![]() | | #41 | ![]() |
![]() Join Date: Nov 2008 Location: pensacola FL
Rep Power: 580 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
me + sb + tuning =
__________________ 2008.5 Mazdaspeed 3 Built Engine- CP Pistons 9.5:1/Pauter Rods -- Holset Big Turbo-- DNP Manifold w/ewg -- Tial 44mm EWG -- STRATIFIED EBCS CP-E Catback Exhaust -- Custon Downpipe-- CUSTOM 3.25 MAF-- CP-E 4 inch Turbo Inlet, custom Proto-type Injector Seals COBB AP CUSTOM TUNE-- COBB FMIC Fuel Pump Internals -- Devils Own Meth Kit #7 -- Spin-on Oil Filter -- 3 Step Colder Plugs -- TWM Short Shift Custom Center Gauge Pod -- Custom 1 Of A Kind MS3 Gauges -- Halo Lights -- Front Lip -- Emblem Less Grill -- Rice Gen1&2 Hood Hybrid 513whp MS3<-- for now (sold)1993 RX7 FD build in progress!!!!!! | |
![]() | | #42 | ![]() |
![]() Join Date: Sep 2009 Location: CREVE COUER, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
Groans: 75
| Not Ranked : 0 score got any pics of the welds on that flange? |
![]() | | #43 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
| Not Ranked : 0 score Looks really good man. Good luck with the tuning. That's where the fun will begin
__________________ 2012 WRX HB w/mudflaps yo! |
![]() | | #44 | ![]() |
![]() | | #45 | ![]() |
Groans: 75
![]() | | #46 | ![]() |
| The Following User Says Thank You to austin102085 For This Useful Post: | Fagwagon (03-29-2010) |
![]() | | #47 | ![]() |
Groans: 75
![]() | | #48 | ![]() |
Groans: 60
I'll be at work all day tomorrow...
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score o yea awd... hahah. imma swing by if its cool..
![]() | | #50 | ![]() |
Groans: 60
| Not Ranked : 0 score Shouldn't be a problem...
![]() | | #51 | ![]() |
Groans: 60
| Not Ranked : 0 score Where are your logs??
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score log in post #3
![]() | | #53 | ![]() |
Groans: 60
| Not Ranked : 0 score I would try adding about 10% fuel pressure from 4K to redline... There's no knock, but your still a little lean.. You need to put -10 in the cells in the fuel pressure map not +10..
![]() | | #54 | ![]() |
![]() Join Date: Mar 2010 Location: WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 223
| Not Ranked : 0 score Love it! I'm doing a holset set up on my 99 Eclipse. |
![]() | | #55 | ![]() |
(Thread Starter) | Not Ranked : 0 score 1. new log added to post #3 2. video will be posted today/tomm 3a. got a dyno done most made was 287/ sb(pnp) no flashes, no tune, only 15psi(ewg spring) no meth. 3b. dyno printer was down i will have the charts up as soon as i get them
| The Following User Says Thank You to austin102085 For This Useful Post: | djuosnteisn (04-08-2010) |
![]() | | #56 | ![]() |
![]() Join Date: May 2008 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 179
Groans: 46
| Not Ranked : 0 score I'm no tuning expert my ANY means, but your 2nd log graph just looks a little off to me. You got a big knock jump, and your boost pressure spikes like a Guido's hair on J.S.. Feel free to tell me i'm wrong and explain the answer though, I enjoy learning. |
![]() | | #57 | ![]() |
![]() Join Date: Mar 2010 Location: LA/OC
| Not Ranked : 0 score Holset makes great turbos. |
![]() | | #58 | ![]() |
the kr is no big deal its only up to 0.7 not bad. but the boost is fucked and i have no idea why. your guess is as good as mine. imma do some sb logs instead of dh tomm afternoon.
![]() | | #59 | ![]() |
![]() Join Date: Nov 2008 Location: Monterrey / San Antonio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51
| Not Ranked : 0 score in your log your boost spikes and drops under acceleration wtf???
__________________ yes it's modded. |
| The Following User Says NO Thank You to Huligan For This Un-useful Post: |
![]() | | #60 | ![]() |
Groans: 78
| Not Ranked : 0 score yeah that log is pretty effed. how did the car feel during that? |
![]() | | #61 | ![]() |
![]() | | #62 | ![]() |
car felt fine during the run. i didnt notice any thing out of the norm. imma make a sb log today and see what that looks like.
__________________ 2008.5 Mazdaspeed 3 Built Engine- CP Pistons 9.5:1/Pauter Rods -- Holset Big Turbo-- DNP Manifold w/ewg -- Tial 44mm EWG -- STRATIFIED EBCS CP-E Catback Exhaust -- Custon Downpipe-- CUSTOM 3.25 MAF-- CP-E 4 inch Turbo Inlet, custom Proto-type Injector Seals COBB AP CUSTOM TUNE-- COBB FMIC Fuel Pump Internals -- Devils Own Meth Kit #7 -- Spin-on Oil Filter -- 3 Step Colder Plugs -- TWM Short Shift Custom Center Gauge Pod -- Custom 1 Of A Kind MS3 Gauges -- Halo Lights -- Front Lip -- Emblem Less Grill -- Rice Gen1&2 Hood Hybrid 513whp MS3<-- for now (sold)1993 RX7 FD build in progress!!!!!! Last edited by austin102085; 04-09-2010 at 11:18 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #63 | ![]() |
![]() | | #64 | ![]() |
(Thread Starter) | Not Ranked : 0 score so i know i havent been updating this like i should but car is running great. just need to get the flashes and stop running on 14.5 psi. then ill be golden. any way i went racing this weekend and got beat by a car that no one needs to be beat by and it put a bad taste in my mouth so imma be looking to get the flashes soon. so more to come from another BT sb tuned car with flashes.
