  • 1 Post By JDMCRX
  • 1 Post By JDMCRX
 Old 05-14-2014, 06:57 AM   #1
JDMCRX's Avatar
Posts: 128   (View Stats)
JDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond repute
Groaned at 18 Times in 6 Posts
Default GT3071R MS6 Daily Driver Build
Hey guys thought i would post it up doing a customers/friends MS6.
GT3071R
CPE HPFP
Ebay Down Pipe with IMR modded 02 Housing
Magnaflow Exhaust for now
CPE top mount
Cobb Access Port
AEM Intake.
Stock turbo is smoking pretty bad after 180,000km so he opted for a GT30.
I did some heavy reconstruction of the 02 housings, as alot of the builds on here i notice do not modify or check the 02 hosuings. The housings are a crappy fit on the stock K04 from all the DP i have seen. The ebay 02 housing was over 1/2" in the turbine discharge side and on the wastegate side the flange pertruded over 1/4" at the flapper witch creats alot of turbulance and does not allow the exhaust to flow intern on both aspects slows spool times and power and raisies EGT temps !!
Some pics of the car
This is the stock ebay flange style 02 housing flange sticking in the turbine track and wastegate path.
Some pre heating and welding to build up the housing for the port work and proper gasket surface area!
Area after welding needing porting you can see the amount that has to be removed.
End results of the work
Turbo is all back together , the housing reshaping and porting finished.
Turbo is dropped into the MS6 suprised how it all went together so well so far.
SpeedLife likes this.
JDMCRX is offline   Reply With Quote
The Following 7 Users Say Thank You to JDMCRX For This Useful Post:
802MS3 (06-18-2014), Hush (05-27-2014), impossible (05-21-2014), Mazdazilla6 (05-27-2014), Mistersix (06-22-2014), Poohster (05-21-2014), SpeedLife (05-21-2014)
 Old 05-16-2014, 07:05 AM   #2
JDMCRX's Avatar
more progress the turbo is installed and now just need to install the intercooler and figure out where i am going to put the wastegate vacum soruce nipple. Also installing a CPE HPFP
The Following User Says Thank You to JDMCRX For This Useful Post:
 Old 05-21-2014, 08:06 AM   #3
SpeedLife's Avatar
Posts: 890   (View Stats)
SpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the world
Looking good bro
Sent from my Pu
2013 Mazdaspeed3
Mods:Stock as shit, trading in for e92
Add me on instagram: @mario_speed3
SpeedLife is offline   Reply With Quote
 Old 05-27-2014, 04:07 PM   #4
That's a very clean port job! My turbo is past it's last leg and is crawling with its hands now
 Old 05-28-2014, 07:30 PM   #5
JDMCRX's Avatar
Thanks guys customer is waiting on his cobb waste gate silnoid and new cobb to show up then he can turn it up !
 Old 06-18-2014, 07:29 AM   #6
JDMCRX's Avatar
Well guys the car is being tuned via freak tune over email and the car is running realy good. I will take some vids soon
GT3071R EWG build Goodrich27 2010 MS3 - Big Turbo Builds 26 07-20-2014 03:15 PM
GT3071r Build Problems 48-f1 MazdaSpeed 3/6 - Big Turbo Builds 49 05-21-2012 04:22 PM
Genpu GT3071R Build w/ videos and dyno sheet JP@edgeautosport.com 2010 MS3 - Big Turbo Builds 212 03-21-2012 02:03 AM
Page generated in 0.28433 seconds with 22 queries
