| Banned ![]() Join Date: Jun 2011 Location: Marysville CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
Groans: 43
Groaned at 111 Times in 19 Posts
(Thread Starter) | Not Ranked : 0 score So far parts I have: HKS SSQV3 dick mod BOV. epic thanks to my east coast nator friends. @drummermike58 treadstone tr8 FMIC with 2.5" aluminum piping cork sport 3" CBE ATP DP (with cat soon to be gutted and exhaust wrapped) dumped the grimmspeed ebcs went manual ebcs per advice from @Captain KR other minor parts not having to do with BT can be found in sig. Parts i picked up for this build. @eric@edgeautosport.com for helping out GTX3076r IWG (taking that shit off as soon as it comes in) 3.5 bar map with pig tail (i have big goals once i get the build) CP-e Nvicsid big TIP CP-e Xcel XL 3.25" MAF sri. hallman pro RX MBC JBR Stg 2 OCC. PTP Seals and studs (only 99.50 on sale order now if you gotta) @11cruzito11 for hooking me up with his used mani tubular pg EWG manifold 1 bar tial 38mm. @Death-From-A-Mile is gonna be fabbing up a custom oil return line for us MS6 BT guys and I'm gonna be giving it a test out, pricing and availability haven't been discussed yet, will let you know how easy the install is and rate the over all product when i get it in. Trying to get this installed in 2 days. (less the OCC, seals and studs, and new pcv) gonne be attempting to get @Lex to tune me and given everything goes well we will be able to dial it in at the may 27th socal dyno day and post numbers! Last edited by Darksun280; 04-27-2012 at 12:03 AM. |
| The Following 9 Users Say Thank You to Jonny Quest For This Useful Post: | 11cruzito11 (04-26-2012), 86AmishMs3 (05-03-2012), AZSPEED3 (04-26-2012), BobbleHead (04-27-2012), Death-From-A-Mile (04-26-2012), DiGi Faggot (05-20-2012), drummermike58 (04-26-2012), EdgeAutosport.com (04-26-2012), TRSpeed (04-26-2012) |
![]() Join Date: Mar 2008 Location: Kirkland, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 342
Groans: 87
| Not Ranked : 0 score Good luck with the setup brother! |
| The Following User Says Thank You to Death-From-A-Mile For This Useful Post: | Jonny Quest (04-26-2012) |
Groans: 43
(Thread Starter) | Not Ranked : 0 score yea once i get that oil return line in and on you can start charging people for them |
![]() Join Date: Jul 2011 Location: hesperia, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 295
| Not Ranked : 0 score FIRST! ANYWAYS GJ WITH THE EWG FTW. WHO ARE YOU BTW? LOL SEE YOU AT NATOR EDIT. FUCK I THOUGHT I WAS FIRST. ANYWAYS THANKS FOR THE SEALS FIND. WHAT'S JOHN NUMBER? Sent from my DROID4 using Tapatalk 2
__________________ 2008.05 True Red Mazdaspeed3 Lex Tuned GTX3071r | 38mm Tial WG | Hallman MBC Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod | Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM | Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs |
Groans: 43
haha scott beat you to it. lets see, jonnyquest calispddemon coloradospddemon zpelesb1tch (briefly) phd in phaggotry mclovin (breifly) and a few others i don't remember :X | |
ITS CAPS LOCK THURSDAY BOY. RAGE ON! ANYWAYS YA THAT BASTARD LOL DAMN NAME CHANGER Sent from my DROID4 using Tapatalk 2
__________________ 2008.05 True Red Mazdaspeed3 Lex Tuned GTX3071r | 38mm Tial WG | Hallman MBC Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod | Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM | Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs | |
| The Following 2 Users Say Thank You to TRSpeed For This Useful Post: | Jonny Quest (04-26-2012), silvapain (04-26-2012) |
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score *THAT GUY WHO CHANGES HIS NAME TOO MUCH |
| The Following User Says Thank You to TWOptSL0W For This Useful Post: | silvapain (04-26-2012) |
Groans: 43
Groans: 125
| Not Ranked : 0 score thats what she said |
Groans: 43
![]() Join Date: Jan 2011 Location: Woodbridge VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 262
| Not Ranked : 0 score good luck with build... Take your time, do it right. buy extra torx bits for injector studs... I broke 3 in the process... T40 IIRC
__________________ [SIGPIC][/SIGPIC]--2010 BM MS3-- Treadstone tr8 fmic core with 2.5" piping ## self made 3.5" MAF ## Gtx3076 .82 a/r t-3/vband hotside ## RaceRoots EWG exh mani/3" vband ## RaceRoots tubular DP ## TIAL MVR EWG ## UR Catback ## Sure shortshifter plate ## Sure R3 rmm ## Eagle Rods ## Custom SP63 10.5:1 .020 over pistons ## balanced rotating assy ## ARP head and main studs ## Autotech internals ## Accessport ## 3bar map sensor ## vtcs delete ## EGR delete ## Balance shaft delete ## Hallman MBC ## HKS SSQV 4 BOV ## NGK iridium spark plugs ## Cusco OCC ## Aquamist HFS-4 Methanol injection with 2 gallon Howerton Engineering tank ## D2 coilovers ## Nextmod lip kit ## SPC rear camber arms ## Wedsport SA-15r 18x9.5 et +23 ## 225/45/18 NITTO Motivo tires ## chinese HIDs ## JB shift knob ## 35% tinted ## still RichTuning... |
Groans: 43
thanks im gonna post pics along the way hopefully only takes 2 days :/ im gonna be pulling shit out today and this week waiting for parts to come | |
Groans: 43
(Thread Starter) | Not Ranked : 0 score First part to arrive. Manifold thanks again @11cruzito11 going out today to start the tear down, gonna get that ATP down pipe off and gut the cat so on tuesday i can wrap the DP with the exhaust mani. |
| The Following User Says Thank You to Jonny Quest For This Useful Post: | 11cruzito11 (04-27-2012) |
Groans: 43
(Thread Starter) | Not Ranked : 0 score manifold is off, awaiting other parts for install. anyone have ideas on how to gut an ATP catted DP? no way to get a rod into the cat |
Groans: 43
(Thread Starter) | Not Ranked : 0 score updated manifold. still have some exhaust wrap left. hmu if you want it. |
Groans: 43
(Thread Starter) | Not Ranked : 0 score just got it in plan on putting it in tomorrow, waiting on the Intake TIP and MBC. @jbarone for quick shipping! |
Groans: 43
(Thread Starter) | Not Ranked : 0 score Bt installed waiting for @Death-From-A-Mile 's intake manifold to bolt up the front side. waiting on the MBC, TIP and intake to get here. Lost the bolt to my PMM so i decided to replace the whole assembly. |
| Not Ranked : 0 score Jonny, got your info! I will have a base map for you this evening to fire it up once the parts are on!
