 Old 03-02-2011, 11:19 PM   #1
SkwidKid007's Avatar
Posts: 248   (View Stats)
SkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond repute
Groaned at 3 Times in 1 Post
Default Help with BT
Ok, im looking at getting a 3071R... What do i need as for intake? i have the cobb SRI and RPMCC TIP... Im sure the IP is going to be junked, but is there a way i can buy the ATP IP and make it work with the Cobb SRI? Or will i have to buy the ATP IP and SRI?? If not, whats some ideas of "Custom" work?
Thanks guys! Your contributing to another BT member!
2008.5 MS3 White
BNR StageIII, RPMC TIP, NGK ITV7IX-11, GS EBCS, Cobb SRI, HKS SSQV3 VTA, Exhaust Depot Black IC Piping, Godspeed FMIC, PTP HPFP, CP-e 75 duro RMM, Turbo XS long 3" DP, Magnaflow 3" CBE, Raceland CO, TWM STS & Bushings, Hawk Pads, Stop-tech Slotted Rotors, Pioneer Avic-Z130BT, Motegi MR-116's wrapped with 235/40/18 Eagle GTs
320WHP/364WTQ 20lbs 93- Calvin @ Cobb (13.3@109 Skreet Tires)
3/8 mix E85 21lbs- Ziggo (12.9@113 Skreet Tires)
SkwidKid007 is offline   Reply With Quote
 Old 03-02-2011, 11:41 PM   #2
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
The ATP inlet is shit, and it doesnt line up to the stock location where it meets the intake.
Get the CPe inlet for big turbo.
Here is a pic from when I was installing.
ATP.......................... CPE.......................... Stock
2008 STi
Intake
Turboback
AP
The Following 3 Users Say Thank You to danesti For This Useful Post:
Docnox (03-19-2011), dougefresh_ (03-19-2011), jracer (03-20-2011)
 Old 03-02-2011, 11:42 PM   #3
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
intake wont matter, what will matter is your inlet.... u will need either a custom one, a cpe big inlet or an ATP one that has a 4 inch coupler.
thats all
 Old 03-02-2011, 11:44 PM   #4
Thanks! so i can go to my cobb from the cpe?
never mind... that question is answered! Thanks!
2008.5 MS3 White
Last edited by SkwidKid007; 03-02-2011 at 11:44 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-02-2011, 11:44 PM   #5
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
yes, but when u order it SPECIFY that u has cobb sri and they will send u the metal insert/reducer
have fun, dont blow up
easy (03-03-2011)
 Old 03-02-2011, 11:50 PM   #6
I am... and i plan on not blowing up... haha.. i have back up money in case i do!
Cobb is doing all the tuning, so i will be sure to let them know its not built and needs just a conservative tune until i do build..
one more ?... the kit says it comes with everything to bolt right up... does that mean the Coolant, and oil inlet lines has adapters? or does it just bolt right up?
once again thanks!
2008.5 MS3 White
 Old 03-02-2011, 11:54 PM   #7
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
educate yourself on the most awesome thread ever
http://www.mazdaspeedforum.org/forum/foru...ver-too-63559/
 Old 03-02-2011, 11:55 PM   #8
danesti's Avatar
Groans: 137
Moar Pics
As far as the kit goes...
You should be provided with all the proper stuff (My turbo used mostly stock stuff, just different banjo bolts), I cant remember for sure though.
I modified my oil return line.
It came with the necessary coolant line.
2008 STi
Intake
Turboback
AP
The Following User Says Thank You to danesti For This Useful Post:
Docnox (03-19-2011)
 Old 03-03-2011, 12:01 AM   #9
reading the thread
the reason i ask is bc im buying the turbo used, and i dont think the guy has any of the lines... he said he thinks all i need is a return line for the oil.. im just making sure before i buy, of what all i need...
2008.5 MS3 White
 Old 03-03-2011, 12:06 AM   #10
danesti's Avatar
Groans: 137
Pretty sure you need a coolant line
2008 STi
Intake
Turboback
AP
 Old 03-03-2011, 12:11 AM   #11
ok... we have a local shop that makes braided lines, so im trying to get together what all ill need... this almost makes me want to just go with the BNR stage 3... hahah
2008.5 MS3 White
 Old 03-19-2011, 12:17 AM   #12
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Any luck getting the line? I'm about to go w/ a 3076 and I forgot I have to revisit all that shit. I was pretty damn sure you can make do with all the stock lines except the coolant line it comes with... but I've been wrong once before and it's been awhile. GLWBT
 Old 03-19-2011, 12:19 AM   #13
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
all ? are answered on ma thread.... i have spoken!
 Old 03-19-2011, 12:34 AM   #14
^Ah yes it is. I'll have to reread through that tomorrow. And I need to figure some shit out this week! I want to see the welder to "fix" my hot pipe tapped, so I can get ordering shit and get this thing going. I had the pipe tapped on the left (over the mani) before I bought the DNP on a fluke (brand new, good price from a local friend, so got that and DP). Sooo... with the heat shields gone, my unrestricted boost source tap is hovering over the mani. Gonna have that chopped off and sealed, and retapped on the intake side so it's away from the heat. There's a 75% chance that's where my boost leak is that i still haven[t bothered looking for, lol.
EDIT: If I had a garage that leak would've been fixed 2 months ago :/
Page generated in 0.33493 seconds with 22 queries
