 Old 03-05-2012, 11:55 PM   #1
Sickspeed3's Avatar
Posts: 71   (View Stats)
Sickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of light
Groaned at 75 Times in 8 Posts
Default Gt3076 help.please
I would first off like to say this may be a stupid question to ask but, I have a 2008 ms3 fully bolted with a gt3076. I have the atp turbo kit, but the question is on my tu rbo theres not a place to run a vacuum line on the turbo. Im also running ewg so im tryinb to see the best places to run a vac line to and from for a boost source and good vac source.
Sickspeed3 is offline   Reply With Quote
 Old 03-06-2012, 12:08 AM   #2
leon78's Avatar
Posts: 2,595   (View Stats)
GT Series Turbo Questions.
look into that here
2013 Scion FR-S (Whiteout)
Less parking more racing
 Old 03-06-2012, 12:11 AM   #3
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
ATP states to run the line from as close to the turbo as possible so do do that you have to buy a boost a tap and drill a hole in a coupler then put the boost source there. i personally would just run off a boost source like your bpv line and run the vacuum line from there, it will work fine.
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
done! gt3076 samsel450r MazdaSpeed 6 - Engine, Transmission & Driveline 122 11-09-2009 04:35 PM
GT3076 owners please help 18psiWhiteMS3 MazdaSpeed 3/6 - Turbo Induction 5 10-22-2009 09:37 AM
Page generated in 0.24069 seconds with 22 queries