![]() | | #19 | ![]() |
Groans: 43
![]() | | #20 | ![]() |
Groans: 43
(Thread Starter) | Not Ranked : 0 score So, after 3 weeks of being torn down, waiting for parts. getting held up and getting the run around I said fuck it, ordered a new coupler (the only thing i was waiting on) and 2 joiner pipes over nighted that shit took 16 hours from Time of order to Time of deliver (thats what i call customer service!, Cxracing is awesome). First start up video is about to come. have a few pics of the finished product. (waiting for them to send) later to come P/C valve cover (same color as IC piping), and P/C the MAF housing either black or red haven't decided. and now i have a fuel issue.... AWESOME!... looks like the injector didn't seal on the fuel rail side... we shall see.. took wife and i 45 minutes to pull the IM and fuel rail... talk about dynamic duo!! @Daddy Chinkus for holding my hand Last edited by Jonny Quest; 05-17-2012 at 11:09 PM. |
![]() | | #21 | ![]() |
Groans: 43
(Thread Starter) | Not Ranked : 0 score Well the build is on hold till I can tap out this oil drain line... and will NOT be going back to PERM/Stratified tuning upon completion... 50$ for a base map is fucking ridiculous.. @Bucker gonna tune my BT when i finish up haha |
![]() | | #22 | ![]() |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
| Not Ranked : 0 score Dude are ypu kidding me??? Perm tune especially alex is a fucking boss. Fine be cheap and don't get a "pro" tune, up to you, but the only person I trust with my car is alex and dj. And look where I am now? Stock internals and running like a boss. Trust me, when I hwave an issue I always hit up alex first cuz this dude knows his shit. But w/e its your fucking call bro
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
| The Following User Says Thank You to dooderek For This Useful Post: | DiGi Faggot (05-20-2012) |
![]() | | #23 | ![]() |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score Derek... your boy is hopeless.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
![]() | | #24 | ![]() |
Groans: 31
| Not Ranked : 0 score It's the oil feed, not the oil drain. Why does everyone and their mother get those two mixed up? Sucks when you get blamed for shit that isn't your fault, huh?
| The Following User Says Thank You to bmylez For This Useful Post: | Jonny Quest (05-23-2012) |
![]() | | #25 | ![]() |
Groans: 43
![]() @Daddy Chinkus i just trust bucker thats all. he is "affordable" and gets shit done. besides i wouldn't be able to meet the time frame alex puts on the tunes. i go to NC in a week and that would be the end of my tune. its not like im trying to run max power out of the block, im gonna sit 350ish and hold till i build then ill be getting a protune. | |
![]() | | #26 | ![]() |
Groans: 31
| Not Ranked : 0 score Yeah, I have the number (when I get home). I thought you would have gotten it as well. Perhaps they will show up later in the day, who knows.
![]() | | #27 | ![]() |
![]() Join Date: Jul 2011 Location: Fayetteville, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,655
__________________ [SIGPIC][/SIGPIC] | |
![]() | | #28 | ![]() |
Groans: 43
![]() | | #29 | ![]() |
| MY ATR Journey... | cld12pk2go | Cobb ATR Support | 120 | 06-14-2011 05:11 PM |
| Autoblog Podcast #230: with Jonny Lieberman of Motor Trend | Haltech | Automotive News | 0 | 05-17-2011 04:10 PM |
| Regrets, I've Had a Few: Jonny Lieberman bids farewell to Autoblog | Haltech | Automotive News | 0 | 07-29-2010 01:20 PM |
| Jonny Greaves jumps 301 feet to claim 2WD truck record | Haltech | Automotive News | 1 | 12-21-2009 06:45 AM |
| Jonny Lieberman joins the Autoblog crew | Haltech | Automotive News | 0 | 07-27-2009 10:20 AM |
