 Old 11-23-2011, 07:07 PM   #1
NycSpd3's Avatar
Posts: 56   (View Stats)
NycSpd3 is a name known to allNycSpd3 is a name known to allNycSpd3 is a name known to allNycSpd3 is a name known to allNycSpd3 is a name known to allNycSpd3 is a name known to all
Groaned at 9 Times in 7 Posts
Default gt3076 ewg w/ grimspeed ebcs
ok so after installing my gt3076 w/ewg on my spd3 ive run into a problem idk how to plug all this up into my grimspeed ebcs ive heard various different ways nd i want the most accurate way or best way possible with out killing myself. i know i should of searched but im trying to get this finished 2night all help would be hightly apperciated
ive heard u dont run vented on the top of the wastegate
please just need help
Dee
09 Mazdaspeed3 Metro Grey
TurboXS DP
HKS SSQV BOV
Cobb AP
BC Coilovers
EVO-X rims
KMD Internals
APEXI N1 custom 3in exhaust
Godspeed Core& PG pipping
Snow Performance Meth Kit Stage 2
GT3076 w/ ewg
Grimspeed EBCS
ACT clutch coming SOON
NycSpd3 is offline   Reply With Quote
The Following User Says Thank You to NycSpd3 For This Useful Post:
AzSpeedin (11-23-2011)
 Old 11-23-2011, 07:29 PM   #2
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
I think grimmspeed shows you how online in the guide. The interrupt mode instructions
Sent from my DROIDX using Tapatalk
 Old 11-23-2011, 07:32 PM   #3
NycSpd3's Avatar
the install guide online is for IWG not EWG im really bad at this dats y im asking for help b4 my spd3 goes boom boom
Dee
TurboXS DP
HKS SSQV BOV
Cobb AP
BC Coilovers
EVO-X rims
KMD Internals
GT3076 w/ ewg
Grimspeed EBCS
 Old 11-23-2011, 07:43 PM   #4
theschrum's Avatar
Posts: 1,031   (View Stats)
Run interrupt mode which is at the bottom of the manual found here
GrimmSpeed
Compressor housing, to port 3, out port 2, into bottom EWG nipple. vent top to atmosphere.
"EWG
Hook up vacuum lines. See Figure 3. Port 3 connects to a high-pressure boost source (there is
a vacuum nipple on the turbo compressor outlet). Port 2 connects to the bottom port on the
external wastegate. The factory restrictor pill should be removed for operation. It is
recommended that a plastic zip tie is used to secure vacuum lines. The electrical is plug and
play with the supplied connector."
08 Speed 3|SOLD
Last edited by theschrum; 11-23-2011 at 07:44 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-23-2011, 08:04 PM   #5
NycSpd3's Avatar
GrimmSpeed
"EWG
thanks bro i really apperciate it just 1 more question my turbo does not have a high pressure boost source nipple on my turbo where else can i get this boost source
Dee
TurboXS DP
HKS SSQV BOV
Cobb AP
BC Coilovers
EVO-X rims
KMD Internals
GT3076 w/ ewg
Grimspeed EBCS
 Old 11-23-2011, 08:19 PM   #6
kmac's Avatar
Posts: 1,792   (View Stats)
Tap your intercooler pipe
First 500whp stock block mazdaspeed3 (503whp 423wtq)
<3 Tokay.
 Old 11-23-2011, 08:37 PM   #7
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
just t off the boost source on the bpv
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
atvfreek (11-24-2011)
 Old 11-23-2011, 08:50 PM   #8
LiEast's Avatar
Posts: 582   (View Stats)
LiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the world
^^ what he said.. i think its the best boost source
2008 RED MS3 GT>>>T3 GT35R .82 A/R>>>Tial 44 EWG dumping>>>SteedSpeed T3 Mani>>>Built Motor
PERM!
LiEast is offline   Reply With Quote
 Old 11-24-2011, 05:18 AM   #9
NycSpd3's Avatar
thnks ppl i really apperciate the help my car should b up in running by this weekend, i ran into anotha prob my PG pipping does not clear enough to connect to my turbo so now i gotta customize to make this work
Dee
TurboXS DP
HKS SSQV BOV
Cobb AP
BC Coilovers
EVO-X rims
KMD Internals
GT3076 w/ ewg
Grimspeed EBCS
 Old 11-24-2011, 06:03 AM   #10
Eventually, you can get an atp quick tap also.
http://www.atpturbo.com/mm5/merchant...egory_Code=BCS
kmac (11-24-2011), MZR165 (11-24-2011), Sid3wayS (04-04-2012)
 Old 11-24-2011, 07:03 AM   #11
kmac's Avatar
Tap your hot side pipe , not off the bov. u want it as close to the turbo as possible for proper response.
<3 Tokay.
 Old 11-24-2011, 07:30 AM   #12
NycSpd3's Avatar
K just curious who has ran into dis problem my hot pipe on the I/C doea not wanna meet up with my turbo the cuppling is to short ive searched all my local shops and. Cant find anything
Dee
TurboXS DP
HKS SSQV BOV
Cobb AP
BC Coilovers
EVO-X rims
KMD Internals
GT3076 w/ ewg
Grimspeed EBCS
 Old 11-24-2011, 08:17 AM   #13
Groans: 398
Pretty much everyone with a BT... look at how long that outlet on the k04 is! You either need to find one long enough or hook 2 together. Im on my phone and can't link to it but I know several people have documented how they did it.
 Old 11-24-2011, 08:31 AM   #14
Groans: 134
Yeah, like freundb said, EVERYONE runs into this. U shoulda seen our initial ghetto set up. We used some thin metal piling that I could've almost crushed in my hand and two clamps. It held 16psi though lol. I just took it to a shop that welds and had them extend my hot pipe.
@kmac I've heard someone mention being closer to the turbo before, but is the difference really noticeable? Would it help tame my 2psi boost spike when I wot or remove 50 rpms from my spool up? Just curious.
The Following 2 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
kmac (11-24-2011), rfinkle2 (11-24-2011)
 Old 11-24-2011, 09:35 AM   #15
kmac's Avatar
It very well might . Being as close to the turbo as possible will most likely fix it it takes to long for the wg to respond at that distance. If your requesting 20 psi and the manifold reaches 20 and it goes to controller the ebcs. By the ebcs and wastegate respond It's already a couple of pounds past It's requested.
<3 Tokay.
The Following 3 Users Say Thank You to kmac For This Useful Post:
Ckmazdaspeed3 (11-24-2011), Hamilton69 (11-24-2011), rfinkle2 (11-24-2011)
 Old 11-24-2011, 08:44 AM   #16
NycSpd3's Avatar
Yea i figured dat was my last option
Dee
TurboXS DP
HKS SSQV BOV
Cobb AP
BC Coilovers
EVO-X rims
KMD Internals
GT3076 w/ ewg
Grimspeed EBCS
grimspeed EBC question pearl_ms3 MazdaSpeed 3/6 - Big Turbo Builds 12 02-07-2011 02:06 AM
done! gt3076 samsel450r MazdaSpeed 6 - Engine, Transmission & Driveline 122 11-09-2009 04:35 PM
Page generated in 0.36061 seconds with 26 queries
