Like Tree4Likes
  • 1 Post By Chimmike
  • 2 Post By Chimmike
 Old 08-19-2012, 10:57 AM   #1
Mikey's Avatar
Posts: 2,049   (View Stats)
Mikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the world
Groans: 104
Groaned at 45 Times in 36 Posts
Default help on this piece please
installing my gt3071r and have everything figured out except this one lil piece? Any help would be awesome.
Thanks
2007 Cosmic Blue
Built HTA 3076 Corn Fed with shot of Meth and Freektuned
Mikey is offline   Reply With Quote
 Old 08-19-2012, 11:30 AM   #2
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
nevermind bump
 Old 08-19-2012, 11:56 AM   #3
MS6_Auburn_Fan's Avatar
Posts: 481   (View Stats)
That's the quick tap for the boost reference to connect to your boost control solenoid. It's made to tap into the coupler right off the turbo.
MS6_Auburn_Fan is offline   Reply With Quote
 Old 08-19-2012, 12:04 PM   #4
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
drill hole in silcone coupler, install. Rocket science it is not.
This concerns me........
07 MS3
The original Genpoo Hater
 Old 08-19-2012, 04:42 PM   #5
Mikey's Avatar
Groans: 104
bump
update:
we finished installing the 3071r and JBR 3.5 intake. as we start the vehicle it turns on then no higher than 1rpm shuts off. we even started it then gave it gas and still goes no high than 1rpm. any ideas? we double check, retighten every bolt,nut, and the maf. Need to know where the pigtail 3bar maf goes though.
2007 Cosmic Blue
The Following 2 Users Say NO Thank You to Mikey For This Un-useful Post:
cbspd3flip (08-20-2012), Chimmike (08-20-2012)
 Old 08-19-2012, 06:55 PM   #6
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Didnt realize this was the section for the confused.
Shouldnt this kind of shit been posted elsewhere?
700HP CLUB
11.479@124mph
#DIX
 Old 08-19-2012, 07:00 PM   #7
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Originally Posted by Mikey View Post
bump
update:
Did you adjust your mafcal for the new intake?
The Following 3 Users Say Thank You to Etipp98 For This Useful Post:
silentwolf8 (08-20-2012), smoogs12 (08-19-2012), uncorked11 (08-19-2012)
 Old 08-19-2012, 07:03 PM   #8
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Pigtail goes on the map sensor, left side of intake manifold on the last runner half way down, i believe its an 8mm screw holding the sensor in place, if you unplug the 2 big grey clips it makes it easier to see. +1 on maf cal, to much air coming in and your car is goin fucking ceazy
TEAM LUXURY
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
MS6FL (08-19-2012), rolanblack (08-19-2012)
 Old 08-19-2012, 09:03 PM   #9
rolanblack's Avatar
Posts: 2,110   (View Stats)
Thanks dude, Mikey, RED and I install the turbo and later it was just Mikey and I installing everything else. We were stumped on the 3bar mafMAF on where it goes. Now the only problem we ran into was after the startup and give it a little WOT! She backfires and stumbles getting up there. Any ideas?
 Old 08-19-2012, 09:09 PM   #10
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Well im gonna guess that you have not done much (any?) tuning for the new turbo so thats a possibility for why you are having issues.
Also did you set the scalars and offset for the new map sensor?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 08-19-2012, 09:11 PM   #11
snailD's Avatar
Posts: 3,039   (View Stats)
map sensor and big maf both have to be accounted for in the tune. without that car wont start
The Following User Says Thank You to snailD For This Useful Post:
 Old 08-19-2012, 09:15 PM   #12
rolanblack's Avatar
Yep, loaded a stock tune for the his new turbo. After we loaded, the vehicle started up.
 Old 08-19-2012, 09:20 PM   #13
smoogs12's Avatar
Groans: 423
So you didnt set the scalars for the 3 bar nor did you scale the maf sensor.
ugh.
Do both of these things now.
What are you using for boost control?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 08-20-2012, 03:43 PM   #14
Will fuck up ur day
Chimmike's Avatar
Groans: 433
OP, did you do any fuckin' research on this stuff before randomly installing it all?
<------is even more concerned now.
p057 likes this.
