 Old 02-21-2014, 10:57 PM   #1
Hanzodurrr's Avatar
Posts: 240   (View Stats)
Hanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the world
Default Hanzodurrr BT Build
After all my time lurking on BT Build section the time has come for me to contribute. I was original going to go with a GTX3076 on stock mani with a eBay downpipe and all the other essentials for going BT.......but then since the wife was in Hawaii when the order was going down I got a case of the Yolos and went with all this instead
Precision Ball Bearing Turbo PT5558 CEA Vband in/out Ported S cover
CP-E Manifold w/Precision Flange
CP-E SafeSeal Injector Seals
Kozmic Precision Downpipe
Kozmic Motorsports Dump Tube
Kozmic Oil Feed Line Precision Turbo
Kozmic Motorsports Primary EGR Delete
Kozmic Motorsports Oil Catch Can
Kozmic Motorsports Oil Return Line Kit
PERM Tuning PCV Plate
JBR 51R Small Battery
ITV22's
Grimmspeed EBCS
Tial MVR Purple
Bitwise Motorsports Bosch MAP Sensor Connector
Bosch 3 Bar
Looking to just get it to as much power on a safe tune as I can for now since I'll be staying with stock block. Hopefully once I recover from the wife killing me I'll be able to build the motor. Inb4zzb
Once I start getting everything in I'll start taking pics for all to see and hopefully get some good pictures of the install process/outcome as well. Big props to @EdgeAutosport.com; for the good deal and fantastic customer service. Hopefully I get to start seeing some tracking numbers next week for all this ish.
EDIT : Car Blew the head gasket in August 2014 then I became a depressed ghost.
August 2015: Long Block from SP63 Purchased!
Build Stats:
SPEED PERF6RMANC3 Built Long Block For Mazda MZR-DISI
Pistons: SP63 9.5:1 - 88.0mm, Head Studs: 12mm H11, Manley H-Beam, Rod Bolts ARP 2000, Coat Bearings, Balance Shaft Delete Kit, Keyed Crank Crank Pulley & Sprockets
SP63 Custom Headwork for Mazda MZR-DISI
SuperTech 55lb, Pinned Camshaft
Other Mods:
JBR FMIC Under mounted Piping kit
TR8
JMF V1
Mics: gaskets, plugs, oil etc.
Getting parts powder coated along with all this so I don't have to touch anything again.
Compressor housing: Purple
JMF: Purple
Valve Cover: Wrinkle Black
All Piping: Wrinkle Black
Misc Parts: Wrinkle Black/Purple
December 2015: Long Block arrived
Shooting for first startup to be in January sometime but that's all part and powder coat dependent.
JBR Wrinkly Black Dong//CX FMIC w/Wrinkle black piping//PPT Tune//Autotech HPFP//Corksport Springs//TWM Full Replacement//JBR 88tmm 88rmm 80pmm//JBR OCC//JBR EGR delete//JBR TIG//GFB 100% Rice to Air//TB bypass// Kozmic Vband DP//CP-E ExMani//PTE 5558//Stoptech Power Slots all around//Stoptech SS lines//EBC Yellows//
BLEW UP AUG 2014
Aug 2015 SP63 Long Block coming soon!!!
Hanzodurrr is offline   Reply With Quote
The Following 15 Users Say Thank You to Hanzodurrr For This Useful Post:
ABQ Speed6 (02-22-2014), brandonf (08-24-2015), Code Monkey (02-24-2014), Dahouse702 (02-22-2014), ItsNox (02-23-2014), JgamB (02-24-2014), killer-ms3 (03-06-2014), LatinKraze (02-21-2014), m.a.vega1 (02-21-2014), Mochi (02-22-2014), nlgiebel (12-24-2015), REBarker (01-26-2016), SpeedRebirth (03-10-2014), Vader (04-16-2014), x09MS3GT (03-06-2014)
 Old 02-21-2014, 11:30 PM   #2
LatinKraze's Avatar
Posts: 804   (View Stats)
I'm a phone call away when this shit goes down...after getting permission from the boss.
2016 CX-5 GT AWD
The Following User Says Thank You to LatinKraze For This Useful Post:
 Old 02-21-2014, 11:46 PM   #3
m.a.vega1's Avatar
Posts: 88   (View Stats)
m.a.vega1 is the leader of the worldm.a.vega1 is the leader of the worldm.a.vega1 is the leader of the worldm.a.vega1 is the leader of the worldm.a.vega1 is the leader of the worldm.a.vega1 is the leader of the worldm.a.vega1 is the leader of the worldm.a.vega1 is the leader of the worldm.a.vega1 is the leader of the worldm.a.vega1 is the leader of the worldm.a.vega1 is the leader of the world
GLWB! You know I'm so excited to tune this ish... I really need to stop thinking about it, this broner is starting to hurt...
