Like Tree13Likes
 Old 12-10-2011, 04:11 PM   #41
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
Well, that's just if you're not careful. The true reason is that the stocker can't handle all the air that a BT throws at it. Also, I'm not sure if you need a pill with the Grimmspeed...
+1 but as of yet no need for a pill
2008 MS3 gt
470hp/463tq on GT35r at 29psi
JacksonMS30 (12-10-2011)
 Old 12-19-2011, 06:55 AM   #42
Vader's Avatar
Posts: 1,651   (View Stats)
Groans: 45
Installed the turbo this weekend. Much blood, and coolant, were offered to the gods.
Overall it went well, took my time and methodically checked things. Car fired up first shot... But then, Fail ensued.
The fucking coolant hose that you reuse blew on me... And that bitch is a total ass pain to fix once everything is installed.
To anyone doing this install, just do what people say and get yourself an 18" piece of new hose, and some small hose clamps. You will thank yourself later.
As mentioned the turbo is super silent But I can feel the potential it has. Time to tune
Big thanks to the following:
@eric@edgeautosport, jp@edgeautosport - for the parts, you guys rock.
@cld12pk2go, @JacksonMS30 - for the documentation, they helped more than you know.
A few things to note:
If you're reusing the stock recirc tube. Put it on the TIP before you install.
If using the COBB SRI, the stupid breather hose from the valve cover, is a hair too short. Attach it to the SRI, before mounting the SRI to anything.
If using the CP-e TMIC, you will have to cut ~1" off each end of the supplied boost tube.
JacksonMS30 - Attached is the page referencing the proper order to tighten manifold. Feel free to embed it into the main post.
The Following 5 Users Say Thank You to Vader For This Useful Post:
EdgeAutosport.com (03-16-2012), JacksonMS30 (12-20-2011), Manny3 (05-30-2012), NoLeftTurn (12-19-2011), rfinkle2 (12-19-2011)
 Old 12-19-2011, 10:50 AM   #43
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Yeah, the part about the coolant line needs to be in about 128 font, bolded, and flashing. So easy to do with everything out, so insanely hard when everything is back together.
Glad my guide helped. :-)
The Following 3 Users Say Thank You to cld12pk2go For This Useful Post:
JacksonMS30 (12-20-2011), rfinkle2 (12-19-2011), Vader (12-19-2011)
 Old 12-19-2011, 12:03 PM   #44
lulz @Raider
burn813's Avatar
@Vader correct me if I am wrong but aren't you Joel's neighbor that was going to keep is stuff stock?
2008 MS3 gt
 Old 12-19-2011, 02:05 PM   #45
Vader's Avatar
Groans: 45
Nope, not me.
 Old 12-19-2011, 02:08 PM   #46
lulz @Raider
burn813's Avatar
Lol ok! Was amazed if it were the case
2008 MS3 gt
 Old 12-19-2011, 02:29 PM   #47
Vader's Avatar
Groans: 45
@JacksonMS30 @cld12pk2go
Here is a link to the hose people should get...
Might want to reference in first post of both of your threads.
Reinforced Hose
The Following 3 Users Say Thank You to Vader For This Useful Post:
JacksonMS30 (12-20-2011), NoLeftTurn (12-19-2011), rfinkle2 (12-19-2011)
 Old 12-19-2011, 03:07 PM   #48
NoLeftTurn's Avatar
Posts: 188   (View Stats)
NoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the world
It's the 5/16" ID right? What hose do you guys use for the Wastegate?
NoLeftTurn is offline   Reply With Quote
The Following 2 Users Say Thank You to NoLeftTurn For This Useful Post:
 Old 12-19-2011, 05:08 PM   #49
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Yes, 5/16" hose for turbo coolant and 3/32" hose should work for anything that needs a vacuum reference.
