![]() Join Date: Aug 2009
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score My first post in the forum (sorry if somes grammatical mistake French is my first language) I have a Speed 3 1st gen with GT2871R, CPe DP catted + racing beat catback. I'm using the stock turbo manifold. I try to found somes info for the best manifold for the price. We can found OBX at 250$ and steedspeed at 750$ and between DNP at approx 565$. If you know other brand please give me info What is your suggestion, somes people have one of this manifold coupled with the GT2871R. At wich RPM the best increase power Thanks Last edited by AXELATNO; 12-18-2011 at 03:12 PM. |
![]() Join Date: Jul 2010 Location: Bayonne, NJ
Rep Power: 1439 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,348
Groans: 267
| Not Ranked : 0 score obx is cheap stuff, idk if i would trust fitment dnp is sweet because its tubular so air flow is nice, but they can crack at the welds over time. (you can also get one from protege garage) steedspeed is a cast manifold and will last forever and still flow smoother than stock all are good options, all will net you more power.
__________________ 2006 LPM MS6 GT (totaled) 0-60 mph : 4.2 second (as per DH) 12.83 @ ???MPH 1.67 60ft 2002 Miata Se (convertible whore) |
Groans: 31
| Not Ranked : 0 score Honestly, are you looking to absolutely max out your turbo? A manifold will give you some power, but if you run a methanol injection system and get a really good ECU tune, it would be good enough. Steedspeed manifolds are awesome, but I just want to make sure you realize, you won't make a ton more power with the 2871. There is a guy with stock manifold *and* catback exhaust making about 400 hp at the wheels with a gt3076. If he were to run ehtanol or methanol, he would make even more. Just depends on if you want to max out your turbo or not.
(Thread Starter) | Not Ranked : 0 score My last dyno run 347WHP at 18psi, no timming advance ajustment. AFR at 12:1 at WOT. No water met in my futur project. But I think the stock manifold don't have the best design to have the best exhaust flow to push the turbine. You know other manifold brand ?? Steedsped look great but the price is great too |
![]() Join Date: Apr 2011 Location: Decatur, Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
Groaned at 8 Times in 7 Posts
__________________ 2007-Mazdaspeed 6 BNRSIII~all supportings Zoom Zoom Boom part out. | |
(Thread Starter) | Not Ranked : 0 score Below the dyno sheet. First run and run five. For the run 3 and 4 I lean the mix up to 12.5:1 and return to 12:1. Base MAP Cobb 1.08 stg2 with fuel tab correction by me. Working in Load target logic. Contol with EBC Greddy type S Last edited by AXELATNO; 12-18-2011 at 02:07 PM. |
| The Following User Says Thank You to AXELATNO For This Useful Post: | Fail_6 (03-29-2014) |
| Not Ranked : 0 score ohh missed the part where you were a MS3. lulz Still kinda high numbers, must be those liberaleuro dynos :-P
Groans: 31
| Not Ranked : 0 score What is that sharp turn in the graph at 3800 rpm? So you are looking for maybe 375whp? A manifold might help with that, but you also need to push more boost. 18 is nothing.
![]() Join Date: Nov 2010 Location: Lancaster, PA
Rep Power: 1111 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,516
Groans: 56
| Not Ranked : 0 score um.... dumb question. but do you have an aftermarket fuel pump or fuel pump internals?? |
![]() Join Date: Dec 2008 Location: VA Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 930
| Not Ranked : 0 score Steedspeed FTW! Tubular will eventually crack. I sold my DNP to get a Steedspeed. http://www.mazdaspeedforum.org/forum/foru...markers-99248/ Edit: noticed you are not VIP. Link is to my extra Steedspeed mani that I have for sale. PM me if interested.
__________________ 06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block... 08 Speed 3|SOLD Last edited by theschrum; 12-18-2011 at 03:24 PM. Reason: add info |
| Not Ranked : 0 score The OBX has an IHI flange, not K04. It will not work unless you get the correct flange welded on.
__________________ 06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block... 08 Speed 3|SOLD |
What I try to found is dyno sheet with DNP or steedspeed manifold to evaluate if this is a good move for the price. ex.: stock turbo stock manifold VS stock turbo and aftermarket manifold CPe fuel pump Last edited by AXELATNO; 12-18-2011 at 03:25 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 2 Users Say Thank You to AXELATNO For This Useful Post: | Broxer (12-19-2011), SIXual Panda (12-18-2011) |
Full boost at 3800rpm? Something doesn't sound right. I usually hit 19lbs around 3100 rpm with a GT2871.
