(Thread Starter) | Not Ranked : 0 score The HX35w that I am going to use is a journal bearing burbo that is not cooled with coolant so the install is easier, but not by much. Holset requires a oil drain that has a 19mm ID or 3/4" which is a an12 hose. I found a T3 drain to an12 fitting here: Race Proven Motors Store - Flange - T4 Oil Drain - 12an Male and here: Wolfe Race Craft - Detail they are difficult but not impossible to find. They are mainly used on ~100mm large frame turbos. There are no clearance issues fitting an12 parts to the turbo, there is plenty of room. The oil hose must have a minimum of 30* of downward angle, there must be no uphill sections or kinks. The oil input side is a little more complex. We have a very good high flow oil pump from the factory and it is capable of very high pressures. Holset set the oil pressure spec at 85psi max cold, 75psi max warm with a 10psi minimum pressure at idle. Diesel trucks run lower rpms and generally have lower oil pressures when compared to gas engines. So we have to run a restrictor. Most of the people that I have seen are running a 0.075" restrictor and on a an4 feed. A an4 to m12x1.5 fitting for the turbo end can be found here: EXTREME PSI : Your #1 Source for In Stock Performance Parts Two issues that I immediately see are: The oem oil feed may not be the same pressure as the oil pressure at the filter. Has anyone measured this? The oil restrictor used on other engines hasnt been used on ours. People have gotten 300rpm+ faster spool times by lowering the pressure of the oil feed, the minimum full spool oil pressure spec is ~30psi so anyone have any input or measurements of oil pressure at the fitting under the alternator?
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
__________________ [01:31 PM] SoAgg159: my dick is called "quarter mile" it's about 1/4" long and i can give about 14secs of pleasure [07:06 PM] DarkHeartMS6: yeah. I actually hope i catch my wife with another dude. gives me an excuse to open the emergency door and bail. LOL [09:13 PM] Pu Manchu: i like to take my gf through the drive thru so i can prove that i can pleasure a woman |
| The Following 3 Users Say Thank You to forcedinduktion For This Useful Post: |
![]() Join Date: Jan 2011 Location: Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 658
Hey whats up man, so what I am using is just the factory line and banjo bolt. So far it if working great, you could try the upgraded restricter for the ko4 if you are worried about it blowing the seals. As for spool I am seeing 21.5psi at 4k (spring pressure) on the 35 which is plenty fast out of a turbo that size. I also have almost 5k on this turbo set up now too
__________________ Hx35 sold New sc6266 | |
| The Following User Says Thank You to sleepyspeed6 For This Useful Post: | 06Speed6 (04-14-2013) |
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | |
I also have a ton of info on fittings and such in there if you just look for all the fittings and visio stuff you can see all the other parts. here is my feed point for the sending unit. edit: info on fittings and lines in OP The FAIL formerly known as "Dano's Drop-in Build" two different restrictors are included in the parts list but not sure the banjo bolt is the same on the HX.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| The Following 3 Users Say Thank You to Dano For This Useful Post: |
| Not Ranked : 0 score No I figured since it hasn't blown the ko4's glass seals the hx would be fine. If they did blow it's cheap to rebuild these turbos, I would rebuild it and put a smaller restricter in the banjo
| The Following 2 Users Say Thank You to Dano For This Useful Post: | 06Speed6 (04-15-2013), torquemaniac (11-08-2015) |
(Thread Starter) | Not Ranked : 0 score Turbo is gonna need a restrictor then. Its cool that we dont have a oil pressure loss somewhere in the motor though so I cant complain too much.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | Boosted Beluga (04-15-2013) |
| Not Ranked : 0 score Is the oil inlet the same as OEM/garrett? I am using a 1mm restrictor banjo bolt from eBay that you could drill out if you have some tiny bits. Tappin
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 04-15-2013 at 08:56 AM. |
| The Following User Says Thank You to Dano For This Useful Post: | 06Speed6 (04-16-2013) |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score I've been considering going to a 10W oil.
__________________ | |
| The Following User Says Thank You to silvapain For This Useful Post: | Dano (04-16-2013) |
| Not Ranked : 0 score Makes me feel better about my pressure. Maybe my location is good and I don't have issues with my bearings. With motor fully warm to hot I am running 9 psi at idle. New motor has ProSupport sammach plate. Tappin
Groans: 70
| Not Ranked : 0 score How about running a sandwich plate as such, can run oil temp and pressure sensor? Mishimoto MMOP-SP Silver Oil Sandwich Plate M20
Groans: 136
| Not Ranked : 0 score Probably the clearances. Maybe I should hook up a pressure gauge, LOL!
| The Following User Says Thank You to phate For This Useful Post: | silvapain (04-16-2013) |
(Thread Starter) | Not Ranked : 0 score In "5w30" the 5 is its cold viscosity and the 30 is the warm viscosity. Going with a 10w30 wont help you at all with warm oil pressures. A 10w50 would.
| The Following 2 Users Say Thank You to 06Speed6 For This Useful Post: | silvapain (04-17-2013), torquemaniac (11-08-2015) |
Groans: 136
| Not Ranked : 0 score I'd rather go 5W40 than jump right up to 10W50, but you make a good point.
| The Following User Says Thank You to silvapain For This Useful Post: | 06Speed6 (04-17-2013) |
(Thread Starter) | Not Ranked : 0 score I forgot about the 5w40, I havent seen a 5w50 though.
![]() | | #19 | ![]() |
![]() Join Date: Mar 2010 Location: Tampa/Zephyrhills, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 80
| Not Ranked : 0 score This Is good info and that you are looking into the correct pressure for these turbo's. As I am currently gathering everything to do a HX35w 7 blade build.
__________________ 2008.5 CPW JBR:3.5 intake, fmic, r51 Battery Box, Ancors, EGR Delete, Thermal Spacers, 5mm Wheel spacers, Shift plate. Matt Dimond OCC, Autotech Internals, CNT catted downpipe, itv-22, Threadstone T8L FMIC,SU Turbosmart Bpv, SUv2 Rmm |
![]() | | #20 | ![]() |
| Banned ![]() Join Date: Jan 2013 Location: Clinton Township, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 254
| Not Ranked : 0 score just did my hx35w install over the weekend. very impressed with the very quick spool time so far. i cant wait to start polishing up the tune. |
![]() | | #21 | ![]() |
![]() Join Date: Jun 2010 Location: France, Fos sur mer
Rep Power: 130 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score I want to do the same setup (T3 TwinScroll top mount & hx35 7 blades). Say what you took as oil feed/return lines. In twin scroll, HX35 spool at 3500 rpm, 3800 ?? Thanks. Last edited by Fracass; 05-28-2013 at 09:12 AM. |
| Holset HX35 turbo | 06Speed6 | MazdaSpeed 3/6 - Turbo Induction | 3 | 04-05-2013 10:34 PM |
| holset turbo powa | austin102085 | MazdaSpeed 3/6 - Big Turbo Builds | 106 | 06-24-2010 01:09 PM |