2007 CTS-V - Trying to sell
The Following 4 Users Say Thank You to bmylez For This Useful Post:
JacksonMS30 (12-20-2011), NoLeftTurn (12-19-2011), rfinkle2 (12-19-2011), Vader (12-20-2011)
 Old 12-19-2011, 05:16 PM   #50
Schmitty5's Avatar
Posts: 979   (View Stats)
Schmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the world
Groaned at 20 Times in 12 Posts
Subbed for coming back to when I'm ready/ have $ saved up
2010 MS3 - 13.42 at 107 - street tires - 306whp/338tq Moore automotive (dynojet)
Roadcoursing > all http://www.youtube.com/watch?v=GO-xoFpsgj4
Schmitty5 is offline   Reply With Quote
 Old 12-19-2011, 05:42 PM   #51
Eth/Meth Junkie
cld12pk2go's Avatar
Reinforced Hose
That link is for 5/8'' hose; what you want is 5/16'' like this:
Silicone Heater Hose, 0.310" ID, 0.630 OD, 0.160 Wall, Blue Color-Flex Technologies
JacksonMS30 (12-20-2011), NoLeftTurn (12-19-2011), Vader (12-20-2011)
 Old 12-19-2011, 06:33 PM   #52
bmylez's Avatar
Groans: 31
Negative, Ghost Rider. If you scroll down, the 5/16 hose is there
The Following 2 Users Say Thank You to bmylez For This Useful Post:
JacksonMS30 (12-20-2011), Vader (12-20-2011)
 Old 12-19-2011, 06:35 PM   #53
Eth/Meth Junkie
cld12pk2go's Avatar
Doah! I just looked at the one on the top. You are correct as the one of the bottom should be fine.
The Following 2 Users Say Thank You to cld12pk2go For This Useful Post:
 Old 12-20-2011, 08:10 AM   #54
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
Updated thread to show ex mani tightening pattern, and link to coolant return line upgrade. Thanks @Vader for the link and the PDF for tightening the mani!
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M.Tuning -
The Following User Says Thank You to JacksonMS30 For This Useful Post:
Vader (12-20-2011)
 Old 12-20-2011, 01:58 PM   #55
Vader's Avatar
Groans: 45
Used the supplied hose that came with my Grimmspeed MBC.
 Old 12-20-2011, 02:41 PM   #56
I used 6mm silicone hose. I suggest using just a slightly smaller diameter (4.5mm or something like that). Mine blew off at the drag strip and is now secured with a zip tie...
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
burn813 (03-16-2012)
 Old 03-16-2012, 12:15 PM   #57
knarfies's Avatar
Posts: 2,568   (View Stats)
knarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the world
before we knew this i suffered the same fate. After Eric from edgeautosports and a couple of our other great nator nm guys installed the turbo ( lets not forget that atp sent me a turbo with the actuator backwards ) Dustin and i were tuning out in the boonies and i lost every drop of coolant on the highway fml. we limped it home turning the car on and off coasting as to not overheat the motor. needless to say the hose split down the middle.
**********************Riding Rainbows Since 1986.**************************
knarfies is offline   Reply With Quote
The Following 2 Users Say Thank You to knarfies For This Useful Post:
JacksonMS30 (03-19-2012), Vader (03-16-2012)
 Old 05-30-2012, 01:17 PM   #58
Bump for helpful how to
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
knarfies (05-30-2012)
 Old 06-01-2012, 03:26 AM   #59
ktpguy's Avatar
Posts: 23   (View Stats)
ktpguy is a jewel in the roughktpguy is a jewel in the roughktpguy is a jewel in the rough
what size studs do i need for the oil return line?
ktpguy is offline   Reply With Quote
 Old 06-01-2012, 08:04 AM   #60
They will come with the kit Reuse the ones on the block side only
 Old 06-03-2012, 08:17 AM   #61
Resident Baus
duappleganger's Avatar
Posts: 504   (View Stats)
duappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the world
Groans: 34
Groaned at 56 Times in 18 Posts
Anybody have a link to where I can buy a turbo flange gasket and a downpipe gasket? And @eric@edgeautosport , you're saying we wont need to buy any studs for the ATP kit correct?
