  • 1 Post By BlckMs3
 Old 03-28-2013, 07:53 PM   #1
Juliandlr1004's Avatar
Posts: 226   (View Stats)
Juliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the world
Groaned at 8 Times in 4 Posts
Default gtx30xx ewg members...i have a question!
I got a gtx3071r ewg kit from atp. The ewg kit didnt have any directions on how to assemble/install. I noticed it came with plugs and fittings (1 on top, 2 h2o, and 2 air). My question is,.is which ones do i use and which ones do i plug? And where do those lines go to? Sorry if this.irritates some of you.
Gtx3071r//Tial ewg//Wiseco Pistons//K1 Rods//Cometic head gasket//JBR bsd and baffle//Jbr egr delete//ARP main studs//ARP head studs//Stratified 3 port ebcs// 3 bar map and pnp harness//ACT 6 puck with prolite flywheel//ARP flywheel bolts//Treadstone tr8 core with cx racing intercooler piping//CPE safe seals//CPE big turbo inlet pipe//CPE 3.25" maf housing//Turbosmart dual port nov//h&r springs// Whiteline rear sway bar//Sure dreadnought//Sure juggernaut//Sure rmm//3" dp//Custom exhaust//Drag wheels//KMD hpfpinternals//Cobb AP
Juliandlr1004 is offline   Reply With Quote
 Old 03-28-2013, 08:14 PM   #2
BlckMs3's Avatar
Posts: 769   (View Stats)
BlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the world
Groans: 30
they figured when youre ready to buy a turbo set up like that, you werent a noob and needed directions...its pretty cute tho that you have it in your sig already when its not installed
Juliandlr1004 likes this.
Stance will make her dance, but boost will make her sploosh
[12:57 PM] Enki: kim should sell her used tampons to msf as fresh teabags
2007 Mazdaspeed3 SOLD
2014 Mustang GT
BlckMs3 is offline   Reply With Quote
 Old 03-28-2013, 08:14 PM   #3
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
The one on top stays open/unplugged.
plug the water.
plug one of the air holes.
the other air take a fitting and goes to the boost controller.
 Old 03-28-2013, 08:56 PM   #4
Oh ok. Since im running the stratified 3 port do i have to use the top dont i? Noticed you have a speed 6 kit...what did you have to modify on the line? My kit only came with one line attached with the rubber hose at the end of it
I figured to block off the water ones but just wanted to make sure.
Last edited by Juliandlr1004; 03-28-2013 at 08:56 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Juliandlr1004 For This Useful Post:
crazyp (03-29-2013)
Page generated in 0.24852 seconds with 22 queries
