Like Tree3Likes
  • 1 Post By i8urgti
  • 1 Post By theschrum
 Old 12-18-2011, 01:04 PM   #1
AXELATNO's Avatar
Posts: 9   (View Stats)
AXELATNO is a jewel in the roughAXELATNO is a jewel in the roughAXELATNO is a jewel in the roughAXELATNO is a jewel in the rough
Question GT2871R - Best manifold ? DNP, steedspeed or OBX
Hello everyone,
My first post in the forum (sorry if somes grammatical mistake French is my first language)
I have a Speed 3 1st gen with GT2871R, CPe DP catted + racing beat catback.
I'm using the stock turbo manifold. I try to found somes info for the best manifold for the price.
We can found OBX at 250$ and steedspeed at 750$ and between DNP at approx 565$. If you know other brand please give me info
What is your suggestion, somes people have one of this manifold coupled with the GT2871R. At wich RPM the best increase power
Thanks
AXELATNO is offline   Reply With Quote
 Old 12-18-2011, 01:09 PM   #2
i8urgti's Avatar
Posts: 1,660   (View Stats)
i8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the world
Groans: 267
obx is cheap stuff, idk if i would trust fitment
dnp is sweet because its tubular so air flow is nice, but they can crack at the welds over time. (you can also get one from protege garage)
steedspeed is a cast manifold and will last forever and still flow smoother than stock
all are good options, all will net you more power.
1sicms3 likes this.
2006 LPM MS6 GT (totaled)
0-60 mph : 4.2 second (as per DH)
12.83 @ ???MPH 1.67 60ft
2002 Miata Se (convertible whore)
i8urgti is offline   Reply With Quote
 Old 12-18-2011, 01:27 PM   #3
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Honestly, are you looking to absolutely max out your turbo? A manifold will give you some power, but if you run a methanol injection system and get a really good ECU tune, it would be good enough. Steedspeed manifolds are awesome, but I just want to make sure you realize, you won't make a ton more power with the 2871. There is a guy with stock manifold *and* catback exhaust making about 400 hp at the wheels with a gt3076. If he were to run ehtanol or methanol, he would make even more. Just depends on if you want to max out your turbo or not.
2007 CTS-V - Trying to sell
 Old 12-18-2011, 01:41 PM   #4
AXELATNO's Avatar
My last dyno run 347WHP at 18psi, no timming advance ajustment. AFR at 12:1 at WOT.
No water met in my futur project.
But I think the stock manifold don't have the best design to have the best exhaust flow to push the turbine.
You know other manifold brand ??
Steedsped look great but the price is great too
 Old 12-18-2011, 01:45 PM   #5
zenger's Avatar
Posts: 602   (View Stats)
zenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the world
Groaned at 8 Times in 7 Posts
thats a huge power number for no timing advance on that turbo with only 18psi. In fact I don't believe it at all. Because that's exactly what I dyno'd with 2871 E40 and 22psi and timing added ...
2007-Mazdaspeed 6
BNRSIII~all supportings
Zoom Zoom Boom part out.
zenger is offline   Reply With Quote
 Old 12-18-2011, 01:57 PM   #6
AXELATNO's Avatar
Below the dyno sheet. First run and run five. For the run 3 and 4 I lean the mix up to 12.5:1 and return to 12:1.
Base MAP Cobb 1.08 stg2 with fuel tab correction by me. Working in Load target logic. Contol with EBC Greddy type S
The Following User Says Thank You to AXELATNO For This Useful Post:
Fail_6 (03-29-2014)
 Old 12-18-2011, 02:02 PM   #7
zenger's Avatar
ohh missed the part where you were a MS3. lulz
Still kinda high numbers, must be those liberaleuro dynos :-P
2007-Mazdaspeed 6
 Old 12-18-2011, 02:59 PM   #8
bmylez's Avatar
Groans: 31
What is that sharp turn in the graph at 3800 rpm?
So you are looking for maybe 375whp? A manifold might help with that, but you also need to push more boost. 18 is nothing.
 Old 12-18-2011, 03:14 PM   #9
SIXual Panda's Avatar
Posts: 2,363   (View Stats)
Groans: 56
um.... dumb question. but do you have an aftermarket fuel pump or fuel pump internals??
