![]() Join Date: Jul 2008 Location: Houston
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
(Thread Starter) | Not Ranked : 0 score Got what is hopefully a quick question. I'm running a 3071 which was originally installed by Cobb in Dallas, using the CPE big turbo silicone intake. I'm upgrading to the HTP 3.5" intake. There is a gizmo in the way. Here are some pictures. In the pictures, you can see mounting bolts for it. So, I'm figuring that I just have to unbolt it and discard it. But, I figured I'd post pictures so people can tell me for sure what I'm looking at and what the best solution is. Note that Cobb installed the CPE intake with the gizmo in place and it deformed the shape of the intake to some degree. But more or less worked. I can't do that with the hard pipe of the HTP. Here are the pics. Thanks.
__________________ 360 AWD HP/380 TQ Cobb Mustang Dyno: 3071 .83 A/R, Steedspeed manifold, CPE FMIC, Cobb AP/tuning, CP pistons, Pauter Rods, CPE DP hacked to have V-band, GHL exhaust |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
__________________ www.tunedbynishan.com |
![]() Join Date: Jan 2010 Location: Austin, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 372
| Not Ranked : 0 score Looks like a bracket for that hose, My 6 never had some shit like that |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score I believe you're referring to the small black metal bracket for the shifter cables.
__________________ |
| The Following User Says Thank You to silvapain For This Useful Post: | phate (02-17-2013) |
![]() Join Date: Apr 2010 Location: Elizabeth /NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,623
| Not Ranked : 0 score I am assuming that your 3.5 inlet HTP doesn't clear the bracket that hold shifter and if so you can't remove that bracket just contact HTP and let them know your problem so they can revise the inlet
__________________ [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to SPEED6 KILLAH For This Useful Post: | Speedie6 (02-17-2013) |
(Thread Starter) | Not Ranked : 0 score Okay, now it sounds like my problem is my fucking Steedspeed manifold. I get the swept-back version which I was told placed the turbo farther from the block, closer to the firewall, supposedly for more room. But, I'm thinking it put the turbo too low. For there is no way to make a 3.5" intake fit here. You can't tell 3-dimensions from my pictures, but the bracket is right in line with the turbo. I had been told that I should consider getting a CPE manifold instead to maximize my potential. Looks like I may have to. But, that would mean I will need to have my downpipe refabbed again. Grrr. I guess I need to verify for sure that the CPE manifold doesn't have this problem, but I presume it doesn't.
| Approved MSF Vendor ![]() Join Date: Dec 2010
Rep Power: 675 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score That bracket is for the rubber isolator that positions the shifter cables. I have seen many MS3's come through the shop that don't have the rubber isolator pushed on the bracket (due to who ever worked on it) with no ill effect. I would remove that metal bracket, but I will get back to you in the morning after looking for a more viable option. Matt |
__________________ 360 AWD HP/380 TQ Cobb Mustang Dyno: 3071 .83 A/R, Steedspeed manifold, CPE FMIC, Cobb AP/tuning, CP pistons, Pauter Rods, CPE DP hacked to have V-band, GHL exhaust | |
That bracket is there just to help with the routing of the shift cables. The shift cables are still securely mounted to the transmission. I agree that removing it is not the first option.
*Just looked a speed 6 tranny here and the bracket on ours is facing the opposite way......Is there any way you can rotate that bracket around? Matt | |||
| The Following User Says Thank You to HTP For This Useful Post: | Speedie6 (02-18-2013) |
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
(Thread Starter) | Not Ranked : 0 score Thanks for confirming. I now certainly regret getting the SS manifold. But, at the time I got it, I thought it was supposed to be the greatest fucking thing since Internet porn. I might yet get the CPE, but, I'd have to get the DP refabbed or buy a new one. I think I got the concept. I will pull the bracket off and see what I can do.
Well, this sounded like a perfect idea. I can rotate the bracket such that the pin comes up rearward of the cables instead if between cables and turbo. It would only be held on by one bolt, but, put some locktite on it and that would be more than adequate. Problem is, the rubber piece isn't removable to turn around 180 degrees without disconnecting the cables. Actually, two cables run through it, and it looks like the bottom pops open to allow you to remove the bottom cable. But the top is solid rubber. I'd have to cut it. And then it wouldn't hold anymore. But, for test fitment, I did just remove the bracket to see how your intake will fit. Due to it mounting the turbo in the wrong place, it doesn't fit. Not your fault of course. I'll post pictures in your forum.
![]() Join Date: Oct 2011 Location: brooklyn, ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 240
| Not Ranked : 0 score Would the 3.5 intake make that much of a difference to have to get another manifold and custom fab a dp? Stick with the 3inch and call it day.. |
| Not Ranked : 0 score we had this same problem this weekend on @RichieRichness; car but his JBR 3.5" intake cleared just fine. A silicone inlet is the best choice because it can deform however you want it to and never lose the total ID. and i would never remove that bracket because it hold your shiftier cables at the correct angle to make sure they dont get caught on anything. It would be like having a cable actuated throttle with no mount for the linkage.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner Last edited by superskaterxes; 02-18-2013 at 08:41 AM. |
| Not Ranked : 0 score You may be able to slightly deform the intake and make it fit. As long as it still seals with the coupler how much massaging work would the pipe need to clear?
![]() Join Date: Mar 2010 Location: Manassas, VA
Rep Power: 2313 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,791
Groans: 35
| Not Ranked : 0 score What if you trimmed a bit off the turbo side of the intake pipe? Might give you a tad more clearance. My JBR was very close but clears it by about 1/2"
__________________ CP-e Atmosphere GTX3076r w1.06 Tial | JMF IM | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | Denso ITV24 | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Sonic Tuning Coils | DSS Driver Side Axle | JMF OCC BT - 395 awhp 345 awtq @ Moore Automotive 4/12/2014 on 93 octane Stock Turbo - 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 12.263 @ 111.75 mph 1.669 60' 11/17/2012 |
| Gold, tophat looking washer fell out when installing inlet+intake.. | breakfasteatre | Mazdaspeed3/6 General Discussion | 10 | 03-02-2011 05:48 PM |
| help re-installing stock intake | builthatch | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 11-24-2010 09:59 PM |
