Like Tree73Likes
 Old 07-19-2014, 07:24 PM   #41
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
YOU WAIT TILL MY SHIT GETS TOTALLED YOU POS
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
The Following 2 Users Say Thank You to alphasaur For This Useful Post:
ItsNox (07-20-2014), Tokay444 (07-19-2014)
 Old 07-19-2014, 07:52 PM   #42
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Interesting, I would assume that you know that ford sold the ranger with 2.3L duratec with no balance shaft, basically same motor. If there was concern about longevity, would they have been sold without balance shaft? The understanding is that the balance shaft is only for NVH. No reason to put that shit back in.
How much torque did the ranger make again?
(Condescending tone) Did you buy parts off of Facebook?
No
"Exclusivity" - CP-enis
Demodded.
The Seals
Last edited by Tokay444; 07-19-2014 at 07:52 PM. Reason: MSF Database - Automerged Doublepost
ALPINEST4RS (07-29-2014), chaser27 (09-24-2014), Mauro_Penguin (07-20-2014), SpeedThrizzle (07-19-2014)
 Old 07-19-2014, 08:00 PM   #43
No
Good then it's time for @Raider; to ruin someone's day
Where did you get the head?
 Old 07-19-2014, 08:04 PM   #44
Tokay444's Avatar
Groans: 793
The only person's day raider wants to ruin is mine, because I'm a whiny cunt who brings nothing to the platform and am not obese.
Demodded.
The Seals
The Following 8 Users Say Thank You to Tokay444 For This Useful Post:
chaser27 (09-24-2014), dpolseno41 (07-19-2014), ItsNox (07-20-2014), lilred (07-19-2014), Mauro_Penguin (07-20-2014), Pointless (08-07-2014), someguy (07-19-2014), white'swhiteMPS (07-29-2014)
 Old 07-19-2014, 08:07 PM   #45
IF being a whiny cunt was the deciding factor far fewer people would get his assistance.
Besides your Canadian whiny cuntness is bred in.
 Old 07-19-2014, 10:07 PM   #46
Don't care. Head looks perfect. Bolt it in.
 Old 07-19-2014, 11:20 PM   #47
lilred's Avatar
Posts: 5,792   (View Stats)
Agreed.
QC signed off on the head stop being a whiny cunt.
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
Easter Bunny (07-20-2014), Tokay444 (07-20-2014)
 Old 07-28-2014, 08:46 PM   #48
Tokay444's Avatar
Groans: 793
Nliiitend1 and Mauro_Penguin like this.
Demodded.
The Seals
Mauro_Penguin (07-30-2014), mzr0818 (07-29-2014)
 Old 07-29-2014, 07:16 AM   #49
Hurry up and put this thing together already.
 Old 07-29-2014, 02:50 PM   #50
Tokay444's Avatar
Groans: 793
It's going together bit by bit.
Head goes back together tomorrow. Was waiting on new valve seals.
donjohnk and Mauro_Penguin like this.
Demodded.
The Seals
Mauro_Penguin (07-30-2014), mzr0818 (07-30-2014)
 Old 07-30-2014, 11:21 AM   #51
Mauro_Penguin's Avatar
Posts: 1,997   (View Stats)
Groans: 171
That aluminum radiator is so nice! Since your build is so well thought out, I hope you don't mind if I geek out for a minute and ask a couple of questions...
1) What oil do you plan on using once everything is broken in?
2) Will you be adding any kind of baffles to help guide airflow to your radiator and intercooler? It seems like a lot of people ditch the factory one when they go front mount, not a lot of people have tried to fab them up for their cars.
Tokay444 (07-30-2014)
 Old 07-30-2014, 12:26 PM   #52
Tokay444's Avatar
Groans: 793
Once it's broken in I'll use T6 Rotella. I need to find a place to get ZDDP up here though.
As for baffles, I have thought about sealing the back of the bumper to the end tanks of the intercooler to force air through rather than around, and I'll remove the ducting that would normally feed the top mount, and see what I can do about re-directing towards the rad. I believe corksport has a solution for this.