#Spoolbus3: Manley Rods, Wiseco Pistons, H11 Head Studs, Super-tech valves/guides/springs/retainers/seals, CP-E Injector Seals, Keyed Crank, PERM/Kozmic 6th-port w/ID1000's, TR10 FMIC, HTP 4' Intake, VTCS Delete/Lightly Ported IM, CP-E Exhaust Manifold, 44mm TIAL EWG, Kozmic V-band Down-Pipe/Dump Tube, PTE Gen 2 6266 ... Killah Built/Vega Tuned
m.a.vega1 is offline   Reply With Quote
 Old 02-22-2014, 07:02 AM   #4
katoom17's Avatar
Posts: 33   (View Stats)
katoom17 is a name known to allkatoom17 is a name known to allkatoom17 is a name known to allkatoom17 is a name known to allkatoom17 is a name known to allkatoom17 is a name known to all
Nice!! I am going this same route, but I am choosing the PTE 5858. I am in the process of building my motor also looks like I will need to start a thread and Share my Journey as well.
2007 Cosmic Blue Speed3
*built motor *PTE 5858 *CPE manifold* PTE wastage *custom aluminum exhaust *and much much more!!* tuned by Realgib3
katoom17 is offline   Reply With Quote
The Following User Says Thank You to katoom17 For This Useful Post:
Hanzodurrr (02-22-2014)
 Old 02-22-2014, 08:58 AM   #5
Mochi's Avatar
Posts: 152   (View Stats)
Mochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the world
Groaned at 9 Times in 5 Posts
zoom zoom muthafucker ............... should be the highest hp ms3 in vegas
1975 280Z Datsun - EX header, mild intake port, hotter cam, flattop pistons, black dragon muffler, 5speed swap - Retired Autox shit box
1991 240sx Nissan - shitty ebay "cold air intake", walboro 255 (Murdered by ExGF)
2008 Mazdaspeed 3 COBB V3 AP. JBR RMM. MD OCC. TRL8 w/CX RACING. JBR SHIFT WEIGHT. EVO X RIMS. MD PS COOLER. COBB SIR TIP. CORKSPORT RECIR. PURE tuned
2015 Mazda 3 - bone stock, Gen 1 speed3 rims in the front, Business in the back, 40MPG
"hold'n my dick!"
Mochi is offline   Reply With Quote
The Following User Says Thank You to Mochi For This Useful Post:
m.a.vega1 (02-22-2014)
 Old 02-24-2014, 08:03 PM   #6
Dahouse702's Avatar
Posts: 487   (View Stats)
Dahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the world
you going to clean your VAVLES?!?!?!?!
2007 MS3 Black Mica-Totaled @98500 on 09/2014
Current Car...
2009 MS3 Black Mica GT JBR TRU 3.0 Widepath full intake, BNR S3 v1, GS EBCS, 3 BAR , Forge BPV V2, Autotech internals , Denso Itv22, CNT Downpipe, CX-Racing piping with Cobb v2 core, Cobb AP v2, JBR RMM, JBR PMM, JBR TMM, JBR Oil Catch Can, EGR Delete, JBR TIG, Toyota Seals, HTP battery tray, DashHAWK
Zoom Zoom
Dahouse702 is offline   Reply With Quote
The Following User Says Thank You to Dahouse702 For This Useful Post:
Hanzodurrr (02-24-2014)
 Old 02-24-2014, 09:09 PM   #7
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Awesome Build.
You will LOVE that turbo!
www.tunedbynishan.com
m.a.vega1 (03-09-2014)
 Old 02-24-2014, 09:25 PM   #8
Hanzodurrr's Avatar
Awesome Build.
God I hope so.
Note 2 Tappin
BLEW UP AUG 2014
 Old 02-28-2014, 08:57 PM   #9
Hanzodurrr's Avatar
Looks like @EdgeAutosport.com; should have everything next week. Then they are gonna mock it up for a NSFW photo shoot and send it all my way. Maybe if they offer it as a kit it can be called "The Durrr" haha.
BLEW UP AUG 2014
 Old 03-06-2014, 12:20 PM   #10
Hanzodurrr's Avatar
Getting everything on friday can't wait.
Note 2 Tappin
BLEW UP AUG 2014
 Old 03-06-2014, 12:35 PM   #11
Mochi's Avatar
When you going to get some tires to handle all that power
"hold'n my dick!"
