Like Tree8Likes
  • 5 Post By sassyspeed3
  • 3 Post By PapaSmurf
 Old 05-27-2012, 09:15 AM   #1
sassyspeed3's Avatar
Posts: 1,054   (View Stats)
sassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the world
Default Husband & Wife - Two GTX3071R Builds
Over the past two weeks, me and @DISIindahead have been installing our 3071's. About a month and a half ago, we decided to pull the trigger on two big turbo builds once our debt was paid off. I managed to get a new turbo from a local guy who's car got stolen the day it was delivered and we ordered one through Edge Autosport. After finally receiving the delivery, it was install time. Before I get started a few thank you's for the people with the most.
@JP@edgeautosport.com & @eric@edgeautosport for dealing with my bitchiness about my order taking so long. You guys came through and I appreciate everything you did for us.
@slikr for the late nights and humping to get these two cars done.
@JasonMzdSpd3 for coming over and letting us use your monster needle nose and zip ties...you still didn't bring us food though
@Captain KR for allowing us to call and get advice on the Grimmspeed and the coolant line. You sir, are a life saver.
@rfinkle2 you are , kidding, you have been nothing but a great advisor on tuning and technical needs. I can't wait to see what you can do with these turbos since I enjoyed my K04 tune so much. Zoom Zoom!
@StayBroke because you told me how to do my WG arm adjustment. I probably would have figured it out but I like the guidance.
@ Everyone with a build thread. Your errors and accomplishments have made our two builds go by a lot smoother with very few mishaps. Thank you for being the guinea pigs of the ms3's & ms6's so I won't make the same mistake.
@ All the guys in shout, including you @predapio, @Daddy Chinkus and @chimmike, you guys have learned to deal with me in shout almost everyday while managing to tease me to get back in the kitchen and make sammichs. Well, I actually got my hands dirty to go waist deep in these builds and I appreciate you all for building up my confidence and knowledge.
and finally, Thank you MazdaSpeedForums as a whole for all the knowledge that can finally come together and be a one stop shop. Peace, Love and Mazda for life.
Onto the build:
My car was first so I guess you could say it was the red headed step child, literally. When the turbo was put on, I had 28,200 miles. I have had the car for about 4 months and was fully bolted for about 2 of them. Everything went smoothly. I was able to get my turbo ported in no time.
I think that porting is becoming a normal occurrence, it was no big deal to us but a word of advice, remember that the smaller bolt that connects the hot side goes under the banjo bolt that is to the oil feed line on top of the turbo. we had to take the manifold off again to realize the mistake. Using the dremel worked well on both turbos, you just need the right stone and patience.
Once I finished porting the turbo, we decided to do the PTP Safe Seals and Stud Kit.
Dirty
We attempted to clean with not much luck. We'll be seafoaming on the next oil change.
Once we got the intake manifold off, we can obviously see the importance of an oil catch can.
After we did the seals and got the manifold put back on, it was onto the turbo part.
Tip: do this to keep track off all of your bolts
Here is a picture of everything out. We didn't run into any problems on mine, however, the pu was a different story. (stupid pu)
During dis-assembly, Mike also took a coolant bath. Remember to clamp the line or at least put a pan underneath the car to catch it all. DERP.
The classic picture of old versus new.
Did someone say twin turbo MS3?
So we dropped the turbo in the bay first and then bolted on the DNP mani, thanks @drummermike58 and @Jonny Quest for the wrap.
By this time, we were all like this...
We ran into an issue with the oil feed and banjo bolt (typical from what I have read but @slikr had a great idea and it worked. You will need someone to hold up the turbo and be steady with it while the other holds the bottom washed with a piece of tape and screws the banjo bolt in. See below.
Once the banjo bolt is screwed on, you can lightly yank the tape and it'll come right off without leaving anything. It worked after dropping it at least once.
Once everything was bolted on, here is the finished product.
I hoped for no leaks and definitely got lucky. First start up was a little rough. We purged the fuel line and Jason primed the turbo. AFR's started at about 9.7 on first time but then evened out after about 10 minutes. Then it was time to drive.
Here is my ricer moment, driving around with my hood off for the first time.
Still clear of leaks. We buttoned everything up and finished up about 9 pm on Sunday night.
On to the next build. The pu was a bitch, as always. There isn't a lot of pictures because he started when I was at work but this is what we do have. We originally blew the turbo seal at about 12,000 miles and replaced with a re manufactured K04 that has been awesome. Putting the BT on, we had 32,092 miles. I really thought the uninstall would go as smooth as mine did. This is what not to do:
His valve cover seal was leaking so we replaced that and while it was off, we also painted it.