Mauro_Penguin likes this.
Demodded.
The Seals
 Old 07-30-2014, 07:53 PM   #53
Tokay444's Avatar
Groans: 793
I installed all new valve seals tonight.
Checked tappet clearances, and I have a couple that are on the loose side of spec on the intake, and then a couple that are too tight for spec on the exhaust side.
Luckily, all the tappet markings are quite close in size to each other. I'm hoping I can swap some around. I'll mic them all when I'm home from the long weekend and see what I can put where.
Demodded.
The Seals
ItsNox (07-31-2014), Mauro_Penguin (08-07-2014)
 Old 07-30-2014, 08:02 PM   #54
dpolseno41's Avatar
Posts: 1,819   (View Stats)
Hope your build doesn't stall out due to lack of injector seals.
Tokay444 likes this.
The Following 4 Users Say Thank You to dpolseno41 For This Useful Post:
Easter Bunny (07-30-2014), ItsNox (07-31-2014), Mauro_Penguin (08-07-2014), Tokay444 (07-30-2014)
 Old 07-30-2014, 08:03 PM   #55
You going to file the exhaust valve stems down to make them work?
 Old 07-30-2014, 08:47 PM   #56
Tokay444's Avatar
Groans: 793
If it came to that, I'd likely just order the proper tappet sizes I need.
If I still worked in a shop with a surface grinder, I would have sparked off a couple thou for sure.
Demodded.
The Seals
Easter Bunny (07-31-2014), Mauro_Penguin (08-07-2014), meicalnissyen (10-07-2014)
 Old 07-31-2014, 08:12 AM   #57
Tokay444's Avatar
Groans: 793
3 bar map and plug & play pigtail are here.
Courtesy of @Polish_Eagle;
Polish_Eagle likes this.
Demodded.
The Seals
ItsNox (07-31-2014), Mauro_Penguin (08-07-2014), Polish_Eagle (07-31-2014)
 Old 08-07-2014, 04:36 PM   #58
Done yet?
Mauro_Penguin (08-07-2014), SarcasticOne (08-07-2014)
 Old 08-07-2014, 05:26 PM   #59
Tokay444's Avatar
Groans: 793
Done yet?
No
Demodded.
The Seals
 Old 08-07-2014, 05:27 PM   #60
WEll stop getting more parts before you finish with the ones you already have.
 Old 08-07-2014, 05:32 PM   #61
Tokay444's Avatar
Groans: 793
That's the problem when it's a full build. It everything comes in waves.
Like my paycheques.
Demodded.
The Seals
Last edited by Tokay444; 08-07-2014 at 05:32 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-07-2014, 05:35 PM   #62
Admit you just missed dailying a honda.
 Old 08-07-2014, 06:38 PM   #63
Tokay444's Avatar
Groans: 793
This honda won't die.
I did a leak down and compression test last week for shits.
180psi on all 4 and 4% leak. 315000kms.
Demodded.
The Seals
 Old 08-07-2014, 07:19 PM   #64
If only they still made cars I wanted.
magicka (08-11-2014), Mauro_Penguin (08-11-2014)
 Old 08-10-2014, 05:56 PM   #65
Tokay444's Avatar
Groans: 793
Head is torqued down.
Some new tappet sizes may be in my near future.
Demodded.
The Seals
Mauro_Penguin (08-11-2014), Realgib3 (08-11-2014)
 Old 08-15-2014, 04:49 AM   #66
Polish_Eagle's Avatar
Posts: 408   (View Stats)
The one step I hated most during my old build was those damn tappets. Some were hard to get due to them being back ordered.
The Following 2 Users Say Thank You to Polish_Eagle For This Useful Post:
Mauro_Penguin (08-17-2014), Tokay444 (08-15-2014)
 Old 09-23-2014, 06:35 PM   #67
Tokay444's Avatar
Groans: 793
Thanks to the boys over at @relentlesscustoms;
Koke382 and Mauro_Penguin like this.
Demodded.
