 Old 11-29-2011, 08:51 AM   #1
NycSpd3's Avatar
Posts: 56   (View Stats)
NycSpd3 is a name known to allNycSpd3 is a name known to allNycSpd3 is a name known to allNycSpd3 is a name known to allNycSpd3 is a name known to allNycSpd3 is a name known to all
Groaned at 9 Times in 7 Posts
If you were to put this on the turbo: Oil Return Flange with integrated 5/8" barb For GT15 Through GT35R : atpturbo.com
Cut this line to the right size: Hi Temp Rubber/Silicone Oil Drain Hose - 5/8" (-10 AN equivalent ID) : atpturbo.com
Then put this on the block: Oil Return Flange with integrated -10 Flare for GT15 Through GT35R : atpturbo.com along with Russell 624100 Russell Twist-Lok AN Hose Ends
No way that can't fit.
That is a minimum of 12", which I'm pretty sure is too long...
edit: just looked and you're right, they say to use 12"....which is weird because some people complain of it being too long
Ordered the fitting u recommended car is up nd running now thanks every1 who helpedd out
Dee
09 Mazdaspeed3 Metro Grey
TurboXS DP
HKS SSQV BOV
Cobb AP
BC Coilovers
EVO-X rims
KMD Internals
APEXI N1 custom 3in exhaust
Godspeed Core& PG pipping
Snow Performance Meth Kit Stage 2
GT3076 w/ ewg
Grimspeed EBCS
ACT clutch coming SOON
NycSpd3 is offline   Reply With Quote
Custom return Line BrianZX10R Mazdaspeed3/6 General Discussion 9 11-06-2010 10:16 AM
CDFP return line 06Speed6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 15 01-14-2010 12:13 PM
Turbo Oil Return Line 11cruzito11 MazdaSpeed 3/6 - Turbo Induction 21 09-27-2009 09:15 PM
Page generated in 0.23610 seconds with 21 queries
