 Old 03-20-2010, 01:36 AM   #1
mattizle14's Avatar
Posts: 96   (View Stats)
mattizle14 is a jewel in the roughmattizle14 is a jewel in the roughmattizle14 is a jewel in the roughmattizle14 is a jewel in the rough
Default GT35R
I am wanting to get the GT35R and put that in along with a tubular ex mani...from what you can see from my sig what should i expect to gain from this and what else might i need to get? learning in process
2008.5 Mazdaspeed 3 GT...Fully Forged Block...Ported Heads...Wiseco Forged Pistons/Pauter Forged Rods...COBB SRI...COBB DP...COBB AP...PnP Fuel Pump Internals...Cometic Head Gasket...ARP Head Studs...Denso Iridium HR:8...StreetUnit Rear Motor Mount...ACT 6 Puck Sprung Clutch Kit...Aluminum Flywheel...
mattizle14 is offline   Reply With Quote
 Old 03-20-2010, 04:35 AM   #2
holeinmypocket's Avatar
Posts: 1,129   (View Stats)
holeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the world
Neutral  :  -1 score
the search button is your friend
holeinmypocket is offline   Reply With Quote
The Following User Says Thank You to holeinmypocket For This Useful Post:
ganque (03-23-2010)
The Following User Says NO Thank You to holeinmypocket For This Un-useful Post:
 Old 03-20-2010, 05:28 AM   #3
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Build your block. And you wont make power with a big turbo without the standback and flashes. Even with a 35r on a cobb ap you wont break into the 400s.
 Old 03-20-2010, 07:34 AM   #4
mattizle14's Avatar
i already have my engine built...just wondering what it will take to get it to the 400s...anything else i will be needing?
 Old 03-20-2010, 07:50 AM   #5
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
that turbo is big.
i'm not speaking from experience, so please take this post with a grain of salt.
but i think you will have turbo lag.
our cars can't wind up the engine into rpms high enough to fully take advantage of a gt35.
OR A 40 FOR THAT MATTER, mark...
MarkyMark (03-20-2010)
 Old 03-20-2010, 07:55 AM   #6
cageyvet's Avatar
Posts: 715   (View Stats)
35r is not a big turbo. I'd rather run a DBB 6262 cuz you would get better spool and more power
 Old 03-20-2010, 07:56 AM   #7
mattizle14's Avatar
just wondering but what if i got one of the aluminum flywheels?
 Old 03-20-2010, 08:04 AM   #8
MarkyMark's Avatar
Posts: 1,624   (View Stats)
Groans: 62
that turbo is big.
have you owned a car with a nonfactory turbo setup?
have you built a car with a non-factory turbo setup?
have you driven a car with a non-factory turbo setup?
have you ridden in a car with non-factory turbo setup?
If you answered "no" to any of the above questions, Please cease and desist on the phail.
MarkyMark is offline   Reply With Quote
The Following 3 Users Say Thank You to MarkyMark For This Useful Post:
JefeSpeed (05-25-2010), madvillain (03-21-2010), nutsac76 (03-23-2010)
 Old 03-20-2010, 08:18 AM   #9
SneakyP86's Avatar
Posts: 1,162   (View Stats)
Damn Phailly guess you just got called out.......and bitch slapped all at the same time......possibly even got your dick knocked in the dirt.......so tell me hows that feel.
 Old 03-20-2010, 08:30 AM   #10
mattizle14's Avatar
damn such violence...i was just wondering if a aluminum flywheel would help since they help spool faster...guess this town isnt big enough for wrong ppl lol
 Old 03-20-2010, 09:23 AM   #11
SneakyP86's Avatar
That was directed at PhaillyB.........guess I should have been more specific. But I do have a Fidanza Lightweight flywheel I haven't put on that I might be willing to part with.
 Old 03-20-2010, 09:25 AM   #12
mattizle14's Avatar
i kno it was directed to him just jokin...but would it help with a spool problem though?
