 Old 07-25-2011, 12:08 PM   #1
JMEngineer's Avatar
Posts: 2,122   (View Stats)
Default JMEngineer's Build
The story behind the build (aka the tl;dr;nce section):
This car was originally supposed to be my DD that would be left completely stock or maybe get a couple Mazdaspeed parts that wouldn't void my warranty... I think it took about 4 days before I ordered an AEM CAI and an AP, and an ETS TMIC followed shortly after that.
I had also planned to keep living somewhat like a poor college student after graduation and get my loans paid off in a year or two. That still would have given me a decent 'toys' budget but, just like leaving the MS6 stock, I didn't follow through with that plan.
After buying a new house, getting engaged, finishing school, and starting a year-round full time job with regular hours, I decided to just make minimum payments on my student loans (no reason to pay more when the interest rates are only 2-4%) and use the extra money to buy a bunch of toys while I'm still young and can enjoy them. Sure I could save my whole life and live like a king when I retire, but with my addiction to speed and all the other dangerous things I enjoy I probably wouldn't live long enough anyway.
I decided I like this car enough to keep it for a long time and dump a bunch of money into it so I'm planning to go all out eventually but I'm doing it in phases. Phase 1 was originally going to be a 3076 setup with full supporting mods including a built block. I have all the parts to do that but I'm gonna see what the stock block can handle first.
I started collecting parts and bought a Mitsubishi Montero Sport to use as a DD while the 6 is in pieces over a year ago. I never expected it to take this long for all the parts to come in and to get my friend to fix the Montero - he sold it to me dirt cheap because it needed a few things and he offered to install all the new parts after I bought them because he already had it in pieces in his garage.. then he forgot which fuel lines go where and we had a lot of trouble tracking down a service manual.
The Montero is finally a couple hours of work away from running and I have all the parts I need so it looks like I'm finally ready to start Phase 1 of my build...
THE GOOD STUFF:
This is the plan for now but I'm sure a few things will change
Phase 1 Main Parts:
Steedspeed twin scroll top mount manifold
Twin TiAL MV-S water-cooled wastegates
GT3076R - .78A/R divided T3 V-Band turbine housing, 4" anti-surge compressor housing
Djuosnteisn intake and downpipe
Treadstone TR1035 intercooler
Phase 2:
Built block
-stock bore
-CP pistons (.5 CR lower to run higher boost)
-Pauter rods
-DCR cam timing thingy
ACT 6-puck clutch (I might sell this and go with a twin disc to make sure it lasts)
ACT flywheel (say what you want, I like the feel of cars with light flywheels so nce)
Upgraded Axles
PAR Engineering custom gearset
Meth
Phase 2.5:
GTX35R
Phase 3:
Upgraded head
-stiffer valve springs
-full port/polish
-cams
Custom intake manifold with secondary injection
Big brakes
Even bigger turbo?
Other plans along the way:
Look into crankshaft options to destroke to 2.0L and significantly raise redline
Carbon driveshaft
KW V2 coilovers
Chassis bracing (bolt-on or welded)
Recaro seats
Thanks to Djuosnteisn for the parts and tuning and Dougefresh for documenting everything to make my phase 1 build quick and easy.
-GTX2867R Coming Soon
Last edited by JMEngineer; 07-30-2011 at 03:36 PM. Reason: MSF Database - Automerged Doublepost
The Following 11 Users Say Thank You to JMEngineer For This Useful Post:
08.5MS3 (07-25-2011), djuosnteisn (07-25-2011), Don06speed6 (07-25-2011), doubleflusher (07-25-2011), dougefresh_ (07-25-2011), Erich (07-25-2011), jracer (08-19-2011), MPSdriver (07-27-2011), MS3-a(sore)ASS-rex (07-25-2011), PunjabiPlaya (07-25-2011), rfinkle2 (07-25-2011)
 Old 07-25-2011, 12:11 PM   #2
JMEngineer's Avatar
Heres the 'before' dyno:
The Following 4 Users Say Thank You to JMEngineer For This Useful Post:
djuosnteisn (07-25-2011), doubleflusher (07-25-2011), dougefresh_ (07-25-2011), PunjabiPlaya (07-25-2011)
 Old 07-25-2011, 12:36 PM   #3
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
gears? which ones an what ratio's did u change?
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
JMEngineer (07-25-2011)
 Old 07-25-2011, 02:12 PM   #4
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
That's phase 2, we're still in phase 1.