I envy your ass raping.
 Old 12-18-2011, 03:14 PM   #10
theschrum's Avatar
Posts: 1,031   (View Stats)
Steedspeed FTW! Tubular will eventually crack. I sold my DNP to get a Steedspeed.
http://www.mazdaspeedforum.org/forum/foru...markers-99248/
Edit: noticed you are not VIP. Link is to my extra Steedspeed mani that I have for sale. PM me if interested.
dougefresh_ likes this.
08 Speed 3|SOLD
 Old 12-18-2011, 03:20 PM   #11
theschrum's Avatar
The OBX has an IHI flange, not K04. It will not work unless you get the correct flange welded on.
08 Speed 3|SOLD
 Old 12-18-2011, 03:25 PM   #12
AXELATNO's Avatar
The GT28 full boost at 3800rpm. I run now at 19.5-20PSI. Not more because I keep the MAP sensor stock and my boost limit is at 21.5psi and fuel cut at 22.5psi.
What I try to found is dyno sheet with DNP or steedspeed manifold to evaluate if this is a good move for the price.
ex.: stock turbo stock manifold VS stock turbo and aftermarket manifold
CPe fuel pump
Last edited by AXELATNO; 12-18-2011 at 03:25 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to AXELATNO For This Useful Post:
Broxer (12-19-2011), SIXual Panda (12-18-2011)
 Old 12-18-2011, 03:26 PM   #13
theschrum's Avatar
CPe fuel pump
Full boost at 3800rpm? Something doesn't sound right. I usually hit 19lbs around 3100 rpm with a GT2871.
ms3destroyer likes this.
08 Speed 3|SOLD
 Old 12-18-2011, 03:38 PM   #14
AXELATNO's Avatar
Maybe something can be improve to full boost earlier, but I'm dealing with the full boost after 3500rpm. I'm stock for piston, rod, connecting rod. At more high rpm I have less inertia and less chance to break something.
The boost is set 18psi last time but this is not the max for the turbo is only the psi I set for the run.
Thanks for all your answer and comments but if you know other manifold brand please post info
 Old 12-18-2011, 03:38 PM   #15
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
hmm 347WHP, not trying to insult your intellegience or anything but those are very high numbers for the mods you state, especially only being on an ots tune. quite possibly to get those high numbers wonder if maybe they did not use the proper correction factor for the wheels being off.
but anyway not hating haha just curious.
for manifolds id say a pg mani, care though since if you have a tmic one of the runners come dangerously close to the top boost tube.
 Old 12-18-2011, 03:45 PM   #16
Groans: 56
lol^ pg..
i also switched from a DNP to a steedspeed.
 Old 12-18-2011, 03:57 PM   #17
AXELATNO's Avatar
The Cobb MAP is modified by myself except timming. I Have also CX racing FMIC with custom 2.25'' inlet piping and aftermarket air intake (CPe core I used with HKS filter), Cpe turbo inlet.
But the subject of the thread is to found the best manifold for the best price.
For PG I have some bad experiences with this vendor
 Old 12-18-2011, 04:09 PM   #18
2zz mr-s
dooderek's Avatar
Groans: 239
all the manifolds do what they are designed to do. get a tubular and your set. dnp's and pg's have been known to crack with a bigger turbo. if you dont want to modify your stock turbo mount or weld jigs onto the flanges for piece of mind. personally ive never had any issues with my pg cracking and i have a BT. but its still early to tell, esp since i havent launched the car yet. steedspeeds are more expensive but you get what you pay for. and the manifold does not seem to have any issues integrity wise.
 Old 12-18-2011, 04:10 PM   #19
AXELATNO's Avatar
I can't send pm because I don't have 15 post
You had (2) steedspeed mani. I check maybe for the steedspeed can be bolt on the stock turbo because my GT2871 is bolt on the stock manifold using internal WG (ATP kit). Is it the one you have in sale. Please send me in PM info and price Thanks
 Old 12-19-2011, 04:09 PM   #20
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
I sold my DNP when going bt and went w/ a divided SS mani. FLow is great, but durabilty was a huge issue for me. $200 more not to worry about cracks, welding, etc... def worth it imo. I'm not familiar w/ the cheapo one, but SS manis are the only ones I know of that do not require bracing, etc etc gl.