 Old 03-06-2014, 02:11 PM   #12
Hanzodurrr's Avatar
Psssh 80 rolls only
Note 2 Tappin
BLEW UP AUG 2014
The Following 2 Users Say Thank You to Hanzodurrr For This Useful Post:
Dahouse702 (03-07-2014), x09MS3GT (03-06-2014)
 Old 03-08-2014, 03:31 PM   #13
Hanzodurrr's Avatar
Forgot to take pictures till it was too late. Got some shots of pita bolts, new parts and help not helping
BLEW UP AUG 2014
The Following 4 Users Say Thank You to Hanzodurrr For This Useful Post:
Dahouse702 (03-08-2014), LatinKraze (03-12-2014), m.a.vega1 (03-09-2014), Mochi (03-10-2014), ms3blackmica (03-10-2014)
 Old 03-08-2014, 07:13 PM   #14
Dahouse702's Avatar
Damn it wish I could of made it over!
Current Car...
Zoom Zoom
 Old 03-10-2014, 11:15 AM   #15
Hanzodurrr's Avatar
More progressuploadfromtaptalk1394471635567.jpguploadfromtaptalk1394471657621.jpguploadfromtaptalk1394471673333.jpguploadfromtaptalk1394471717263.jpg
Note 2 Tappin
BLEW UP AUG 2014
The Following 7 Users Say Thank You to Hanzodurrr For This Useful Post:
ItsNox (03-11-2014), LatinKraze (03-12-2014), m.a.vega1 (03-11-2014), Mochi (03-10-2014), ms3blackmica (03-10-2014), nlgiebel (12-24-2015), SpeedRebirth (03-10-2014)
 Old 03-10-2014, 02:47 PM   #16
speed3 britz's Avatar
Posts: 1,155   (View Stats)
Awesome, I just noticed Edge just rolled this out as a complete kit.
Precision Turbo Kit V-Band Ball Bearing Turbo Mazdaspeed 3 2007-2013
The Following User Says Thank You to speed3 britz For This Useful Post:
 Old 03-12-2014, 06:04 AM   #17
romano1990's Avatar
Posts: 9   (View Stats)
romano1990 will become famous soon enough
Default Looks sweet
Bust blew my motor last week getting the motor built, going gtx3076 or gt35r.
Shooting for as close to 500 as possible. Ill race you :p
romano1990 is offline   Reply With Quote
 Old 03-12-2014, 06:16 AM   #18
Hanzodurrr's Avatar
I'm not worried haha.
BLEW UP AUG 2014
The Following User Says Thank You to Hanzodurrr For This Useful Post:
 Old 03-12-2014, 11:26 AM   #19
Mochi's Avatar
Thinking about buying that kit....
"hold'n my dick!"
 Old 03-13-2014, 12:52 AM   #20
Hanzodurrr's Avatar
Other than the CP-e mani and the EWG spring install the rest of what I tried to accomplish today was a pita. Only had a solid 3 hours or so messing with it all most of that was just planing and talking. Of course got the turbo mounted somewhat and holy shit does it sit lower than I expected. It sits right on top of those bitch ass heater hoses so I wanna replace them with longer lines.
I'm not quite sure if i can replace the hard line with a soft line so that will require some research unless someone that's following this knows. On top of that the Turbo didn't come with the return line bolts which aren't the same size as what came off of the stock so had to make a trip for those. Time to get with edge and kozmic tomorrow and barrage them with more questions.
BLEW UP AUG 2014
Mochi (03-13-2014)
 Old 03-13-2014, 03:19 AM   #21
m.a.vega1's Avatar
I ran into the same issue with the return line. It's definitely an easy fix, however, if edge is going to make it a kit then supplying the ALL the required hardware will make things a lot easier for those looking for a straight "bolt-on" kit. Keep giving them feed-back to make this happen!
The Following User Says Thank You to m.a.vega1 For This Useful Post:
Mochi (03-13-2014)
 Old 03-14-2014, 01:30 AM   #22
Hanzodurrr's Avatar
Got some more stuff done today with the help of @LatinKraze; I removed the coolant hard line that was right by the housing when I mocked it up yesterday and replaced it with a soft line. Got the Intake manifold back on with the new tig amd got the turbo, dp and wastegate mounted up to check fitment with the orientation of the turbo. Still need to tackle the oil return line that is mighty close to the block and figure how the f I'm going to secure the JBR whale penis.
So far everything looks good obviously slight hiccups but nothing so far that makes me regret getting it all. Hoping to have this thing running by tomorrow pending i can track down a silicone coupler for the turbo.
BLEW UP AUG 2014
LatinKraze (03-14-2014), Mochi (03-14-2014)
 Old 03-14-2014, 01:47 AM   #23
xTRELLx's Avatar
Posts: 396   (View Stats)
xTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the world
Groaned at 27 Times in 14 Posts
Fuck dude stop making me jealous... ugh I just can't wait. Let me know about every little problem u have so I can be ready when I do my install.