Here is the turbo bolted up to the manifold.
We got done with his car last night and his is running smooth as well. No leaks and all levels were good. I wish we would have taken more pictures but I think we all just wanted to get done. Another problem we had was we had to additionally grind the top of the shorter bolt on the hot side of the turbo so the oil feed line would fit. After we did that, everything went together smoothly. With two builds under our belt, I hope that we're able to do another one in the near future, cough @slikr. But after these two grueling weekends, I feel like this and am hopefully done for a while.
2013 Mitsubishi Lancer Evolution GSR
2008 Red MS3
BT & All
Eth Mix - 460hp/429tq
Pump - 411hp/403tq
**SOLD**
[02:58 PM] dturboman: and ZZB will happen one day, its just how long you can avoid it for
[09:15 PM] Erich: if you aren't notching your block, your turbo isn't big enough
sassyspeed3 is offline   Reply With Quote
The Following 43 Users Say Thank You to sassyspeed3 For This Useful Post:
06Speed6 (05-27-2012), adlpb (05-27-2012), atvfreek (05-27-2012), AZSPEED3 (11-12-2012), bertrand_CX_7 (05-27-2012), Boost_creep (05-27-2012), BPASPEED (05-27-2012), Coaststarlight (05-27-2012), Code Monkey (01-13-2013), Dahouse702 (01-13-2013), DISIindahead (05-27-2012), Dmurray06 (05-27-2012), donjohnk (01-13-2013), Easter Bunny (11-12-2012), EdgeAutosport.com (05-28-2012), edowney4711 (05-28-2012), Ferdball (05-27-2012), Importfan12 (11-14-2012), JasonMzdSpd3 (05-29-2012), Jh8909 (05-27-2012), JP@edgeautosport.com (05-28-2012), KILLER_VIZ (05-27-2012), kritz (01-13-2013), leon78 (11-12-2012), lilred (05-27-2012), Littlescroll (01-14-2013), mazdafreak (05-30-2012), Micha (05-30-2012), ms3bamf (05-27-2012), neotide87 (11-18-2012), NJSPEED3 (05-31-2012), phate (11-20-2012), psychophyr (11-13-2012), rfinkle2 (05-27-2012), Roddiy (05-27-2012), skeurton (05-27-2012), slikr (05-28-2012), snailD (05-27-2012), speedms6 (11-19-2012), StayBroke (05-27-2012), taf0422 (01-13-2013), TriO (05-27-2012), uncorked11 (05-27-2012)
The Following User Says NO Thank You to sassyspeed3 For This Un-useful Post:
dooderek (05-27-2012)
 Old 05-27-2012, 09:26 AM   #2
Ferdball's Avatar
Posts: 1,340   (View Stats)
Good idea! Nice builds.
The Following 8 Users Say Thank You to Ferdball For This Useful Post:
06Speed6 (05-27-2012), DISIindahead (05-27-2012), dsmluck (05-27-2012), feldm4n (05-28-2012), lilred (05-27-2012), Mizzle (05-30-2012), sassyspeed3 (05-27-2012), Schmitty5 (05-27-2012)
 Old 05-27-2012, 09:32 AM   #3
snailD's Avatar
Posts: 3,039   (View Stats)
i want a gtx3071 so bad lol. glad u got everything in without any major issues. now, enjoy
The Following 3 Users Say Thank You to snailD For This Useful Post:
DISIindahead (05-27-2012), sassyspeed3 (05-27-2012), sleepyspeed6 (05-27-2012)
 Old 05-27-2012, 09:38 AM   #4
Cheeto's Avatar
Posts: 762   (View Stats)
Cheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the world
Insane!!!
Sweet write up and pics!!
I chick that into turbos, and help on the builds, that's a keeper.
Good job guys!
Chad Erwin -ATX
06 MazdaSpeed6 Gt AWD/Turbo/#5994
MODS:
COBB AP // MSD Dashhawk // Street Unit TMIC // Street Unit Test Pipe // CorkSport Power Series Catless DP // COBB SRI intake // Speedies TIP // Turbosmart BOV // RPM Street Spring // Bilstein Struts/Shocks // TWM Stage 2 Short Shifter // CPE Dogbone rear mount // CPE JuggerNaught Diff mount // COBB Shifter weight // HPFP Internals // Magnaflow FULL 3IN Back// Denso ITV 22s // Full TIGS // EGR Delete // Shorty Antenna // PA Engineering OCC // LED swap
Cheeto is offline   Reply With Quote
The Following 2 Users Say Thank You to Cheeto For This Useful Post:
 Old 05-27-2012, 10:11 AM   #5
KILLER_VIZ's Avatar
Posts: 451   (View Stats)
KILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the world
Groaned at 28 Times in 14 Posts
Hopefully we will have some sort of meet soon. I would love to see the two speeds together. Good thread by the way.