 Old 03-20-2010, 09:26 AM   #13
Realgib3's Avatar
Posts: 2,443   (View Stats)
If you want to stay IWG I have a brand new DCR turbo mani for cheap... Just throwin it out there
 Old 03-20-2010, 09:35 AM   #14
mattizle14's Avatar
btw i was kind of confused on this...why r so many ppl going external wgt...and what r pros/cons of ext and int
 Old 03-20-2010, 09:46 AM   #15
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
IWG= boost creep unless its ported. ATP has fixed their creep problems I beleve on the 2871/3071/3076 kits by porting the WG.
oh an some like the horrific sound an EWG gives if VTA. Buddy of mine has an LGT with a custom turbo setup and EWG-VTA. I don't like it at all and we are dumping it back into his DP this weekend.
Edit: BTW he has a spare brand new in the box Tial 38MM EWG he might part with. It's purple but still a good piece. I think he bought if from a girl LOL!
mattizle14 (03-20-2010)
 Old 03-20-2010, 09:50 AM   #16
mattizle14's Avatar
i just see ewg being sooooooo much more expensive than a regular iwg bolt on like atp
 Old 03-20-2010, 09:56 AM   #17
SneakyP86's Avatar
Well it will help with the car revving faster but not with the spooling of the turbo so much. The stock turbo spools really early between 2000-2500 rpm and can hit full boost before 3000 rpm and drops off in the higher RPM's. Something the size of the 35R probably wont even start spooling good till about 3500 rpm but will hold boost better later in the RPM's(I dont have one but from what I've seen it seems to be about right). But that can actually be a good thing if your running to redline anyways the RPM's arent gonna drop below that. Also the K04 spools so early it seems to put a strain on the rods that spooling later doesn't seem to do.
Well the early GT turbos seemed to have a problem with boost creep. But supposedly Garrett has ported the IWG more than it was which should help that problem. I myself will be going EWG in the future when as I just prefer it myself. Having the AP I believe you may have a little more boost tunability using an external wastegate in conjunction with a EBCS like either Grimmspeed or Perrin.
The Following User Says Thank You to SneakyP86 For This Useful Post:
 Old 03-20-2010, 10:01 AM   #18
Trail of Fail
Dano's Avatar
and a big PITA to route back to the DP if you don't like VTA and I'll bet you'll get tired of it real quick. I am researching a new turbo and I'll only make the jump if I can go IWG. You are on a built motor though and going bigger turbo so EWG may be your only choice. I am looking at a BNR Stage 2 or ATP 2871.
Edit: For best performance you need to route the EWG pipe downstream of the cat so again PITA.
 Old 03-20-2010, 10:03 AM   #19
mattizle14's Avatar
im wanting to go the power route...my goal by end of this year is be apart of the 400+hp group...i kno i will have to get front mount intercooler which is must with the dreaded heatsoak...and get new exhaust mani...and the turbo...which i was looking at the 35r...also on side i was wanting to get new stage 3+ clutch from spec...but thats what im looking at...what you think?
 Old 03-20-2010, 10:04 AM   #20
SneakyP86's Avatar
Well you could always put a muffler on the screamer pipe to quiet it down quite a bit before going to the trouble of routing it back into the DP. I imagine you could find several lawnmower mufflers that might work.
 Old 03-20-2010, 10:06 AM   #21
mattizle14's Avatar
i heard they r coming out with a stage 3 soon or its just bout to be out...but what ur sayin if i want high power i will have to go ewg?
 Old 03-20-2010, 10:11 AM   #22
SneakyP86's Avatar
A lot of people here lately seem to be using the ACT clutch setup here lately. Not sure if its better or not or whether people have been just getting the wrong Spec clutch or what. But here is what I do know if you get the Fidanza lightweight flywheel it will NOT work with the ACT clutch and the ACT flywheel will not work with the SPEC clutch. Spec does not make a flywheel for our cars so Fidanza is the best option. I think the Spec 3+ clutch is the right one for your setup rather than just the plain 3 as I think the + clutches give better driveability.
 Old 03-20-2010, 10:15 AM   #23
Trail of Fail
Dano's Avatar
I don’t' know enough to say one way or the other but the more exhaust you push thru the turbo the harder it will be to get out of the relatively smaller IWG compared to a 38 or 44mm EWG. Someone else on here will chime in and clear it up.