The Seals
The Following 10 Users Say Thank You to Tokay444 For This Useful Post:
Agent_Orange (09-23-2014), ALPINEST4RS (09-24-2014), chaser27 (09-24-2014), Code Monkey (09-23-2014), Easter Bunny (09-24-2014), Koke382 (10-06-2014), magicka (09-24-2014), Mauro_Penguin (09-23-2014), nindoja (09-23-2014), Pointless (09-24-2014)
 Old 09-24-2014, 07:31 AM   #68
White is right.
Now hurry the fuck up and get this back on the road.
Tokay444 (09-24-2014)
 Old 09-24-2014, 08:10 AM   #69
Yatta's Avatar
Posts: 1,862   (View Stats)
Aside from the spiffy color and the commitment it takes to keep it that way, is this a thermal coating as well? Watching this thread with a lot of interest as I will be starting a parts collection soon. Are you keeping VTCS because Canada? Or is it just the gear to fool the ECU?
Looks like the start of an epic build thread and I can't wait to see the silicone intercooler.
The Following 2 Users Say Thank You to Yatta For This Useful Post:
Easter Bunny (09-24-2014), Mauro_Penguin (09-24-2014)
 Old 09-24-2014, 08:27 AM   #70
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
The balance shaft is not there to balance an out of weight crank.
It is there to relieve the inherent imbalance of the firing order in an inline 4 cylinder motor.
If the rotating assembly isn't weight balanced accordingly, you're gonna have a bad day from the get go and no balance shaft or harmonic balancer is gonna help you.
I know I'm late to the party on this one, but I thought the balance shaft was there to cancel out the vibes from the engine. NOT because of the firing order, since we always have two pistons going up while two are going down, but because the acceleration of the piston is actually higher at the top of the stroke vs. the bottom. This is due to the finite length of the rods. The shorter the rods, the larger the discrepancy between the accelerations, so the larger the vibration of the engine. If our rods were infinitely long, we wouldn't need one.
This is what I've always thought, so if I'm wrong please correct me.
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
 Old 09-24-2014, 09:17 AM   #71
Crarrs's Avatar
Posts: 1,662   (View Stats)
The accelerations are higher at the top and bottom of the stroke because all four pistons are stopping at the same time. The flywheel is the component that smooths out that effect to some extent. The balance shaft is there for secondary-phase vibrations.
EDIT: If you've got the attention span, this paper will tell you more than you ever want to know about vibrations, forces, and balance.
http://www.tonyfoale.com/Articles/En...ineBalance.pdf
2004 MSM TiGrey
The Following 4 Users Say Thank You to Crarrs For This Useful Post:
Easter Bunny (09-24-2014), ItsNox (09-25-2014), Mauro_Penguin (09-25-2014), Tokay444 (09-24-2014)
 Old 09-24-2014, 10:05 AM   #72
chaser27's Avatar
Groans: 42
This paragraph is what I was trying to get at... The piston motion isn't actually sinusoidal, so the forces at top and bottom are not the same, causing vibration.
"The motion of the piston is approximately sinusoidal, and therefore so too are the acceleration
forces. If the connecting rod was infinitely long, that motion would actually be truly sinusoidal, but
most conrods are approximately twice the crankshaft stroke in length. This relative shortness of the
rod means that, except for the TDC and BDC positions, the rod will not remain in line with the
cylinder axis through a working cycle. The angularity of such a short conrod throughout a complete
crankshaft revolution modifies the piston motion, see figure 3. With a very long conrod we would
expect that the maximum velocity (and hence zero acceleration) of the piston would occur at 90° of
rotation from TDC. With a 2:1 conrod length to stroke ratio, maximum velocity occurs just past 77°.
In fact an infinite number of higher order harmonics are introduced into the piston acceleration.
These harmonics complicate the balancing of an engine. Fortunately, as the harmonics increase in
order, their magnitude decreases, and so they become less important. In practice, it is usual only to
consider the first and second harmonics when doing balance calculations. The reciprocating forces
with a frequency equal to the engine RPM are known as primary forces and the reciprocating forces
from the second harmonic, which cycle at twice engine speed, are known as secondary forces."
