![]() | | #41 | ![]() |
| Not Ranked : 0 score
| The Following User Says Thank You to Jeff23spl For This Useful Post: | JMEngineer (02-04-2016) |
![]() | | #42 | ![]() |
![]() Join Date: Apr 2009 Location: Cincinnati
Rep Power: 2046 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
| Not Ranked : 0 score maybe... I still have a few things to sort out before the real tuning starts. Right now it makes decent power with a lot of boost but the AFR's and timing are very conservative. With a few degrees of timing I'll probably have to turn down the boost to avoid knock. It's my DD so I'm not planning to run any meth or E. If it still hits 30psi with no knock then I'll probably upgrade the gauge.
__________________ 2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list... ![]() 2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch -GTX2867R Coming Soon |
![]() | | #43 | ![]() |
| Not Ranked : 0 score At first i was like: how can he know it is at 30 when the gauge stop at 20...but then...saw the needle at the beginning but on the wrong side of the stop pin héhédo you have internal mods to spool that early or it is just because of the twin scroll ? (higher CR, porting etc)
![]() | | #44 | ![]() |
Groans: 111
| Not Ranked : 0 score 30PSI on pump gas on a 2.3 litre engine may not work. 25-26 though will.
| The Following User Says Thank You to mituc For This Useful Post: | JMEngineer (02-04-2016) |
![]() | | #45 | ![]() |
I estimated it would end up somewhere around 27-28psi at 9.0:1 which is about the same effective CR as 25-26psi and 9.5:1
__________________ 2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list... ![]() 2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch -GTX2867R Coming Soon | |
![]() | | #46 | ![]() |
| Approved MSF Vendor ![]() Join Date: Nov 2011
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I ran 30+ PSI on 93 octane R+M/2 no meth or eth with 9:1 CP pistons. I plan to run more soon. |
| The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post: | JMEngineer (02-04-2016), Mauro_Penguin (02-05-2016) |
![]() | | #47 | ![]() |
Groans: 111
| Not Ranked : 0 score I'm just curious, how much timing were you running at, say, 5500, 6000, 6250, 6500 and 6700rpm, assuming that there was no major KR?
![]() | | #48 | ![]() |
| Not Ranked : 0 score @Steve@VersaTune; How's this going? I'm really excited to see how it works for you. I'm curious to see how well such a large AR will spool with twinscroll. Also, I never realized VT was based out of MI. I'm on the other side of the state from you guys just North of Grand Rapids!
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | MD1032 (03-04-2016) |
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score Cool, glad to know that the West side is represented here ![]() I've been so damn busy with VT, I have not had any time to work on the car. I need to fix some leaks and move the O2 sensors. It's 99% done. |
| The Following 6 Users Say Thank You to Steve@VersaTune For This Useful Post: | cshunter (03-05-2016), Mauro_Penguin (03-04-2016), Mazdazilla6 (03-03-2016), MD1032 (03-04-2016), SpeedRebirth (03-04-2016), WetzMS3 (03-04-2016) |
![]() | | #50 | ![]() |
You should try to make it out the MWM this year! Last year was in IL, but the year before was MI. It's a whole group of a bunch of awesome dudes (and lady dudes) who love hanging out talking about car stuff. They also do some car and non car related stuff too.
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | WetzMS3 (03-04-2016) |
![]() | | #51 | ![]() |
| Not Ranked : 0 score Anything new?
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score Looking for a fab shop in Detroit that actually wants work. None have returned my calls. Can't get anyone to redo the DP and WG pipes. |
![]() | | #53 | ![]() |
![]() ![]() Join Date: Jun 2010 Location: Morton Grove, il
Rep Power: 1485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,886
Groans: 78
| Not Ranked : 0 score Not sure how I missed that you're doing this. Definitely going to bug you about this at some point. It seems top mount might not be worth it? That hotside looks real close to the shroud in your pictures, so may not have much room to grow bigger.
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT |
![]() | | #54 | ![]() |
| Not Ranked : 0 score If you'd like I can ask the welders at my work if they'd be interested. Are you looking to get them completely remade or modified to fit?
![]() | | #55 | ![]() |
(Thread Starter) | Not Ranked : 0 score The WG pipes need flex bellows added, and one of the WG pipes hits the firewall when the engine rocks under torque. I'm looking for a full service shop to just make it work. I don't have time to deal with it. The car has been sitting for over 2 years. |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | impossible (05-29-2017) |
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score It's ALIVE!!!!! The intake piping needs to be redone with prettier custom bent pipe, but it runs now. Useful boost starts around 3200-3300. Pulling hard by 3500. I'm still on WG spring pressure of 20 PSI. BCS will be attached soon for 35 PSI. |
| The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post: |
![]() | | #57 | ![]() |
Groans: 111
![]() | | #58 | ![]() |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | mituc (01-23-2018) |
![]() | | #59 | ![]() |
Groans: 111
| Not Ranked : 0 score Well, at 30-31PSI I'm flowing about 435/440 pump gas g/s through the OEM mani with the VCTS on, so if you plan to leave that on and boost up to 35PSI with that huge turbo and flanges this setup should be good for quite a lot of power.
![]() | | #60 | ![]() |
Sent from my SM-G935V using Tapatalk | |
| Oil prices headed up or down? Experts divided | Haltech | Automotive News | 0 | 05-11-2015 08:50 AM |
| Stage 2 Topmount logs | Speeed3 | MazdaSpeed 3/6 - ECU Computer Tuning | 59 | 11-10-2011 12:05 PM |
