem to be using the factory oil return instead of the braided line ATP includes which has to be cut to fit. Also the turbo isn't bolted to the manifold. How do you expect to get the lines on if it's not bolted up tight? IDK about the banjo bolt. Mine fit fine.
2008 CBM MS3
CP-E RMM | JBR 3.5" WP | GTX3071R | JBR OCC + IM TIG | SU TMIC | Turbosmart Compact BPV | Autotech Internals | Cobb AP + TBE + EBCS | NGK 1 Step Colder | TWM Shifter | Hotchkis Sways | Bilstein Sports | Swift SPEC-Rs | SPC Camber Arms | Freektune
soul.survivor is offline   Reply With Quote
The Following User Says Thank You to soul.survivor For This Useful Post:
silvapain (07-12-2013)
 Old 07-12-2013, 06:52 PM   #14
MS6_Newb's Avatar
I had no issues with coolant. I know its one per side of banjo but my fingers were in the way for the pic that way.
I finally got everything on. I wouldn't call it fail just lack of some important info.
Mine never came with any lines.
After all this I finally received some awesome wisdom from Alan Jackson at EdgeAutosport. He told me to stuff the socket with paper towel really tight then use it to force the bolts in. This worked and the turbo is fully installed now. This issue should be noted in the sticky and the stuff advise should be in it as well. Either way its in this thread so if anyone else has this problem they now know how to solve it.
Time to get Lex tuned. So excited.
 Old 07-12-2013, 07:44 PM   #15
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
don't blame the info that is here that is totally free and available to all. do more research next time. preparation son, you haz none.
'08 CWP MS3 w/ T3 3071r
 Old 07-12-2013, 07:58 PM   #16
thehead's Avatar
Groans: 143
If you got the kit from edge it definitely came with lines, they know their shit and wouldn't send a turbo kit out without them (I know my kit came with them...) also, if it didn't come with lines, how did you get it hooked up? I'm confused
2016 BMW M235i
 Old 07-12-2013, 10:24 PM   #17
Info is here. You fail at reading.
2008 CBM MS3
 Old 07-13-2013, 11:05 AM   #18
MS6_Newb's Avatar
The only line that came with it was the coolant. I masked about the other lines but they I don't "need" them.
I read that post along with others numerous times. I would never have attempted it if I wasn't sure that I could do the job. The info that was missing is the stuffing of the socket and forcing the bolts in.
Either way its in now so this thread can be closed.
 Old 07-13-2013, 05:31 PM   #19
silvapain's Avatar
Groans: 136
I am currently installing an ATP GTX3076 purchased from MAP right now, and it didn't come with a -AN oil drain line. However, my ATP GTX3071 kit purchased from Edge did.
I don't know if it's the vendor or a change in the kit from ATP.
HKS SSQV IV w/ CP-E Kit Install Problems iammike 2010 MS3 - Engine, Transmission & Driveline 28 01-19-2013 01:47 PM
Problems after turbo install keke MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 05-03-2012 09:49 PM
problems with ots map after dp install Zbrit00x 2010 MS3 - ECU Computer Tuning 17 11-03-2011 01:14 PM
ETS TMIC Problems after install (Help!) Bujwazay MazdaSpeed 3/6 - Turbo Induction 17 02-10-2011 07:40 PM
Problems with gen2 PNP fitment nynhex Custom Performance Engineering (cp-e.com) 21 05-11-2010 02:16 PM
Page generated in 0.39671 seconds with 31 queries
