| View Poll Results: keep it or forget it? | |||
| yes keep it!! | | 2 | 20.00% |
| thats a fail waiting to happen | | 6 | 60.00% |
| i have no clue | | 2 | 20.00% |
| Voters: 10. You may not vote on this poll | |||
| Not Ranked : 0 score Most of those small inline type filters are designed for valve cover oilers and they have a high micron screen that is designed for engines that are completely rebuilt after every race. Those types of filters are worthless when used in a oil system that uses a street type oil filter because that type of oil filter will filter particles that are orders of magnitude smaller than that race screen. If it does have a small micron filter it is probably supposed to be used as a fuel filter because its overall size is too small for use with oil. Ide say dump it, its either completely worthless combined with increased complexity, or fail waiting to happen.
| The Following 3 Users Say Thank You to 06Speed6 For This Useful Post: |
| inline converter colors??? | bikerboy2182 | 2010 MS3 - Car Audio & Electronics | 4 | 03-09-2011 08:47 AM |
| Bid farewell to BMW's legendary M inline-six | Haltech | Automotive News | 0 | 12-30-2008 09:40 AM |
| Inline bov video | steedspeed | MazdaSpeed 3/6 - Turbo Induction | 2 | 10-07-2008 10:49 AM |