__________________ 06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block... 08 Speed 3|SOLD | |
The boost is set 18psi last time but this is not the max for the turbo is only the psi I set for the run. Thanks for all your answer and comments but if you know other manifold brand please post info Last edited by AXELATNO; 12-18-2011 at 06:28 PM. | |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
| Not Ranked : 0 score hmm 347WHP, not trying to insult your intellegience or anything but those are very high numbers for the mods you state, especially only being on an ots tune. quite possibly to get those high numbers wonder if maybe they did not use the proper correction factor for the wheels being off. but anyway not hating haha just curious. for manifolds id say a pg mani, care though since if you have a tmic one of the runners come dangerously close to the top boost tube.
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
Groans: 56
| Not Ranked : 0 score lol^ pg.. i also switched from a DNP to a steedspeed. |
But the subject of the thread is to found the best manifold for the best price. For PG I have some bad experiences with this vendor | |
Groans: 239
| Not Ranked : 0 score all the manifolds do what they are designed to do. get a tubular and your set. dnp's and pg's have been known to crack with a bigger turbo. if you dont want to modify your stock turbo mount or weld jigs onto the flanges for piece of mind. personally ive never had any issues with my pg cracking and i have a BT. but its still early to tell, esp since i havent launched the car yet. steedspeeds are more expensive but you get what you pay for. and the manifold does not seem to have any issues integrity wise.
![]() | | #19 | ![]() |
You had (2) steedspeed mani. I check maybe for the steedspeed can be bolt on the stock turbo because my GT2871 is bolt on the stock manifold using internal WG (ATP kit). Is it the one you have in sale. Please send me in PM info and price Thanks | |
![]() | | #20 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
| Not Ranked : 0 score I sold my DNP when going bt and went w/ a divided SS mani. FLow is great, but durabilty was a huge issue for me. $200 more not to worry about cracks, welding, etc... def worth it imo. I'm not familiar w/ the cheapo one, but SS manis are the only ones I know of that do not require bracing, etc etc gl.
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
![]() | | #21 | ![]() |
![]() Join Date: Jan 2010 Location: Ladera Ranch, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 91
| Not Ranked : 0 score Seems like you are running an iwg setup....if you were ewg I'd sell you my pg mani for super cheap. But the problem is its got a crack on the collector weld and its got a 38mm wastegate tube on it too. I was going to rebuild it for my build but have chosen not to and go with a used ss mani + vband dp I found fs. Tapatalka
__________________ 2008 MAZDASPEED 3 GT | Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP | | Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 | | Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip | |
![]() | | #22 | ![]() |
Full boost at 3380rpm (not 3800 sorry for the bad info) and average boost of 17.6psi Last edited by AXELATNO; 12-23-2011 at 05:38 PM. | |
![]() | | #23 | ![]() |
![]() Join Date: Sep 2011 Location: SCRANTON
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score sorry for bringing up an old post, but did we get to a verdict? which is better after all? steedspeed? and for those who suggested SS, do you have a link or was it custom made?
__________________ Upgrades so far:
![]() | | #24 | ![]() |
Groans: 31
| Not Ranked : 0 score There isn't really a "best" one. Look up some videos and see which sounds the best to you.
![]() | | #25 | ![]() |
| Robust Mongoloid ![]() Join Date: Aug 2009 Location: South Charlotte, NC
Rep Power: 6481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,137
Groans: 399
__________________ ______________________ Built By NATOR Tons of Ricer Mods
| The Following User Says NO Thank You to 09Speed3Z For This Un-useful Post: | Bratschist (05-07-2012) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Ass........
![]() | | #27 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
| Not Ranked : 0 score DNP,PG, CPE, and Full Race are all SS manifolds
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts |
![]() | | #28 | ![]() |
somehow though, from this post i had the impression that dnp isn't SS
| The Following User Says Thank You to Bratschist For This Useful Post: | dougefresh_ (05-09-2012) |
![]() | | #29 | ![]() |
![]() Join Date: Mar 2011 Location: Hampton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,760
| Not Ranked : 0 score I'm guessing that in his post, he meant he went from DNP to a SteedSpeed (SS).
__________________ 2011 MAZDASPEED 3 BNR: 352 hp / 342 ft-lbs K04: 296 hp / 343 ft-lbs BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges |
| The Following User Says Thank You to skeurton For This Useful Post: | dougefresh_ (05-09-2012) |
![]() | | #30 | ![]() |
| Not Ranked : 0 score ^That is correct. DNP is SS, but it's not as sturdy as the SS mani, and therefor requires bracing. That alone is reason to go with a SS mani imho.
| The Following User Says Thank You to dougefresh_ For This Useful Post: | skeurton (05-09-2012) |
| steedspeed manifold | mazda2011 | 2010 MS3 - Engine, Transmission & Driveline | 8 | 10-24-2011 03:59 AM |
| Steedspeed Exhaust Manifold? | Abilor | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 09-17-2011 08:37 PM |
| steedspeed manifold ebay | ms3boost | MazdaSpeed 3/6 - Turbo Induction | 4 | 05-25-2009 02:31 PM |