Sent while fappin wit the Eskimos
xTRELLx is offline   Reply With Quote
The Following User Says Thank You to xTRELLx For This Useful Post:
Hanzodurrr (03-14-2014)
 Old 03-14-2014, 01:50 AM   #24
Hanzodurrr's Avatar
Haha its not on purpose talking about it all helps me not be as frustrated once im done each night lol. I wish there weren't any hiccups at all.
Note 2 Tappin
BLEW UP AUG 2014
 Old 03-14-2014, 01:54 AM   #25
xTRELLx's Avatar
There's always hiccups lol. I'm hoping my friend and I can get the install done in a day or 2
 Old 03-14-2014, 05:52 AM   #26
ms3driver213's Avatar
Posts: 251   (View Stats)
ms3driver213 is the leader of the worldms3driver213 is the leader of the worldms3driver213 is the leader of the worldms3driver213 is the leader of the worldms3driver213 is the leader of the worldms3driver213 is the leader of the worldms3driver213 is the leader of the worldms3driver213 is the leader of the worldms3driver213 is the leader of the worldms3driver213 is the leader of the worldms3driver213 is the leader of the world
Sweet build. Going bb 5858 in a couple of weeks...need to finish buying some odds and ends. What are you doing for intercooler? Can you run anything that will fit k04/gtx or do you need custom pipe?
sent while riding Pegasus through the fiery depths of tartarus
You're probably the idiot that goes wot in 6th gear at 2000 rpm
ms3driver213 is offline   Reply With Quote
 Old 03-14-2014, 06:09 AM   #27
Sebs6's Avatar
Posts: 201   (View Stats)
Sebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the world
Cannot wait to see ur Shit like This gonna be tits.
Sebs6 is offline   Reply With Quote
 Old 03-14-2014, 07:55 AM   #28
LatinKraze's Avatar
Same piping. We just need to pick up a new coupler for the hot pipe to compressor discharge.
2016 CX-5 GT AWD
 Old 03-14-2014, 08:02 AM   #29
No dofferent from a gtx. Thanks
 Old 03-14-2014, 11:07 PM   #30
xTRELLx's Avatar
I demand an update right now!!!
 Old 03-14-2014, 11:22 PM   #31
Hanzodurrr's Avatar
Getting it all bolted back up maybe ill have a startup vid soon
Note 2 Tappin
BLEW UP AUG 2014
 Old 03-14-2014, 11:23 PM   #32
xTRELLx's Avatar
Kool. I want to show u what's been pissing me off the entire day.
P.S. I live in Anchorage, AK.
 Old 03-14-2014, 11:24 PM   #33
xTRELLx's Avatar
 Old 03-14-2014, 11:46 PM   #34
Hanzodurrr's Avatar
Haha fuck that go puck it up
Note 2 Tappin
BLEW UP AUG 2014
 Old 03-15-2014, 02:57 AM   #35
Hanzodurrr's Avatar
ITS ALIVE!!!.......but AFR's are reading 20-22 at idle so I'll be getting with my tuner and rechecking everything. Also got a little coolant leak from the allen screw in the EGR delete so I'm gonna coat that bitch with rtv later today once I wake up. @VegasMS3; and @mr_mazda329; have video of it starting up and me being a scared bitch. Maybe they can post is up at some point. I'll finish off with some pics off the hardline delete and other shit.
BLEW UP AUG 2014
The Following 3 Users Say Thank You to Hanzodurrr For This Useful Post:
Dahouse702 (03-15-2014), LatinKraze (03-16-2014), m.a.vega1 (03-16-2014)
 Old 03-15-2014, 03:05 AM   #36
xTRELLx's Avatar
Sweet. So how much time would u say u spent on the build all together?
 Old 03-15-2014, 03:07 AM   #37
Hanzodurrr's Avatar
Prob about 15 hours ish maybe. Alot was bsing time since I had to wait for clamps and the intake mani tig.
Note 2 Tappin
BLEW UP AUG 2014
 Old 03-15-2014, 04:55 AM   #38
xTRELLx's Avatar
Sweet. Hoping for a 1 day install
 Old 03-15-2014, 07:07 AM   #39
2012FailWheelDrive's Avatar
Posts: 327   (View Stats)
Good idea on changing out those hoses
Sent from my HTC6500LVW using Tapatalk
"under construction"
The Following User Says Thank You to 2012FailWheelDrive For This Useful Post:
Hanzodurrr (03-15-2014)
 Old 03-16-2014, 01:10 AM   #40
LatinKraze's Avatar
We need boost leak test? I may as well keep the 3.5" tester over at your place
2016 CX-5 GT AWD
Hanzodurrr (03-16-2014)
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 02:16 PM
Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy Haltech Automotive News 0 09-02-2011 07:20 AM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.57747 seconds with 33 queries