 Old 03-20-2010, 10:19 AM   #24
mattizle14's Avatar
yeah i was doin research on it and the + gave it more drivability...but then my buddies were like go for the stage 4 or 5...i was like ur right cuz im still going to be driving this to work btw haha...also i just heard some things about act...and not to much about spec...idk all confusing i just go off of reviews basically everyones trials and errors...but do u think with the setup i talked about above...u think i can hit the 400+ with that?
i hope someone does cuz its all confusing to me...im a do it urselfer when it comes to this *BESIDES THE TUNING...I=DUMB WHEN IT COMES TO THAT SO I WONT BE DOIN THAT NOT THAT DUMB* had to get that out of the way...but im still learning with all this...if/whenever that person chimes in could u tell me what all i would need with the ewg setup and how/what better way would i install it...
Last edited by mattizle14; 03-20-2010 at 10:19 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-20-2010, 10:21 AM   #25
Realgib3's Avatar
Your 400whp goals will not be held back by running IWG, BUT they will be held back by not having a standback and flashes from cpe.
The Following 2 Users Say Thank You to Realgib3 For This Useful Post:
Dano (03-20-2010), mattizle14 (03-20-2010)
 Old 03-20-2010, 10:30 AM   #26
SneakyP86's Avatar
With what you have I believe you will be able to hit 400 whp.......BUT......CPE seems to have the HP advantage right now over COBB as they are the only tuning solution to actually cross over that mark in the sand.........BUT.......JJ has a pretty radical build that was done by DCR that he is fixing to get tuned at COBB in Utah so wee shall see how it goes. But something tells me if when he gets tuned they can't go over 400 your going to see the price on used COBB AP's drop radically and the price for a used CPE SB go up.
 Old 03-20-2010, 10:34 AM   #27
mattizle14's Avatar
thats what i was afraid of...i keep hearing about it and the full management by cpe...so iwg wont hold me back at all from goin 400...btw might sound pretty stupid to ask but im asking it...what if i went and got the 35r...later on down the road couldnt i just remove the iwg and weld it shut with a plate and hook up a ewg?
 Old 03-20-2010, 10:44 AM   #28
SneakyP86's Avatar
Yes you could do that but it will be less expensive and time consuming to do it from the get go. As a exh. manifold would probably be less expensive to have made with the EWG flange built on it rather than having to weld it on later and also welding up the IWG. Also dont forget about the time consumption of removing the exh. manifold and reinstalling it back yet again. If you go either route I would highly recommend getting the manifold and the hotside of the turbo ceramic coated as it will help hold down underhood temps.
 Old 03-20-2010, 10:46 AM   #29
mattizle14's Avatar
well im still waitin for that person to come along with advice on my post from above
 Old 03-20-2010, 10:49 AM   #30
SneakyP86's Avatar
If you mean post 27 check post 28. Otherwise.........HUH???
 Old 03-20-2010, 10:51 AM   #31
mattizle14's Avatar
post 24 quote
 Old 03-20-2010, 10:59 AM   #32
phillyb's Avatar
Groans: 1,940
so what you're saying is you were able to use that gt40 efficiently, right?
and like i said in my post, i have on experience with bt's, so your post is redundant.
MarkyMark (03-22-2010)
 Old 03-20-2010, 11:10 AM   #33
SneakyP86's Avatar
So you want to know what you will need is that it? Okay well you'll need an exhaust manifold that is setup for EWG (I believe that DNP and PTP both have them that way now). A EWG and I would suggest a TIAL either a 38 or 44mm with a 14 or 15 pound spring in it. you will also need a EBCS there are two you can go with either Perrin or Grimmspeed. The Grimmspeed is PNP but the Perrin has to be splced in but you could buy a plug from Grimmspeed to make the Perring PNP also. You will need to get a screamer pipe made that is either VTA or routed back into the DP. You may also have to have new oil lines and water lines run as the OEM ones may be to short.
You can get a turbo w/o water cooling but I don't recommend it myself, you can also get journal bearing over ball bearings but I also dont recommend that. To me though the big thing to decide when your getting ready to order your turbo and FMIC is knowing what you want to do and ordering appropriately. In other words make sure you order the turbo that meets what you want it to do and that it is in its maximum efficiency range while doing it. Same thing with the FMIC make sure it is sized right to meet your HP needs while at the same time its not to big as it may add to your turbo lag if it is.