GL with the build! Lemme know if you need anything at all man.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 07-25-2011, 02:18 PM   #5
zenger's Avatar
Posts: 602   (View Stats)
zenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the world
Groaned at 8 Times in 7 Posts
Those before numbers mods are ?
2007-Mazdaspeed 6
BNRSIII~all supportings
Zoom Zoom Boom part out.
zenger is offline   Reply With Quote
The Following User Says Thank You to zenger For This Useful Post:
 Old 07-25-2011, 02:24 PM   #6
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Good luck J!!
NATOR PA
 Old 07-25-2011, 04:15 PM   #7
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Good stuff! Phase 1 does look quite familiar, haha. I still need to up grade my fmic :/ Looking forward to the progress.
I would recommend adding a meth kit to install during phase 1. GL with build!
EDIT: This turbo spools silly quick for a BT. I've haven't gotten anywhere near pushing this turbo, but I kinda wish I gt35r. On the dyno in 4th, he went wot at like 2K, and I was at my wg spring (16psi) at 3116 rpms with no ebcs. Hits the same @ 3340rpms in 3rd. That's pretty quick spool imo... I wish someone around here had a ts gt35r that I could check out to see if there's any noticeable lag. twin scroll ftw! I'd definitely try a larger hot side down the road, but mind you, I am VERY happy with the way the car drives, spools, etc. Zero complaints . You will be psyched!!
The Following 2 Users Say Thank You to dougefresh_ For This Useful Post:
djuosnteisn (07-25-2011), JMEngineer (07-25-2011)
 Old 07-25-2011, 04:20 PM   #8
XLT_66's Avatar
Posts: 850   (View Stats)
XLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the world
I would recommend adding a meth kit to installed during phase 1. GL with build!
Beat me to it.
+1 for Meth on Phase 1.
2009 CWP MS3 Sport
Built Motor and Twinscroll T3 35r - 415WHP/400WTQ - 93 Pump Gas, No Meth - Mustang Dyno
Custom Tubular Manifold - HTP 3.5" Intake - 3" V-Band TBE - Custom COBB FMIC - COBB EBCS - COBB 44mm WG - KW V2 Coilovers
SOLD!
2008 Toyota Tacoma TRD Sport 4x4
XLT_66 is offline   Reply With Quote
The Following 3 Users Say Thank You to XLT_66 For This Useful Post:
djuosnteisn (07-25-2011), dougefresh_ (07-25-2011), JMEngineer (07-25-2011)
 Old 07-25-2011, 04:22 PM   #9
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
So many awesome builds going on. Good luck!
The Following 3 Users Say Thank You to triplejumper18 For This Useful Post:
 Old 07-25-2011, 08:22 PM   #10
JMEngineer's Avatar
I'm probably going to replace at least 1-4 and the final drives. I may go straight cut 1-4 if that makes sense but I need to look into it more.
AEM CAI, CPE DP, Autotech internals
Good luck J!!
Thanks!
I'll be able to knock out the intercooler in a couple hours - I have all the piping bends I could need and I have my own bead roller for anything that needs to be trimmed.
I went for a ride in Joel's car last weekend which I think has the same turbo we do and it was a beast.. It's exactly what I wanted for Phase 1
Originally Posted by XLT_66 View Post
Beat me to it.
I just don't love the idea of having meth on a DD. I may go ahead and install it now but I won't use it until I really need it.
Thanks!
The Following 2 Users Say Thank You to JMEngineer For This Useful Post:
djuosnteisn (07-26-2011), dougefresh_ (07-25-2011)
 Old 08-18-2011, 08:45 PM   #11
Updates?
The Following User Says Thank You to dougefresh_ For This Useful Post:
JMEngineer (08-18-2011)
 Old 08-18-2011, 09:57 PM   #12
JMEngineer's Avatar
Ha... I won't have enough time to make any progress until after my wedding next month so I haven't even started yet.
djuosnteisn (08-19-2011), dougefresh_ (08-19-2011)
 Old 08-18-2011, 10:32 PM   #13
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
well shit, congrats. honeymoon secks for he motherfucking win!
The Following User Says Thank You to tddvrrn For This Useful Post:
JMEngineer (08-19-2011)
New build? forcedinduktion Computers & Technology News 2 12-08-2010 09:24 PM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.36155 seconds with 29 queries
