 Old 03-20-2010, 04:41 PM   #41
zx2man's Avatar
Posts: 1,356   (View Stats)
zx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the world
[QUOTE=Dano2010;459033]There is a load cap in the Mazda ECU that Cobb hasn't been able to get past yet. Yeah they can do it with just about any other car but not ours. I think their ProTuners tune around the cap to a certain extent but can't get over 400 IIRC. I am running with the mods in my sig and I had to work around the load cap to maintain consistant AFR and boost. The cap doesn't appear to effect everyone but the numbers are signifiant.
Awww I did not know... Thank you very much...Thats good info
zx2man is offline   Reply With Quote
 Old 03-21-2010, 02:23 AM   #42
mattizle14's Avatar
Posts: 96   (View Stats)
mattizle14 is a jewel in the roughmattizle14 is a jewel in the roughmattizle14 is a jewel in the roughmattizle14 is a jewel in the rough
yeah me too...its kind of disappointing cobb couldnt get around the throttle problem and cap
2008.5 Mazdaspeed 3 GT...Fully Forged Block...Ported Heads...Wiseco Forged Pistons/Pauter Forged Rods...COBB SRI...COBB DP...COBB AP...PnP Fuel Pump Internals...Cometic Head Gasket...ARP Head Studs...Denso Iridium HR:8...StreetUnit Rear Motor Mount...ACT 6 Puck Sprung Clutch Kit...Aluminum Flywheel...
mattizle14 is offline   Reply With Quote
 Old 03-21-2010, 11:28 AM   #43
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
I will be bolting on a t4 t67, which is essentially a 3582 with journal bearings soon, I'll be sure to post speedo vids here when everything is situated
The Following 2 Users Say Thank You to madvillain For This Useful Post:
Docnox (03-23-2010), gsrtype1 (03-23-2010)
 Old 03-21-2010, 12:19 PM   #44
mattizle14's Avatar
sweet cant wait to see stats
 Old 03-21-2010, 05:02 PM   #45
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Are you using the AP or a SB as a tuning solution?
Sounds like an interesting project and if you are using an AP I would love to know if you already hit the cap or will with the BT.
 Old 03-22-2010, 01:45 PM   #46
madvillain's Avatar
Groans: 78
Im using the AP. I'm not going for big power right now, just something safe.
 Old 03-22-2010, 03:21 PM   #47
mattizle14's Avatar
im wanting/needing to go to sb especially with the results ive seen...unless somehow cobb pulls a miracle out and can break through their barrier
 Old 03-22-2010, 10:23 PM   #48
Trail of Fail
Dano's Avatar
Are you hitting a load cap?
It is evidenced by a logged flat-line load , starting just after WOT holding til around 5.5k then falling. When in actuality your load continues to climb [like a torque curve] but the ECU doesn't calculate it above a certain point. For me it was 195-197ish and held there from 3.5K to 5.5K IIRC. When this happens fueling becomes a major issue above 18PSI.
SB and flashes...its a no brainer in your situtation!
Cobb has known about this for a long time now and haven't fixed it yet so why should we think they will. they have had over 3 years for Gods sake!!!!!
Last edited by Dano; 03-22-2010 at 10:23 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-23-2010, 09:06 AM   #49
mattizle14's Avatar
they have failed me
 Old 03-23-2010, 09:20 AM   #50
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
you don't need a 650hp capable turbo to break in the 400s. So srsly, why the GT35R? Other than lag lag lag....
07 MS3
The original Genpoo Hater
 Old 03-23-2010, 09:26 AM   #51
mattizle14's Avatar
im going big yeah i kno...but i want to go big so that i have it...its more of a ill have it later if somethin new comes out for the ms3 later on down the road that will make it more capable of hp in the future
 Old 03-23-2010, 09:30 AM   #52
Will fuck up ur day
Chimmike's Avatar
Groans: 433
so you'll make do with big lag now for possible 500whp later? A 3076R will make more power now than you can probably do with the motor anyways.......
07 MS3
 Old 03-23-2010, 09:31 AM   #53
mattizle14's Avatar
not that much lag...boost brake all the way hahahahahaha
 Old 03-23-2010, 11:14 AM   #54
madvillain's Avatar
Groans: 78
I actually like the later spool. A lot of people do not agree or understand, but I like the feel that an oversized turbo provides. If I decide that I don't like it down the road, I can always switch it out now that I have a proper t4 manifold and vband downpipe that is more universal than that fail mazda flange.
 Old 03-23-2010, 12:43 PM   #55
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
The lag really isn't all that bad, sure you don't hit full boost until ~4K, but I have a very usable 10 psi around 3K and that thousand rpms passes by VERY quickly...
The Following 4 Users Say Thank You to SSinstaller For This Useful Post:
gsrtype1 (03-23-2010), madvillain (03-23-2010), MarkyMark (03-24-2010), mattizle14 (03-23-2010)
 Old 03-23-2010, 01:21 PM   #56
mattizle14's Avatar
see...i knew it wouldnt really matter that much...i dont care...
 Old 03-24-2010, 09:48 AM   #57
Speedkid's Avatar
Posts: 65   (View Stats)
Speedkid is just really niceSpeedkid is just really niceSpeedkid is just really niceSpeedkid is just really nice
What is the biggest turbo we can fit without getting a top mounted mani? Because i wanted a gt35r 63 a/r.
