 Old 11-27-2011, 07:23 PM   #1
NycSpd3's Avatar
Posts: 56   (View Stats)
NycSpd3 is a name known to allNycSpd3 is a name known to allNycSpd3 is a name known to allNycSpd3 is a name known to allNycSpd3 is a name known to allNycSpd3 is a name known to all
Groaned at 9 Times in 7 Posts
Default GT3076 w/ ewg return line problem
Im havin some problems wid my return line its not clearing the wastegate how have most of u guyz ran ur setups in running this on a stock manifold please i needa get my car on the road... I kno this is a noob thread ive tried so many things nd it dnt clear
Dee
09 Mazdaspeed3 Metro Grey
TurboXS DP
HKS SSQV BOV
Cobb AP
BC Coilovers
EVO-X rims
KMD Internals
APEXI N1 custom 3in exhaust
Godspeed Core& PG pipping
Snow Performance Meth Kit Stage 2
GT3076 w/ ewg
Grimspeed EBCS
ACT clutch coming SOON
NycSpd3 is offline   Reply With Quote
 Old 11-27-2011, 07:39 PM   #2
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Need a pic man.
2007 CTS-V - Trying to sell
rfinkle2 (11-29-2011)
 Old 11-27-2011, 07:41 PM   #3
NycSpd3's Avatar
Im just curious as far as wat kind of return line do most of u use
Dee
TurboXS DP
HKS SSQV BOV
Cobb AP
BC Coilovers
EVO-X rims
KMD Internals
GT3076 w/ ewg
Grimspeed EBCS
 Old 11-27-2011, 07:49 PM   #4
bmylez's Avatar
Groans: 31
What return line??? Gotta be specific.
 Old 11-27-2011, 07:50 PM   #5
NycSpd3's Avatar
The oil return line dat comes off the turbo
Dee
TurboXS DP
HKS SSQV BOV
Cobb AP
BC Coilovers
EVO-X rims
KMD Internals
GT3076 w/ ewg
Grimspeed EBCS
 Old 11-27-2011, 07:52 PM   #6
bmylez's Avatar
Groans: 31
So you're saying the return line that ATP provided doesn't fit? I'm confused because the ewg points straight down off of the turbine housing. It shouldn't really be that close to the return line. A picture would REALLY help. Hell, draw something if you have to.
 Old 11-27-2011, 08:00 PM   #7
NycSpd3's Avatar
I bought the kit used off of a fellow member i dnt have the orignal line dat come with the kit
Dee
TurboXS DP
HKS SSQV BOV
Cobb AP
BC Coilovers
EVO-X rims
KMD Internals
GT3076 w/ ewg
Grimspeed EBCS
 Old 11-27-2011, 08:02 PM   #8
MarineMazda's Avatar
Posts: 354   (View Stats)
MarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the world
Yes this is boggling my mind as well... It should not even come close with the ATP supplied Oil return line.
Scratch that.... Posted your comment just before mine
MarineMazda is offline   Reply With Quote
The Following User Says Thank You to MarineMazda For This Useful Post:
 Old 11-27-2011, 08:02 PM   #9
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
Groaned at 30 Times in 25 Posts
Sounds like you need a fitting onto the turbo and a stainless steel braided -10 line to block (old drain is)
if you didnt get it from the member you bought it from.
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
The Following User Says Thank You to J-Liss For This Useful Post:
 Old 11-27-2011, 08:09 PM   #10
bmylez's Avatar
Groans: 31
If you don't have the ATP drain, we REALLY need a picture then. The oil drain should seriously be at least a couple INCHES away from the ewg.
 Old 11-27-2011, 08:10 PM   #11
NycSpd3's Avatar
Can some1 send me a pic of wat i have to get or a link
Dee
TurboXS DP
HKS SSQV BOV
Cobb AP
BC Coilovers
EVO-X rims
KMD Internals
GT3076 w/ ewg
Grimspeed EBCS
 Old 11-27-2011, 08:15 PM   #12
Link for Return Flange
Oil Return/Drain Fitting for Mazdaspeed3 : atpturbo.com
Link for Line
Oil Return Line -10 - 12" ST/ST : atpturbo.com
 Old 11-27-2011, 08:17 PM   #13
bmylez's Avatar
Groans: 31
If you were to put this on the turbo: Oil Return Flange with integrated 5/8" barb For GT15 Through GT35R : atpturbo.com
Cut this line to the right size: Hi Temp Rubber/Silicone Oil Drain Hose - 5/8" (-10 AN equivalent ID) : atpturbo.com
Then put this on the block: Oil Return Flange with integrated -10 Flare for GT15 Through GT35R : atpturbo.com along with http://www.jegs.com/i/Russell/799/624100/10002/-1
No way that can't fit.
Originally Posted by MarineMazda View Post
That is a minimum of 12", which I'm pretty sure is too long...
edit: just looked and you're right, they say to use 12"....which is weird because some people complain of it being too long
Last edited by bmylez; 11-27-2011 at 08:18 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to bmylez For This Useful Post:
MarineMazda (11-27-2011), rfinkle2 (11-29-2011)
 Old 11-29-2011, 08:51 AM   #14
NycSpd3's Avatar
Then put this on the block: Oil Return Flange with integrated -10 Flare for GT15 Through GT35R : atpturbo.com along with Russell 624100 Russell Twist-Lok AN Hose Ends
Ordered the fitting u recommended car is up nd running now thanks every1 who helpedd out
Dee
TurboXS DP
HKS SSQV BOV
Cobb AP
BC Coilovers
EVO-X rims
KMD Internals
GT3076 w/ ewg
Grimspeed EBCS
 Old 11-27-2011, 08:20 PM   #15
Makes sense seeing My oil return is only 16" long and that is a Top Mount set up
You can custom order Length as well
 Old 11-27-2011, 08:24 PM   #16
bmylez's Avatar
Groans: 31
Custom Oil Return Line Built to Order #10 (-10) size steel braided : atpturbo.com
Minimum of 10". I think if you got 11", it would be perfect, though I can't say for sure. Get a straight end and a 45* end. 45* goes to the block.
Custom return Line BrianZX10R Mazdaspeed3/6 General Discussion 9 11-06-2010 10:16 AM
CDFP return line 06Speed6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 15 01-14-2010 12:13 PM
Turbo Oil Return Line 11cruzito11 MazdaSpeed 3/6 - Turbo Induction 21 09-27-2009 09:15 PM
Page generated in 0.34619 seconds with 23 queries