| The Following 2 Users Say Thank You to austin102085 For This Useful Post: | cageyvet (05-02-2010), djuosnteisn (05-02-2010) |
![]() | | #65 | ![]() |
(Thread Starter) | Not Ranked : 0 score ECU SENT TO CP-E FOR ALLLLLL THE FLASHES.... should get it back in a couple days and gonna up the boost and fuck aroud with it. with a lil help from jake.. then in 3-4 weeks will be making a drive to cp-e and getting a no shit tune. so look forward to another great ms3 on the road.... thanks to all that follw my thread and progress. p.s. ms3077 still a bitch hahaha (if you knew it would be funny)
| The Following 3 Users Say Thank You to austin102085 For This Useful Post: |
![]() | | #66 | ![]() |
| Not Ranked : 0 score GL man. You're gonna love what Jake does to that thing. Spinning tires in fourth is cool.
| The Following User Says Thank You to spnkr21 For This Useful Post: | djuosnteisn (05-07-2010) |
![]() | | #67 | ![]() |
| Not Ranked : 0 score Vids or DIE.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #68 | ![]() |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
| Not Ranked : 0 score can't wait for cp-e results! |
![]() | | #69 | ![]() |
| The Following User Says Thank You to austin102085 For This Useful Post: | djuosnteisn (05-07-2010) |
![]() | | #70 | ![]() |
Groans: 78
| Not Ranked : 0 score Congrats man. Can't wait to see what she does! |
![]() | | #71 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks. just cut my work in half and send me ur tune...
| The Following User Says Thank You to austin102085 For This Useful Post: | madvillain (05-07-2010) |
![]() | | #72 | ![]() |
![]() Join Date: Aug 2009 Location: Albany, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 867
Groans: 39
| Not Ranked : 0 score titties |
![]() | | #73 | ![]() |
Groans: 60
| Not Ranked : 0 score Some advice.... Buy extra injector seals... I have to stay under ~20 psi or mine pop and that's with just the flashes and no tune... I think you still don't realise how much power your going to pick up just with the flashes...
![]() | | #74 | ![]() |
(Thread Starter) | Not Ranked : 0 score hahah and this is a bad thing.
![]() | | #75 | ![]() |
Groans: 78
| Not Ranked : 0 score Just go to home depot and pick up a big bag of cement, mix it up, and slather it on your head around the injectors. Once dry, begin tuning. |
![]() | | #76 | ![]() |
if only billy mayes was around he could make mazdaspeed mighty injector seal puddy....
| The Following User Says Thank You to austin102085 For This Useful Post: | Realgib3 (05-10-2010) |
![]() | | #77 | ![]() |
![]() Join Date: Oct 2008 Location: Houston,Tx
Rep Power: 429 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
Groaned at 16 Times in 14 Posts
__________________ 2008 HG Bullitt Mustang. Long Tube headers, SCT tuner,MGW short throw, FRPP hot rod cams high flow cats, charge motion plate delete |
![]() | | #78 | ![]() |
(Thread Starter) | Not Ranked : 0 score so i got the flashes back and hooked the ecu back up...... in saying that im not going to post a review or anything till i talk with jake at cp-e and get some things figured out. i am also going to be upping my boost to 20-22 psi in the next week also videos will be posted soon. i am going to cp-e at the end of the month/ first week in june to get tuned.
| The Following 5 Users Say Thank You to austin102085 For This Useful Post: | djuosnteisn (05-17-2010), Fagwagon (05-17-2010), madvillain (05-17-2010), Realgib3 (05-17-2010), xcoldricex (05-16-2010) |
![]() | | #79 | ![]() |
Groans: 78
| Not Ranked : 0 score You're going up there?! Yes! |
![]() | | #80 | ![]() |
![]() Join Date: Jan 2009 Location: Cleveland, OH
Rep Power: 3292 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,280
| The Following User Says Thank You to Realgib3 For This Useful Post: | djuosnteisn (05-18-2010) |
| holset hx35? | Fagwagon | MazdaSpeed 3/6 - Turbo Induction | 154 | 09-13-2012 01:39 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | Haltech | Automotive News | 0 | 02-16-2010 03:20 PM |
| POWA!!! PG MANI INSTALLED!!! | gsrtype1 | MazdaSpeed 3/6 - Turbo Induction | 102 | 06-03-2009 09:07 PM |
| First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo | Haltech | Automotive News | 2 | 05-04-2009 06:48 PM |
| I NEED MORE POWA!!!! | Eazy | Mazdaspeed3/6 General Discussion | 8 | 01-27-2009 02:00 PM |
