Like Tree44Likes
 Old 07-30-2012, 03:49 AM   #761
Jackis's Avatar
Posts: 428   (View Stats)
Jackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the world
Alan is now running top-mount mega-setup and no longer drives GTX. And btw so far on stock bottom-end
Does your MS3 start when it's -30C (-22F)?
Forged, bolted, tuned, gtx30/tial/ewg. Thanks.
Jackis is offline   Reply With Quote
The Following 2 Users Say Thank You to Jackis For This Useful Post:
djuosnteisn (07-30-2012), JacksonMS30 (07-30-2012)
 Old 07-30-2012, 08:44 AM   #762
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
Originally Posted by rgvms6 View Post
Im thinking of going gtx3071 as well. do you have forged rods and pistons? What else would I need to run this turbo? My mods are in my sig.
Like Jackis said, I am no longer on this setup but I am still on the stock block (check my sig). The GTX3071 is a great turbo!
Really, the only thing you need to make it work is a turbo inlet pipe that fits...
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M.Tuning -
The Following 3 Users Say Thank You to JacksonMS30 For This Useful Post:
atvfreek (08-04-2012), djuosnteisn (07-30-2012), nybe0010 (05-18-2013)
 Old 08-04-2012, 08:54 AM   #763
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
I still think you should've left it alone. That car drove perfectly IMO, it had just the right amount of power and spool for FWD in order to maintain control and still not be laggy. Good luck with the new setup though! Call me once you get it dyno tuned and tell me the nasty numbers you get out of it.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline   Reply With Quote
The Following User Says Thank You to Nataphen For This Useful Post:
JacksonMS30 (08-04-2012)
 Old 08-04-2012, 09:25 AM   #764
Oh believe me, I know! The perfect turbo for this car is the GTX3071 hands down. This was just an opportunity I couldn't pass up. When I get around to getting another turbo, I will probably either get a GTX2867 or GTX3071 again to switch out for when I go to the track (road course that is). I still may end up selling the HTA3586 and getting a GTX3076 for altitude friendliness... We will see how it goes after some tuning and some dyno numbers...
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
The Following 5 Users Say Thank You to JacksonMS30 For This Useful Post:
Jackis (08-06-2012), Nataphen (08-04-2012), nybe0010 (05-18-2013), rfinkle2 (01-25-2013), silvapain (03-30-2013)
 Old 03-30-2013, 06:27 AM   #765
stokes620's Avatar
Posts: 281   (View Stats)
stokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the world
How many miles on the engine? Have you recently checked compression before and after switching turbos?
07 Speed 3
COBB AP / Sure Aeros SRI / HTP TIP / PG Pipes/Godspeed Type C Core / Autotech Internals / PTP Injector Seals / CNT Catless TBE / Sure TIG / CP-e 75A RMM / SU PMM & TMM / JBR SSP / JBR Heavy Shift Knob / KSport Kontrol Pro CO / JBR RSB / HTP Battery Tray / Prosport Boost Gauge
Permed CORN Fed 25% - SOLD
[COLOR="Blue"][CENTER]2012 Speed 3 - Sold
stokes620 is offline   Reply With Quote
 Old 05-12-2013, 07:47 AM   #766
Rayd's Avatar
Posts: 171   (View Stats)
Rayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond repute
Nice one dude...
Am i reading your logs right though? 3.25s 60-100 times??
05 MPS 6 - Self Tuned
Borg Warner EFR T4 Twin Scrolled, Forged Block, Snow Performance S3 WMI, 5th/6th Port Injection, CPe: Ex Mani, Custom intake 3.75" MAF, CPe HPFP, Injector Seals, REM, SURE: Rear Diff Front mount & Brace, TIG's; Tial EWG, HDI FMIC, Custom 3" TBE, 3.5-Bar MAP sensor, AWR SEM, SouthBend S4 Clutch, Custom Head Unit, Car-LED Tails, 6000K HIDs, Auto Head-light Kit, Mugen Visors, LED conv., BC Coilovers, SPC Ball Joints, Brembo BBK
Rayd is offline   Reply With Quote
 Old 05-17-2013, 09:31 PM   #767
I put 25,000 miles on that turbo at 386whp and 400wtq. When I switched between the GTX3071 and the top mount HTA3586 I checked compression. In Denver (5280ast), I did 165, 165, 145, 165 from cyl 1 to cyl 4. So 20psi low in cylinder number 3 after 25k miles. I've been running the HTA3586 for the last 7000 miles and its making 410whp uncorrected (503 corrected). There are 102,699 miles on the car now.
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
atvfreek (05-18-2013), djuosnteisn (05-20-2013), Fail_6 (05-20-2013)
 Old 05-18-2013, 12:49 AM   #768
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
I have about 50k on my gtx3071r now
And @JacksonMS30; dibs
2008 MS3 gt
470hp/463tq on GT35r at 29psi
Last edited by burn813; 05-18-2013 at 12:49 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to burn813 For This Useful Post:
JacksonMS30 (05-20-2013), WhiteWidow (05-18-2013)
How to Build a Car Haltech Automotive News 0 03-21-2011 10:40 AM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Sq build Strytnyne MazdaSpeed 3/6 - Car Audio & Electronics 10 12-18-2008 03:19 PM
Page generated in 0.30922 seconds with 26 queries
