Like Tree13Likes
 Old 10-25-2012, 11:36 AM   #81
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
Originally Posted by Davsetz View Post
Bump for awesome write up. Saved my ass. Heads up though I almost had to pull the manifold after getting it back on to get the damned the coolant feed banjo bolt on. But then again I left the Dp attached and still hanging.
Glad it was able to help you out!
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M.Tuning -
 Old 10-30-2012, 06:45 PM   #82
Matrix311's Avatar
Posts: 2,133   (View Stats)
Thanks for this thread. I'll be installing my gtx3017r on the 10th. I'm working onf the new coolant line and studs to prep for the install.
The Following User Says Thank You to Matrix311 For This Useful Post:
JacksonMS30 (10-31-2012)
 Old 11-26-2012, 03:35 PM   #83
alfre127's Avatar
Posts: 291   (View Stats)
alfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond repute
For that CNT Bolt do you think you can grind the DP a bit to have more space, i currently have it installed with out that bolt, no leaks, but i am doing a BT net week was wondering.
GTX3076 EWG // Tial Waste Gate // Sure 3.25 Big Mouth // // JBR Side Motor Mounts // JBR, SS Kit, Corksport RMM Inserts // Cobb Pipping with TRL8 // CNT DP // CNT Cat back // DNP Mani // Autotech HPFP // Rota G-force 18x8.5 // Eibach Pro Kit Springs // Cobb AP, // Auto meter boost and vacuum gauges // AEM A/F gauge // AEM Meth Stage 2 kit // Hella Horns // PTP injector seals // PNP IM // TIGS // EGR Delete // ACT 6 Puck Sprung/Streetlite // Superskaterex 74MM TB //
alfre127 is offline   Reply With Quote
 Old 11-26-2012, 05:07 PM   #84
I had to grind on mine to get the bolt to fit.
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
The Following User Says Thank You to JacksonMS30 For This Useful Post:
alfre127 (11-27-2012)
 Old 11-29-2012, 08:31 PM   #85
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
Thanks for this; I picked up a used GTX3071 and manifold last night, which I'll be installing over Christmas.
Needed: Driver mod
The Following User Says Thank You to BigRedSpecial For This Useful Post:
JacksonMS30 (11-30-2012)
 Old 04-21-2013, 11:23 AM   #86
bump for the turbo installs next weekend
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
 Old 04-21-2013, 02:22 PM   #87
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
-__- nemesis...
2008 MS3 gt
470hp/463tq on GT35r at 29psi
JacksonMS30 (04-21-2013)
 Old 12-25-2013, 10:16 AM   #88
resilientone's Avatar
Posts: 139   (View Stats)
resilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond repute
Bump for the big turbo installs this weekend.
resilientone is offline   Reply With Quote
The Following User Says Thank You to resilientone For This Useful Post:
JacksonMS30 (12-25-2013)
 Old 03-16-2014, 10:08 AM   #89
Goodrich27's Avatar
Posts: 678   (View Stats)
Goodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the world
bump for my gt3071r ewg install as soon as it comes from Edge.
Go fasters:Manley H beams and Wiseco 87.5mm Forged pistons with stock compression, GTX3076 with Tial 38mm EWG, Full Race exhaust manifold w/2000* ceramic coating, MD meth injection TB spacer and Devils Own DC30 WMI with DO14 nozzle, Cobb 3 port ebcs, Ultimate Racing V2 Catless DP, Relentless Customs PNP IM with VTCS delete, TR11 core with HTP under route piping,ACT 6 puck, Corksport catless RP and CBE, CPE Stage II RMM,Cpe side mounts, perm plate with MD sealed and VTA OCC, HTP 4in Intake,ISC N1 coilovers, CS RSB, Tial BPV, Auto tech internals, Cobb ap v3, CPE injector seals,ngk step colder plugs, JBR throttle body TIG and coolant bypass, Corksport polyurethane exhaust hangers, Motorcraft unicorn juice, t6 rotella, Stoptech slotted and drilled front rotors with posi quiet pads.
Rice:corksport led fogs, Corksport eyelids, Corksport hood struts ,blacked out genpu rims, red evil M front and rear, red calipers, Corksport black mud flaps, Corksport shift knob, powder coat red valve cover, Intercooler pipes, and black gloss intake manifold A pillar gauge mount w/ AEM AFR, Oil temp, and Oil pressure gauges.
Goodrich27 is offline   Reply With Quote
Do I need a drop? RMCAT Appearance - WHITE 10 11-17-2011 10:20 PM
225/45/18 et 50+....can I drop eliminator MazdaSpeed 3/6 - Suspension & Brakes 5 02-04-2011 11:37 AM
My drop NJSPEED3 MazdaSpeed 3/6 - Suspension & Brakes 33 04-17-2010 03:11 PM
Won't Drop corbs
Cobb ATR Support
8 05-28-2009 01:25 PM
Page generated in 0.30261 seconds with 27 queries