ECU: self-tuned
The Following User Says Thank You to chaser27 For This Useful Post:
 Old 09-24-2014, 10:37 AM   #73
Tokay444's Avatar
Groans: 793
I'm just retaining vtcs system to fake the ecu. There aren't any valves left in the runners.
The powder coat will likely add some insulation, which isn't ideal.
Anytime you can shed head from your intake tract, you want to. But it glows in the dark, so NCE.
Koke382 and Yatta like this.
Demodded.
The Seals
Easter Bunny (09-24-2014), Koke382 (10-06-2014), Mauro_Penguin (09-25-2014), Yatta (09-24-2014)
 Old 09-24-2014, 10:40 AM   #74
Crarrs's Avatar
In short, yes, the balance shaft is there because infinite-length connecting rods are impossible, and the piston speeds are always changing, causing second-order harmonic issues.
Buy this. Read it. Enjoy your new knowledge. Mine's sitting on a shelf in my closet.
Mechanical Vibrations (4th Edition) 4th Edition | Rent 9780130489876 | 0130489875
2004 MSM TiGrey
The Following 5 Users Say Thank You to Crarrs For This Useful Post:
chaser27 (09-24-2014), Easter Bunny (09-24-2014), Mauro_Penguin (09-25-2014), mize13 (09-29-2014), Tokay444 (09-24-2014)
 Old 09-24-2014, 03:48 PM   #75
ledfootrob's Avatar
Posts: 195   (View Stats)
ledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the world
Did you use the SST installing the Balance Shaft? And were the original shims used again and in spec?
2012 Black Mazda 3 MPS
CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC
2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate
OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors
Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks
Versus Eurolace 19 x 8 +45 - Hankook RS3
Built & Tuned by Rob
Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18
DBA T3 Rotors - Carbotech XP10 Brake Pads
ledfootrob is offline   Reply With Quote
 Old 09-24-2014, 04:36 PM   #76
Tokay444's Avatar
Groans: 793
I did Not use the sst and the original shims were re-used.
It came out it a brand new block long enough to put the rods in and went right back in.
Demodded.
The Seals
Easter Bunny (09-25-2014), Mauro_Penguin (09-25-2014)
 Old 09-29-2014, 07:29 PM   #77
Oni
Oni's Avatar
Posts: 565   (View Stats)
Oni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the world
@speed3 britz; he's using your unicorn turbo
Sent from my iPad using Tapatalk HD
'12 Velocity Red Mica MS3
Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune
Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness
Oni is offline   Reply With Quote
The Following User Says Thank You to Oni For This Useful Post:
speed3 britz (10-01-2014)
 Old 10-06-2014, 03:14 PM   #78
Tokay444's Avatar
Groans: 793
Aquamist HFS-4 ordered.
Demodded.
The Seals
The Following 7 Users Say Thank You to Tokay444 For This Useful Post:
chaser27 (10-06-2014), Code Monkey (10-06-2014), ItsNox (10-06-2014), Justin@Freektune (10-06-2014), Koke382 (10-06-2014), Mauro_Penguin (10-06-2014), twenty5psi (10-07-2014)
 Old 10-06-2014, 08:08 PM   #79
Groans: 171
Jesus fucking christ, your build is everything I'm planning for mine.
The Following 2 Users Say Thank You to Mauro_Penguin For This Useful Post:
Roddiy (10-06-2014), Tokay444 (10-07-2014)
 Old 10-07-2014, 05:39 AM   #80
Tokay444's Avatar
Groans: 793
I've also decided to go FreekBuilt on the head over the winter.
taf0422 and Mauro_Penguin like this.
Demodded.
The Seals
Code Monkey (10-07-2014), Drive By Fire (10-07-2014), Mauro_Penguin (10-08-2014)
Video: The 2011 Porsche Cayenne commercials have begun Haltech Automotive News 0 05-24-2010 11:40 AM
Your Formula 1 season has officially begun, Brawn GP in the lead Haltech Automotive News 0 03-28-2009 11:50 AM
Page generated in 0.57221 seconds with 33 queries