 Old 12-19-2011, 04:23 PM   #21
EL F00LI0's Avatar
Posts: 703   (View Stats)
EL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the world
Seems like you are running an iwg setup....if you were ewg I'd sell you my pg mani for super cheap. But the problem is its got a crack on the collector weld and its got a 38mm wastegate tube on it too. I was going to rebuild it for my build but have chosen not to and go with a used ss mani + vband dp I found fs.
Tapatalka
2008 MAZDASPEED 3 GT
| Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP |
| Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 |
| Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip |
EL F00LI0 is offline   Reply With Quote
 Old 12-23-2011, 05:03 PM   #22
AXELATNO's Avatar
I found this evening the log of the last run of this dyno day .
Full boost at 3380rpm (not 3800 sorry for the bad info) and average boost of 17.6psi
 Old 05-06-2012, 11:57 AM   #23
Bratschist's Avatar
Posts: 79   (View Stats)
Bratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud of
sorry for bringing up an old post, but did we get to a verdict? which is better after all? steedspeed? and for those who suggested SS, do you have a link or was it custom made?
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  3. CorkSport LED light kit
  4. TWM Performance Shifter
  5. SLS Test Pipe
  6. CorkSport FMIC and SR air intake
  7. SURE Motorsport Torq R6
  8. AccessPort Stage 2+ Map
  9. QTP Electronic Exhaust Cut-Out
  10. KMD HPFP Internals Upgrade
  11. CorkSport Downpipe
Bratschist is offline   Reply With Quote
 Old 05-06-2012, 12:37 PM   #24
bmylez's Avatar
Groans: 31
There isn't really a "best" one. Look up some videos and see which sounds the best to you.
 Old 05-06-2012, 09:54 PM   #25
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
Let Me Google That For You.....
Lazy......
______________________
Built By NATOR
Tons of Ricer Mods
The Following User Says NO Thank You to 09Speed3Z For This Un-useful Post:
Bratschist (05-07-2012)
 Old 05-07-2012, 11:25 PM   #26
Bratschist's Avatar
wow, let me reiterate that because maybe you cant understand English. I have no interest in searching info on steedspeed because I know it. Also, since the thread it about steedspeed and throughout the post no one has mentioned the best results, I want to know what conclusion they arrived HERE, not on google. Also, I have no interest in knowing where to find steedspeed, although it should be clear, since I asked links for SS (stainless steel) manifolds that were mentioned here. I know a bunch of manifolds for our car, but none of them are SS (stainless steel), which is why I asked.
Ass........
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  5. SLS Test Pipe
 Old 05-09-2012, 05:10 AM   #27
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
DNP,PG, CPE, and Full Race are all SS manifolds
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-09-2012, 01:11 PM   #28
Bratschist's Avatar
Thanks smoogs12,
somehow though, from this post i had the impression that dnp isn't SS
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  5. SLS Test Pipe
The Following User Says Thank You to Bratschist For This Useful Post:
dougefresh_ (05-09-2012)
 Old 05-09-2012, 01:26 PM   #29
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
Thanks smoogs12,
I'm guessing that in his post, he meant he went from DNP to a SteedSpeed (SS).
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
The Following User Says Thank You to skeurton For This Useful Post:
 Old 05-09-2012, 02:04 PM   #30
^That is correct. DNP is SS, but it's not as sturdy as the SS mani, and therefor requires bracing. That alone is reason to go with a SS mani imho.
The Following User Says Thank You to dougefresh_ For This Useful Post:
skeurton (05-09-2012)
steedspeed manifold mazda2011 2010 MS3 - Engine, Transmission & Driveline 8 10-24-2011 03:59 AM
Steedspeed Exhaust Manifold? Abilor MazdaSpeed 3 - Engine, Transmission & Driveline 14 09-17-2011 08:37 PM
steedspeed manifold ebay ms3boost MazdaSpeed 3/6 - Turbo Induction 4 05-25-2009 02:31 PM
Page generated in 0.47178 seconds with 32 queries