07 MS3
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
Colin1337 (08-20-2012), jman46 (08-20-2012), p057 (08-20-2012)
 Old 08-20-2012, 03:48 PM   #15
darkcherry's Avatar
Posts: 930   (View Stats)
darkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the world
In before, new thread: Zoom zoom boom.
mods:
Do wmi 50/50, freek tune 306hp/350tq.
blitz bov, cpe hpfp, tmic, excel nano sri, tip, blue duro rmm, 3" ss catted dp, 3" ss cs cat back exhaust, Cobb AP, sure short cut, counter weight, twm stage 1&2, ms cf shift knob, msd dh, autoexe rear brace, whiteline rsb, tt rear diff mount, awr pmm , winter=stock wheels w/winter tires / summer=18x8 adr hyp black wheels w/bfg force kdw, eibach sportline springs. Soon to come: bt, slotted rotors, cf fi hood
darkcherry is offline   Reply With Quote
The Following 3 Users Say Thank You to darkcherry For This Useful Post:
Chimmike (08-20-2012), jman46 (08-20-2012), p057 (08-20-2012)
 Old 08-20-2012, 03:58 PM   #16
silentwolf8's Avatar
Posts: 1,986   (View Stats)
silentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the world
Groans: 44
Agreed.. why would you decide to go WOT after starting it, when it died at idle..
This is a ZZB waiting to happen. I mean seriously, who decides to WOT to see if the car will stay on after start.
You must have not read on the JBR intake either during his first batch of intakes.. i think i was first to post the issue with the dieing at idle.. then everyone started jumping on and it became a maf cal discussion.. RESEARCH BEFORE DOING
ZOOM ZOOM left the Room
2013 SPW STi // COBB SRI w/Box // COBB BPV // UR Catless DP// UR CBE // COBB Lowering Springs // COBB Sway Bars // +1 NGK // DW65c FP
AWDTuning Tuned
silentwolf8 is offline   Reply With Quote
The Following User Says Thank You to silentwolf8 For This Useful Post:
 Old 08-20-2012, 03:59 PM   #17
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
more like " Fucking mazda making shitty motors"
guys, really? no research was done before just throwing these parts on?
I must have done like a month's worth of reading prior to doing the actual install. And i'm still learning things about it even though I did the upgrade back in March or whatever.
p057 is offline   Reply With Quote
The Following 2 Users Say Thank You to p057 For This Useful Post:
Chimmike (08-20-2012), darkcherry (08-20-2012)
 Old 08-20-2012, 04:02 PM   #18
Matx's Avatar
Posts: 1,681   (View Stats)
Matx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the world
..... DEAR GOD: WE HAVE TOO MANY IDIOTS PLEASE STOP MAKING THEM, KTHKSBYE!
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
Originally Posted by backward_0 View Post
.... I will be more than happy to fuck your world off....
Matx is offline   Reply With Quote
The Following 2 Users Say Thank You to Matx For This Useful Post:
 Old 08-20-2012, 04:07 PM   #19
Will fuck up ur day
Chimmike's Avatar
Groans: 433
today has been a fucking orgy of idiocy, and i'm losing patience. next one I'm just gonna close the fucking thread. after that I may start randomly banning.
silentwolf8 and Matx like this.
07 MS3
The Following 4 Users Say Thank You to Chimmike For This Useful Post:
darkcherry (08-20-2012), jman46 (08-20-2012), Matx (08-20-2012), silentwolf8 (08-20-2012)
 Old 08-20-2012, 04:09 PM   #20
Groans: 44
no shit.. it seems to be everywhere.. i cant go an hour with out something stupid being posted about a part, or direction.. and now this crap.
AWDTuning Tuned
Chimmike (08-21-2012)
 Old 08-20-2012, 04:15 PM   #21
darkcherry's Avatar
I think op needs some of this to get his car running right, then maybe it won't stall and backfire when wot after no maf cal or tune.
mods:
The Following User Says Thank You to darkcherry For This Useful Post:
 Old 08-20-2012, 04:54 PM   #22
rolanblack's Avatar
ugh.
I honestly don't know what your talking about. Enlighten please.
He is still using his stock Bcs.
 Old 08-20-2012, 04:58 PM   #23
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
map sensor needs to be accounted for, as does the diameter of the maf housing. he's getting too much air not reading pressure properly...that will fuck shit up
Blue Pu.
 Old 08-20-2012, 05:05 PM   #24
jman46's Avatar
Posts: 3,169   (View Stats)
jman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the world
Groaned at 26 Times in 20 Posts
@chimmike I think we need a "Big Fail Builds" section.