Speedkid is offline   Reply With Quote
 Old 03-24-2010, 09:51 AM   #58
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Why in the fuck would you run a GT35R at 10psi ? For fucks sake, don't even run that turbo if you're not going to run 1 bar or higher on a daily basis. Seriously. It's not even warmed up at 1 bar. Not even close it it's operating range at 10psi.
Please tell me you're running more than 10psi.
07 MS3
 Old 03-24-2010, 09:57 AM   #59
Groans: 60
Reading Comprehension > You
What I sad was that I have at least 10psi by 3000RPM, no where in my post did I say that was my peak boost. I am running off the wastegate right now, with a 1.4bar spring setup...
 Old 03-24-2010, 10:06 AM   #60
H3llfir3's Avatar
Posts: 255   (View Stats)
H3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the world
why do you guys act like theres SOOOOOOO much turbo lag with a 35R?
If you have half a skull and want to keep your car in one piece you dont floor it or begin to build boost until 3k-3,500 rpm so full boost at 4K is pretty fast aint it.
P.S. Roll racing mark when he wasnt brake boosting, his turbo would take a half a second more than my stock turbo to spool up and start raping me. Where is his magic year long lag?
2006 black Mica MS6 GT- It has tons of shit on it and it's still slow.
NATOR of Florida
H3llfir3 is offline   Reply With Quote
The Following User Says Thank You to H3llfir3 For This Useful Post:
madvillain (03-24-2010)
 Old 03-24-2010, 10:20 AM   #61
mattizle14's Avatar
i have no idea where they r getting this forever long lag...idk
 Old 03-24-2010, 10:25 AM   #62
Will fuck up ur day
Chimmike's Avatar
Groans: 433
taking a portion of my post vs. the full post = fail.
That's why I said "please tell me you're not running 10psi"
I could care less about the lag but I think there are people posting in this thread *cough*noobs*cough* who just want to run a GT35R and really have no reasons for it other than it sounds cool.
07 MS3
 Old 03-24-2010, 02:12 PM   #63
kore2000's Avatar
Posts: 448   (View Stats)
kore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the world
Groans: 90
Groaned at 69 Times in 21 Posts
Didn't you just join a month ago...
noobs..
kore2000 is offline   Reply With Quote
 Old 03-29-2010, 11:23 PM   #64
h0rsies's Avatar
Posts: 133   (View Stats)
h0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond repute
so standback for the win?
h0rsies is offline   Reply With Quote
 Old 03-30-2010, 06:52 AM   #65
Speedkid's Avatar
Yep you got that right lol.
 Old 04-07-2010, 01:04 PM   #66
mattizle14's Avatar
until cobb fixes what they r doin and get past that wall
 Old 04-07-2010, 01:19 PM   #67
dizzin9's Avatar
Posts: 1,807   (View Stats)
Groans: 77
i would LOVE to see a gt35r powered speed making 450whp... 450! i'm not asking too much right? i'm pretty sure at least 10 people here in msf are fully bolted and has a standback, so where are these 450+whp cars?????????
 Old 04-07-2010, 01:22 PM   #68
Groans: 60
Mine is on a lift with a burnt oil return line, a leaking transfer case, and a leaking timing cover/front mail seal...
$1K from now it'll be ready to tune....again...maybe?
 Old 04-07-2010, 01:57 PM   #69
Will fuck up ur day
Chimmike's Avatar
Groans: 433
noobs..
yah, cuz this is the first turbo car I've ever owned. or first car in general. tool.
I guess I can't include a 400whp 12 second street-tired 350z turbo that I built.
a 91 SE-R turbo
2001 sentra turbo I built, twice. cuz, you know. oil starvation is fun.
okay, maybe the first factory turbo car. lol.
apparently tewning is the big roadblawk. there are a few of them running turbos that are certainly capable of that power and more.
07 MS3
Last edited by Chimmike; 04-07-2010 at 01:57 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-07-2010, 02:10 PM   #70
yoichi's Avatar
Posts: 557   (View Stats)
Ah man...seriously???
I feel your troubles though as mine has also been a pita since it was finished.
Good Luck man
2003 E39 ///M5
yoichi is offline   Reply With Quote
 Old 04-07-2010, 04:49 PM   #71
Trail of Fail
Dano's Avatar
I predect it will never happen they are on to other things. Moving to Austin. GT-R, Civics etc.
The "wall" breakthru is always around the corner for Cobb....trouble is where is that corner?
but hell I have been wrong before. LOL
 Old 04-07-2010, 05:06 PM   #72
kore2000's Avatar
Groans: 90
a 91 SE-R turbo
So if I can't judge you by your join date, don't use that assumption with others aswell. Everyone was a noob at one time.
Part of your original statement:
I think you are making a lot of assumptions there huh? I just thought it would be nice to point out the hypocrisy in your statement
Also, technically, since you haven't owned a MS turbo, you are still a noob.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/gt35r-51638/
BOOST CREEP + IWG ? Mazda MPS Owners Club This thread Refback 01-14-2015 12:46 PM
Mazda MPS Owners Club • View topic - BOOST CREEP + IWG This thread Refback 04-02-2011 01:45 AM
GT35r Spool jhershorin MazdaSpeed 3/6 - Turbo Induction 25 02-21-2013 07:13 PM
GT35R housing. Right? SPD6Tuner MazdaSpeed 3/6 - Turbo Induction 2 06-24-2009 10:49 PM
gt35r: Should I do it? madvillain Mazdaspeed3/6 General Discussion 38 05-26-2009 11:43 AM
Page generated in 0.49728 seconds with 31 queries