KILLER_VIZ is offline   Reply With Quote
The Following 3 Users Say Thank You to KILLER_VIZ For This Useful Post:
DISIindahead (05-27-2012), edowney4711 (05-28-2012), sassyspeed3 (05-27-2012)
 Old 05-27-2012, 10:14 AM   #6
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
I wish my girlfriend was as awesome as you... fuck lol
nice builds
860whp/677wtq
2.7 V6 Ecoboost
AZSPEED3 (11-12-2012), sassyspeed3 (05-27-2012), StayBroke (05-27-2012)
 Old 05-27-2012, 10:34 AM   #7
ZPrice's Avatar
Posts: 321   (View Stats)
ZPrice is the leader of the worldZPrice is the leader of the worldZPrice is the leader of the worldZPrice is the leader of the worldZPrice is the leader of the worldZPrice is the leader of the worldZPrice is the leader of the worldZPrice is the leader of the worldZPrice is the leader of the worldZPrice is the leader of the worldZPrice is the leader of the world
Lovely the GENDONE and PU at the same time, I like the cardboard, I use baggies and a sharpie myself, hate to have leftovers at the end of an install.
@sassyspeed3 Quick question, what paint did you use on the valve cover or did you have in powdercoated?
Zman 2010 L MS3
GTX3076 w EWG | CPE BT SRI/TI | Cobb DP | HKS SSQ IV | CPE FMIC | CPE HPFP | IM SSPMod/PnP | GS 3P EBCS | CPE Inj Seals | Sure TIG | UR CBE | CPE RMM/SMM | BC Coilovers (8/5) w/ Rear Camber Arms | RR RSB | TWM SS replacement | Forgestar F14 10/9.5 | JVC KWAVX830 HU w/ XD 600/1 XD600/4 amps JL subs/components | AP and tuned w/ Freak
Parts to install: DO Meth
ZPrice is offline   Reply With Quote
The Following User Says Thank You to ZPrice For This Useful Post:
thehead (05-27-2012)
 Old 05-27-2012, 10:41 AM   #8
DISIindahead's Avatar
Posts: 911   (View Stats)
DISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the world
We used barbecue grille paint lol basically high temp spray paint. @slikr did 3 light coats and 3 regular coats. When you do it be sure to follow the bolt pattern on torque specs for the valve cover when you do it as well. Get them snug first before torquing them down. Be sure to also clean the valve cover really good before painting.
Sent from my Etch a Sketch
2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD
2012 Jeep Wrangler Unlimited Sport: Current DD
DISIindahead is offline   Reply With Quote
The Following 2 Users Say Thank You to DISIindahead For This Useful Post:
Fail_6 (05-27-2012), thehead (05-27-2012)
 Old 05-27-2012, 11:05 AM   #9
Pics of your husband's cock/balls or I call BS.
Do you have a sister?
 Old 05-27-2012, 08:29 PM   #10
Stealth01's Avatar
Posts: 6,910   (View Stats)
Groans: 201
I was over there today, so I can confirm they're real peeps, married, and have MZR parts all the fuck over the place. When I was there, there was a Pu on the street, Sassy's ride in the driveway, an MS6 in the right bay and an MS3 in the left. It's like they're running this Mazdaspeed shop out of their garage.
I wish my S.O. was into cars. Or anything else I'm into.
Stealth01
2006 Mazdaspeed6 GT
The Following 5 Users Say Thank You to Stealth01 For This Useful Post:
Code Monkey (05-27-2012), DISIindahead (05-27-2012), dsmluck (05-27-2012), Easter Bunny (11-12-2012), sassyspeed3 (05-27-2012)
 Old 05-27-2012, 09:14 PM   #11
Yep, would love to meet a girl who is into cars.
 Old 05-27-2012, 01:17 PM   #12
Will pics of sassy getting mushroom stamp work?
atvfreek (05-27-2012), lilred (05-27-2012)
 Old 05-27-2012, 01:44 PM   #13
Come on, I'm classier than that lol
sent from my cleavage via Tapatalk
2008 Red MS3
BT & All
Pump - 411hp/403tq
**SOLD**
The Following User Says Thank You to sassyspeed3 For This Useful Post:
 Old 05-27-2012, 08:08 PM   #14
Jonny Quest's Avatar
Posts: 365   (View Stats)
Jonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the world
Groans: 43
Groaned at 111 Times in 19 Posts
@DISIindahead @sassyspeed3 ... i hate you both... my car MIGHT be done tomorrow... i have almost come to live with the fact we will only have the TDI now lol. meh oh well
Jonny Quest is offline   Reply With Quote
 Old 05-27-2012, 08:22 PM   #15
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
Good work, the end result is well worth the work.