Also what kind of fasteners are best to use on the flexible part of the return line? The ones securing the OEM line?
2011 Black Mica MS3
FREEKTUNE (On hold 'til EWG) ATP GTX3071R IWG (soon to be EWG) Full Race exhaust manifold CP-e whale peen + 3.25 in. intake
COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport CBE + Brake Pads Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k
Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC
HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Goodridge SS Brake Lines
Installation TBD: H&R springs + Koni yellow shocks + struts
duappleganger is offline   Reply With Quote
The Following User Says Thank You to duappleganger For This Useful Post:
EdgeAutosport.com (06-04-2012)
 Old 06-04-2012, 12:00 PM   #62
You will need M6x1 studs at least 1.25" to 1.5" long and some flange nuts to fit the studs (you may have to make the studs using a stick of all thread). You only need to for where the return line bolts to the block.
I suggested replacing those stock bolts where the return line mates to the block because the ATP return line flange is thicker than stock and engages less less of the threads on the factory bolt. The studs are longer and, though they can be done without, can help save somebody from stripping out the threads in the block like I did.
edgeautosports.com: The Leading Edge Auto Sports Site on the Net or just call Eric. The oil return line comes complete in the kit from ATP with everything including the fasteners to bolt it to the turbo. You just either have to reuse the stock fasteners for the block side of the return line, or you buy/make studs to reduce the risk of striping your block and causing yourself a world of trouble.
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
 Old 07-09-2012, 10:29 PM   #63
Eighty8's Avatar
Posts: 458   (View Stats)
Eighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the world
Thanks for all the info. It'll def help me out with my BT install I'm doing soon.
Eighty8 is offline   Reply With Quote
The Following 2 Users Say Thank You to Eighty8 For This Useful Post:
EdgeAutosport.com (07-10-2012), JacksonMS30 (07-10-2012)
 Old 07-11-2012, 01:20 PM   #64
Boonestafa's Avatar
Posts: 204   (View Stats)
Boonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the world
i guess it may be old hat but did ATP finaly solve the compresser surge issue with the IWG? i'm finaly getting interested in BT now that everyone has done the pioneering zoom zoom boom shit.
2008 True Red MS3 GT HKS ssqv black, JBR SRI, JBR TIP, CPE ToW PlatE.
JBR RMM, HPFP Internals, cobb AP in near future!
Boonestafa is offline   Reply With Quote
 Old 07-11-2012, 02:37 PM   #65
I can't speak for everyone, but I have yet to experience any compressor surge on my setup.
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
 Old 07-12-2012, 05:10 AM   #66
Eth/Meth Junkie
cld12pk2go's Avatar
Nor have I...
JacksonMS30 (07-16-2012)
 Old 09-12-2012, 01:13 PM   #67
Bump for those of you who recently purchased an ATP turbo and were worrying about the install.
Don't worry, its not as difficult as you think
Happy modding
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
 Old 09-12-2012, 01:35 PM   #68
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Happy modding
Hahhaha soooo glad you bumped this.
Going to save some headaches FOR SURE!
JacksonMS30 (09-12-2012)
 Old 09-12-2012, 02:50 PM   #69
MattJackson86's Avatar
Posts: 1,407   (View Stats)
I am collecting BT parts right now and this will come in very handy, hopefully soon
MattJackson86 is offline   Reply With Quote
The Following 2 Users Say Thank You to MattJackson86 For This Useful Post:
InFeXIoN (09-12-2012), JacksonMS30 (09-12-2012)
 Old 09-12-2012, 05:59 PM   #70
Shadow's Avatar
Posts: 430   (View Stats)
Shadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the world
Subbed for when my balls get bigger. Brilliant write up. Thanks op.