Is that anything like the experience you had with that transvestite??
BUT DONT FORGET PHILLY........MUCH LOVE MAN.........just different than the transvestite.
Last edited by SneakyP86; 03-20-2010 at 11:28 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to SneakyP86 For This Useful Post:
mattizle14 (03-20-2010), phillyb (03-21-2010)
 Old 03-20-2010, 12:19 PM   #34
mattizle14's Avatar
thanks again for the info...anyone else wants to add their two cents feel free!
 Old 03-20-2010, 12:29 PM   #35
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
i was confused b.c mark thanked his post. i guess he meant to groan him
2015 Mazda 6
The Following User Says NO Thank You to IshiKage For This Un-useful Post:
 Old 03-20-2010, 12:44 PM   #36
Trail of Fail
Dano's Avatar
Tried the muffler on the LGT w screamer = creep. The muffler was too restrictive and was from some motor cross bike or the like.
Edit: oh and the LGT was only running a VF39 which is a factory STI turbo so anything like OP is wanting to run would def not work with a muffler. It is either VTA or route to the DP past the cat.
 Old 03-20-2010, 02:07 PM   #37
zx2man's Avatar
Posts: 1,356   (View Stats)
zx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the world
Why cant you with the AP?............is it the turbo isnt very compatable with the AP or just the belief that AP sucks?......The reason why I ask if my tuner Tim Baily has tuned 500 whp sti's,400 whp wrx's,600 whp Nissan GT-Rs,500 whp evo's,450 whp Legacy Gt's and so on..True to best of my knowledge He hasnt done a 400 whp ms3 yet, but thats only cause he hasnt worked with a ms3 that has the mods to do so yet..to me the Cobb AP seems like a very capable performer...Now im not trying to piss on anyone using ther SB either..ive heard alot of good things..and I run Cp-e products on my car-great company...gave my car to Tim and with just a Cobb catted downpipe-cobb intake and ETS 3.5 tmic I made 296 whp and 322 wtq on a mustang dyno withy 0 knock..super safe afr's and a conservative 17 psi tune..maybe Im overlooking some shit..but The Cobb AP seems like a pretty good platform to tune cars. Thanks
zx2man is offline   Reply With Quote
 Old 03-20-2010, 03:18 PM   #38
Trail of Fail
Dano's Avatar
There is a load cap in the Mazda ECU that Cobb hasn't been able to get past yet. Yeah they can do it with just about any other car but not ours. I think their ProTuners tune around the cap to a certain extent but can't get over 400 IIRC. I am running with the mods in my sig and I had to work around the load cap to maintain consistant AFR and boost. The cap doesn't appear to effect everyone but the numbers are signifiant.
ECU Load cap shattered!
I think only CP-E can consistantly produce big numbers.
Now don't get me wrong I love my AP and will probaly not need to go to something else. I think it's like this.
Stock to fully bolted = AP
Anything more = SP + flashes
802MS3 (03-21-2010), mattizle14 (03-20-2010), zx2man (03-20-2010)
 Old 03-20-2010, 03:41 PM   #39
mattizle14's Avatar
just for clarifications what is sp
 Old 03-20-2010, 03:45 PM   #40
SneakyP86's Avatar
He means the CP-E StandBack + a couple of flashes that work with it.
Dano (03-21-2010), mattizle14 (03-20-2010)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/gt35r-51638/
BOOST CREEP + IWG ? Mazda MPS Owners Club This thread Refback 01-14-2015 12:46 PM
Mazda MPS Owners Club • View topic - BOOST CREEP + IWG This thread Refback 04-02-2011 01:45 AM
GT35r Spool jhershorin MazdaSpeed 3/6 - Turbo Induction 25 02-21-2013 07:13 PM
GT35R housing. Right? SPD6Tuner MazdaSpeed 3/6 - Turbo Induction 2 06-24-2009 10:49 PM
gt35r: Should I do it? madvillain Mazdaspeed3/6 General Discussion 38 05-26-2009 11:43 AM
Page generated in 0.57465 seconds with 30 queries