New....Camaro SS/RS
Stocked out selling parts.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
Last edited by uncorked11; 05-27-2012 at 08:23 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-27-2012, 09:14 PM   #16
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
your dead to me
 Old 05-27-2012, 09:20 PM   #17
dereeek's Avatar
Posts: 2,053   (View Stats)
dereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the world
Groans: 386
so jelly. i wish my sandwich maker would like cars, but she bought a prius.
BNR3-FREEK-PU-398HP
I lost track of the mods in my car.
dereeek is offline   Reply With Quote
The Following 5 Users Say Thank You to dereeek For This Useful Post:
Don06speed6 (05-27-2012), Easter Bunny (11-12-2012), KILLER_VIZ (05-28-2012), sassyspeed3 (05-27-2012), slikr (05-28-2012)
 Old 05-27-2012, 10:09 PM   #18
Originally Posted by Daddy Chinkus View Post
your dead to me
I'll make it up to you when I see you in a couple weeks. Vox me fool!
2008 Red MS3
BT & All
Pump - 411hp/403tq
**SOLD**
 Old 05-27-2012, 10:21 PM   #19
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
y'all make me jelly!!!!
Congrats on the builds guys!
I'll definitely have you guys on speed dial if/when i do my BT build, though, i think mine is going to be a little more in depth when the time comes. lol
again, congrats, and i'm excited to see them!!!
99 miata: sold
The Following 2 Users Say Thank You to Mortose For This Useful Post:
 Old 05-27-2012, 11:47 PM   #20
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
Good times, good cars, good peeps...fo sho!!!
Chris, it was good seeing ya again...finally...and tell ur daughter she can stay with me haha
The Following User Says Thank You to tbot For This Useful Post:
 Old 05-30-2012, 09:39 PM   #21
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Nice job, good to see it go so smooth.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 05-30-2012, 09:52 PM   #22
Thanks! We aren't in the clear yet though
2008 Red MS3
BT & All
Pump - 411hp/403tq
**SOLD**
 Old 11-12-2012, 09:47 AM   #23
Matrix311's Avatar
Posts: 2,133   (View Stats)
I just finished my gtx3071r build over the weekend. Install went smooth as well. Did you get both cars tuned and what kind of dyno numbers you hit between the two? Would love to see a comparison.
The Following User Says Thank You to Matrix311 For This Useful Post:
 Old 11-18-2012, 04:54 PM   #24
Sickspeed3's Avatar
Posts: 71   (View Stats)
Sickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of light
Groaned at 75 Times in 8 Posts
Wish I could of been there to lend a hand
Sickspeed3 is offline   Reply With Quote
The Following User Says Thank You to Sickspeed3 For This Useful Post:
sassyspeed3 (11-18-2012)
 Old 01-13-2013, 05:13 PM   #25
KNTRBND's Avatar
Posts: 178   (View Stats)
KNTRBND has a reputation beyond reputeKNTRBND has a reputation beyond reputeKNTRBND has a reputation beyond reputeKNTRBND has a reputation beyond reputeKNTRBND has a reputation beyond reputeKNTRBND has a reputation beyond reputeKNTRBND has a reputation beyond reputeKNTRBND has a reputation beyond reputeKNTRBND has a reputation beyond reputeKNTRBND has a reputation beyond reputeKNTRBND has a reputation beyond repute
Groaned at 10 Times in 2 Posts
Bumpin a semi old thread but whos was faster? That is the real question. I now know that pu has Meth.
KNTRBND is offline   Reply With Quote
TRSpeed GTX3071r EWG TRSpeed MazdaSpeed 3/6 - Big Turbo Builds 110 03-27-2013 09:05 AM
Video: Woman delivers own baby while husband drives, films Haltech Automotive News 1 01-25-2012 01:07 PM
GTX3071R? Cataphract_40 MazdaSpeed 3/6 - Big Turbo Builds 17 10-28-2011 10:46 AM
Report: Husband of wrong-way motorist who killed seven sues state, others Haltech Automotive News 8 07-29-2011 07:36 PM
Page generated in 0.50165 seconds with 39 queries