'06 F350 Lariat PSD - 458whp/818wtq
'07 MS3 - 313hp/323tq - sold - the FIRST EVER FREEKPerm.
'06 F150 SCrew 4x4 5.4l - sold
'03 Marauder - Vortech on only 8psi 485whp/435wtq - sold
'95 Mustang GT - sold
'95 SHO MTX - sold
jman46 is offline   Reply With Quote
The Following User Says Thank You to jman46 For This Useful Post:
 Old 08-20-2012, 05:06 PM   #25
smoogs12's Avatar
Groans: 423
Uhoh...
Fist thing you need to do is neuter the WGDC table. Set ALL of the values to 0. (EDIT: or just unplug the solenoid)
Then buy an mbc. Its generally accepted as the easiest method of controlling boost with a BT.
After that read this Stock Fitment 3 Bar Map Sensor Upgrade. The scalars and offests are in the bottom of the op. There is also0 much discussion as to what numbers work the best. Read through the thread.
Next you need to scale your entire maf table by 26% (I believe this is what it is, someone please correct me if Im wrong). Then you need to do a proper maf cal.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
rolanblack (08-20-2012)
 Old 08-20-2012, 05:07 PM   #26
rolanblack's Avatar
@Mikey
Need to read.
 Old 08-20-2012, 05:11 PM   #27
smoogs12's Avatar
Groans: 423
@Mikey
Need to read.
Just so you know that was a VERY basic list of things to do.
I highly recommend contacting an etuner and having them make a base map to get things going safely.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
snailD (08-20-2012)
 Old 08-20-2012, 05:15 PM   #28
rolanblack's Avatar
I believe his tuner sent him his new stock tune with the turbo added to the equation. But honestly dude, thanks for the information.
The Following 2 Users Say Thank You to rolanblack For This Useful Post:
smoogs12 (08-20-2012), snailD (08-20-2012)
 Old 08-20-2012, 05:54 PM   #29
Speeden6's Avatar
Posts: 598   (View Stats)
Speeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the world
Respect for going BT but i have to Sub to see if he blows after reading the first little bit.
make sure to mention me in your For Sale Post so i can have dibs on that turbo, honestly, best of luck though!
2007 MS6 -
CPE TMIC, CS HPFP Internals, CS Stage 2 Intake and Inlet, Turbo Smart 50/50 BPV / BOV, Catless DP
2006 Acura TL Fully bolted and Running Nitrous! 330WHP SOLD
SOLD 1992 Corrado VR6
268 Cams, air intake, cat back, upgrade plugs and wires, coilovers.
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
CAI, TIP, ETS TMIC, AutoTech Internals, TBE catless, E85 30%,
19PSI, Cobb AP, RMM, K04, HKS SSQ4 VTA,
TUNED BY LEX FOR 330 AWHP / 380 TQ
Custom tune by
The habits we form today are the ones that Define us tomorrow
Speeden6 is offline   Reply With Quote
The Following 2 Users Say Thank You to Speeden6 For This Useful Post:
Chimmike (08-21-2012), greenespeed (08-20-2012)
 Old 08-21-2012, 06:24 AM   #30
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Really, really disappointed in the lack of fucking research done by OP on this build. If you don't know what shit is, what business do you have installing it?
p057 likes this.
07 MS3
jman46 (08-21-2012), p057 (08-21-2012)
 Old 08-21-2012, 09:36 AM   #31
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
ok, so OP is local to me, but i don't really know him. i'll say that he's a nice guy and is always helpful to the locals in installing parts. i'm honestly a little surprised that he didn't do more homework.
i believe he is perm tuned, so he has that resource available to him.
that said...
it's fun to do bad things
SURE 1 piece RMM swampthigger MazdaSpeed 3 - Engine, Transmission & Driveline 23 12-30-2010 10:42 AM
SU MS3 2 piece MM to 1 piece MM Frosty MazdaSpeed 3 - Engine, Transmission & Driveline 5 04-05-2010 07:29 PM
HELP!!! Broken Piece!! taf0422 Custom Performance Engineering (cp-e.com) 20 04-23-2009 07:28 PM
What is this piece that broke for? Element MazdaSpeed 3 - Engine, Transmission & Driveline 12 03-30-2009 12:36 PM
Page generated in 0.51182 seconds with 38 queries
