![]() Join Date: Oct 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,548
Groans: 30
(Thread Starter) | Not Ranked : 0 score Ok, so I've been looking at 3071Rs a *lot* lately, and I heard about the new GTX line from garrett...supposedly they have ultra-gucci compressors that will pwn noobs, pay off your mortgage, cure herpes, etc etc... I found this on ATP's site: Garrett GTX3071R Dual Ball Bearing Turbo : atpturbo.com It's a GTX3071R compressor side with NO turbine housing. I couldn't find a Mazdafail flange standalone turbine housing on their site, only their pre-built kits. I'm extremely n00b when it comes to turbo construction, so here's my question. The stock flange turbine housings exist. We know this because many people, including lenny, are sputtering along with one. The GTX3071R compressor side exists. Let's just stick them together! Shouldn't it be possible to get JUST the stock flange turbine housing and attach it to a GTX3071R compressor?? 1+1=2 right? Or am I just wrong and full of fail??
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks Last edited by Cataphract_40; 01-18-2011 at 09:09 PM. |
| The Following User Says Thank You to Cataphract_40 For This Useful Post: | Monotonous ONE (01-19-2011) |
Groans: 31
| Not Ranked : 0 score I'm sure ATP could supply you with a Mazda hot side. The exhaust wheel of a Mazda-specific 3071 is the same size as a regular 3071.
Groans: 78
| Not Ranked : 0 score Yeah, you could do that, assuming you could get a housing alone. ATP's customer service blows, so I'd contact Mark or another Garrett vendor and see if they can get through faster, thats what I did a few times and it worked out much better. Personally, I think thats a heeeeeeeell of a lot of money for a turbo. I mean, I know its a sick turbo, I do. But the gtx3071 is a faster spooling, better top end gt3071, am I right? With the stock sized exhaust housing, spool is quick enough on both the 3071 and 3076. I think someone posted compressor maps of the gtx3071 vs the regular 3076 and the top ends were almost identical. I'm not saying you should be a jew and go buy a $800 turbo like I did, all I'm saying is I really don't think that it'd be worth the extra money to go for the gtx model. Yes, you're getting quicker spool.. but why? The 3076 with stock exhaust housing spools to FULL boost by just after 3000 (if I remember correctly).. shit, SSinstaller is seeing 25psi by 3500 on a t3 gt35!!!!. You could probably hit full boost on a 3076 sooner if you really loaded it up, but personally I'm not going to use the power then anyways. Even in the few hundred RPMS between, you're going to have some boost (5-10psi) or whatever and you'll be moving just fine. But were splitting hairs now. Its a sick turbo for sure, but I think you could utilize the extra money elsewhere to help the car progress once you've got the turbo on. You'll be eating tires. You'll need motor mounts. You'll need to tune it. Shit will break - god knows shit will break.
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] |
| The Following 4 Users Say Thank You to madvillain For This Useful Post: |
Groans: 30
Yeah I was just spitballing ideas...I want to go BT in the near future when I have more monies, but I haven't decided exactly what I want. I was just tossing around some ideas, and this possibility occurred to me. Worth keeping in mind for the future I suppose.
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks | |
| The Following User Says Thank You to Cataphract_40 For This Useful Post: | dougefresh_ (03-19-2011) |
Groans: 78
| Not Ranked : 0 score Werd. Hey I won't hate, I'd love to see someone get one of those turbos. If I had the money I would too.
| The Following 2 Users Say Thank You to madvillain For This Useful Post: | Cataphract_40 (01-19-2011), dougefresh_ (03-19-2011) |
Groans: 30
(Thread Starter) | Not Ranked : 0 score Yeah that was part of it...kinda wanted to blaze a new(ish) trail for msf...custom made ATP turbo etc etc...maybe create my own fail legend when it all goes horribly wrong
| Banned ![]() Join Date: Mar 2010
| Not Ranked : 0 score Create you own , Look at the HX turbos.. |
Groans: 30
(Thread Starter) | Not Ranked : 0 score That's exactly what I want to do. I want to call up ATP (or Garrett I guess) and tell them to slap a mazdafail turbine housing on a GTX3071R compressor. Then I'll slap said turbo on my fail motor and watch the fireworks
Groans: 224
| Not Ranked : 0 score He said HX as in a Holset turbo. I plan to run a Borg-Warner and there are others with differet ideas as well. Your idea just happens to cost more lol. The problem I have with the GTX line of turbos is that they're saying they've increased the prussure ratios by a certain percentile. But I'm willing to bet you'd need to run 25+psi to actually make a difference between a GTX and a regular GT series turbo. This isn't like Garrett just came up with this idea though...BW has been doing it for about 5 years now with their ET technology, they just happen to be a JB turbo... It's definitely a cool idea, and if you're comfortable fronting that kind of money for a turbo then by all means have at it. Either way good luck!
Groans: 30
(Thread Starter) | Not Ranked : 0 score Yeah I got the holset reference about the borgwarner thing..do you mean the new EFR series? Aren't they kinda pricey?
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,870
| Not Ranked : 0 score http://www.mazdaspeedforum.org/forum/foru...ds-shit-64974/ Brian's got a ATP 76 Mazda Specific hotside for sale...... I would make sure its compatible before u go any further That actually a good deal for anyone, that wants to go BT 3076. Buy a generic one(GT 3076) and switch out hotsides for the mazda specific one if u dont want to go the full custom route
__________________ 08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock! 99 Miata NB - Stock for now Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors |
Groans: 30
(Thread Starter) | Not Ranked : 0 score Also: the ATP GT3071R kit for MS3s costs somewhere in the neighborhood of $1900...maybe a couple hundred cheaper if you shop around...the GTX3071R compressor side is $1400, add in 300-400 for the turbine housing...that's $1800...so it doesn't seem to be much different than the ATP GT3071R kit already is...
![]() Join Date: Oct 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
| Not Ranked : 0 score I know this thread is dead but I had to comment
__________________ 2007 Cosmic Blue Mazdaspeed 3 GT | |
| The Following User Says NO Thank You to RichB For This Un-useful Post: | MS3-a(sore)ASS-rex (10-28-2011) |
Groans: 224
| Not Ranked : 0 score Not the EFR series. I mean the Borg-Warner Bullseye power S-series.
Groans: 224
| Not Ranked : 0 score ATP sells bolt-on Ewg exhaust sides for our cars. So no, he wouldn't need an iwg
| Not Ranked : 0 score Ok..... you'd still need to factor in the price of a Waste Gate (Internal or External).
Groans: 224
| Not Ranked : 0 score Yes, but that wasn't the point you were trying to make in your first post. I'm over it.
| Not Ranked : 0 score Understood I think we are on the same page now