Sent from my ADR6400L using Tapatalk 2
2012 Black Mica MS3 w tech
Cobb AP, CS SRI, CS TIP, Catless DP/TP, Autotech Internals, NGK Plugs 1 colder, Magnaflow CBE, HKS V2 BOV Recirc, ETS TMIC, CS SSP, CS RMM Inserts, CS RSB, CS Springs, Hankook ventus z214 c71 225/45r17 r comp tires for autocross, Stock doneflops for everything else
Shadow is offline   Reply With Quote
The Following User Says Thank You to Shadow For This Useful Post:
JacksonMS30 (09-13-2012)
 Old 09-12-2012, 06:03 PM   #71
InFeXIoN's Avatar
Posts: 1,159   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
Yea mines going in this Sat and going to be scrapping the coolant lines for AN fittings and braided lines same for the oil feed.
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is offline   Reply With Quote
The Following User Says Thank You to InFeXIoN For This Useful Post:
 Old 09-13-2012, 01:07 PM   #72
Good luck with the install!
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
 Old 09-13-2012, 01:41 PM   #73
InFeXIoN's Avatar
Thank you good sir!!
Build Complete!!!!
 Old 09-20-2012, 10:15 AM   #74
Bump for the guys who will be installing a turbo soon.
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
 Old 09-20-2012, 10:47 PM   #75
h0ckeyman's Avatar
Posts: 1,126   (View Stats)
h0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the world
This thread is awesome. Big time thanks to @JacksonMS30 @cld12pk2go @Vader for awesome input. Will be installing my BT in the next week and this thread has me well prepared.
Rapey Agendas Racing
h0ckeyman is offline   Reply With Quote
The Following User Says Thank You to h0ckeyman For This Useful Post:
JacksonMS30 (09-21-2012)
 Old 10-04-2012, 12:16 PM   #76
Anybody installing a turbo this weekend?
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
 Old 10-04-2012, 12:19 PM   #77
lilred's Avatar
Posts: 5,792   (View Stats)
@K7addict hurry up
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
JacksonMS30 (10-04-2012)
 Old 10-04-2012, 03:02 PM   #78
K7addict's Avatar
Posts: 909   (View Stats)
K7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the world
I'm almost ready to roll, but I need one more silicone coupler and an AN fitting and line for for the stock coolant line. I'm not fucking with bending that stock pos again.
@lilred aka chuntaro
JacksonMS30 likes this.
2013 DODGE RAM 2500 LARAMIE
2012 MS3 Black Mica : Traded
2010 MS3 Velocity Red : Traded
2007 Suzuki GSX-R 750 : Crashed & Fixed
2004 Sentra SE-R Spec V : Traded
1995 Nissan Altima : Sold
1987 RX-7 : Sold
Originally Posted by helmetfail View Post
Cop: Sir, your car smells of marijuana, would you mind showing me your ashtray?
You: Um, there's no weed there sir...Just Meth...
Cop: %&#*#(#&$
K7addict is offline   Reply With Quote
The Following 2 Users Say Thank You to K7addict For This Useful Post:
JacksonMS30 (10-04-2012), lilred (10-04-2012)
 Old 10-08-2012, 04:03 PM   #79
This is for the GTX3071 being installed in New Jersey this weekend!
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
 Old 10-18-2012, 03:30 PM   #80
Davsetz's Avatar
Davsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the world
Bump for awesome write up. Saved my ass. Heads up though I almost had to pull the manifold after getting it back on to get the damned the coolant feed banjo bolt on. But then again I left the Dp attached and still hanging.
Davsetz is offline   Reply With Quote
The Following User Says Thank You to Davsetz For This Useful Post:
JacksonMS30 (10-25-2012)
Do I need a drop? RMCAT Appearance - WHITE 10 11-17-2011 10:20 PM
225/45/18 et 50+....can I drop eliminator MazdaSpeed 3/6 - Suspension & Brakes 5 02-04-2011 11:37 AM
My drop NJSPEED3 MazdaSpeed 3/6 - Suspension & Brakes 33 04-17-2010 03:11 PM
Won't Drop corbs
Cobb ATR Support
8 05-28-2009 01:25 PM
Page generated in 0.58785 seconds with 41 queries
