Like Tree4Likes
  • 1 Post By
  • 1 Post By
  • 1 Post By
  • 1 Post By mituc
 Old 08-10-2015, 11:39 AM   #1
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
139k stock block low compression in cylinder 3 gtx3076 ewg @ 20psi up to redline on stock catback and cpe tmic. Took a 392 srt8 twice.
When I had cracked ringlands in #3 and #2 (probably your case too for #3 ) the engine was making 5% more torque than before (about 520Nm/385lbft crank torque, 480Nm/355lbft) but about 4% less power (about 365 crank HP/340whp versus 380 crank Hp/350whp). the engine is totally recoverable with reasonable costs from a cracked ringland problem as long as you do not let it go too far and run into cylinder surface integrity problems.
Cheapspeed likes this.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Wes' 2010 GTX3076 build Wes10S3 2010 MS3 - Build Diaries 7 08-02-2014 11:04 AM
GTX3076 Build.... The time haz arrived! LumberJack 2010 MS3 - Big Turbo Builds 162 07-31-2013 06:10 PM
LakeSpeed6 GTX3076 Build Lakespeed6 MazdaSpeed 3/6 - Big Turbo Builds 60 04-12-2013 08:09 AM
Stock Block BT build threads xcoldricex MazdaSpeed 3/6 - Big Turbo Builds 50 07-13-2010 08:37 AM
Page generated in 0.23705 seconds with 22 queries
