 Old 11-24-2011, 09:35 AM   #1
kmac's Avatar
Posts: 1,792   (View Stats)
Originally Posted by Ckmazdaspeed3 View Post
Yeah, like freundb said, EVERYONE runs into this. U shoulda seen our initial ghetto set up. We used some thin metal piling that I could've almost crushed in my hand and two clamps. It held 16psi though lol. I just took it to a shop that welds and had them extend my hot pipe.
@kmac I've heard someone mention being closer to the turbo before, but is the difference really noticeable? Would it help tame my 2psi boost spike when I wot or remove 50 rpms from my spool up? Just curious.
It very well might . Being as close to the turbo as possible will most likely fix it it takes to long for the wg to respond at that distance. If your requesting 20 psi and the manifold reaches 20 and it goes to controller the ebcs. By the ebcs and wastegate respond It's already a couple of pounds past It's requested.
First 500whp stock block mazdaspeed3 (503whp 423wtq)
<3 Tokay.
The Following 3 Users Say Thank You to kmac For This Useful Post:
Ckmazdaspeed3 (11-24-2011), Hamilton69 (11-24-2011), rfinkle2 (11-24-2011)
grimspeed EBC question pearl_ms3 MazdaSpeed 3/6 - Big Turbo Builds 12 02-07-2011 02:06 AM
done! gt3076 samsel450r MazdaSpeed 6 - Engine, Transmission & Driveline 122 11-09-2009 04:35 PM
Page generated in 0.23447 seconds with 21 queries
